Hi, the vectorwork is often freezing and no responding.
lixinpm
Hi,
the Vectorworks often frozen when I did some very simple options, such as moving, copy or editing object. When it became frozen, the mouse became round showing the computer is running and then is not resumed any more.
Would you let me know what is the problem for that? The VW version is 2021
Please check the error report and my computer infor. below.
Thank you very much!
Date/Time:       2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
OS Version:      Mac OS X 10.14.6 (Build 18G9323)
Architecture:    x86_64h
Report Version:  28
Data Source:     Stackshots
Shared Cache:    0x9555000 A71CD26D-D779-3CDE-A9AF-18650323DC94
Shared Cache:    0 F81C5386-7151-356C-886A-20626377C068
Command:         Vectorworks
Path:            /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/MacOS/Vectorworks
Identifier:      net.nemetschek.vectorworks
Version:         26.0.5 (622768) (26.0.5)
Parent:          launchd [1]
PID:             62926
Event:           hang
Duration:        1.09s (process was unresponsive for 198 seconds before sampling)
Steps:           11 (100ms sampling interval)
Hardware model:  iMac18,3
Active cpus:     8
Time Awake Since Boot: 710000s
Time Since Wake: 29000s
Fan speed:       1194 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5]
  11  ??? (Vectorworks + 3394241) [0x10e387ac1]
  11  NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0]
  11  -[NSApplication run] + 755 (AppKit + 81100) [0x7fff324f5ccc]
  11  ??? (Vectorworks + 4481429) [0x10e491195]
  11  ??? (Vectorworks + 4482082) [0x10e491422]
  11  -[NSApplication(NSEvent) sendEvent:] + 331 (AppKit + 152919) [0x7fff32507557]
  11  ??? (Vectorworks + 604859) [0x10e0deabb]
  11  -[NSWindow(NSEventRouting) sendEvent:] + 478 (AppKit + 1596787) [0x7fff32667d73]
  11  -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2295 (AppKit + 1599666) [0x7fff326688b2]
  11  -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5724 (AppKit + 2424699) [0x7fff32731f7b]
  11  ??? (Vectorworks + 3885724) [0x10e3ffa9c]
  11  -[NSControl mouseDown:] + 791 (AppKit + 3618806) [0x7fff328557f6]
  11  -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 698 (AppKit + 3813236) [0x7fff32884f74]
  11  -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 2375 (AppKit + 3624377) [0x7fff32856db9]
  11  -[NSButtonCell _sendActionFrom:] + 96 (AppKit + 3813923) [0x7fff32885223]
  11  -[NSCell _sendActionFrom:] + 178 (AppKit + 3630238) [0x7fff3285849e]
  11  __26-[NSCell _sendActionFrom:]_block_invoke + 136 (AppKit + 3630492) [0x7fff3285859c]
  11  -[NSControl sendAction:to:] + 86 (AppKit + 3630698) [0x7fff3285866a]
  11  -[NSApplication(NSResponder) sendAction:to:from:] + 312 (AppKit + 3195672) [0x7fff327ee318]
  11  ??? (Vectorworks + 3544206) [0x10e3ac48e]
  11  ??? (Vectorworks + 43709810) [0x1109fa572]
  11  ??? (Vectorworks + 43710760) [0x1109fa928]
  11  ??? (Vectorworks + 43702080) [0x1109f8740]
  11  ??? (Vectorworks + 38174180) [0x1104b2de4]
  11  ??? (Vectorworks + 37517611) [0x11041292b]
  11  ??? (Vectorworks + 38158533) [0x1104af0c5]
  11  ??? (Vectorworks + 38097118) [0x1104a00de]
  11  ??? (Vectorworks + 31830500) [0x10fea61e4]
  11  ExtendedProps::CEPEmoduleImp::HandleObjectEvent(char**, ParametricMessage&, int&) + 178 (Support + 339936) [0x1617dcfe0]
  11  ??? (Support + 341103) [0x1617dd46f]
  11  ??? (Vectorworks + 31825540) [0x10fea4e84]
  11  ??? (Vectorworks + 33184827) [0x10fff0c3b]
  11  ??? (Vectorworks + 33092813) [0x10ffda4cd]
  11  VWFC::PluginSupport::VWParametric_EventSink::Execute(ParametricMessage*) + 299 (Landscape + 6329371) [0x13bc5e41b]
  11  SiteModel::CObjectDTM_EventSink::OnObjectUIButtonHit(int) + 119 (Landscape + 170229) [0x13b67e8f5]
  11  SiteModel::CObjectDTM_EventSink::ResetThisObject(bool, bool) + 102 (Landscape + 170594) [0x13b67ea62]
  11  SiteModel::CObjectDTMRecalc::ResetModel(bool, bool, bool, bool) + 381 (Landscape + 1422839) [0x13b7b05f7]
  11  SiteModel::CObjectDTMRecalc::ProcessModifiers(bool, VWFC::Tools::CProgressStepper&) + 352 (Landscape + 1419708) [0x13b7af9bc]
  11  SiteModel::Modifiers::CVWModifiersData::ProcessModifiers(SiteModel::TIN::CTINModel&) + 141 (Landscape + 1395303) [0x13b7a9a67]
  11  SiteModel::Modifiers::CSiteModifierPad::ProcessModifier(SiteModel::TIN::CTINMesh&) + 120 (Landscape + 1334174) [0x13b79ab9e]
  7   SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 929 (Landscape + 1294909) [0x13b79123d]
  4   ??? (Landscape + 4818200) [0x13baed518]
Process:         Vectorworks [62926] [unique pid 162509]
UUID:            B87780CD-7B21-35B2-AB7E-132D7E480425
Parent:          launchd [1]
UID:             504
Footprint:       13.50 GB
Start time:      2022-12-30 22:13:30 -0800
Num samples:     11 (1-11)
CPU Time:        0.999s (4.4G cycles, 2.0G instructions, 2.18c/i)
Note:            Unresponsive for 198 seconds before sampling
Note:            2 idle work queue threads omitted
  Thread 0xa4b9cd           DispatchQueue 1           Thread name "CrBrowserMain"                         11 samples (1-11)         priority 47 (base 47)     cpu time 0.995s (4.4G cycles, 2.0G instructions, 2.17c/i)
  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  ??? (Vectorworks + 3394241) [0x10e387ac1] 1-11
      11  NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11
        11  -[NSApplication run] + 755 (AppKit + 81100) [0x7fff324f5ccc] 1-11
          11  ??? (Vectorworks + 4481429) [0x10e491195] 1-11
            11  ??? (Vectorworks + 4482082) [0x10e491422] 1-11
              11  -[NSApplication(NSEvent) sendEvent:] + 331 (AppKit + 152919) [0x7fff32507557] 1-11
                11  ??? (Vectorworks + 604859) [0x10e0deabb] 1-11
                  11  -[NSWindow(NSEventRouting) sendEvent:] + 478 (AppKit + 1596787) [0x7fff32667d73] 1-11
                    11  -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2295 (AppKit + 1599666) [0x7fff326688b2] 1-11
                      11  -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5724 (AppKit + 2424699) [0x7fff32731f7b] 1-11
                        11  ??? (Vectorworks + 3885724) [0x10e3ffa9c] 1-11
                          11  -[NSControl mouseDown:] + 791 (AppKit + 3618806) [0x7fff328557f6] 1-11
                            11  -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 698 (AppKit + 3813236) [0x7fff32884f74] 1-11
                              11  -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 2375 (AppKit + 3624377) [0x7fff32856db9] 1-11
                                11  -[NSButtonCell _sendActionFrom:] + 96 (AppKit + 3813923) [0x7fff32885223] 1-11
                                  11  -[NSCell _sendActionFrom:] + 178 (AppKit + 3630238) [0x7fff3285849e] 1-11
                                    11  __26-[NSCell _sendActionFrom:]_block_invoke + 136 (AppKit + 3630492) [0x7fff3285859c] 1-11
                                      11  -[NSControl sendAction:to:] + 86 (AppKit + 3630698) [0x7fff3285866a] 1-11
                                        11  -[NSApplication(NSResponder) sendAction:to:from:] + 312 (AppKit + 3195672) [0x7fff327ee318] 1-11
                                          11  ??? (Vectorworks + 3544206) [0x10e3ac48e] 1-11
                                            11  ??? (Vectorworks + 43709810) [0x1109fa572] 1-11
                                              11  ??? (Vectorworks + 43710760) [0x1109fa928] 1-11
                                                11  ??? (Vectorworks + 43702080) [0x1109f8740] 1-11
                                                  11  ??? (Vectorworks + 38174180) [0x1104b2de4] 1-11
                                                    11  ??? (Vectorworks + 37517611) [0x11041292b] 1-11
                                                      11  ??? (Vectorworks + 38158533) [0x1104af0c5] 1-11
                                                        11  ??? (Vectorworks + 38097118) [0x1104a00de] 1-11
                                                          11  ??? (Vectorworks + 31830500) [0x10fea61e4] 1-11
                                                            11  ExtendedProps::CEPEmoduleImp::HandleObjectEvent(char**, ParametricMessage&, int&) + 178 (Support + 339936) [0x1617dcfe0] 1-11
                                                              11  ??? (Support + 341103) [0x1617dd46f] 1-11
        11  ??? (Vectorworks + 31825540) [0x10fea4e84] 1-11
        11  ??? (Vectorworks + 33184827) [0x10fff0c3b] 1-11
        11  ??? (Vectorworks + 33092813) [0x10ffda4cd] 1-11
        11  VWFC::PluginSupport::VWParametric_EventSink::Execute(ParametricMessage*) + 299 (Landscape + 6329371) [0x13bc5e41b] 1-11
        11  SiteModel::CObjectDTM_EventSink::OnObjectUIButtonHit(int) + 119 (Landscape + 170229) [0x13b67e8f5] 1-11
        11  SiteModel::CObjectDTM_EventSink::ResetThisObject(bool, bool) + 102 (Landscape + 170594) [0x13b67ea62] 1-11
        11  SiteModel::CObjectDTMRecalc::ResetModel(bool, bool, bool, bool) + 381 (Landscape + 1422839) [0x13b7b05f7] 1-11
        11  SiteModel::CObjectDTMRecalc::ProcessModifiers(bool, VWFC::Tools::CProgressStepper&) + 352 (Landscape + 1419708) [0x13b7af9bc] 1-11
        11  SiteModel::Modifiers::CVWModifiersData::ProcessModifiers(SiteModel::TIN::CTINModel&) + 141 (Landscape + 1395303) [0x13b7a9a67] 1-11
        11  SiteModel::Modifiers::CSiteModifierPad::ProcessModifier(SiteModel::TIN::CTINMesh&) + 120 (Landscape + 1334174) [0x13b79ab9e] 1-11
        3   SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 865 (Landscape + 1294845) [0x13b7911fd] 1-3
        1   ??? (Landscape + 4818200) [0x13baed518] (running) 1
        2   ??? (Landscape + 4818204) [0x13baed51c] (running) 2-3
        7   SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 929 (Landscape + 1294909) [0x13b79123d] 4-10
        1   ??? (Landscape + 4818200) [0x13baed518] (running) 4
        2   ??? (Landscape + 4818204) [0x13baed51c] (running) 5-6
        1   ??? (Landscape + 4818194) [0x13baed512] (running) 7
        3   ??? (Landscape + 4818200) [0x13baed518] (running) 8-10
        1   SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 446 (Landscape + 1294426) [0x13b79105a] 11
        1   ??? (Landscape + 4818200) [0x13baed518] (running) 11
  Thread 0xa4b9e8           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0>
  11  <truncated backtrace> 1-11
    11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
     *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0xa4b9ea           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
        11  cef_time_delta + 2801911 (Chromium Embedded Framework + 46868023) [0x121064637] 1-11
          11  cef_time_delta + 2548493 (Chromium Embedded Framework + 46614605) [0x12102684d] 1-11
            11  cef_time_delta + 2549645 (Chromium Embedded Framework + 46615757) [0x121026ccd] 1-11
              11  cef_time_delta + 2547256 (Chromium Embedded Framework + 46613368) [0x121026378] 1-11
                11  cef_time_delta + 2862147 (Chromium Embedded Framework + 46928259) [0x121073183] 1-11
                  11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
                   *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0xa4b9eb           Thread name "Chrome_IOThread"                       11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4b9ec           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4b9ed           Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4b9f0           Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4b9f1           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
          11  cef_time_delta + 2548637 (Chromium Embedded Framework + 46614749) [0x1210268dd] 1-11
  Thread 0xa4b9f3           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
    11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
     *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0xa4b9f5           Thread name "ThreadPoolSingleThreadForegroundBlocking0"                       11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4b9f9           Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking1"                 11 samples (1-11)         priority 0 (base 0)
  Thread 0xa4b9fa           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking2"                 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbc4           11 samples (1-11)         priority 31 (base 31)
  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
  Thread 0xa4bbc5           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbc6           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbc7           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbc8           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbc9           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbca           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbcb           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bbd6           11 samples (1-11)         priority 1 (base 1)
        11  ??? (Vectorworks + 17628112) [0x10f11abd0] 1-11
          11  ??? (Vectorworks + 17450057) [0x10f0ef449] 1-11
            11  ??? (Vectorworks + 17447721) [0x10f0eeb29] 1-11
              11  ??? (Vectorworks + 17447150) [0x10f0ee8ee] 1-11
                11  __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11
                 *11  hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11
                   *11  unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11
                     *11  recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11
                       *11  ??? (kernel + 7556385) [0xffffff8000934d21] 1-11
                         *11  soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11
                           *11  sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11
                             *11  msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11
                               *11  ??? (kernel + 7168269) [0xffffff80008d610d] 1-11
                                 *11  lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11
                                   *11  thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11
                                     *11  ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11
                                       *11  machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11
  Thread 0xa4bc46           11 samples (1-11)         priority 31 (base 31)
          11  ??? (Vectorworks + 17394558) [0x10f0e1b7e] 1-11
            11  ??? (Vectorworks + 17396163) [0x10f0e21c3] 1-11
              11  ??? (Vectorworks + 17626325) [0x10f11a4d5] 1-11
                11  _dispatch_semaphore_wait_slow + 98 (libdispatch.dylib + 17311) [0x7fff60e4f39f] 1-11
                  11  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11
                   *11  semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11
  Thread 0xa4bc66           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (40.1K cycles, 5.1K instructions, 7.93c/i)
        11  cineware::BeginThread(void*) + 9 (Renderworks + 1788825) [0x145a54b99] 1-11
          11  cineware::BaseThread::Action() + 62 (Renderworks + 1789086) [0x145a54c9e] 1-11
            11  cineware::IpKillThread::Main() + 58 (Renderworks + 2038698) [0x145a91baa] 1-11
              11  usleep + 53 (libsystem_c.dylib + 501768) [0x7fff60f5f808] 1-11
                11  __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11
  Thread 0xa4bccf           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 47 (base 47)     cpu time 0.004s (16.6M cycles, 4.6M instructions, 3.60c/i)
        11  _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11
          11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
            11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
              11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0xa4bcf7           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd05           11 samples (1-11)         priority 31 (base 31)
        11  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11
          11  ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11
            11  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11
  Thread 0xa4bd06           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd07           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd08           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd09           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd0a           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd0b           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd0c           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bd61           11 samples (1-11)         priority 31 (base 31)
        11  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, std::__1::__bind<void (sio::client_impl::*)(), sio::client_impl*> > >(void*) + 62 (Vectorworks + 32197214) [0x10feffa5e] 1-11
          11  ??? (Vectorworks + 32171974) [0x10fef97c6] 1-11
            11  ??? (Vectorworks + 32173555) [0x10fef9df3] 1-11
              11  ??? (Vectorworks + 15150369) [0x10eebdd21] 1-11
                11  ??? (Vectorworks + 15151379) [0x10eebe113] 1-11
                  11  kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11
  Thread 0xa4bd62           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4be28           11 samples (1-11)         priority 28 (base 31)
        11  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11
          11  ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11
  Thread 0xa4be29           11 samples (1-11)         priority 29 (base 31)
  Thread 0xa4be2a           11 samples (1-11)         priority 25 (base 31)
  Thread 0xa4be2b           11 samples (1-11)         priority 22 (base 31)
  Thread 0xa4be2c           11 samples (1-11)         priority 23 (base 31)
  Thread 0xa4be2d           11 samples (1-11)         priority 28 (base 31)
  Thread 0xa4be2e           11 samples (1-11)         priority 30 (base 31)
  Thread 0xa4be2f           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4be32           11 samples (1-11)         priority 31 (base 31)
        11  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 59 (VWGraphicsModule + 1114197) [0x1676e5055] 1-11
          11  ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 319 (VWGraphicsModule + 1112455) [0x1676e4987] 1-11
  Thread 0xa4beca           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4becb           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4becc           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4becd           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bece           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4becf           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bed0           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa57739           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa5773b           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa5773c           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa5773d           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa5773e           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa5773f           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa57740           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa57741           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa57742           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa578f2           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b2b           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b49           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b4a           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b4b           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b4c           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b4d           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b4e           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b4f           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89b50           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89bc1           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c33           11 samples (1-11)         priority 31 (base 31)
