Cristiano Alves Posted March 2, 2023 Share Posted March 2, 2023 (edited) Hello. I'm tryng use the Speaker Array Tool, but when I try use a bumber, something happen with th 2D model: I tried to edit the 2D Component, and figure out that "line" stays on a class "NonPlotLoci". I tried to delete that "line" but when I go out of the Edit mode, the line doesn't disappear. Just for notice, its a LAcoustic Kara Bumper Any idea? -------- To small speakers for exame L'Acoustic X12, final resoult is strange too: Edited March 2, 2023 by Cristiano Alves Quote Link to comment
C. Andrew Dunning Posted March 2, 2023 Share Posted March 2, 2023 2 things: The line assigned to the "NonPlot-Loci" Class is hard-coded so you can't delete it. The reason the line is so long and the bumper isn't appearing correctly (and, that the speaker isn't drawn correctly) is that the data in the Record attached to the Symbols is not correct. The different dimension fields all must be "Text" fields and must include the correct units marker (like "mm"). Likely, the fields in the Records attached to your symbols contain metric values but VW is treating them as imperial. Quote Link to comment
