Working with referencing viewports and am frustrated by something. So wanted to put a feature request, and also ask for a reason as to why Vectorworks acts like this.
The Request:
Simple; I'd love to see the ability to reference viewports directly from another file, OR reference the geometry (like we do now in a design layer viewport) while being able to control the visibilities in the sheet layer viewports individually.
At the moment, the process of viewport referencing is:
Create a new viewport ( View > Create New Viewport... )
Designate the viewport to a design layer (i.e. Design Layer-1 )
Set the source to be another file
Select all design layers in the file you want in the viewport
EITHER:
Copy a viewport from the file you are referencing
OR
Create new sheet layer viewports from the reference design layer viewport
Make the one design layer with the design layer viewport in it visible to see the architecture being referenced
The Problem:
If you want to hide any design layers from the referenced file you need to show/hide/gray them in the design layer viewport, meaning if you want different visibilities in other sheet layer viewports you need to:
Create a separate design layer with that same referenced viewport in it
Show/hide/gray each referenced design layer in each design layer viewport
Show/hide/gray the active file design layers (the ones holding the design layer viewports in the active file) in each sheet layer viewport
That's the request, either managing the referenced design layers from each sheet layer viewport directly or referencing viewports directly from another file.
My question is:
What's the point of the current workflow? Why would it make more sense to have this seemingly roundabout way of achieving this vs a more direct link with more management of the visibilities? Genuinely curious as to the thought process behind this decision and why we haven't see this evolve to be more flexible within viewports in a file referencing another.
JanezicDesign
Hello!
The Request:
My question is:
Thanks for any support or input!
9 answers to this question
