rudybeuc@gmail.com Posted January 13 Share Posted January 13 Please fix the roof fascia tool. I tried to place facia on a roof after it was created and cannot figure out how to get it inserted correctly. Please create insertion options for the facia option for roofs. This way perhaps I can get them to work as desired. Thanks, Rudy Beuc Quote Link to comment
0 rudybeuc@gmail.com Posted January 15 Author Share Posted January 15 Ok I ended up creating all the gutters and facias using the "extrude along path" method. However I find this workflow very manual, finicky, and very time consuming, and therefore really not desirable. As a single practitioner, time is a precious resource. Since the first post, I've noticed that this feature has been asked for for many years. Why It hasn't been implemented, I don't know. But I do have a second idea that I believe could work just as well. It could also work for other disciplines for other purposes. It would be a new modeling function called "extrude along picked edge". A profile could be drawn or picked from the resource manager. If picked from the resource manager as a 2d symbol, it's insertion point would be used as the origin for the extrusion. when implemented, one would pick the profile or profile symbol, and then pick a series of edges along a model for the extrusion. If the new path could be associated with the picked edges, the extrusion would adjust position as changes are made to the hose object. A flip x axis and flip y axis option for the profile would be needed for adjustments if the extrusion needed to be reversed along the path. combined with a shell option this could work great for metal wall copings. This would also work great for curbs, wall trim, and ect... Thanks, Rudy Beuc 1 Quote Link to comment
rudybeuc@gmail.com
Thanks,
Rudy Beuc
1 answer to this question
