matto
Multiple Duplicate Selection
i wish i may...
i wish i might...
have an option in the multiple duplicate dialog box to leave the orginal objects selected once completed.
instead of the created objects.
or as well as the created objects.
ok thats three options in all.
maybe in pop-up menu.
that way i can then duplicate the same objects agian in the other direction.
best regards
matt
4 answers to this question
If by "other direction" you mean at 90 degrees, use the rectangular array option to get everything in one step.
ok rectangular array i use that all the time
but it's not what i'm looking for by this.
as you can imagine rectanglar array gives a rectanglar mass of duplicates.
what i'm suggesting means you could easily do an 'L' shape of duplicates.
or draw an object in the center of a room then put spaced duplicates left and then right of the original.
or stop that annoying thing of all the duplicates in a rectanglar array being selected except the original.if there is several objects in the original or it was a fiddly selection to start with.
as it now you have to redo that selection before you can tweak the position enmass.
oh one more option
-that just the last of the duplicates is selected.
hope that makes sense
matt
I know you might be looking for something different, but if this helps you for now any
try the Duplicate/Multiple command found on VectorDepot
