3D rotate of text
See attached for clarity.  I'm trying to figure out how to 3D rotate a string of text within the script.  Rotate3D, Set3DRot, and SetRot3D doesn't work on the text unless I convert the text to a 3D object which I'm trying to avoid.  Not sure if I have to flip my working plane first and then create it?  I'm hoping I can avoid that.  Hoping someone out there might know a command I haven't tried yet.
Here's a quick example to show how it could work..
Cheer!
PROCEDURE TextExample;
CONST
    TEXTANGLE = 90;  { Set the text degrees here }
VAR
    TXTHandle:HANDLE;
    BOO :BOOLEAN;
BEGIN
TextOrigin(0,0);
BeginText;
  'TEST'
EndText;
  TXTHandle:=Lnewobj;
  BOO:= SetEntityMatrix(TXTHandle, 0,0,0,TEXTANGLE,0,0);
END;
RUN(TextExample);