        11  CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11
          11  CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11
            11  CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11
  Thread 0xa89c34           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c35           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c36           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c37           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c38           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c39           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa89c3a           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa91fc3           Thread name "CVDisplayLink"                         11 samples (1-11)         priority 54 (base 54)
        11  CVDisplayLink::runIOThread() + 695 (CoreVideo + 93723) [0x7fff36c77e1b] 1-11
  Binary Images:
           0x10e04b000 -        0x1128a5fff  net.nemetschek.vectorworks 26.0.5 (622768) (26.0.5)    <B87780CD-7B21-35B2-AB7E-132D7E480425>  /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/MacOS/Vectorworks
           0x11e3b2000 -        0x12655ffff  org.chromium.ContentShell.framework 84.3.3.0 (3.0)     <33CBB18A-CD37-38C4-94FB-B9E1EDFF8658>  /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
           0x13b655000 -        0x13be57fff  net.nemetschek.vectorworks.LandscapeModule (1.0)       <7307AC6E-23CD-33DF-AF2E-43CE67C80B39>  /Applications/Vectorworks 2021/*/Landscape
           0x14098c000 -        0x1410effff  com.datalogics.DL150PDFL DL150PDFL 15.0.4.9 (15.0.4.9) <27AF6E78-DCCD-3973-BE38-F4F002B8D176>  /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/DL150PDFL.framework/Versions/A/DL150PDFL
           0x1458a0000 -        0x145afbfff  net.nemetschek.vectorworks.Renderworks (1.0)           <C2509A26-D398-3562-8C14-437D9B27FBDE>  /Applications/Vectorworks 2021/*/Renderworks
           0x16178a000 -        0x161d4bfff  net.nemetschek.vectorworks.Support (1.0)               <B1DEC882-5C8F-3C75-A0B5-6549113C009B>  /Applications/Vectorworks 2021/*/Support
           0x1675d5000 -        0x1677adfff  net.nemetschek.vectorworks.VWGraphicsModule (1.0)      <97598144-4A9E-3FAE-8654-5B4C37611D8B>  /Applications/Vectorworks 2021/*/VWGraphicsModule
        0x7fff324e2000 -     0x7fff33297fff  com.apple.AppKit 6.9 (1671.60.112)                     <4AFB032C-2786-3AD7-8EDA-576956992A9C>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)                <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff36c61000 -     0x7fff36ca1fff  com.apple.CoreVideo 1.8 (281.4)                        <10CF8E52-07E3-382B-8091-2CEEEFFA69B4>  /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff5e0c2000 -     0x7fff5e115fff  libc++.1.dylib (400.9.4)                               <9A60A190-6C34-339F-BB3D-AACE942009A4>  /usr/lib/libc++.1.dylib
        0x7fff60e4b000 -     0x7fff60e84fff  libdispatch.dylib (1008.270.1)                         <97273678-E94C-3C8C-89F6-2E2020F4B43B>  /usr/lib/system/libdispatch.dylib
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                                <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
        0x7fff60ee5000 -     0x7fff60f6cfff  libsystem_c.dylib (1272.250.3)                         <6016EDA1-440B-34D7-A232-686CD7FBEE90>  /usr/lib/system/libsystem_c.dylib
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70)                   <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                    <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                          <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                                   <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         5A4RE8SF68.com.tencent.xinWeChat.IPCHelper [29126] [unique pid 128718]
UUID:            4F2CECA3-DEE0-3EC7-BFE9-93EB5210AB5B
Path:            /Applications/WeChat.app/Contents/Library/LoginItems/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper.app/Contents/MacOS/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper
Parent:          launchd [1]
UID:             504
Sudden Term:     Tracked
Footprint:       1160 KB
Note:            1 idle work queue thread omitted
  Thread 0x7e4271           11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10dd32000 -        0x10dd35fff  5A4RE8SF68.com.tencent.xinWeChat.IPCHelper <4F2CECA3-DEE0-3EC7-BFE9-93EB5210AB5B>  /Applications/WeChat.app/Contents/Library/LoginItems/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper.app/Contents/MacOS/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper
Process:         AAM Updates Notifier [9885]
Architecture:    i386
Footprint:       10.94 MB
End time:        2022-12-30 22:13:30 -0800
Num samples:     1 (1)
  Thread 0xe5f91            DispatchQueue 1           1 sample (1)              priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), IO tier 0>
  1  ??? [0x3edc] 1
    1  ??? [0x3fad] 1
      1  NSApplicationMain + 1140 (AppKit + 12235) [0x91492fcb] 1
        1  -[NSApplication run] + 751 (AppKit + 78291) [0x914a31d3] 1
          1  -[NSApplication(NSEvent) nextEventMatchingMask:untilDate:inMode:dequeue:] + 108 (AppKit + 101170) [0x914a8b32] 1
            1  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 957 (AppKit + 102135) [0x914a8ef7] 1
              1  _DPSNextEvent + 1345 (AppKit + 107489) [0x914aa3e1] 1
                1  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 40039) [0x92de9c67] 1
                  1  ReceiveNextEventCommon + 741 (HIToolbox + 40811) [0x92de9f6b] 1
                    1  RunCurrentEventLoopInMode + 323 (HIToolbox + 41585) [0x92dea271] 1
                      1  CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1
                        1  CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1
                          1  __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1
                            1  __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1
                              1  mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1
                               *1  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1
  Thread 0xe5f9d            Thread name "com.apple.NSURLConnectionLoader"       1 sample (1)              priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
  1  thread_start + 34 (libsystem_pthread.dylib + 10190) [0xa7df27ce] 1
    1  _pthread_start + 78 (libsystem_pthread.dylib + 26615) [0xa7df67f7] 1
      1  _pthread_body + 137 (libsystem_pthread.dylib + 13816) [0xa7df35f8] 1
        1  __NSThread__start__ + 1220 (Foundation + 72459) [0x951a3b0b] 1
          1  -[NSThread main] + 39 (Foundation + 72802) [0x951a3c62] 1
            1  +[__CoreSchedulingSetRunnable _run:] + 129 (CFNetwork + 311833) [0x92a8c219] 1
              1  -[__CoreSchedulingSetRunnable runForever] + 579 (CFNetwork + 312800) [0x92a8c5e0] 1
  Thread 0xe5f9e            Thread name "com.apple.CFSocket.private"            1 sample (1)              priority 46 (base 46)
    1  __select + 10 (libsystem_kernel.dylib + 33458) [0xa7d472b2] 1
     *1  ??? (kernel + 7168864) [0xffffff80008d6360] 1
  Thread 0xe5fa3            Thread name "com.apple.NSEventThread"               1 sample (1)              priority 46 (base 46)
        1  _NSEventThread + 165 (AppKit + 138826) [0x914b1e4a] 1
  Binary Images:
            0x91490000 -         0x921d9fff  com.apple.AppKit 6.9 (1671.60.112)      <BB017928-5FEA-349A-B027-FB9B124D5E7D>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0x92a40000 -         0x92dbbfff  com.apple.CFNetwork 978.6 (978.6)       <62DEE66F-F853-354E-9ACB-AFC35D260B03>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
            0x92de0000 -         0x93162fff  com.apple.HIToolbox 2.1.1 (918.7)       <57D8E18B-2E59-3DAF-BF46-75DEFB58CED0>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
            0x93812000 -         0x93c4cfff  com.apple.CoreFoundation 6.9 (1575.405) <F1CC263B-4936-396B-B6D9-8CB06EBEF2EA>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x95192000 -         0x954f8fff  com.apple.Foundation 6.9 (1575.405)     <A65B2384-6516-3412-85A1-6161024D4BCD>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0xa7d3f000 -         0xa7d67fff  libsystem_kernel.dylib (4903.278.70)    <12ABC81E-9EC6-3E76-85AA-FFD1EECD3419>  /usr/lib/system/libsystem_kernel.dylib
            0xa7df0000 -         0xa7dfbfff  libsystem_pthread.dylib (330.250.2)     <5E586CDB-3E20-39C1-8194-1FA564E947DD>  /usr/lib/system/libsystem_pthread.dylib
UUID:            3307CE76-A723-DE76-98CC-A5D92FDA63D9
Path:            /Applications/Utilities/Adobe Application Manager/*/AAM Updates Notifier.app/Contents/MacOS/AAM Updates Notifier
Architecture:    i386
Parent:          launchd [1]
UID:             504
Footprint:       10.94 MB
Num samples:     10 (2-11)
CPU Time:        8.814s (27.5G cycles, 7.7G instructions, 3.56c/i)
  No threads sampled
  Binary Images:
                0x1000 -            0x26fff  com.adobe.PDApp.AAMUpdatesNotifier 6.0.335.0 (6.0.335.0) <3307CE76-A723-DE76-98CC-A5D92FDA63D9>  /Applications/Utilities/Adobe Application Manager/*/AAM Updates Notifier.app/Contents/MacOS/AAM Updates Notifier
Process:         accountsd [290]
UUID:            F6DED804-7E8B-3153-BC98-5C49BB5793A8
Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Parent:          launchd [1]
UID:             504
Sudden Term:     Tracked (allows idle exit)
Footprint:       29.32 MB
  Thread 0x852              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    11  ??? (accountsd + 2490) [0x10e7239ba] 1-11
  Binary Images:
           0x10e723000 -        0x10e723fff  accountsd (677.6.0.8)                   <F6DED804-7E8B-3153-BC98-5C49BB5793A8>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Process:         adid [363]
UUID:            FC2CF85B-F9E9-302E-8FB0-1DEE4BA24650
Path:            /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
Parent:          launchd [1]
UID:             265
Footprint:       13.39 MB
  Thread 0xce8              11 samples (1-11)         priority 4 (base 4)
    11  ??? (adid + 903416) [0x105c548f8] 1-11
      11  CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11
  Binary Images:
           0x105b78000 -        0x105d0cfff  adid (4.19)                             <FC2CF85B-F9E9-302E-8FB0-1DEE4BA24650>  /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
Process:         Adobe Flash Player Install Manager [10592]
UUID:            D56AB41D-A770-3265-B55D-EF948BB42BD1
Path:            /Applications/Utilities/Adobe Flash Player Install Manager.app/Contents/MacOS/Adobe Flash Player Install Manager
Parent:          launchd [1]
UID:             504
Footprint:       21.05 MB
CPU Time:        <0.001s (57.6K cycles, 24.5K instructions, 2.35c/i)
  Thread 0xec463            DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2>
  11  start + 52 (Adobe Flash Player Install Manager + 8244) [0x10f7dc034] 1-11
      11  -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11
        11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11
          11  _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11
            11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11
              11  ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11
                11  RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11
  Thread 0xec477            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0xec478            Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Thread 0xec48c            Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
  <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2>
  Binary Images:
           0x10f7da000 -        0x10fa53fff  com.adobe.flashplayer.installmanager 32.0.0.465 (32.0.0.465) <D56AB41D-A770-3265-B55D-EF948BB42BD1>  /Applications/Utilities/Adobe Flash Player Install Manager.app/Contents/MacOS/Adobe Flash Player Install Manager
        0x7fff3415a000 -     0x7fff34451fff  com.apple.HIToolbox 2.1.1 (918.7)                            <88D7F19C-8C9D-384B-BAB5-8205CA282F2C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         AdobeAcrobat [16858]
Architecture:    i386
Footprint:       54.62 MB
Num samples:     1 (1)
  Thread 0x1c4b29           DispatchQueue 1           1 sample (1)              priority 4 (base 4)
  1  ??? [0x2571] 1
    1  ??? [0x264a] 1
      1  ??? [0x2e8b] 1
        1  ??? [0x7fd83f80] 1
          1  ??? [0x7fd84a54] 1
  Thread 0x1c4b68           1 sample (1)              priority 4 (base 4)
  <process suppressed, timers tier 5 (throttled), IO tier 2>
    1  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1
     *1  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1
  Thread 0x1c4b69           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b6a           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b6b           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b6c           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b6d           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b6e           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b6f           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b70           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b71           1 sample (1)              priority 4 (base 4)
  Thread 0x1c4b9c           Thread name "com.apple.NSEventThread"               1 sample (1)              priority 4 (base 4)
  Thread 0x1c4ca7           1 sample (1)              priority 4 (base 4)
    1  kevent + 10 (libsystem_kernel.dylib + 29614) [0xa7d463ae] 1
     *1  ??? (kernel + 6978560) [0xffffff80008a7c00] 1
  Thread 0x1c4cb3           1 sample (1)              priority 4 (base 4)
  Thread 0x1c50d2           1 sample (1)              priority 4 (base 4)
        1  PrivateMPEntryPoint + 51 (CarbonCore + 541794) [0x948e9462] 1
          1  ??? [0x73dde6d5] 1
            1  ??? [0x73dfcdfc] 1
              1  MPWaitOnQueue + 181 (CarbonCore + 540704) [0x948e9020] 1
                1  TSWaitOnConditionTimedRelative + 137 (CarbonCore + 694137) [0x9490e779] 1
                  1  pthread_cond_timedwait_relative_np + 27 (libsystem_pthread.dylib + 20061) [0xa7df4e5d] 1
  Binary Images:
            0x94865000 -         0x94b44fff  com.apple.CoreServices.CarbonCore 1178.33 (1178.33) <9CEC8866-FBAD-3000-88A3-3451F1A09F95>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
UUID:            BD0419A6-AC29-4210-9EA0-0BBAFC5682FE
Path:            /Applications/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
Architecture:    i386
Parent:          launchd [1]
UID:             504
Footprint:       54.62 MB
Num samples:     3 (2-4)
CPU Time:        41.059s (138.7G cycles, 40.1G instructions, 3.46c/i)
  No threads sampled
  Binary Images:
                0x1000 -             0x2fff  AdobeAcrobat <BD0419A6-AC29-4210-9EA0-0BBAFC5682FE>  /Applications/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
Architecture:    i386
Parent:          launchd [1]
UID:             504
Footprint:       54.61 MB
Num samples:     6 (6-11)
  Binary Images:
Process:         adprivacyd [428]
UUID:            084C3546-CE3A-36CD-B47E-61EDF990A4EF
Path:            /usr/libexec/adprivacyd
Parent:          launchd [1]
UID:             504
Footprint:       10.54 MB
  Thread 0xe87              11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0xe6952            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10b616000 -        0x10b617fff  adprivacyd                           <084C3546-CE3A-36CD-B47E-61EDF990A4EF>  /usr/libexec/adprivacyd
Process:         AirPlayUIAgent [421]
UUID:            723E9B35-AF43-3059-B177-B04457F05C89
Path:            /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Parent:          launchd [1]
UID:             504
Footprint:       4552 KB
CPU Time:        <0.001s (85.2K cycles, 28.9K instructions, 2.95c/i)
  Thread 0xe6f              DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0>
  Thread 0xe98              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x102929000 -        0x102932fff  AirPlayUIAgent                          <723E9B35-AF43-3059-B177-B04457F05C89>  /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Process:         AirPlayXPCHelper [112]
UUID:            1A758229-3364-33BD-A0FD-EA958108C0B3
Path:            /usr/libexec/AirPlayXPCHelper
Parent:          launchd [1]
UID:             0
Footprint:       18.28 MB
CPU Time:        <0.001s (226.5K cycles, 48.5K instructions, 4.67c/i)
Note:            4 idle work queue threads omitted
  Thread 0x34c              DispatchQueue 11          11 samples (1-11)         priority 31 (base 31)
    11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11
     *11  ??? (kernel + 7168864) [0xffffff80008d6360] 1-11
  Binary Images:
           0x106ed6000 -        0x106ed8fff  AirPlayXPCHelper                     <1A758229-3364-33BD-A0FD-EA958108C0B3>  /usr/libexec/AirPlayXPCHelper
Process:         airportd [199]
UUID:            A5267A8F-BA7D-3838-88F3-A2C8422353C2
Path:            /usr/libexec/airportd
Parent:          launchd [1]
UID:             0
Footprint:       12.68 MB
  Thread 0x596              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0>
    11  ??? (airportd + 313403) [0x10025b83b] 1-11
      11  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11
        11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  Thread 0x5a0              DispatchQueue 82          11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default, ipc override default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0>
    11  ??? (airportd + 411993) [0x100273959] 1-11
      11  CFReadStreamRead + 249 (CoreFoundation + 468242) [0x7fff34f3e512] 1-11
        11  fileRead + 31 (CoreFoundation + 470600) [0x7fff34f3ee48] 1-11
          11  read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11
               *11  read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11
                 *11  ??? (kernel + 7270151) [0xffffff80008eef07] 1-11
                   *11  ??? (kernel + 4319092) [0xffffff800061e774] 1-11
                     *11  spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11
                       *11  cdev_read + 378 (IO80211Family + 451393) [0xffffff7f81d53341] 1-11
  Thread 0x60c              11 samples (1-11)         priority 31 (base 31)
  Thread 0x60e              11 samples (1-11)         priority 31 (base 31)
  Thread 0x60f              Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 31 (base 31)
        11  __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11
  Binary Images:
           0x10020f000 -        0x10033efff  airportd (1380.2)                              <A5267A8F-BA7D-3838-88F3-A2C8422353C2>  /usr/libexec/airportd
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)            <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
   *0xffffff7f81ce5000 - 0xffffff7f81d9afff  com.apple.iokit.IO80211Family 12.0 (1200.12.2) <177476EF-3F2E-3C6B-9324-0D624FDCF290>  /System/Library/Extensions/IO80211Family.kext/Contents/MacOS/IO80211Family
