Opening project file offline
kkestler
I posted this in the general discussion area, but no one seems to have seen it between now and when I posted it in August, so I thought maybe I would try posting here and see if I can get some better traction.
Quote
I have a file I saved from a previous employer to be able to use as a reference for future personal work. However, when I open the file, it won't let me switch to other sheets or views, and it appears that all of the layers are checked out. Is there a way to convert this to a usable standard .vwx file without reconnecting to the project file first?
As a follow-up, I was able to have someone send me the parent file for the file I mentioned above. But when I try to open it it tells me it needs to update, so I hit OK. It then tells me "This is an unrecognized file. It may be a Vectorworks file created by a newer version (unlikely since it told me it needed to update), it may be a very old MiniCAD file (it's not), it may have been created by another application (again, not the case), or it may have been corrupted by a hardware or system error." I really need to be able to use these files for a personal project I'm working on, can anyone help?
Link to other thread:
Thank you all in advance for your help!
0 answers to this question
