Stefan Bender Posted April 6, 2023 Share Posted April 6, 2023 Dear developers, how can I create a generic solid that has the shape of a sphere? I tried CreateSphere and then ConvertToGenericSolid, but the conversion failed. Surprisingly, even manually (using menu command "Modify->Convert->Convert to generic solids") the action failed with an error message saying that this object type can't be converted. So what else can I do? A sphere isn't such an exotic object type so there really should be a way to to that. Thanks for any ideas, Stefan Bender Quote Link to comment
VIRTUALENVIRONS Posted April 6, 2023 Share Posted April 6, 2023 (edited) Hi Stefan, The Sphere in the 3D nurbs palette is a generic solid or appears to be. But, if you sweep a half circle to create a sphere and then convert to generic solids, it will work. Edited April 6, 2023 by VIRTUALENVIRONS Quote Link to comment
