JBenghiat Posted February 27 Share Posted February 27 I've had to re-install Windows, which meant updating to 11, and now I can't get buildvwr.exe to run without error. I have a few questions: - Is the .vwr the same for Windows and Mac? If so, I can just copy from the Mac install and avoid this issue - Looking at a previous .vwr built with the Windows script, it appears to be a zip file. This seems to be contrary to the information in the developer wiki, which states the .vwr is just a directory with an extension (which is definitely true on Mac) - If the answer to my first question is "no," has anyone encountered this and figured out a solution? As a side note, I've eliminated the buildvwr step when compiling on Mac, and used a Copy Bundle Resources step, which both copies the .vwr and sets any needed permissions and flags. Quote Link to comment
PatW Posted February 28 Share Posted February 28 Yes the VWR is a ZIP file. You could create a batch file that creates the zip with "7Zip" in the Post build event. This was quickly put together and is untested: cd C:\Program Files\7-Zip 7z a "C:\Users\pwink\Desktop\res.zip" "C:\Users\pwink\Documents\DEV\CableTools\CableTools.vwr\DialogLayout" "C:\Users\pwink\Documents\DEV\CableTools\CableTools.vwr\Images" "C:\Users\pwink\Documents\DEV\CableTools\CableTools.vwr\Strings" Quote Link to comment
JBenghiat Posted March 13 Author Share Posted March 13 I figured out the issue. buildvwr.exe requires the 64 bit versions of msvcp100.dll and msvcr100.dll, which aren't included in Windows 11. I was able to grab copies from a wine install, and now the build functions without error. I'll attach here if anyone else runs into this issue. msvc*100_dll.zip 1 Quote Link to comment