Process:         akd [361]
UUID:            4165B30D-1898-3C40-88FC-15C75C0EFA27
Path:            /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Parent:          launchd [1]
UID:             504
Footprint:       13.22 MB
CPU Time:        <0.001s (94.9K cycles, 23.1K instructions, 4.11c/i)
  Thread 0xcde              11 samples (1-11)         priority 4 (base 4)
  Thread 0x53640            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10525b000 -        0x105309fff  akd (181.8.0.2)                      <4165B30D-1898-3C40-88FC-15C75C0EFA27>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process:         amfid [192]
UUID:            8A693E78-7B5D-3C10-8FBD-AA2E78F4561B
Path:            /usr/libexec/amfid
Parent:          launchd [1]
UID:             0
Footprint:       33.20 MB
Note:            Suspended for 1 sample
  Thread 0x429              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
     *1   ??? (kernel + 7168864) [0xffffff80008d6360] (suspended) 2
     *9   ??? (kernel + 7168864) [0xffffff80008d6360] 3-11
  Binary Images:
           0x102a9e000 -        0x102aacfff  amfid                                <8A693E78-7B5D-3C10-8FBD-AA2E78F4561B>  /usr/libexec/amfid
Process:         analyticsd [306]
UUID:            2E2247B3-29A9-3979-A196-1B2200210042
Path:            /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
Parent:          launchd [1]
UID:             263
Footprint:       9136 KB
  Thread 0x8f0              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x109209000 -        0x1092bcfff  analyticsd (50.1)                       <2E2247B3-29A9-3979-A196-1B2200210042>  /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
Process:         apfsd [204]
UUID:            A318C4BE-A45D-3852-89F4-C84305273E92
Path:            /usr/libexec/apfsd
Parent:          launchd [1]
UID:             0
Footprint:       1292 KB
  Thread 0x5c9              11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x106a74000 -        0x106a85fff  apfsd (945.275.10)                   <A318C4BE-A45D-3852-89F4-C84305273E92>  /usr/libexec/apfsd
Process:         APFSUserAgent [355]
UUID:            FB95C17E-18DA-3707-A06E-C0DA2CE5F194
Path:            /System/Library/CoreServices/APFSUserAgent
Parent:          launchd [1]
UID:             504
Footprint:       1100 KB
  Thread 0xafc              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10688a000 -        0x10688ffff  APFSUserAgent                        <FB95C17E-18DA-3707-A06E-C0DA2CE5F194>  /System/Library/CoreServices/APFSUserAgent
Process:         appleeventsd [60]
UUID:            3D5AB89D-29F1-3AF4-BFC2-3A0DB8898F93
Path:            /System/Library/CoreServices/appleeventsd
Parent:          launchd [1]
UID:             55
Footprint:       10.66 MB
  Thread 0x6f3              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x10fdd3000 -        0x10fdd3fff  appleeventsd                         <3D5AB89D-29F1-3AF4-BFC2-3A0DB8898F93>  /System/Library/CoreServices/appleeventsd
Process:         AppleSpell [668]
UUID:            E52723D9-B46D-35AB-80E0-A3788CF4121E
Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Parent:          launchd [1]
UID:             504
Footprint:       42.27 MB
  Thread 0x1e1a             DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
    11  ??? (AppleSpell + 5204) [0x10ceef454] 1-11
      11  -[NSSpellServer run] + 73 (Foundation + 2208793) [0x7fff3736f419] 1-11
  Binary Images:
           0x10ceee000 -        0x10cff9fff  com.apple.AppleSpell 2.4 (430.16.16)    <E52723D9-B46D-35AB-80E0-A3788CF4121E>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process:         applessdstatistics [80013]
UUID:            A470A49C-DD14-35C6-8CE0-889B4C4760FC
Path:            /usr/libexec/applessdstatistics
Parent:          launchd [1]
UID:             0
Footprint:       800 KB
  Thread 0x508f1c           11 samples (1-11)         priority 20 (base 20)
    11  __ulock_wait + 10 (libsystem_kernel.dylib + 14810) [0x7fff60fd29da] 1-11
     *11  ??? (kernel + 7307696) [0xffffff80008f81b0] 1-11
  Binary Images:
           0x100a4d000 -        0x100a85fff  applessdstatistics (118.260.1)       <A470A49C-DD14-35C6-8CE0-889B4C4760FC>  /usr/libexec/applessdstatistics
Process:         appstoreagent [894]
UUID:            2469E0C7-E31C-3D96-B4C6-1211B4FC6786
Path:            /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
Parent:          launchd [1]
UID:             504
Footprint:       13.36 MB
  Thread 0xa1e7             DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (appstoreagent + 7155) [0x106c96bf3] 1-11
      11  ??? (appstoreagent + 274378) [0x106cd7fca] 1-11
        11  ??? (appstoreagent + 274665) [0x106cd80e9] 1-11
  Thread 0x47a1f1           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x106c95000 -        0x106d1afff  appstoreagent (5.4.3)                   <2469E0C7-E31C-3D96-B4C6-1211B4FC6786>  /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
Process:         apsd [85]
UUID:            399BDED0-DC36-38A3-9ADC-9F97302C3F08
Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Parent:          launchd [1]
UID:             0
Footprint:       10.93 MB
  Thread 0x26c              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
    11  ??? (apsd + 499291) [0x103e5be5b] 1-11
  Thread 0xde8              Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 31 (base 31)
  Thread 0xdf6              Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x103de2000 -        0x103ed5fff  apsd (625.35)                           <399BDED0-DC36-38A3-9ADC-9F97302C3F08>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Process:         ARDAgent [366]
UUID:            C9097C01-A695-389B-BD31-2097BC5356C1
Path:            /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
Parent:          launchd [1]
UID:             504
Footprint:       22.21 MB
  Thread 0xd08              DispatchQueue 1           11 samples (1-11)         priority 20 (base 20)
    11  ??? (ARDAgent + 7180) [0x1025aec0c] 1-11
  Thread 0xd17              11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
  Thread 0xd18              11 samples (1-11)         priority 20 (base 20)
  Thread 0xd19              11 samples (1-11)         priority 97 (base 97)
  <thread QoS utility, timers tier 3 (coalesced), IO tier 1>
  Thread 0xd1b              11 samples (1-11)         priority 20 (base 20)
  Thread 0xd1c              11 samples (1-11)         priority 20 (base 20)
  Thread 0xd1d              11 samples (1-11)         priority 20 (base 20)
    11  __accept + 10 (libsystem_kernel.dylib + 20966) [0x7fff60fd41e6] 1-11
         *11  accept_nocancel + 562 (kernel + 7544722) [0xffffff8000931f92] 1-11
  Thread 0xaa0be7           11 samples (1-11)         priority 20 (base 20)
        11  ??? (ARDAgent + 335428) [0x1025fee44] 1-11
          11  ??? (ARDAgent + 336025) [0x1025ff099] 1-11
            11  __connect + 10 (libsystem_kernel.dylib + 21822) [0x7fff60fd453e] 1-11
                 *11  connect_nocancel + 650 (kernel + 7547418) [0xffffff8000932a1a] 1-11
  Thread 0xaa0be8           11 samples (1-11)         priority 20 (base 20)
  Thread 0xaa0c07           11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x1025ad000 -        0x1026b4fff  com.apple.RemoteDesktopAgent 3.9.8 (525.51) <C9097C01-A695-389B-BD31-2097BC5356C1>  /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
Process:         aslmanager [145]
UUID:            2C1732C8-0F63-3418-A9E3-862A12A133D6
Path:            /usr/sbin/aslmanager
Parent:          launchd [1]
UID:             0
Footprint:       2584 KB
  Thread 0x300              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 3>
  Binary Images:
           0x104c50000 -        0x104c59fff  aslmanager                           <2C1732C8-0F63-3418-A9E3-862A12A133D6>  /usr/sbin/aslmanager
Process:         aslmanager [44100]
Parent:          launchd [1]
UID:             0
Footprint:       772 KB
  Thread 0x3b2399           11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3>
  Binary Images:
           0x105b9c000 -        0x105ba5fff  aslmanager                           <2C1732C8-0F63-3418-A9E3-862A12A133D6>  /usr/sbin/aslmanager
Process:         assertiond [4066]
UUID:            3D32AB97-9560-331C-8A11-EC038C3CFD0F
Path:            /usr/libexec/assertiond
Parent:          launchd [1]
UID:             504
Footprint:       1808 KB
  Thread 0x4be3f            DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10cf8d000 -        0x10cfc6fff  assertiond                           <3D32AB97-9560-331C-8A11-EC038C3CFD0F>  /usr/libexec/assertiond
Process:         AssetCache [800]
UUID:            8FEDE7C4-E643-3F29-8F62-E1AF5CF42939
Path:            /usr/libexec/AssetCache/AssetCache
Parent:          launchd [1]
UID:             235
Footprint:       3880 KB
  Thread 0x3f5a             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x101cda000 -        0x101e7ffff  AssetCache                           <8FEDE7C4-E643-3F29-8F62-E1AF5CF42939>  /usr/libexec/AssetCache/AssetCache
Process:         assistant_service [5602]
UUID:            0CBCDE32-AA6A-331B-8CCD-5BFF625EC8AE
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
Parent:          launchd [1]
UID:             504
Footprint:       47.59 MB
  Thread 0x75c05            11 samples (1-11)         priority 4 (base 4)
  Thread 0xe692d            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x104b1c000 -        0x104b28fff  assistant_service (1737.195)         <0CBCDE32-AA6A-331B-8CCD-5BFF625EC8AE>  /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
Process:         assistantd [404]
UUID:            BDBA8173-6CC1-3710-BD77-1A8205C77A20
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
Parent:          launchd [1]
UID:             504
Footprint:       37.57 MB
CPU Time:        <0.001s (81.6K cycles, 23.2K instructions, 3.52c/i)
  Thread 0xe2c              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (assistantd + 79405) [0x10b84162d] 1-11
      11  ??? (assistantd + 80634) [0x10b841afa] 1-11
  Binary Images:
           0x10b82e000 -        0x10bae1fff  assistantd (1737.195)                   <BDBA8173-6CC1-3710-BD77-1A8205C77A20>  /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
Process:         atsd [825]
UUID:            180E9A70-84DA-3766-BE14-F400A058B32B
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/atsd
Parent:          launchd [1]
UID:             504
Footprint:       5040 KB
  Thread 0x4dff             11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested user initiated), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    11  main_handler + 4300 (libATSServer.dylib + 513971) [0x7fff333d57b3] 1-11
  Binary Images:
           0x10e0ea000 -        0x10e0edfff  atsd                                    <180E9A70-84DA-3766-BE14-F400A058B32B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/atsd
        0x7fff33358000 -     0x7fff333edfff  libATSServer.dylib (453.11.2.2)         <37E698CA-67D9-3A99-82C9-F42157DF145A>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
Process:         AudioComponentRegistrar [193]
UUID:            C285208A-5AD6-3F78-BC69-D31BB3DA96D1
Path:            /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Parent:          launchd [1]
UID:             0
Footprint:       4164 KB
  Thread 0x42d              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10a6c7000 -        0x10a6c8fff  AudioComponentRegistrar (975.97)     <C285208A-5AD6-3F78-BC69-D31BB3DA96D1>  /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Process:         AudioComponentRegistrar [765]
Parent:          launchd [1]
UID:             504
Footprint:       5468 KB
  Thread 0x32e2             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10f5f1000 -        0x10f5f2fff  AudioComponentRegistrar (975.97)     <C285208A-5AD6-3F78-BC69-D31BB3DA96D1>  /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Process:         authd [144]
UUID:            7903F716-AB62-3E2E-9AC3-862FBBA8939F
Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
Parent:          launchd [1]
UID:             0
Footprint:       7588 KB
  Thread 0x32b              11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    11  __read_nocancel + 10 (libsystem_kernel.dylib + 8634) [0x7fff60fd11ba] 1-11
                 *11  ??? (kernel + 6732104) [0xffffff800086b948] 1-11
  Thread 0x347              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c6f2000 -        0x10c715fff  com.apple.authd 1.0 (58286.270.14)   <7903F716-AB62-3E2E-9AC3-862FBBA8939F>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
Process:         autofsd [96]
UUID:            AD1F8C75-D277-350C-B5E9-C1AFAEA10A83
Path:            /usr/libexec/autofsd
Parent:          launchd [1]
UID:             0
Footprint:       848 KB
  Thread 0x504              11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x100831000 -        0x100831fff  autofsd                              <AD1F8C75-D277-350C-B5E9-C1AFAEA10A83>  /usr/libexec/autofsd
Process:         avconferenced [42201]
UUID:            0F476CC8-645D-3B24-B860-A54963C9F1B9
Path:            /usr/libexec/avconferenced
Parent:          launchd [1]
UID:             504
Footprint:       5792 KB
  Thread 0x35e75f           11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10bf4b000 -        0x10bf4bfff  avconferenced (1475.4.8)             <0F476CC8-645D-3B24-B860-A54963C9F1B9>  /usr/libexec/avconferenced
Process:         awdd [191]
UUID:            94D581CA-04CA-3AA7-8087-D09B74E2AB67
Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Parent:          launchd [1]
UID:             0
Footprint:       10.59 MB
  Thread 0x41e              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x102477000 -        0x10255afff  awdd (930.11)                           <94D581CA-04CA-3AA7-8087-D09B74E2AB67>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Process:         backgroundtaskmanagementagent [313]
UUID:            8E407DD0-50B5-354F-9E63-8FA504F97D8B
Path:            /System/Library/CoreServices/backgroundtaskmanagementagent
Parent:          launchd [1]
UID:             504
Footprint:       10.85 MB
  Thread 0x930              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10e3b3000 -        0x10e3cdfff  backgroundtaskmanagementagent        <8E407DD0-50B5-354F-9E63-8FA504F97D8B>  /System/Library/CoreServices/backgroundtaskmanagementagent
Process:         backupd [13157] [unique pid 112763]
UUID:            ED3C2C56-EDE6-3E72-B8CF-EC105C7A956B
Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
Parent:          launchd [1]
UID:             0
Footprint:       2412 KB
  Thread 0x6700b8           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3>
    11  ??? (backupd + 67768) [0x101e358b8] 1-11
  Binary Images:
           0x101e25000 -        0x101eadfff  backupd (283.30)                        <ED3C2C56-EDE6-3E72-B8CF-EC105C7A956B>  /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
Process:         backupd-helper [80]
UUID:            2B55AD03-A067-3608-8808-4C13C56A08CF
Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
Parent:          launchd [1]
UID:             0
Footprint:       2488 KB
  Thread 0x281              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1098ea000 -        0x109906fff  backupd-helper                       <2B55AD03-A067-3608-8808-4C13C56A08CF>  /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
Process:         bird [329]
UUID:            85AD688A-8111-3E36-BBAC-620C07A68E60
Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Parent:          launchd [1]
UID:             504
Footprint:       4052 KB
  Thread 0x9c4              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10d5d8000 -        0x10d5d9fff  bird (575.303)                       <85AD688A-8111-3E36-BBAC-620C07A68E60>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Process:         Bluetooth File Exchange [42140]
UUID:            CF26238B-7C6B-3BD4-878D-B069CE126908
Path:            /Applications/Utilities/Bluetooth File Exchange.app/Contents/MacOS/Bluetooth File Exchange
Parent:          launchd [1]
UID:             504
Footprint:       34.45 MB
CPU Time:        <0.001s (69.6K cycles, 25.4K instructions, 2.73c/i)
  Thread 0x35d262           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0x35d28b           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c45d000 -        0x10c46ffff  Bluetooth File Exchange                 <CF26238B-7C6B-3BD4-878D-B069CE126908>  /Applications/Utilities/Bluetooth File Exchange.app/Contents/MacOS/Bluetooth File Exchange
Process:         bluetoothd [108]
UUID:            A74E6D15-1C2B-301C-99FB-39F53044AF61
Path:            /usr/sbin/bluetoothd
Parent:          launchd [1]
UID:             0
Footprint:       25.84 MB
CPU Time:        0.004s (15.9M cycles, 5.1M instructions, 3.14c/i)
  Thread 0x27d              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)     cpu time 0.004s (15.9M cycles, 5.1M instructions, 3.14c/i)
    11  ??? (bluetoothd + 1033495) [0x109282517] 1-11
  Thread 0x576              Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x109186000 -        0x10944cfff  bluetoothd (6014.1.14)                  <A74E6D15-1C2B-301C-99FB-39F53044AF61>  /usr/sbin/bluetoothd
Process:         bootinstalld [235]
UUID:            D6B1D7C1-DF03-39C1-8851-3AC4046753A4
Path:            /usr/libexec/bootinstalld
Parent:          launchd [1]
UID:             0
Footprint:       2720 KB
  Thread 0x6b5              11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x102e91000 -        0x102e97fff  bootinstalld                         <D6B1D7C1-DF03-39C1-8851-3AC4046753A4>  /usr/libexec/bootinstalld
Process:         Calculator [56872] [unique pid 156457]
UUID:            E26D5AC3-8BB4-3D87-BD39-12C55C5590CE
Path:            /Applications/Calculator.app/Contents/MacOS/Calculator
Parent:          launchd [1]
UID:             504
Footprint:       26.54 MB
CPU Time:        <0.001s (52.4K cycles, 24.7K instructions, 2.13c/i)
  Thread 0x9795d7           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Thread 0x979631           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10d391000 -        0x10d3aefff  Calculator                              <E26D5AC3-8BB4-3D87-BD39-12C55C5590CE>  /Applications/Calculator.app/Contents/MacOS/Calculator
Process:         CalendarAgent [340]
UUID:            DF33ECE0-1050-36DD-A273-A6907BD84488
Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Parent:          launchd [1]
UID:             504
Footprint:       39.59 MB
CPU Time:        <0.001s (150.3K cycles, 29.6K instructions, 5.08c/i)
  Thread 0xa42              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from com.apple.dock.extra [332], IO tier 0>
    11  ??? (CalendarAgent + 5996) [0x10273276c] 1-11
  Thread 0xedf              Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x102731000 -        0x102732fff  CalendarAgent (416.5.2)                 <DF33ECE0-1050-36DD-A273-A6907BD84488>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Process:         CallHistoryPluginHelper [346]
UUID:            9D3403B0-6DC7-3269-A693-F382F13F1521
Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Parent:          launchd [1]
UID:             504
Footprint:       2204 KB
  Thread 0xa60              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1000a5000 -        0x1000a6fff  CallHistoryPluginHelper              <9D3403B0-6DC7-3269-A693-F382F13F1521>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Process:         callservicesd [296]
UUID:            F6A1404C-3C40-3A04-BA99-6BA8714EFE12
Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Parent:          launchd [1]
UID:             504
Footprint:       8480 KB
  Thread 0x883              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (callservicesd + 1140624) [0x105288790] 1-11
  Binary Images:
           0x105172000 -        0x105327fff  callservicesd (977.41)                  <F6A1404C-3C40-3A04-BA99-6BA8714EFE12>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Process:         CalNCService [349]
UUID:            2E0EDC39-AEE1-38B0-A471-2788866DD2DF
Path:            /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
Parent:          launchd [1]
Responsible:     CalendarAgent [340]
UID:             504
Footprint:       16.02 MB
  Thread 0xa9f              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  main + 111 (CalNCService + 49022) [0x10b424f7e] 1-11
      11  -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11
        11  xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11
          11  _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11
  Binary Images:
           0x10b419000 -        0x10b428fff  com.apple.CalendarNotification.CalNCService 1.0 (585.3.1) <2E0EDC39-AEE1-38B0-A471-2788866DD2DF>  /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
        0x7fff610c3000 -     0x7fff610f2fff  libxpc.dylib (1336.261.7)                                 <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8>  /usr/lib/system/libxpc.dylib
Process:         captiveagent [387]
UUID:            E1C27CCE-BF90-3F79-8144-E1CF0900320A
Path:            /usr/libexec/captiveagent
Parent:          launchd [1]
UID:             258
Footprint:       2876 KB
  Thread 0xd81              11 samples (1-11)         priority 4 (base 4)
  Thread 0xd86              Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Thread 0xdc1              Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x100f52000 -        0x100f59fff  captiveagent                         <E1C27CCE-BF90-3F79-8144-E1CF0900320A>  /usr/libexec/captiveagent
Process:         cfprefsd [115]
UUID:            DABBAE9C-E74B-3420-80B8-9298628DFD56
Path:            /usr/sbin/cfprefsd
Parent:          launchd [1]
UID:             0
Footprint:       19.50 MB
  Thread 0x2a2              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10153c000 -        0x10153cfff  cfprefsd                             <DABBAE9C-E74B-3420-80B8-9298628DFD56>  /usr/sbin/cfprefsd
Process:         cfprefsd [263]
Parent:          launchd [1]
UID:             504
Footprint:       9096 KB
  Thread 0x7a5              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10b0da000 -        0x10b0dafff  cfprefsd                             <DABBAE9C-E74B-3420-80B8-9298628DFD56>  /usr/sbin/cfprefsd
Process:         cfprefsd [935]
Parent:          launchd [1]
UID:             501
Footprint:       732 KB
  Thread 0xb144             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1075e1000 -        0x1075e1fff  cfprefsd                             <DABBAE9C-E74B-3420-80B8-9298628DFD56>  /usr/sbin/cfprefsd
Process:         check_afp [681]
UUID:            974DEDC8-BC32-3168-8D4E-838E3F05B9A3
Path:            /System/Library/Filesystems/AppleShare/check_afp.app/Contents/MacOS/check_afp
Parent:          launchd [1]
UID:             0
Footprint:       1228 KB
  Thread 0x1f1d             11 samples (1-11)         priority 20 (base 20)
  Thread 0x1f24             11 samples (1-11)         priority 20 (base 20)
  Thread 0x1f40             Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x10c0f5000 -        0x10c0f8fff  check_afp (508.250.1)                <974DEDC8-BC32-3168-8D4E-838E3F05B9A3>  /System/Library/Filesystems/AppleShare/check_afp.app/Contents/MacOS/check_afp
Process:         chrome_crashpad_handler [725]
UUID:            4C4C4451-5555-3144-A188-34ECCBD38F7D
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/chrome_crashpad_handler
Parent:          launchd [1]
Responsible:     Google Chrome [721]
UID:             504
Footprint:       1304 KB
  Thread 0x2eef             11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
    11  CrashpadHandlerMain + 107 (chrome_crashpad_handler + 51499) [0x10ae6592b] 1-11
      11  CrashpadHandlerMain + 236402 (chrome_crashpad_handler + 287794) [0x10ae9f432] 1-11
        11  CrashpadHandlerMain + 249040 (chrome_crashpad_handler + 300432) [0x10aea2590] 1-11
          11  CrashpadHandlerMain + 639239 (chrome_crashpad_handler + 690631) [0x10af019c7] 1-11
            11  CrashpadHandlerMain + 637521 (chrome_crashpad_handler + 688913) [0x10af01311] 1-11
  Thread 0x2ef4             11 samples (1-11)         priority 31 (base 31)
        11  CrashpadHandlerMain + 630601 (chrome_crashpad_handler + 681993) [0x10aeff809] 1-11
          11  CrashpadHandlerMain + 629275 (chrome_crashpad_handler + 680667) [0x10aeff2db] 1-11
            11  CrashpadHandlerMain + 641502 (chrome_crashpad_handler + 692894) [0x10af0229e] 1-11
              11  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11
                11  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11
  Thread 0x2ef5             11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10ae59000 -        0x10af60fff  chrome_crashpad_handler              <4C4C4451-5555-3144-A188-34ECCBD38F7D>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/chrome_crashpad_handler
Process:         chrome_crashpad_handler [840]
UUID:            4C4C448D-5555-3144-A1F3-9749A01C369E
Path:            /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Helpers/chrome_crashpad_handler
Architecture:    x86_64
Parent:          launchd [1]
Responsible:     Teams [836]
UID:             504
Footprint:       1292 KB
End time:        2022-12-30 22:13:31 -0800
  Thread 0x6187             11 samples (1-11)         priority 31 (base 31)
      11  CrashpadHandlerMain + 92 (chrome_crashpad_handler + 4588) [0x10a9a91ec] 1-11
        11  CrashpadHandlerMain + 147136 (chrome_crashpad_handler + 151632) [0x10a9cd050] 1-11
          11  CrashpadHandlerMain + 154672 (chrome_crashpad_handler + 159168) [0x10a9cedc0] 1-11
            11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 125930 (chrome_crashpad_handler + 506618) [0x10aa23afa] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 124233 (chrome_crashpad_handler + 504921) [0x10aa23459] 1-11
  Thread 0x618a             11 samples (1-11)         priority 31 (base 31)
        11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 116810 (chrome_crashpad_handler + 497498) [0x10aa2175a] 1-11
          11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 109051 (chrome_crashpad_handler + 489739) [0x10aa1f90b] 1-11
            11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 128142 (chrome_crashpad_handler + 508830) [0x10aa2439e] 1-11
  Thread 0x618b             11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10a9a8000 -        0x10ab19fff  chrome_crashpad_handler              <4C4C448D-5555-3144-A1F3-9749A01C369E>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Helpers/chrome_crashpad_handler
Process:         Cineware [62935] [unique pid 162518]
UUID:            8A8E11EB-5237-3C94-96A7-93F983F2D90A
Path:            /Applications/Vectorworks 2021/*/Cineware.app/Contents/MacOS/Cineware
Parent:          Vectorworks [62926] [unique pid 162509]
Responsible:     Vectorworks [62926] [unique pid 162509]
UID:             504
Footprint:       412.53 MB
CPU Time:        0.002s (6.8M cycles, 1325.0K instructions, 5.10c/i)
  Thread 0xa4bc67           DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (4.3M cycles, 846.2K instructions, 5.10c/i)
    11  ??? (Cineware + 33308) [0x102ca921c] 1-11
      11  ??? (Cineware + 34288) [0x102ca95f0] 1-11
        11  ??? (Cineware + 28006) [0x102ca7d66] 1-11
  Thread 0xa4bc6a           Thread name "CoreTimerThread"                       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (91.6K cycles, 7.1K instructions, 12.94c/i)
  Thread 0xa4bc6f           Thread name "Crash Handler"                         11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc7d           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc7e           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc85           11 samples (1-11)         priority 31 (base 31)
        11  ??? (Cineware + 2703640) [0x102f35118] 1-11
          11  ??? (Cineware + 3173146) [0x102fa7b1a] 1-11
            11  ??? (c4dplugin.xlib + 832493) [0x106ac83ed] 1-11
              11  ??? (c4dplugin.xlib + 833463) [0x106ac87b7] 1-11
  Thread 0xa4bc86           Thread name "Default Queue #0: 0x7fe7d809d000 (Q 0x1031a5100, Id 0x70000cd95" 11 samples (1-11)         priority 31 (base 31)
          11  ??? (Cineware + 3173274) [0x102fa7b9a] 1-11
            11  ??? (Cineware + 3171605) [0x102fa7515] 1-11
              11  ??? (Cineware + 2079700) [0x102e9cbd4] 1-11
                11  ??? (Cineware + 2081950) [0x102e9d49e] 1-11
                  11  ??? (Cineware + 2814662) [0x102f502c6] 1-11
  Thread 0xa4bc87           Thread name "Default Queue #1: 0x7fe7d81280c0 (Q 0x1031a5100, Id 0x70000ce98" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc88           Thread name "Default Queue #2: 0x7fe7d8137080 (Q 0x1031a5100, Id 0x70000cf9b" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc89           Thread name "Default Queue #3: 0x7fe7d8146040 (Q 0x1031a5100, Id 0x70000d09e" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc8a           Thread name "Default Queue #4: 0x7fe7d8155000 (Q 0x1031a5100, Id 0x70000d1a1" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc8b           Thread name "Default Queue #5: 0x7fe7d81680c0 (Q 0x1031a5100, Id 0x70000d2a4" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc8c           Thread name "Default Queue #6: 0x7fe7d8177080 (Q 0x1031a5100, Id 0x70000d3a7" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc8d           Thread name "Default Queue #7: 0x7fe7d8186040 (Q 0x1031a5100, Id 0x70000d4aa" 11 samples (1-11)         priority 31 (base 31)
  Thread 0xa4bc8f           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (68.4K cycles, 10.3K instructions, 6.67c/i)
  <thread QoS default (requested user initiated), IO tier 0>
            11  ??? (c4dplugin.xlib + 5183129) [0x106eee699] 1-11
              11  ??? (c4dplugin.xlib + 5176337) [0x106eecc11] 1-11
                11  ??? (xtensions.xlib + 1769147) [0x113826ebb] 1-11
                  11  ??? (c4dplugin.xlib + 13401400) [0x1076c4d38] 1-11
                    11  ??? (network.module.xlib + 186953) [0x10e728a49] 1-11
                      11  ??? (network.module.xlib + 191819) [0x10e729d4b] 1-11
                        11  ??? (network.module.xlib + 195047) [0x10e72a9e7] 1-11
  Thread 0xa4bc90           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (57.6K cycles, 10.2K instructions, 5.67c/i)
                11  ??? (xtensions.xlib + 1771033) [0x113827619] 1-11
  Thread 0xa4bd63           11 samples (1-11)         priority 30 (base 31)
              11  ??? (Cineware + 2080072) [0x102e9cd48] 1-11
  Thread 0xa8cf46           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa8cf48           Thread name "Render Queue #1: 0x7fe7d01e7080 (Q 0x7fe7d00d9d80, Id 0x70000d8" 11 samples (1-11)         priority 8 (base 31)
  Thread 0xa8cf49           Thread name "Render Queue #6: 0x7fe7ec83d000 (Q 0x7fe7d00d9d80, Id 0x70000d9" 11 samples (1-11)         priority 7 (base 31)
  Thread 0xa8cf4a           Thread name "Render Queue #3: 0x7fe7d0205000 (Q 0x7fe7d00d9d80, Id 0x70000da" 11 samples (1-11)         priority 7 (base 31)
  Thread 0xa8cf4b           Thread name "Render Queue #7: 0x7fe7ec9e80c0 (Q 0x7fe7d00d9d80, Id 0x70000db" 11 samples (1-11)         priority 8 (base 31)
  Thread 0xa8cf4c           Thread name "Render Queue #7: 0x7fe7d028d000 (Q 0x7fe7d00d8980, Id 0x70000dc" 11 samples (1-11)         priority 30 (base 31)
  Thread 0xa8cf4d           Thread name "Render Queue #2: 0x7fe7d01f6040 (Q 0x7fe7d00d9d80, Id 0x70000dd" 11 samples (1-11)         priority 8 (base 31)
  Thread 0xa8cf4e           Thread name "Render Queue #4: 0x7fe7ec81f080 (Q 0x7fe7d00d9d80, Id 0x70000de" 11 samples (1-11)         priority 8 (base 31)
  Thread 0xa8cf9f           Thread name "Render Queue #5: 0x7fe7ec82e040 (Q 0x7fe7d00d9d80, Id 0x70000df" 11 samples (1-11)         priority 7 (base 31)
  Thread 0xa8cfa0           Thread name "Render Queue #0: 0x7fe7d01d80c0 (Q 0x7fe7d00d9d80, Id 0x70000e0" 11 samples (1-11)         priority 8 (base 31)
  Binary Images:
           0x102ca1000 -        0x1030d4fff  net.maxon.Cineware 21.2 (308675)        <8A8E11EB-5237-3C94-96A7-93F983F2D90A>  /Applications/Vectorworks 2021/*/Cineware.app/Contents/MacOS/Cineware
           0x1069fd000 -        0x107f33fff  c4dplugin.xlib (0)                      <E8E51742-0C47-38BC-B05B-191ED79B78C2>  /Applications/Vectorworks 2021/*/c4dplugin.xlib
           0x10e6fb000 -        0x10e8e9fff  network.module.xlib (0)                 <FF48F987-C0C9-35A2-9E55-77B1E9F253C7>  /Applications/Vectorworks 2021/*/network.module.xlib
           0x113677000 -        0x113b80fff  xtensions.xlib (0)                      <B439F454-7D8B-376A-913E-6A4B895EA4D4>  /Applications/Vectorworks 2021/*/xtensions.xlib
Process:         cloudd [283]
UUID:            5AFD8372-21B6-3AE3-8B4D-315DC1312137
Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Parent:          launchd [1]
UID:             504
Footprint:       15.28 MB
Start time:      2022-12-30 22:13:30 -0800
Num samples:     11 (1-11)
CPU Time:        <0.001s (126.2K cycles, 26.1K instructions, 4.83c/i)
  Thread 0x814              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from secd [279], process received importance donation from imagent [299], IO tier 0>
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  ??? (cloudd + 7603) [0x107010db3] 1-11
  Binary Images:
           0x10700f000 -        0x107013fff  cloudd (736.232)                        <5AFD8372-21B6-3AE3-8B4D-315DC1312137>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Process:         CloudKeychainProxy [310]
UUID:            0E98A85A-90C8-30F9-BC24-6EC4A26B4F89
Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Parent:          launchd [1]
UID:             504
Footprint:       1572 KB
  Thread 0x911              11 samples (1-11)         priority 4 (base 4)
  11  <truncated backtrace> 1-11
  Binary Images:
           0x102db1000 -        0x102dc2fff  CloudKeychainProxy                   <0E98A85A-90C8-30F9-BC24-6EC4A26B4F89>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Process:         cloudpaird [423]
UUID:            313DCA15-5878-36C7-922E-85EE5FBC235D
Path:            /System/Library/CoreServices/cloudpaird
Parent:          launchd [1]
UID:             504
Footprint:       16.93 MB
  Thread 0xe81              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (cloudpaird + 158273) [0x105171a41] 1-11
  Binary Images:
           0x10514b000 -        0x10519cfff  cloudpaird (6014.1.14)                  <313DCA15-5878-36C7-922E-85EE5FBC235D>  /System/Library/CoreServices/cloudpaird
Process:         cloudphotosd [794]
UUID:            9A7B379F-79E0-3CB3-8D5E-83C185CC0B78
Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Parent:          launchd [1]
UID:             504
Footprint:       9856 KB
CPU Time:        <0.001s (53.9K cycles, 24.1K instructions, 2.24c/i)
Note:            2 idle work queue threads omitted
  Thread 0x3f5d             DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  main + 115 (cloudphotosd + 653642) [0x10405394a] 1-11
      11  NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11
                          11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
                           *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0x3fa0             Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
  Binary Images:
           0x103fb4000 -        0x10408bfff  com.apple.cloudphotosd 4.0 (3461.7.160) <9A7B379F-79E0-3CB3-8D5E-83C185CC0B78>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Process:         cmhelperd [382]
UUID:            1F51BDE3-D183-3B11-8233-0B3CD5BDE1E5
Path:            /Library/MonitoringClient/*/ContactMenu.app/Contents/MacOS/cmhelperd
Parent:          launchd [1]
UID:             504
Footprint:       7260 KB
  Thread 0xd44              DispatchQueue 1           11 samples (1-11)         priority 20 (base 20)
    11  ??? (cmhelperd + 10587) [0x10eeac95b] 1-11
  Thread 0xfb3              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested user interactive), timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10eeaa000 -        0x10eeb5fff  com.monitoringclient.contact-menu 8.0 (8.0) <1F51BDE3-D183-3B11-8233-0B3CD5BDE1E5>  /Library/MonitoringClient/*/ContactMenu.app/Contents/MacOS/cmhelperd
Process:         colorsync.displayservices [226]
UUID:            7157BF3E-2E37-3EC7-8C5A-4A57DBF05286
Path:            /usr/libexec/colorsync.displayservices
Parent:          launchd [1]
UID:             0
Footprint:       1352 KB
  Thread 0x648              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10ed38000 -        0x10ed3dfff  colorsync.displayservices            <7157BF3E-2E37-3EC7-8C5A-4A57DBF05286>  /usr/libexec/colorsync.displayservices
Process:         colorsync.useragent [787]
UUID:            C4411A34-1442-3491-BDFA-13607D908ACC
Path:            /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
Parent:          launchd [1]
UID:             504
Footprint:       2452 KB
  Thread 0x3a12             11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x100808000 -        0x10080bfff  colorsync.useragent                  <C4411A34-1442-3491-BDFA-13607D908ACC>  /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
Process:         colorsyncd [228]
UUID:            D50B720A-09A1-37AF-9A5C-CD01C4FE5CEE
Path:            /usr/libexec/colorsyncd
Parent:          launchd [1]
UID:             0
Footprint:       2280 KB
  Thread 0x64d              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10d5e3000 -        0x10d5e5fff  colorsyncd                           <D50B720A-09A1-37AF-9A5C-CD01C4FE5CEE>  /usr/libexec/colorsyncd
Process:         com.apple.accessibility.mediaaccessibilityd [1089]
UUID:            88B9A527-E1CB-3D8A-8CC4-946FBE4D68B2
Path:            /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Parent:          launchd [1]
UID:             504
Footprint:       1144 KB
  Thread 0x124eb            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1006d4000 -        0x1006d5fff  com.apple.accessibility.mediaaccessibilityd <88B9A527-E1CB-3D8A-8CC4-946FBE4D68B2>  /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Process:         com.apple.AccountPolicyHelper [245]
UUID:            DF61919B-8E51-31EB-B6E4-B1D7FB61542D
Path:            /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Parent:          launchd [1]
UID:             0
Footprint:       1388 KB
  Thread 0x720              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10e86d000 -        0x10e877fff  com.apple.AccountPolicyHelper        <DF61919B-8E51-31EB-B6E4-B1D7FB61542D>  /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Process:         com.apple.AmbientDisplayAgent [392]
UUID:            41254C2E-00A1-3996-B1E1-1B57900BD7F6
Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Parent:          launchd [1]
UID:             0
Footprint:       2620 KB
  Thread 0xda9              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0>
  Thread 0xdb4              11 samples (1-11)         priority 31 (base 31)
  Thread 0xdb6              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10e862000 -        0x10e869fff  com.apple.AmbientDisplayAgent 1.0 (110) <41254C2E-00A1-3996-B1E1-1B57900BD7F6>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Process:         com.apple.appkit.xpc.openAndSavePanelService [4982]
