SimA Posted November 30, 2023 Share Posted November 30, 2023 I used many symbols in my project. Now I want to find symbols with the same name and replace them with a different symbol. Which node can I use to get the name of the inserted symbol? Thanks for your help! Quote Link to comment
Letti R Posted December 5, 2023 Share Posted December 5, 2023 Hello, you can find a node that gives you the name of a symbol in this file, that @DomC shared. It is in the "Object Info" column. However, there are other ways to replace symbols without the use of Marionette. Here is my preferred way of doing it: Select the Option "Symbol name" in this Tool Set all layers you want to search the symbol in to show Select the option "Show/Snap/modofy Others" for the leyers Click on one symbol with the Tool shown above Replace the symbols with the correct one via the "Replace" button in the object info palette. Regards, Letti 2 Quote Link to comment
