MPacheco
16 -
Reputation
5 NeutralPersonal Information
Location
Portugal
Recent Profile Visitors
Irrigation of large dripping areas - how to divide in equal parts
MPacheco posted a question in Troubleshooting
Hi guys! I have a project that has big large dripping areas. What happens is that most of the areas Exceeds Max Line Length at Pressure. Any tips to solve this problem? Is there any function that can divide in equal area parts polygons? Attached the file. irrigation_split.vwx -
Hi Jeff! The intention of this post is to alert the VW team that we have this major issue in Portugal and we need to fix it! We are supposed to help each other in order to get a reliable program, with good results for all users, and avoid dropping VW and moving on to competing programs. Like @jpccrodrigues, we know that Archicad (also from Nemetschek Group) has good DWF export results, so "there's no" escuse! Any help from VW team???
Hi guys! Lately, I have had lots of problems with DWFx exports. This is a major issue, because in Portugal all the public entities only accept this file format. Imagine that you publish all layouts in pdf format and when you publish to DWFx you lose transparencies, some type of line types hatches of graphic legends (VW 2023 SP2), among others. Having contact with other colleagues, they agree that this issue should be fixed, in order to provide public entities projects well represented. In Portugal, the future of projects will be in IFC format files, but the transition will not be made for tomorrow. We still have a few (and long) more years to leave the DWFx format. Can someone from the VW team give feedback? Thanks!
Hey guys! I've forgot to say that the problem is solved! The reason was because the attribute did not have a Solid Fill!
Checked all the options and still nothing. Thanks for your help!
Hi Jeff! Still not showing... I switched Shaded and fast renderworks and nothing. I'm using VW2023 Landmark (portuguese version). Can that be the reason?
Hey guys! I was testing Laubwerk's plants and when I select the appearance options the proxy and low detail options show the object without the appearance it should. Do you know how to solve it? Thanks!
Thank you mate! Problem solved!
Hello! I've created a coordinate worksheet with Stakes values. I also have stakes that I wanted to see only the Z value. Both coordinates stakes are in different classes. The problem is that I can't "hide" the 0 values, as you can see from the following image. I've tried to use a criteria saying to use only the stakes from the stakes coordinates but the worksheet give me back true and false values, like the following image. Is there any way that I can get the worksheet with only the class stakes coordinates class? Can anyone give a help? Attached the file with an example and the worksheet. Thanks!! coordinates_worksheet.vwx
Hi! I´ve given a texture to my site model and this is the result with the shaded render. Is there any way that the texture not to look like a repetition of the contour lines? Thanks!
Hi everyone! I´m trying to import an IFC model from ArchiCAD and it takes too much time to open in VW Landmark 2022, when it open's... Sometimes it's stuck at 50%... Are there any tips to follow? Thanks!
Thank you Monadnoc! I followed your steps and got it! Problem solved! Nice work and great result! Hope that in future VW versions the wall option have some option to get this result.
Hi Monadnoc! Thank's for your reply! I tried to do the process described on the last post of that topic but could not get the result. I followed the steps but only got this result with the Extrude along the patch. More tips to help me?
Hi Tamsin! Thank you for your reply! I've tried the first option you gave but the when a run the Fit Walls to Objects the file crashes. Probably the site model is quite complex to run this option. I will try to do in a The second option you said I managed to do, but in this particular case I don´t want to draw the steps, just want the top of the wall to be an offset of the existing slopes. Does the first option you gave makes the solution like the video shown below?
I want just an offset of the topography slopes. The bottom of the wall must follow the existing terrain.
