MBench Posted January 27, 2023 Share Posted January 27, 2023 I'm fairly new to VW, so there's a lot I'm still figuring out. But I was adding plant tags, and we do one tag per plant type and change the quantity to the number of plants. I changed the plant grouping of some trees to accommodate this, but it sent the symbols under the sidewalk next to them. I can't send them to the front or send the sidewalk to the back, and I made sure to activate the correct layers while trying those things. Does anyone know why this might be happening, and how I can fix it? Or should I just delete the existing tree symbols and replace them? Quote Link to comment
Pat Stanford Posted January 27, 2023 Share Posted January 27, 2023 Probably the Layer Stacking Order. If the Trees are on a layer that is lower than the sidewalk then they won't show. Layer stacking order can be changed in the Navigation Palette or Organization Dialog Box by dragging in the column labeled "#" Quote Link to comment
