Cristiano Alves Posted October 25, 2023 Share Posted October 25, 2023 Good afternoon. In the same Vectorworks project, I have different layers containing different proposals for a stage design project. Different projects have different Lighting Fixtures and different quantities. I would like at the end of each PDF chapter (where I present the drawings of the different projects) a summary of the types of Lighting Fixtures. If I use the Instrument Summary, I get the total of the fixtures in the project [fixtures on Project A + Project B + Project C], and I don't figure out how I can filter this by Layer How can I make it? Thank you so much Quote Link to comment
Jesse Cogswell Posted October 25, 2023 Share Posted October 25, 2023 At the bottom of the Instrument Summary Object Info Palette is a button called Filters. This allows you to filter counts based on class, layer, position, or a custom string. I recently did a similar project where I proposed two different track layouts, one with horizontal track and one with vertical track. In this case, I could have used the Instrument Summary tool with a layer filter in place, as in this example: One thing to keep in mind with this approach is that these filters are applied to the object as a text string, so if you have a lot of filters turned on and you have long layer names, the text string becomes too long to parse and the summary will instead error out. 1 Quote Link to comment
