Cmb Posted September 15 Share Posted September 15 Hello, I made a plug-in object with the option to be inserted in walls, therefore its SParametricDef structure has resets on move / rotate, and wall insertion enabled. When the object inserted in a wall is moved while staying inside the wall, its recalculate event won't be triggered. This is an issue for me as I need my object to be recalculated after a position change inside the wall aswell. I found the following init property which is obsolete : Is there another way to reset the object in wall ? Do i have to catch a move event for this pio type and then reset the object if it is inside a wall ? thx for help Quote Link to comment
Hippocode Posted September 22 Share Posted September 22 Also watch the internal index or GUID of your object inside the reset events. If I remember correctly, when an object is inserted into a wall, a copy is actually made for insertion, removing the original object. Quote Link to comment
Cmb Posted Friday at 08:44 AM Author Share Posted Friday at 08:44 AM The solution i found was to use the reshape event of the wall obj through the update support of the sdk , and to find my object in it : @Hippocode indeed a new copy of the object is made in the wall at insertion time, so i also have to find a way for that Quote Link to comment
