woodworker01 Posted October 10, 2023 Share Posted October 10, 2023 Hello, can anybody tell me the 4th letter of the languages of Vectorworks? I have these infos 'de' = G -> e.g. EHXGMN-......-......-...... 'en' = E - e.g. EHXEGN-......-......-...... 'es' = S 'fr' = B (?) 'it' = I 'nl' = B (?) 'pl' = P 'pt' = ? Thanks for your help 🙂 Quote Link to comment
Peter Vandewalle Posted October 11, 2023 Share Posted October 11, 2023 I think it is a combination of the 4th and the 5th letter that determines the country and language. And then again a serial number for a localised version will also run an english version while the serial for an english version won't allow you to open a localised version. If you need to know the language of the software, you'd better use the GetCurrentLocalization( VAR language  :STRING; VAR subLanguage  :STRING) call. It'll return you a code like ENG, NLD, FRA, PLN, ... 1 Quote Link to comment
woodworker01 Posted October 20, 2023 Author Share Posted October 20, 2023 Thanks so far. We found an api call that delivers the installation language according to ISO 639-3 (that is, what is actually needed - not only the localization of the serial number which can be different) The language codes according to ISO 639-3 are: 'DEU', 'ENG', 'SPA', 'FRA', 'ITA', 'NLD', 'POL', 'POR' Quote Link to comment
