Syntax or country code of serial numbers needed
I think it is a combination of the 4th and the 5th letter that determines the country and language. And then again a serial number for a localised version will also run an english version while the serial for an english version won't allow you to open a localised version.
If you need to know the language of the software, you'd better use the GetCurrentLocalization( VAR language  :STRING; VAR subLanguage  :STRING) call. It'll return you a code like ENG, NLD, FRA, PLN, ...
  • 2 weeks later...
Thanks so far. We found an api call that delivers the installation language according to ISO 639-3 (that is, what is actually needed - not only the localization of the serial number which can be different)
The language codes according to ISO 639-3 are:
'DEU',
'ENG',
'SPA',
'FRA',
'ITA',
'NLD',
'POL',
'POR'
