Model generating glitchy rendering. Why?
LarryO
Hidden render mode is generating stray/erroneous lines from this trimmed framing member. The untrimmed member also has a glitch as seen in the second image.
VW2023. Also smoothing angle fails to remove curvature line(s) in standard viewport views.  Smoothing angle of 5° usually works with standard steel shapes but I am trying to update our template drawing to utilize the framing member tool for hopefully better 3d manipulation. Although the missing data sets that are generated by the steel shapes might make me change back to them. Looking at a W250x32.7 with the top flange coped and holes for the bolts.
image.png.bf2eee45989fa51b21fef35fb8c88b57.pngimage.png.2530d50efc8e1c59e1254dc8d3c48be4.png
Two glitches in the rendering of the subtracted solid, left and enlarged above.
And one from the basic framing member, right above. Changing units accuracy doesn't fix this.
0 answers to this question
There have been no answers to this question yet
