MPacheco Posted July 3, 2023 Share Posted July 3, 2023 Hi guys! I have a project that has big large dripping areas. What happens is that most of the areas Exceeds Max Line Length at Pressure. Any tips to solve this problem? Is there any function that can divide in equal area parts polygons? Attached the file. irrigation_split.vwx Quote Link to comment
0 EdwardMatthew Posted July 4, 2023 Share Posted July 4, 2023 You can try adjusting the pressure settings to optimize the flow within each area. Or you may want to consider implementing a zoning system that divides the polygons into equal area parts. This can be achieved by using functions or tools available in software such as the one you attached. Good luck with your project! 1 Quote Link to comment
MPacheco
Attached the file.
1 answer to this question