UUID:            50C9373E-9EEA-3A6C-919A-1CF94F9098D9
Path:            /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Parent:          launchd [1]
Responsible:     Microsoft Outlook [4828]
UID:             504
Footprint:       63.47 MB
CPU Time:        <0.001s (92.4K cycles, 25.7K instructions, 3.59c/i)
  Thread 0x5854c            DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26542) [0x1050c67ae] 1-11
      11  NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11
        11  -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11
            11  _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11
                  11  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11
                              11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
                                11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
                                  11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0x58562            Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
        11  _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11
  Binary Images:
           0x1050c0000 -        0x1050c9fff  com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <50C9373E-9EEA-3A6C-919A-1CF94F9098D9>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
        0x7fff5c9ed000 -     0x7fff5cac6fff  com.apple.ViewBridge 407 (407)                       <41AB432A-08A7-3808-8079-B07D742D3F33>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process:         com.apple.appkit.xpc.openAndSavePanelService [16669] [unique pid 116270]
Parent:          launchd [1]
Responsible:     WeChat [11139] [unique pid 110747]
UID:             504
Footprint:       32.80 MB
CPU Time:        <0.001s (484.3K cycles, 128.6K instructions, 3.77c/i)
Note:            3 idle work queue threads omitted
  Thread 0x74c949           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0>
    11  main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26542) [0x10cd687ae] 1-11
  Thread 0x74c99a           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x10cd62000 -        0x10cd6bfff  com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <50C9373E-9EEA-3A6C-919A-1CF94F9098D9>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Process:         com.apple.appkit.xpc.openAndSavePanelService [16763] [unique pid 116363]
Parent:          launchd [1]
Responsible:     Preview [6302] [unique pid 105926]
UID:             504
Footprint:       38.75 MB
CPU Time:        <0.001s (76.3K cycles, 24.9K instructions, 3.06c/i)
  Thread 0x752947           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26542) [0x10e24a7ae] 1-11
  Thread 0x752970           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10e244000 -        0x10e24dfff  com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <50C9373E-9EEA-3A6C-919A-1CF94F9098D9>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Process:         com.apple.audio.DriverHelper [170]
UUID:            10B74390-27AB-3E2D-BA86-BA4C50691315
Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Parent:          launchd [1]
Responsible:     coreaudiod [155]
UID:             202
Footprint:       3196 KB
  Thread 0x3a2              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x100f40000 -        0x100f42fff  com.apple.audio.DriverHelper         <10B74390-27AB-3E2D-BA86-BA4C50691315>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Process:         com.apple.audio.SandboxHelper [194]
UUID:            BDEA0F2E-574E-3383-81C6-5AD30808B73B
Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Parent:          launchd [1]
UID:             202
Footprint:       932 KB
  Thread 0x433              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x108725000 -        0x108729fff  com.apple.audio.SandboxHelper        <BDEA0F2E-574E-3383-81C6-5AD30808B73B>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [766]
Parent:          launchd [1]
UID:             504
Footprint:       932 KB
  Thread 0x32ef             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x102367000 -        0x10236bfff  com.apple.audio.SandboxHelper        <BDEA0F2E-574E-3383-81C6-5AD30808B73B>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [845]
Parent:          launchd [1]
Responsible:     assistantd [404]
UID:             504
Footprint:       1040 KB
  Thread 0x620f             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x104226000 -        0x10422afff  com.apple.audio.SandboxHelper        <BDEA0F2E-574E-3383-81C6-5AD30808B73B>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [853]
Parent:          launchd [1]
UID:             504
Footprint:       956 KB
  Thread 0x62c7             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x109ba5000 -        0x109ba9fff  com.apple.audio.SandboxHelper        <BDEA0F2E-574E-3383-81C6-5AD30808B73B>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.audio.SandboxHelper [16753] [unique pid 116353]
Parent:          launchd [1]
UID:             504
Footprint:       876 KB
  Thread 0x751311           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10697a000 -        0x10697efff  com.apple.audio.SandboxHelper        <BDEA0F2E-574E-3383-81C6-5AD30808B73B>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.BKAgentService [8662] [unique pid 108277]
UUID:            D595BCAE-22E2-34D7-9BA1-715559F52134
Path:            /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
Parent:          launchd [1]
UID:             504
Footprint:       1848 KB
  Thread 0x5ffd3a           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10345a000 -        0x1034c8fff  com.apple.BKAgentService             <D595BCAE-22E2-34D7-9BA1-715559F52134>  /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         com.apple.CloudDocs.MobileDocumentsFileProvider [60039] [unique pid 159624]
UUID:            B65F616A-60F9-3202-9B6D-C9E1C5D7F632
Path:            /System/Library/PrivateFrameworks/CloudDocs.framework/PlugIns/com.apple.CloudDocs.MobileDocumentsFileProvider.appex/Contents/MacOS/com.apple.CloudDocs.MobileDocumentsFileProvider
Parent:          launchd [1]
UID:             504
Footprint:       1992 KB
  Thread 0x9f2a77           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c745000 -        0x10c755fff  com.apple.CloudDocs.MobileDocumentsFileProvider <B65F616A-60F9-3202-9B6D-C9E1C5D7F632>  /System/Library/PrivateFrameworks/CloudDocs.framework/PlugIns/com.apple.CloudDocs.MobileDocumentsFileProvider.appex/Contents/MacOS/com.apple.CloudDocs.MobileDocumentsFileProvider
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                            <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         com.apple.CloudPhotosConfiguration [805]
UUID:            77A2324C-F8BB-3991-A2AD-D833B24076E9
Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Parent:          launchd [1]
UID:             504
Footprint:       2636 KB
Note:            1 idle work queue thread omitted
  Thread 0x3fa1             DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  main + 24 (com.apple.CloudPhotosConfiguration + 10873) [0x1084dca79] 1-11
      11  +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 11195) [0x1084dcbbb] 1-11
        11  -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 11407) [0x1084dcc8f] 1-11
  Binary Images:
           0x1084da000 -        0x1084eafff  com.apple.CloudPhotosConfiguration 4.0 (3461.7.160) <77A2324C-F8BB-3991-A2AD-D833B24076E9>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)             <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                             <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         com.apple.cmio.registerassistantservice [495]
UUID:            C147D580-E0BC-32C9-9214-B3DE88D6B0BC
Path:            /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
Parent:          launchd [1]
UID:             0
Footprint:       808 KB
  Thread 0x151a             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10bfcb000 -        0x10bfcdfff  com.apple.cmio.registerassistantservice <C147D580-E0BC-32C9-9214-B3DE88D6B0BC>  /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
Process:         com.apple.CodeSigningHelper [187]
UUID:            DA9B9F7C-0121-3BF3-9941-F1F6498B7D94
Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Parent:          launchd [1]
UID:             0
Footprint:       12.85 MB
  Thread 0x3f6              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x103c67000 -        0x103c68fff  com.apple.CodeSigningHelper          <DA9B9F7C-0121-3BF3-9941-F1F6498B7D94>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Process:         com.apple.ctkpcscd [156]
UUID:            357CFF2A-6330-3539-A2AB-812619DD5D25
Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Parent:          launchd [1]
Responsible:     securityd [90]
UID:             0
Footprint:       1016 KB
  Thread 0x368              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10a535000 -        0x10a53efff  com.apple.ctkpcscd                   <357CFF2A-6330-3539-A2AB-812619DD5D25>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Process:         com.apple.dock.extra [332]
UUID:            3F1E89E9-6587-3558-96F8-E31C12D1F07F
Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Parent:          launchd [1]
Responsible:     Dock [274]
UID:             504
Footprint:       9016 KB
CPU Time:        <0.001s (105.8K cycles, 32.5K instructions, 3.26c/i)
  Thread 0x9c1              DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Dock [274], IO tier 0>
    11  ??? (com.apple.dock.extra + 4388) [0x101ec4124] 1-11
  Thread 0x9e0              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x101ec3000 -        0x101ec6fff  com.apple.dock.extra 1.0 (1)            <3F1E89E9-6587-3558-96F8-E31C12D1F07F>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
        0x7fff324e2000 -     0x7fff33297fff  com.apple.AppKit 6.9 (1671.60.112)      <4AFB032C-2786-3AD7-8EDA-576956992A9C>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)     <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
Process:         com.apple.geod [342]
UUID:            FE72F42B-C7DA-3104-91D4-D845CA2CCE66
Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Parent:          launchd [1]
UID:             504
Sudden Term:     Tracked (allows idle exit)
Footprint:       17.75 MB
  Thread 0xa4f              11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0xa7f              Thread name "NetworkLoad" 11 samples (1-11)         priority 4 (base 4)
  Thread 0x202ab            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x104abf000 -        0x104aedfff  com.apple.geod 1.0 (1364.26.4.19.6)  <FE72F42B-C7DA-3104-91D4-D845CA2CCE66>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Process:         com.apple.hiservices-xpcservice [699]
UUID:            BCAE3700-079A-39EC-957B-B7AB778D7852
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Parent:          launchd [1]
UID:             504
Footprint:       2088 KB
Note:            Unresponsive for 211644 seconds before sampling
  Thread 0x2aa2             DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10b60d000 -        0x10b611fff  com.apple.hiservices-xpcservice      <BCAE3700-079A-39EC-957B-B7AB778D7852>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Process:         com.apple.ifdreader [203]
UUID:            734438E8-0F06-3932-A1A2-CB963F73CD14
Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Parent:          launchd [1]
UID:             0
Footprint:       1196 KB
  Thread 0x5c7              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x101336000 -        0x101341fff  com.apple.ifdreader 1.0 (1)          <734438E8-0F06-3932-A1A2-CB963F73CD14>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Process:         com.apple.iTunesLibraryService [493]
UUID:            B45883A0-D7FE-3F8E-BF68-AB466A221DB7
Path:            /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Parent:          launchd [1]
UID:             504
Footprint:       3180 KB
  Thread 0x1515             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10a88b000 -        0x10a984fff  com.apple.iTunesLibraryService       <B45883A0-D7FE-3F8E-BF68-AB466A221DB7>  /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.iTunesLibraryService [9952]
Parent:          launchd [1]
Responsible:     assistant_service [5602]
UID:             504
Footprint:       5632 KB
  Thread 0xe6926            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1070a9000 -        0x1071a2fff  com.apple.iTunesLibraryService       <B45883A0-D7FE-3F8E-BF68-AB466A221DB7>  /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Process:         com.apple.MediaLibraryService [806]
UUID:            7A484597-FB6E-32F8-A786-3E87357BADE8
Path:            /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
Parent:          launchd [1]
Responsible:     cloudphotosd [794]
UID:             504
Footprint:       10.73 MB
  Thread 0x3fb1             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10e76f000 -        0x10e779fff  com.apple.MediaLibraryService 1.5.0 (764) <7A484597-FB6E-32F8-A786-3E87357BADE8>  /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
Process:         com.apple.PerformanceAnalysis.animationperfd [253]
UUID:            B8021A05-5056-3A6F-93DD-DD7BDA43F453
Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Parent:          launchd [1]
UID:             0
Footprint:       8588 KB
CPU Time:        <0.001s (86.8K cycles, 29.7K instructions, 2.93c/i)
  Thread 0x753              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10d049000 -        0x10d052fff  com.apple.PerformanceAnalysis.animationperfd <B8021A05-5056-3A6F-93DD-DD7BDA43F453>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Process:         com.apple.quicklook.ThumbnailsAgent [795]
UUID:            92DE2ABD-2896-3923-A137-BF9F941F5589
Path:            /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Parent:          launchd [1]
UID:             504
Footprint:       1552 KB
  Thread 0x3f5e             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10aabe000 -        0x10aad3fff  com.apple.quicklook.ThumbnailsAgent  <92DE2ABD-2896-3923-A137-BF9F941F5589>  /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Process:         com.apple.Safari.History [16861]
UUID:            0371D741-EAC9-36E8-A8D5-050ED6422112
Path:            /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
Parent:          launchd [1]
UID:             504
Footprint:       4536 KB
  Thread 0x1c5123           11 samples (1-11)         priority 4 (base 4)
  Thread 0x1c512a           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
    11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
     *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Binary Images:
           0x10d48e000 -        0x10d48ffff  com.apple.Safari.History             <0371D741-EAC9-36E8-A8D5-050ED6422112>  /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)        <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         com.apple.Safari.SafeBrowsing.Service [16870]
UUID:            CE4EC79B-1D39-3862-B885-47EED3C707E7
Path:            /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Parent:          launchd [1]
UID:             504
Footprint:       41.79 MB
CPU Time:        <0.001s (99.7K cycles, 31.2K instructions, 3.19c/i)
  Thread 0x1c51ff           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10eb4e000 -        0x10eb50fff  com.apple.Safari.SafeBrowsing.Service <CE4EC79B-1D39-3862-B885-47EED3C707E7>  /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Process:         com.apple.security.pboxd [15547]
UUID:            FD747B23-EDE1-3793-AE22-157ADC59CCA1
Path:            /System/Library/PrivateFrameworks/RemoteViewServices.framework/XPCServices/com.apple.security.pboxd.xpc/Contents/MacOS/com.apple.security.pboxd
Parent:          launchd [1]
UID:             504
Footprint:       7456 KB
CPU Time:        <0.001s (55.9K cycles, 24.0K instructions, 2.33c/i)
  Thread 0x16878d           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (com.apple.security.pboxd + 12052) [0x10fd4df14] 1-11
      11  -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11
        11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11
          11  _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11
            11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11
              11  ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11
                11  RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11
  Thread 0x1687b2           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10fd4b000 -        0x10fd62fff  com.apple.security.pboxd 2.0 (128)      <FD747B23-EDE1-3793-AE22-157ADC59CCA1>  /System/Library/PrivateFrameworks/RemoteViewServices.framework/XPCServices/com.apple.security.pboxd.xpc/Contents/MacOS/com.apple.security.pboxd
        0x7fff3415a000 -     0x7fff34451fff  com.apple.HIToolbox 2.1.1 (918.7)       <88D7F19C-8C9D-384B-BAB5-8205CA282F2C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         com.apple.siri-distributed-evaluation [7343]
UUID:            9F377692-08EA-3FA5-A8AC-C3A70462DD1F
Path:            /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
Parent:          launchd [1]
UID:             504
Footprint:       3320 KB
  Thread 0xc74e2            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1089ab000 -        0x1089c1fff  com.apple.siri-distributed-evaluation <9F377692-08EA-3FA5-A8AC-C3A70462DD1F>  /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
Process:         com.apple.siri.ClientFlow.ClientScripter [5603]
UUID:            CFA6218C-F629-30D3-8900-C86D4EDA89FD
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter
Parent:          launchd [1]
UID:             504
Footprint:       3104 KB
  Thread 0x75c12            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1034a6000 -        0x1034cffff  com.apple.siri.ClientFlow.ClientScripter <CFA6218C-F629-30D3-8900-C86D4EDA89FD>  /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter
Process:         com.apple.speech.speechsynthesisd [1228]
UUID:            FE40A427-9064-32DC-96FF-DA847EF0004B
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Parent:          launchd [1]
UID:             504
Footprint:       16.22 MB
  Thread 0x1a478            11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x101fc1000 -        0x101fd2fff  com.apple.speech.speechsynthesisd (8.1.3) <FE40A427-9064-32DC-96FF-DA847EF0004B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Process:         com.apple.WebKit.Networking [98174]
UUID:            97B4845A-1405-364D-A61D-C44B32F26F5F
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Parent:          launchd [1]
Responsible:     Mail [98166]
UID:             504
Footprint:       10.20 MB
  Thread 0x588129           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10ee9f867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10ee9f6e2] 1-11
            11  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11
              11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  Thread 0x588139           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
  Thread 0x588151           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Thread 0x58816d           Thread name "com.apple.CFNetwork.CustomProtocols"   11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10ee9e000 -        0x10ee9ffff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)           <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         com.apple.WebKit.Networking [8666] [unique pid 108281]
