I would like the ability to add control points to a 2d/3d hybrid custom PIO that can be moved around in 3d space and return an XYZ value. The user would be able to move this point around freely in 3D space but it would also be good if these 3D points could be set-up in the Edit Plug-in Definition dialog to constrain movement of the points to the XZ plane or the YZ plane or even to an arbitrary 3D plane which could be set by the plug-in script.
Will
Hi
Thanks
Will
2 answers to this question
