CYC lights next version
It would be nice, in the next version, to get multi circuit CYC strips with icons that have the fields for the number of circuits they have.. All of the multiple icons only have one field avaiable for color, etc. There is no way to put a 3 circuit MR-16 or any kind of multi-strip on the plot without using the single cel CYC units and ganging them. They don't take up the same space or look the same.
See page 4-8 of the SpotLight User's Guide for the proper way to create multi-circuit instruments. You need to build them from the parts library. Each symbol is to scale, and should build you a fairly reasonable representation of a strip light.
Kacey Fisher
Quality Assurance Specialist
Integrated Products Group
Nemetschek North America
  • 1 month later...
The parts library is in the same folder as the cyc units. Usually it ends up a the bottom-it is a separate folder called "Altman Cyc Parts" or whichever manufacturer.
HTH
Kacey Fisher
HTH
Kacey Fisher