Parent:          launchd [1]
Responsible:     iTunes [8660] [unique pid 108275]
UID:             504
Footprint:       33.64 MB
  Thread 0x5ffe90           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10049b867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10049b6e2] 1-11
  Thread 0x5ffe9c           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffea2           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10049a000 -        0x10049bfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [12063] [unique pid 111671]
Parent:          launchd [1]
UID:             504
Footprint:       2816 KB
  Thread 0x669a7d           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0>
    11  ??? (com.apple.WebKit.Networking + 6247) [0x104541867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x1045416e2] 1-11
  Thread 0x669a81           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x669a86           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x104540000 -        0x104541fff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [12507] [unique pid 112113]
Parent:          launchd [1]
UID:             504
Footprint:       2796 KB
  Thread 0x66c364           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x104472867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x1044726e2] 1-11
  Thread 0x66c36a           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x66c377           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x104471000 -        0x104472fff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [13057] [unique pid 112663]
Parent:          launchd [1]
UID:             504
Footprint:       2812 KB
  Thread 0x66f60a           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10100b867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10100b6e2] 1-11
  Thread 0x66f60e           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x66f61b           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10100a000 -        0x10100bfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [13886] [unique pid 113492]
Parent:          launchd [1]
UID:             504
Footprint:       2828 KB
  Thread 0x67702d           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x103db3867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x103db36e2] 1-11
  Thread 0x677034           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x67703e           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x103db2000 -        0x103db3fff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [13920] [unique pid 113526]
Parent:          launchd [1]
UID:             504
Footprint:       2828 KB
  Thread 0x677844           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10072b867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10072b6e2] 1-11
  Thread 0x67784c           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x677857           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10072a000 -        0x10072bfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [14195] [unique pid 113800]
Parent:          launchd [1]
UID:             504
Footprint:       2844 KB
  Thread 0x67b724           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x102afa867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x102afa6e2] 1-11
  Thread 0x67b72a           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x67b734           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x102af9000 -        0x102afafff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [14447] [unique pid 114051]
Parent:          launchd [1]
UID:             504
Footprint:       2836 KB
  Thread 0x685c65           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10e6da867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10e6da6e2] 1-11
  Thread 0x685c6e           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x685c7c           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10e6d9000 -        0x10e6dafff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [14524] [unique pid 114128]
Parent:          launchd [1]
UID:             504
Footprint:       2812 KB
  Thread 0x69767f           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x102429867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x1024296e2] 1-11
  Thread 0x697686           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x697690           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x102428000 -        0x102429fff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [23828] [unique pid 123421]
Parent:          launchd [1]
UID:             504
Footprint:       2784 KB
  Thread 0x7ce852           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10ebac867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10ebac6e2] 1-11
  Thread 0x7ce859           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7ce866           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10ebab000 -        0x10ebacfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [24678] [unique pid 124271]
Parent:          launchd [1]
UID:             504
Footprint:       2780 KB
  Thread 0x7d3807           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10f61c867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10f61c6e2] 1-11
  Thread 0x7d380f           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7d3819           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10f61b000 -        0x10f61cfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [25126] [unique pid 124719]
Parent:          launchd [1]
UID:             504
Footprint:       2752 KB
  Thread 0x7d5f9a           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x1084f7867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x1084f76e2] 1-11
  Thread 0x7d5fa2           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7d5fad           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x1084f6000 -        0x1084f7fff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [25298] [unique pid 124891]
Parent:          launchd [1]
UID:             504
Footprint:       2824 KB
  Thread 0x7d717f           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10cd6e867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10cd6e6e2] 1-11
  Thread 0x7d7187           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7d7193           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10cd6d000 -        0x10cd6efff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [25600] [unique pid 125193]
Parent:          launchd [1]
UID:             504
Footprint:       2852 KB
  Thread 0x7d92bd           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x102acc867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x102acc6e2] 1-11
  Thread 0x7d92c5           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7d92d0           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x102acb000 -        0x102accfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [29128] [unique pid 128720]
Parent:          launchd [1]
UID:             504
Footprint:       18.42 MB
CPU Time:        <0.001s (140.8K cycles, 23.8K instructions, 5.93c/i)
  Thread 0x7e4254           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10cfb9867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10cfb96e2] 1-11
  Thread 0x7e4269           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7e4275           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Thread 0x7edcf8           Thread name "WebCore: AsyncFileStream"              11 samples (1-11)         priority 37 (base 37)
  Thread 0x7edd08           Thread name "IndexedDatabase Server"                11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10cfb8000 -        0x10cfb9fff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.Networking [29135] [unique pid 128727]
Parent:          launchd [1]
Responsible:     Mini Program [29130] [unique pid 128722]
UID:             504
Footprint:       2624 KB
  Thread 0x7e4304           DispatchQueue 1           11 samples (1-11)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0>
    11  ??? (com.apple.WebKit.Networking + 6247) [0x10055b867] 1-11
      11  ??? (com.apple.WebKit.Networking + 5858) [0x10055b6e2] 1-11
  Thread 0x7e430c           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x7e4316           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10055a000 -        0x10055bfff  com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Process:         com.apple.WebKit.WebContent [8665] [unique pid 108280]
UUID:            B54D230D-67AC-3B7A-A529-8756CF1E4920
Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Parent:          launchd [1]
UID:             504
Footprint:       210.19 MB
CPU Time:        <0.001s (122.7K cycles, 51.3K instructions, 2.39c/i)
  Thread 0x5ffe8f           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2>
    11  ??? (com.apple.WebKit.WebContent + 6247) [0x103b4d867] 1-11
      11  ??? (com.apple.WebKit.WebContent + 5858) [0x103b4d6e2] 1-11
  Thread 0x5ffe97           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0x5ffea7           Thread name "WebCore: Scrolling"                    11 samples (1-11)         priority 4 (base 4)
        11  WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 15417) [0x7fff381e1c39] 1-11
          11  WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 194 (JavaScriptCore + 1984498) [0x7fff383c27f2] 1-11
            11  WebCore::ScrollingThread::initializeRunLoop() + 252 (WebCore + 276892) [0x7fff41ad699c] 1-11
              11  CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11
  Binary Images:
           0x103b4c000 -        0x103b4dfff  com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fff381de000 -     0x7fff3903efff  com.apple.JavaScriptCore 14607 (14607.3.9)    <E25D3B54-A072-33F3-AA89-6F8588BF5A05>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff41a93000 -     0x7fff43419fff  com.apple.WebCore 14607 (14607.3.9)           <4D9F69EF-D3AF-32C5-8C15-1C8CD7370AFC>  /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
Process:         com.apple.WebKit.WebContent [29134] [unique pid 128726]
Parent:          launchd [1]
UID:             504
Footprint:       29.14 MB
CPU Time:        <0.001s (62.2K cycles, 22.4K instructions, 2.78c/i)
  Thread 0x7e4303           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0>
    11  ??? (com.apple.WebKit.WebContent + 6247) [0x10261a867] 1-11
      11  ??? (com.apple.WebKit.WebContent + 5858) [0x10261a6e2] 1-11
  Thread 0x7e4308           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
        11  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11
          11  bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11
            11  bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11
              11  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11
                11  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11
  Thread 0x7e4317           Thread name "WebCore: Scrolling"                    11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x102619000 -        0x10261afff  com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fff5e0c2000 -     0x7fff5e115fff  libc++.1.dylib (400.9.4)                      <9A60A190-6C34-339F-BB3D-AACE942009A4>  /usr/lib/libc++.1.dylib
Process:         com.apple.WebKit.WebContent [29138] [unique pid 128730]
Parent:          launchd [1]
UID:             504
Footprint:       73.85 MB
CPU Time:        <0.001s (292.4K cycles, 78.0K instructions, 3.75c/i)
  Thread 0x7e4369           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0>
    11  ??? (com.apple.WebKit.WebContent + 6247) [0x108566867] 1-11
      11  ??? (com.apple.WebKit.WebContent + 5858) [0x1085666e2] 1-11
        11  xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11
          11  _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11
  Thread 0x7e436e           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)     cpu time <0.001s (45.9K cycles, 9.0K instructions, 5.10c/i)
            4   bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-4
              4   void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-4
                4   std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-4
                  4   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-4
                   *4   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-4
            7   bmalloc::Scavenger::threadRunLoop() + 262 (JavaScriptCore + 2260422) [0x7fff38405dc6] 5-11
              7   std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 95 (JavaScriptCore + 2265343) [0x7fff384070ff] 5-11
                7   std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117 (JavaScriptCore + 2265653) [0x7fff38407235] 5-11
                  7   std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 5-11
                    7   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 5-11
                     *7   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11
  Thread 0x7e4371           Thread name "WebCore: Scrolling"                    11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x108565000 -        0x108566fff  com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
        0x7fff610c3000 -     0x7fff610f2fff  libxpc.dylib (1336.261.7)                     <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8>  /usr/lib/system/libxpc.dylib
Process:         com.apple.WebKit.WebContent [29950] [unique pid 129542]
Parent:          launchd [1]
UID:             504
Footprint:       84.54 MB
CPU Time:        <0.001s (169.8K cycles, 56.7K instructions, 2.99c/i)
  Thread 0x8050d1           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
    11  ??? (com.apple.WebKit.WebContent + 6247) [0x10667e867] 1-11
      11  ??? (com.apple.WebKit.WebContent + 5858) [0x10667e6e2] 1-11
  Thread 0x8050db           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  Thread 0x8050ea           Thread name "WebCore: Scrolling"                    11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x10667d000 -        0x10667efff  com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [58347] [unique pid 157932]
Architecture:    x86_64
Parent:          launchd [1]
UID:             504
Footprint:       110.00 MB
End time:        2022-12-30 22:13:31 -0800
CPU Time:        <0.001s (123.1K cycles, 53.0K instructions, 2.32c/i)
  Thread 0x9e3343           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (com.apple.WebKit.WebContent + 6247) [0x1052ad867] 1-11
      11  ??? (com.apple.WebKit.WebContent + 5858) [0x1052ad6e2] 1-11
  Thread 0x9e3348           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
  Thread 0x9e335b           Thread name "WebCore: Scrolling"                    11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1052ac000 -        0x1052adfff  com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.apple.WebKit.WebContent [58348] [unique pid 157933]
Parent:          launchd [1]
UID:             504
Footprint:       22.04 MB
CPU Time:        <0.001s (116.3K cycles, 55.2K instructions, 2.11c/i)
  Thread 0x9e3349           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (com.apple.WebKit.WebContent + 6247) [0x10a296867] 1-11
      11  ??? (com.apple.WebKit.WebContent + 5858) [0x10a2966e2] 1-11
  Thread 0x9e3351           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
  Thread 0x9e335c           Thread name "WebCore: Scrolling"                    11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10a295000 -        0x10a296fff  com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Process:         com.paragon-software.ntfsd [464]
UUID:            815ADF1C-C681-39E9-AD7F-AD68A676A107
Path:            /Library/Application Support/Paragon Software/com.paragon-software.ntfsd
Parent:          launchd [1]
UID:             0
Footprint:       2704 KB
  Thread 0x131d             11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
    11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11
     *11  ??? (kernel + 7168864) [0xffffff80008d6360] 1-11
  Binary Images:
           0x10ab98000 -        0x10aba9fff  com.paragon-software.ntfsd           <815ADF1C-C681-39E9-AD7F-AD68A676A107>  /Library/Application Support/Paragon Software/com.paragon-software.ntfsd
Process:         CommCenter [272]
UUID:            7A833E0C-3AF8-3AAE-94DE-176E8C099EEA
Path:            /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
Parent:          launchd [1]
UID:             504
Footprint:       10204 KB
CPU Time:        <0.001s (607.2K cycles, 149.7K instructions, 4.06c/i)
  Thread 0x7c9              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
    11  ??? (CommCenter + 451341) [0x10207e30d] 1-11
      11  ??? (CommCenter + 453852) [0x10207ecdc] 1-11
  Thread 0x846              11 samples (1-11)         priority 31 (base 31)
  Thread 0x861              11 samples (1-11)         priority 31 (base 31)
  Thread 0x870              11 samples (1-11)         priority 31 (base 31)
  Thread 0x87c              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (160.3K cycles, 43.2K instructions, 3.71c/i)
        11  ??? (CommCenter + 4963374) [0x1024cbc2e] 1-11
  Binary Images:
           0x102010000 -        0x10281ffff  CommCenter (6833.1)                     <7A833E0C-3AF8-3AAE-94DE-176E8C099EEA>  /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
Process:         commerce [341]
UUID:            1D7EC6B7-076F-3337-92E6-843D0EF32418
Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
Parent:          launchd [1]
UID:             504
Footprint:       18.73 MB
  Thread 0xa4c              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
    11  ??? (commerce + 142600) [0x10fc72d08] 1-11
  Thread 0x11dd             Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
  Binary Images:
           0x10fc50000 -        0x10fe69fff  commerce (708.6)                        <1D7EC6B7-076F-3337-92E6-843D0EF32418>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
Process:         configd [63]
UUID:            F79C3F1D-07EB-315B-8EBA-57D8C182D704
Path:            /usr/libexec/configd
Parent:          launchd [1]
UID:             0
Footprint:       9000 KB
  Thread 0x25b              DispatchQueue 1           Thread name "SCDynamicStore"                        11 samples (1-11)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process sudden termination clean, IO tier 0>
    11  ??? (configd + 12674) [0x10501c182] 1-11
      11  ??? (configd + 17518) [0x10501d46e] 1-11
  Thread 0x2b1              Thread name "Main plugin thread"                    11 samples (1-11)         priority 31 (base 31)
  Thread 0x2e9              Thread name "InterfaceNamer thread"                 11 samples (1-11)         priority 31 (base 31)
  Thread 0x2ed              11 samples (1-11)         priority 31 (base 31)
  Thread 0x2ef              Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 31 (base 31)
    11  __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11
  Thread 0x32a              11 samples (1-11)         priority 31 (base 31)
  Thread 0x32e              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x105019000 -        0x105072fff  configd (963.270.4)                     <F79C3F1D-07EB-315B-8EBA-57D8C182D704>  /usr/libexec/configd
Process:         ContactsAccountsService [300]
UUID:            DD05F701-37AE-3DE8-84A9-00CB5AE29823
Path:            /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Parent:          launchd [1]
UID:             504
