It would be useful to be able to combine 'align and scale' in a single command. This would be extremely beneficial when overlaying imported files (images / pdf's etc) onto a model. The current scale is very 'brute force' and only scales up from the centre of an object meaning that even if you exactly what scale to apply, you have to manually reposition and potentially rotate etc. to get the correct overlay.
I don't like quotuing old AutoCAd commands - but this has been around for decades, you can select the scale origin and select by distance on a drawing or entered data; it even aligns 2D objects to 3D planes (something the 3D rotate should be able to do).
Kevin C
1 answer to this question
