gfilippini Posted September 27, 2023 Share Posted September 27, 2023 Hello all, I´ve been working in a file with a graphic legend associated to WinDoor windows. It was originally built in VW2023; when I convert the file to VW2024 the graphic legend looks ok. But after I edit the cell layout (and exiting edit mode whitout any change) I can´t keep it working and showing only unique values option anymore. After cell layout edit each object instance shows individually on my graphic legend and I´m not founding how to solve to have again the simplified version (non repeating cells with same value on a specific field). I don´t know if it this happenend to someone else or it´s a known issue; or may be I´m forgetting something. Any help welcome! Regards Quote Link to comment
gfilippini Posted October 2, 2023 Author Share Posted October 2, 2023 On 9/27/2023 at 3:00 PM, gfilippini said: or may be I´m forgetting something Solved. Indeed I forgot something obvious: to install WinDoor for VW2024 when I update the new VW version! After I did it began to work just as expected. Quote Link to comment