Footprint:       2104 KB
  Thread 0x8a6              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x102aad000 -        0x102ab1fff  ContactsAccountsService              <DD05F701-37AE-3DE8-84A9-00CB5AE29823>  /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Process:         ContextService [25715]
UUID:            DA0A4185-C9E6-38F1-8C6B-319CD26CAD4C
Path:            /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
Parent:          launchd [1]
UID:             504
Footprint:       3716 KB
  Thread 0x2a9ad4           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x104380000 -        0x104773fff  ContextService                       <DA0A4185-C9E6-38F1-8C6B-319CD26CAD4C>  /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
Process:         contextstored [148]
UUID:            9B8C5E12-9AA3-3D75-B261-8882EAA4D272
Path:            /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/Resources/contextstored
Parent:          launchd [1]
UID:             0
Footprint:       12.20 MB
CPU Time:        <0.001s (133.4K cycles, 26.3K instructions, 5.08c/i)
  Thread 0x323              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (contextstored + 13746) [0x10d2d55b2] 1-11
  Binary Images:
           0x10d2d2000 -        0x10d2d6fff  contextstored (915.270.2)               <9B8C5E12-9AA3-3D75-B261-8882EAA4D272>  /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/Resources/contextstored
Process:         coreaudiod [155]
UUID:            1CBA9A8B-76AF-317F-A1B3-CBB07EA63E0F
Path:            /usr/sbin/coreaudiod
Parent:          launchd [1]
UID:             202
Footprint:       25.97 MB
Start time:      2022-12-30 22:13:30 -0800
Num samples:     11 (1-11)
CPU Time:        <0.001s (51.1K cycles, 10.7K instructions, 4.77c/i)
  Thread 0x356              DispatchQueue 1           11 samples (1-11)         priority 63 (base 63)
  <process sudden termination dirty, IO tier 0>
    11  ??? (coreaudiod + 169883) [0x109a8f79b] 1-11
  Thread 0x380              Thread name "HAL Async Logger"                      11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
    11  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11
     *11  semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11
  Thread 0x42b              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (51.1K cycles, 10.7K instructions, 4.77c/i)
        11  watchdogThreadFunc(void*) + 19 (MSTeamsAudioDevice + 6816) [0x109c7aaa0] 1-11
          11  sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11
            11  __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11
  Thread 0x4e1              Thread name "Audio HAL Overload Reporting Spool"    11 samples (1-11)         priority 31 (base 31)
  11  <truncated backtrace> 1-11
  Thread 0x502              Thread name "SystemSoundServer"                     11 samples (1-11)         priority 61 (base 61)
  Binary Images:
           0x109a66000 -        0x109bd5fff  coreaudiod (99.32)                                <1CBA9A8B-76AF-317F-A1B3-CBB07EA63E0F>  /usr/sbin/coreaudiod
           0x109c79000 -        0x109c80fff  com.microsoft.MSTeamsAudioDevice 2022.31.01.1 (1) <68C10D3D-2C5A-3CC0-B66C-8C3E7D593D09>  /Library/Audio/Plug-Ins/HAL/MSTeamsAudioDevice.driver/Contents/MacOS/MSTeamsAudioDevice
        0x7fff60ee5000 -     0x7fff60f6cfff  libsystem_c.dylib (1272.250.3)                    <6016EDA1-440B-34D7-A232-686CD7FBEE90>  /usr/lib/system/libsystem_c.dylib
Process:         coreauthd [260]
UUID:            7FDAFA66-D925-3779-8CFA-E8FA8A556247
Path:            /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Parent:          launchd [1]
UID:             0
Footprint:       1900 KB
  Thread 0x786              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x100d9c000 -        0x100dc8fff  coreauthd                            <7FDAFA66-D925-3779-8CFA-E8FA8A556247>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Process:         coreauthd [262]
Parent:          launchd [1]
UID:             504
Footprint:       1776 KB
  Thread 0x79d              11 samples (1-11)         priority 4 (base 4)
    11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
     *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Binary Images:
           0x10af06000 -        0x10af32fff  coreauthd                            <7FDAFA66-D925-3779-8CFA-E8FA8A556247>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Process:         corebrightnessd [111]
UUID:            F2F31403-13E7-3B5F-98CC-32AA38C7EA7D
Path:            /usr/libexec/corebrightnessd
Parent:          launchd [1]
UID:             0
Footprint:       11.90 MB
  Thread 0x278              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x104ce5000 -        0x104ce6fff  corebrightnessd (677.270.12)         <F2F31403-13E7-3B5F-98CC-32AA38C7EA7D>  /usr/libexec/corebrightnessd
Process:         coreduetd [81]
UUID:            56503287-A53B-3BC9-A00C-B875946F5B0A
Path:            /usr/libexec/coreduetd
Parent:          launchd [1]
UID:             0
Footprint:       11.14 MB
  Thread 0x28a              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x102e3f000 -        0x102e5afff  coreduetd                            <56503287-A53B-3BC9-A00C-B875946F5B0A>  /usr/libexec/coreduetd
Process:         CoreLocationAgent [351]
UUID:            9B2E80E2-5217-355D-B3CE-AE6E65429C27
Path:            /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
Parent:          launchd [1]
UID:             504
Footprint:       6052 KB
CPU Time:        <0.001s (57.2K cycles, 24.1K instructions, 2.37c/i)
Note:            2 idle work queue threads omitted
  Thread 0xabe              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11
  Thread 0xac9              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 37 (base 37)
  <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
  Binary Images:
           0x105a78000 -        0x105a7efff  CoreLocationAgent                       <9B2E80E2-5217-355D-B3CE-AE6E65429C27>  /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
Process:         coreservicesd [146]
UUID:            62E24649-7D14-3FF6-BB09-AE23238E874D
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
Parent:          launchd [1]
UID:             0
Footprint:       12.46 MB
CPU Time:        <0.001s (31.0K cycles, 6.2K instructions, 4.98c/i)
  Thread 0x31f              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
    11  _CoreServicesServerMain + 734 (CarbonCore + 563977) [0x7fff3622bb09] 1-11
  Thread 0x333              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (31.0K cycles, 6.2K instructions, 4.98c/i)
        3   fmodWatchConsumer + 198 (CarbonCore + 310728) [0x7fff361eddc8] 1-3
          3   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-3
           *3   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3
        8   fmodWatchConsumer + 285 (CarbonCore + 310815) [0x7fff361ede1f] 4-11
          8   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 4-11
           *8   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11
  Thread 0x334              11 samples (1-11)         priority 31 (base 31)
        11  read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11
         *11  hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11
           *11  unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11
             *11  read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11
               *11  ??? (kernel + 7270151) [0xffffff80008eef07] 1-11
                 *11  ??? (kernel + 4405643) [0xffffff800063398b] 1-11
                   *11  ??? (kernel + 7168593) [0xffffff80008d6251] 1-11
                     *11  thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11
                       *11  ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11
                         *11  machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11
  Binary Images:
           0x107954000 -        0x107954fff  coreservicesd                                       <62E24649-7D14-3FF6-BB09-AE23238E874D>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
        0x7fff361a2000 -     0x7fff36479fff  com.apple.CoreServices.CarbonCore 1178.33 (1178.33) <CB87F0C7-2CD6-3983-8E32-B6A2EC925352>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
Process:         CoreServicesUIAgent [64900] [unique pid 164483]
UUID:            93749292-A63D-3931-A288-8094A215251A
Path:            /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Parent:          launchd [1]
UID:             504
Footprint:       4340 KB
CPU Time:        <0.001s (76.9K cycles, 24.1K instructions, 3.19c/i)
  Thread 0xa6b1ce           DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  Thread 0xa6b1e2           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 37 (base 37)
  Binary Images:
           0x10a01d000 -                ???  CoreServicesUIAgent                     <93749292-A63D-3931-A288-8094A215251A>  /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Process:         corespeechd [405]
UUID:            5E7C0DEC-9CA3-3E90-B708-49DF0EEB8018
Path:            /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Parent:          launchd [1]
UID:             504
Footprint:       1276 KB
  Thread 0xe6b              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x108a52000 -        0x108a5efff  corespeechd                          <5E7C0DEC-9CA3-3E90-B708-49DF0EEB8018>  /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Process:         corespotlightd [481]
UUID:            6AEBF759-35E0-35BD-81D0-73D466D925A8
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
Parent:          launchd [1]
UID:             504
Footprint:       6320 KB
  Thread 0x13c8             11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 3>
  Thread 0x13cd             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x108748000 -        0x108754fff  corespotlightd                       <6AEBF759-35E0-35BD-81D0-73D466D925A8>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
Process:         coresymbolicationd [692]
UUID:            2A2B6FF3-46B6-3938-9C96-0CE3D097112C
Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Parent:          launchd [1]
UID:             0
Footprint:       2652 KB
  Thread 0x262b             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10f731000 -        0x10f73cfff  coresymbolicationd                   <2A2B6FF3-46B6-3938-9C96-0CE3D097112C>  /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Process:         CrashReporterSupportHelper [325]
UUID:            5B9DCA60-E972-3BC2-8B71-4AA9F66AE5CE
Path:            /System/Library/CoreServices/CrashReporterSupportHelper
Parent:          launchd [1]
UID:             0
Footprint:       1388 KB
  Thread 0x976              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x103ceb000 -        0x103cedfff  CrashReporterSupportHelper           <5B9DCA60-E972-3BC2-8B71-4AA9F66AE5CE>  /System/Library/CoreServices/CrashReporterSupportHelper
Process:         ctkahp [312]
UUID:            765D8CB0-55E0-38BB-8A67-A1DFEE962E4B
Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Parent:          launchd [1]
UID:             0
Footprint:       2828 KB
  Thread 0x928              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x109223000 -        0x10923dfff  ctkahp                               <765D8CB0-55E0-38BB-8A67-A1DFEE962E4B>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process:         ctkahp [315]
Parent:          launchd [1]
UID:             504
Footprint:       2920 KB
  Thread 0x93a              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x104c97000 -        0x104cb1fff  ctkahp                               <765D8CB0-55E0-38BB-8A67-A1DFEE962E4B>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Process:         ctkd [163]
UUID:            75C75C15-A3AD-394C-8DCC-5AD92AA9C165
Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Parent:          launchd [1]
UID:             259
Footprint:       2500 KB
  Thread 0x383              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10e960000 -        0x10e96dfff  ctkd                                 <75C75C15-A3AD-394C-8DCC-5AD92AA9C165>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process:         ctkd [317]
Parent:          launchd [1]
UID:             504
Footprint:       2708 KB
  Thread 0x94f              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x107581000 -        0x10758efff  ctkd                                 <75C75C15-A3AD-394C-8DCC-5AD92AA9C165>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Process:         cupsd [212]
UUID:            A64801E0-FD75-389A-912B-720CB81E1519
Path:            /usr/sbin/cupsd
Parent:          launchd [1]
UID:             0
Footprint:       15.99 MB
  Thread 0x626              11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
    11  ??? (cupsd + 97908) [0x10dbe6e74] 1-11
      11  kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11
       *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0x151f             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10dbcf000 -        0x10dc25fff  cupsd (462.16)                       <A64801E0-FD75-389A-912B-720CB81E1519>  /usr/sbin/cupsd
Process:         CVMServer [225]
UUID:            3246C88D-0E30-3A4A-BED4-2790B8DAC5E2
Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Parent:          launchd [1]
UID:             0
Footprint:       2652 KB
  Thread 0x645              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x106641000 -        0x10664afff  CVMServer                            <3246C88D-0E30-3A4A-BED4-2790B8DAC5E2>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process:         dasd [98]
UUID:            1A72AA3E-9F03-3595-A5A2-C375A16F137E
Path:            /usr/libexec/dasd
Parent:          launchd [1]
UID:             0
Footprint:       6404 KB
  Thread 0x290              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10eafe000 -        0x10eafffff  dasd (626.250.5)                     <1A72AA3E-9F03-3595-A5A2-C375A16F137E>  /usr/libexec/dasd
Process:         DataDetectorsSourceAccess [60974]
UUID:            5B9ED6E2-04A7-3BDD-869C-20666D4455D8
Path:            /usr/libexec/DataDetectorsSourceAccess
Parent:          launchd [1]
UID:             257
Footprint:       2364 KB
  Thread 0x43372e           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10bbac000 -        0x10bbadfff  DataDetectorsSourceAccess            <5B9ED6E2-04A7-3BDD-869C-20666D4455D8>  /usr/libexec/DataDetectorsSourceAccess
Process:         dbfseventsd [449]
UUID:            80DC5F36-CF3D-304D-97C6-3E622C45519E
Path:            /Library/DropboxHelperTools/*/dbfseventsd
Parent:          Dropbox [386]
UID:             0
Footprint:       376 KB
CPU Time:        <0.001s (73.8K cycles, 22.9K instructions, 3.22c/i)
  Thread 0xfca              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (73.8K cycles, 22.9K instructions, 3.22c/i)
  <thread QoS default (requested user interactive), process unclamped, IO tier 0>
    11  ??? (dbfseventsd + 2867) [0x10bb34b33] 1-11
  Binary Images:
           0x10bb34000 -        0x10bb3dfff  dbfseventsd (0)                      <80DC5F36-CF3D-304D-97C6-3E622C45519E>  /Library/DropboxHelperTools/*/dbfseventsd
Process:         dbfseventsd [450]
Parent:          dbfseventsd [449]
UID:             0
Footprint:       4468 KB
CPU Time:        <0.001s (247.4K cycles, 102.4K instructions, 2.42c/i)
  Thread 0xfcb              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (247.4K cycles, 102.4K instructions, 2.42c/i)
  <IO tier 0>
    11  ??? (dbfseventsd + 3481) [0x10bb34d99] 1-11
  Binary Images:
Process:         dbfseventsd [451]
Parent:          dbfseventsd [450]
UID:             504
Footprint:       276 KB
CPU Time:        <0.001s (339.9K cycles, 158.2K instructions, 2.15c/i)
  Thread 0xfcc              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (339.9K cycles, 158.2K instructions, 2.15c/i)
  <IO tier 0>
      11  ??? (dbfseventsd + 10009) [0x10bb36719] 1-11
                 *11  ??? (kernel + 7294931) [0xffffff80008f4fd3] 1-11
                   *11  ??? (kernel + 7168269) [0xffffff80008d610d] 1-11
                     *11  lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11
  Binary Images:
Process:         dbkextd [484]
UUID:            0E4C8DB6-3621-3ACF-8E15-3245DF2E0905
Path:            /Library/DropboxHelperTools/*/dbkextd
Parent:          launchd [1]
UID:             0
Footprint:       3432 KB
  Thread 0x13e2             11 samples (1-11)         priority 20 (base 20)
  Thread 0x13e4             11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested utility, ipc override utility), timers tier 3 (coalesced), IO tier 1>
    11  __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11
         *11  recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11
           *11  ??? (kernel + 7556385) [0xffffff8000934d21] 1-11
             *11  soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11
               *11  sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11
                 *11  msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11
  Binary Images:
           0x10143f000 -        0x10144afff  dbkextd                              <0E4C8DB6-3621-3ACF-8E15-3245DF2E0905>  /Library/DropboxHelperTools/*/dbkextd
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         deleted [575]
UUID:            E778FD40-C21A-3399-BE62-8D331B0C263D
Path:            /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Parent:          launchd [1]
UID:             504
Footprint:       3968 KB
  Thread 0x18e5             DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10fe95000 -        0x10fee3fff  deleted                              <E778FD40-C21A-3399-BE62-8D331B0C263D>  /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                 <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         diagnostics_agent [425]
UUID:            B7FE0902-4C63-3140-BA35-8940FD7FC07D
Path:            /System/Library/CoreServices/diagnostics_agent
Parent:          launchd [1]
UID:             504
Footprint:       3812 KB
CPU Time:        <0.001s (106.2K cycles, 32.0K instructions, 3.32c/i)
  Thread 0xe83              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 3>
  Binary Images:
           0x1039b1000 -        0x1039cdfff  diagnostics_agent                    <B7FE0902-4C63-3140-BA35-8940FD7FC07D>  /System/Library/CoreServices/diagnostics_agent
Process:         diskarbitrationd [77]
UUID:            277C434C-AACE-3589-9B85-C9E572E39BB6
Path:            /usr/libexec/diskarbitrationd
Parent:          launchd [1]
UID:             0
Footprint:       2268 KB
Note:            1 idle work queue thread omitted
  Thread 0x266              11 samples (1-11)         priority 31 (base 31)
    11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
      11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Binary Images:
           0x10f584000 -        0x10f59cfff  diskarbitrationd (297.250.7)            <277C434C-AACE-3589-9B85-C9E572E39BB6>  /usr/libexec/diskarbitrationd
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Process:         diskjournald [236]
UUID:            2AFE2477-AFE9-3F95-8217-356FB03A049F
Path:            /Library/MonitoringClient/*/diskjournald
Parent:          launchd [1]
UID:             0
Footprint:       1600 KB
  Thread 0x6da              11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
  Binary Images:
           0x10f39e000 -        0x10f3a5fff  diskjournald (0)                     <2AFE2477-AFE9-3F95-8217-356FB03A049F>  /Library/MonitoringClient/*/diskjournald
Process:         diskmanagementd [80005]
