Stig Runar Posted October 5, 2023 Share Posted October 5, 2023 Hi! I made a new speaker symbol (editing an old one and changed 3d geometry.) and the speaker will not render when using the Speak Array tool. It works fine when using the speaker tool and inserting as a plain object. Here is one speaker added with speaker tool and the other with array tool: Standard look with lacoustics k2 symbol: How it looks when using new A10 symbol: Quote Link to comment
C. Andrew Dunning Posted October 5, 2023 Share Posted October 5, 2023 1 hour ago, Stig Runar said: Hi! I made a new speaker symbol (editing an old one and changed 3d geometry.) and the speaker will not render when using the Speak Array tool. It works fine when using the speaker tool and inserting as a plain object. Would you post a file containing a copy of the Symbol that doesn't render correctly? There might be an issue with how the 3D portion was created. Quote Link to comment
Stig Runar Posted October 9, 2023 Author Share Posted October 9, 2023 On 10/5/2023 at 12:59 PM, C. Andrew Dunning said: Would you post a file containing a copy of the Symbol that doesn't render correctly? There might be an issue with how the 3D portion was created. Here you go! A10 VW speakertest.vwxA10 VW speakertest.vwx Quote Link to comment
C. Andrew Dunning Posted October 9, 2023 Share Posted October 9, 2023 3 hours ago, Stig Runar said: Here you go! The 3D portion of your Symbol is an embedded 3D Symbol - which will not work with tilted speakers. See the attached corrected file. A10 VW speakertest.vwx 1 Quote Link to comment