UUID:            EAF7247B-4681-310B-9BA2-6ED43A0A5C79
Path:            /usr/libexec/diskmanagementd
Parent:          launchd [1]
UID:             0
Footprint:       3636 KB
  Thread 0x508e20           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
  Thread 0x508e22           11 samples (1-11)         priority 31 (base 31)
  Thread 0x508e6b           11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x106245000 -        0x1063f1fff  diskmanagementd (1555.270.2)         <EAF7247B-4681-310B-9BA2-6ED43A0A5C79>  /usr/libexec/diskmanagementd
Process:         DiskUnmountWatcher [10124]
UUID:            95E93163-6465-3F6C-B750-81BD6C853527
Path:            /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
Parent:          launchd [1]
UID:             504
Footprint:       1184 KB
  Thread 0xe6f05            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c905000 -        0x10c905fff  DiskUnmountWatcher                   <95E93163-6465-3F6C-B750-81BD6C853527>  /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
Process:         displaypolicyd [97]
UUID:            862CF853-A279-31A5-A79D-5987ED115768
Path:            /usr/libexec/displaypolicyd
Parent:          launchd [1]
UID:             244
Footprint:       2220 KB
  Thread 0x27c              DispatchQueue 1           11 samples (1-11)         priority 20 (base 20)
  Thread 0x5f8              11 samples (1-11)         priority 20 (base 20)
    11  __accept + 10 (libsystem_kernel.dylib + 20966) [0x7fff60fd41e6] 1-11
         *11  accept_nocancel + 562 (kernel + 7544722) [0xffffff8000931f92] 1-11
  Thread 0x6c6              11 samples (1-11)         priority 20 (base 20)
  Thread 0x6c7              11 samples (1-11)         priority 20 (base 20)
  Thread 0x6c8              11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x10dc33000 -        0x10dc69fff  displaypolicyd (3.50.16)                <862CF853-A279-31A5-A79D-5987ED115768>  /usr/libexec/displaypolicyd
Process:         distnoted [114]
UUID:            186D92BD-74DA-3CA9-9959-2633D3EFB9E7
Path:            /usr/sbin/distnoted
Parent:          launchd [1]
UID:             241
Footprint:       2776 KB
CPU Time:        <0.001s (1260.1K cycles, 1022.4K instructions, 1.23c/i)
  Thread 0x405              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10892d000 -        0x108936fff  distnoted (1575.405)                 <186D92BD-74DA-3CA9-9959-2633D3EFB9E7>  /usr/sbin/distnoted
Process:         distnoted [270]
Parent:          launchd [1]
UID:             504
Footprint:       7128 KB
CPU Time:        <0.001s (3.1M cycles, 3.7M instructions, 0.85c/i)
  Thread 0x7c1              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x1077a5000 -        0x1077aefff  distnoted (1575.405)                 <186D92BD-74DA-3CA9-9959-2633D3EFB9E7>  /usr/sbin/distnoted
Process:         distnoted [384]
Parent:          launchd [1]
UID:             0
Footprint:       2304 KB
CPU Time:        <0.001s (189.3K cycles, 70.5K instructions, 2.68c/i)
  Thread 0xd61              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10f926000 -        0x10f92ffff  distnoted (1575.405)                 <186D92BD-74DA-3CA9-9959-2633D3EFB9E7>  /usr/sbin/distnoted
Process:         distnoted [611]
Parent:          launchd [1]
UID:             89
Footprint:       2452 KB
CPU Time:        <0.001s (188.5K cycles, 70.4K instructions, 2.68c/i)
  Thread 0x1ae5             11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x107518000 -        0x107521fff  distnoted (1575.405)                 <186D92BD-74DA-3CA9-9959-2633D3EFB9E7>  /usr/sbin/distnoted
Process:         distnoted [936]
Parent:          launchd [1]
UID:             501
Sudden Term:     Tracked (allows idle exit)
Footprint:       2328 KB
CPU Time:        <0.001s (212.4K cycles, 77.7K instructions, 2.73c/i)
  Thread 0xb176             11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x100413000 -        0x10041cfff  distnoted (1575.405)                 <186D92BD-74DA-3CA9-9959-2633D3EFB9E7>  /usr/sbin/distnoted
Process:         dmd [412]
UUID:            32CE22BA-1B70-3921-9067-F20A2429934D
Path:            /usr/libexec/dmd
Parent:          launchd [1]
UID:             504
Footprint:       2460 KB
  Thread 0xe85              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    11  ??? (dmd + 412834) [0x101226ca2] 1-11
      11  ??? (dmd + 367644) [0x10121bc1c] 1-11
            11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Binary Images:
           0x1011c2000 -        0x101240fff  dmd (21.1)                              <32CE22BA-1B70-3921-9067-F20A2429934D>  /usr/libexec/dmd
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                 <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         dmd [488]
Parent:          launchd [1]
UID:             0
Footprint:       2404 KB
  Thread 0x145a             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1062bb000 -        0x106339fff  dmd (21.1)                           <32CE22BA-1B70-3921-9067-F20A2429934D>  /usr/libexec/dmd
Process:         Dock [274]
UUID:            4B8B4B37-6468-3F26-A9AD-AFFD3205FBD2
Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
Parent:          launchd [1]
UID:             504
Footprint:       126.40 MB
CPU Time:        0.002s (8.1M cycles, 4.3M instructions, 1.89c/i)
Note:            5 idle work queue threads omitted
  Thread 0x7cf              DispatchQueue 1           11 samples (1-11)         priority 47 (base 47)     cpu time 0.002s (7.7M cycles, 4.2M instructions, 1.85c/i)
  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
    11  ??? (Dock + 22343) [0x103328747] 1-11
      11  autoreleasepool<A>(invoking:) + 47 (libswiftObjectiveC.dylib + 12111) [0x7fff60ba9f4f] 1-11
        11  ??? (Dock + 1637182) [0x1034b2b3e] 1-11
          11  ??? (Dock + 1638515) [0x1034b3073] 1-11
              11  ??? (Dock + 1638414) [0x1034b300e] 1-11
                11  ??? (Dock + 1638803) [0x1034b3193] 1-11
                    1   __CFRunLoopRun + 2524 (CoreFoundation + 243468) [0x7fff34f0770c] 1
                      1   __CFRunLoopDoSource1 + 527 (CoreFoundation + 341985) [0x7fff34f1f7e1] 1
                        1   __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation + 342147) [0x7fff34f1f883] 1
                          1   mshPerform + 11 (HIServices + 51057) [0x7fff336e4771] 1
                            1   ??? (Dock + 141157) [0x103345765] 1
                              1   ??? (Dock + 300160) [0x10336c480] 1
                                1   ??? (Dock + 480587) [0x10339854b] 1
                                  1   ??? (Dock + 482376) [0x103398c48] 1
                                    1   ??? (Dock + 599300) [0x1033b5504] 1
                                      1   _HandlePopUpMenuSelection7 + 49 (HIToolbox + 1761281) [0x7fff34308001] 1
                                        1   _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned int, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 418 (HIToolbox + 1761705) [0x7fff343081a9] 1
                                          1   PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1601 (HIToolbox + 1764561) [0x7fff34308cd1] 1
                                            1   FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 (HIToolbox + 655333) [0x7fff341f9fe5] 1
                                              1   SendMenuItemSelectedEvent + 192 (HIToolbox + 655613) [0x7fff341fa0fd] 1
                                                1   SendMenuCommandWithContextAndModifiers + 49 (HIToolbox + 655694) [0x7fff341fa14e] 1
                                                  1   SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 375 (HIToolbox + 490706) [0x7fff341d1cd2] 1
                                                    1   SendEventToEventTarget + 39 (HIToolbox + 154038) [0x7fff3417f9b6] 1
                                                      1   SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 371 (HIToolbox + 34271) [0x7fff341625df] 1
                                                        1   DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1422 (HIToolbox + 37422) [0x7fff3416322e] 1
                                                          1   ??? (Dock + 481083) [0x10339873b] 1
                                                            1   ??? (Dock + 534772) [0x1033a58f4] 1
                                                              1   ??? (Dock + 476826) [0x10339769a] 1
        1   LQForceQuit + 93 (libquit.dylib + 6208) [0x7fff5ffa2840] 1
        1   _CRProcessWillBeForceQuit + 237 (CrashReporterSupport + 37037) [0x7fff4998a0ad] 1
        1   _CRWriteCrashHistoryForProcess + 74 (CrashReporterSupport + 36450) [0x7fff49989e62] 1
        1   WriteCrashHistoryToURL + 86 (CrashReporterSupport + 36670) [0x7fff49989f3e] 1
        1   _CRWritePropertyListWithPathAndMode + 122 (CrashReporterSupport + 23985) [0x7fff49986db1] 1
        1   ftruncate + 10 (libsystem_kernel.dylib + 16982) [0x7fff60fd3256] 1
        *1   hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1
        *1   unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1
        *1   ftruncate + 404 (kernel + 4272388) [0xffffff8000613104] 1
        *1   vnode_setattr + 331 (kernel + 4372683) [0xffffff800062b8cb] 1
        *1   VNOP_SETATTR + 102 (kernel + 4372982) [0xffffff800062b9f6] 1
        *1   apfs_vnop_setattr + 6583 (apfs + 218589) [0xffffff7f81b8f5dd] 1
        *1   do_iterative_file_extent_removal + 341 (apfs + 479380) [0xffffff7f81bcf094] 1
        *1   iterate_jobjs_with_hint_and_snap + 433 (apfs + 459423) [0xffffff7f81bca29f] 1
        *1   _remove_extents_of_file_cb + 797 (apfs + 482656) [0xffffff7f81bcfd60] 1
        *1   remove_extent_of_file + 282 (apfs + 484154) [0xffffff7f81bd033a] 1
        *1   dereference_phys_range + 96 (apfs + 458819) [0xffffff7f81bca043] 1
        *1   apfs_update_phys_range + 96 (apfs + 454877) [0xffffff7f81bc90dd] 1
        *1   apfs_lock_phys_extents + 432 (apfs + 454185) [0xffffff7f81bc8e29] 1
        *1   tree_lookup_gt + 48 (apfs + 552335) [0xffffff7f81be0d8f] 1
        *1   _bt_lookup_variant + 838 (apfs + 626292) [0xffffff7f81bf2e74] 1
        *1   btree_node_get + 105 (apfs + 591156) [0xffffff7f81bea534] 1
        *1   btree_node_get_internal + 355 (apfs + 591526) [0xffffff7f81bea6a6] 1
        *1   obj_get + 1599 (apfs + 726329) [0xffffff7f81c0b539] 1
        *1   obj_read + 285 (apfs + 728865) [0xffffff7f81c0bf21] 1
        *1   vnode_dev_read + 30 (apfs + 8812) [0xffffff7f81b5c26c] 1
        *1   _vnode_dev_read + 619 (apfs + 12912) [0xffffff7f81b5d270] 1
        *1   buf_biowait + 124 (kernel + 4051148) [0xffffff80005dd0cc] 1
        *1   ??? (kernel + 7168269) [0xffffff80008d610d] 1
        *1   lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1
        *1   thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1
        *1   ??? (kernel + 1882937) [0xffffff80003cbb39] 1
        *1   machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1
                    9   __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 2-10
                      9   __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 2-10
                        9   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 2-10
                         *9   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 2-10
                    1   __CFRunLoopRun + 2130 (CoreFoundation + 243074) [0x7fff34f07582] 11
                      1   __CFRunLoopDoTimers + 330 (CoreFoundation + 369770) [0x7fff34f2646a] 11
                        1   __CFRunLoopDoTimer + 851 (CoreFoundation + 370980) [0x7fff34f26924] 11
                          1   __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 372088) [0x7fff34f26d78] 11
                            1   LQSendSignal + 65 (libquit.dylib + 6771) [0x7fff5ffa2a73] 11
                              1   _LSKillApplication + 329 (LaunchServices + 841888) [0x7fff365998a0] 11
                                1   _LSCopyApplicationInformationItem + 173 (LaunchServices + 49264) [0x7fff364d8070] 11
                                  1   _LSCopyApplicationInformation + 4235 (LaunchServices + 75159) [0x7fff364de597] 11
                                    1   LSClientToServerConnection::sendWithReply(void*) + 213 (LaunchServices + 63141) [0x7fff364db6a5] 11
                                      1   xpc_connection_send_message_with_reply_sync + 178 (libxpc.dylib + 42539) [0x7fff610cd62b] 11
                                        1   dispatch_mach_send_with_result_and_wait_for_reply + 50 (libdispatch.dylib + 96386) [0x7fff60e62882] 11
                                          1   _dispatch_mach_send_and_wait_for_reply + 609 (libdispatch.dylib + 95207) [0x7fff60e623e7] 11
                                            1   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 11
                                             *1   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 11
  Thread 0x9b7              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (261.3K cycles, 93.2K instructions, 2.80c/i)
  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
        11  ??? (Dock + 136618) [0x1033445aa] 1-11
          11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
           *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Binary Images:
           0x103323000 -        0x103765fff  com.apple.dock 1.8 (1963.6)                        <4B8B4B37-6468-3F26-A9AD-AFFD3205FBD2>  /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
        0x7fff336d8000 -     0x7fff3372afff  com.apple.HIServices 1.22 (628)                    <2BE461FF-80B9-30D3-A574-AED5724B1C1B>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff3415a000 -     0x7fff34451fff  com.apple.HIToolbox 2.1.1 (918.7)                  <88D7F19C-8C9D-384B-BAB5-8205CA282F2C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff364cc000 -     0x7fff3667dfff  com.apple.LaunchServices 947.2 (947.2)             <42EA9E02-37CD-36DD-8265-5E5F0D8C62C9>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff49981000 -     0x7fff49992fff  com.apple.CrashReporterSupport 10.13 (938.29)      <5942C233-DB5E-3119-8DA3-201A5C080191>  /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff5ffa1000 -     0x7fff5ffa2fff  libquit.dylib (267.3)                              <FF577E42-737C-3240-9547-E7F784FDEB2F>  /usr/lib/libquit.dylib
        0x7fff60ba7000 -     0x7fff60baafff  libswiftObjectiveC.dylib (1001.8.63.13)            <A4201F26-A2B3-3F2A-8B0F-D17F166C26BC>  /usr/lib/swift/libswiftObjectiveC.dylib
        0x7fff60e4b000 -     0x7fff60e84fff  libdispatch.dylib (1008.270.1)                     <97273678-E94C-3C8C-89F6-2E2020F4B43B>  /usr/lib/system/libdispatch.dylib
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f81b5a000 - 0xffffff7f81c52fff  com.apple.filesystems.apfs 945.275.10 (945.275.10) <A2F8A55F-1345-3CF7-80F5-9AD3619428DD>  /System/Library/Extensions/apfs.kext/Contents/MacOS/apfs
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                      <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         DocumentPopoverViewService [56950] [unique pid 156535]
UUID:            655D06D3-D23D-3180-A827-936BE1655D36
Path:            /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewService.xpc/Contents/MacOS/DocumentPopoverViewService
Parent:          launchd [1]
Responsible:     Preview [6302] [unique pid 105926]
UID:             504
Footprint:       15.41 MB
CPU Time:        <0.001s (119.3K cycles, 31.6K instructions, 3.78c/i)
  Thread 0x980539           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2>
    11  main + 37 (DocumentPopoverViewService + 4435) [0x101902153] 1-11
      11  NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11
        11  -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11
            11  _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11
                11  -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11
                  11  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11
                    11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11
                      11  _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11
                        11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11
                          11  ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11
                            11  RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11
  Thread 0x980557           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
        11  _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11
  Binary Images:
           0x101901000 -        0x101908fff  com.apple.appkit.xpc.documentPopoverViewService 6.9 (1) <655D06D3-D23D-3180-A827-936BE1655D36>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewService.xpc/Contents/MacOS/DocumentPopoverViewService
        0x7fff324e2000 -     0x7fff33297fff  com.apple.AppKit 6.9 (1671.60.112)                      <4AFB032C-2786-3AD7-8EDA-576956992A9C>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff5c9ed000 -     0x7fff5cac6fff  com.apple.ViewBridge 407 (407)                          <41AB432A-08A7-3808-8079-B07D742D3F33>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process:         dprivacyd [1133]
UUID:            DA7D7288-0AB7-3DDB-9D42-0186B9C09D6E
Path:            /usr/libexec/dprivacyd
Parent:          launchd [1]
UID:             0
Footprint:       3848 KB
  Thread 0x12b62            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x100e91000 -        0x100e91fff  dprivacyd                            <DA7D7288-0AB7-3DDB-9D42-0186B9C09D6E>  /usr/libexec/dprivacyd
Process:         Dropbox [344]
UUID:            55A7E285-2AC3-3AB2-9008-2C7324DBAFB5
Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
Parent:          launchd [1]
UID:             504
Footprint:       9900 KB
  Thread 0xa58              11 samples (1-11)         priority 62 (base 62)
  <process unclamped, IO tier 0>
  Thread 0xa76              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process unclamped, IO tier 0>
        11  ??? (DropboxCrashpad + 123372) [0x10e2761ec] 1-11
          11  ??? (DropboxCrashpad + 116865) [0x10e274881] 1-11
            11  ??? (DropboxCrashpad + 145857) [0x10e27b9c1] 1-11
              11  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11
                11  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11
  Thread 0xa77              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x1090bf000 -        0x1090c6fff  Dropbox                              <55A7E285-2AC3-3AB2-9008-2C7324DBAFB5>  /Applications/Dropbox.app/Contents/MacOS/Dropbox
           0x10e258000 -        0x10e2d3fff  com.dropbox.Crashpad 1.0 (1.0)       <9F8A4524-A985-3017-BEEF-4E622B13AB46>  /Applications/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/DropboxCrashpad
Process:         Dropbox [386]
UUID:            928C2064-C6DF-351A-B160-4CD1026B2844
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox
Parent:          launchd [1]
UID:             504
Footprint:       1398.46 MB
CPU Time:        0.004s (16.6M cycles, 6.9M instructions, 2.41c/i)
Note:            3 idle work queue threads omitted
  Thread 0xd7f              DispatchQueue 1           Thread name "CrBrowserMain"                         11 samples (1-11)         priority 62 (base 62)     cpu time 0.002s (9.8M cycles, 2.7M instructions, 3.64c/i)
    11  ??? (Dropbox + 18573) [0x10fda788d] 1-11
      11  ??? (Dropbox + 18227) [0x10fda7733] 1-11
        11  bootstrap_application + 5603 (DropboxCore + 10847011) [0x11080e323] 1-11
          11  ??? (DropboxCore + 10554996) [0x1107c6e74] 1-11
            11  ??? (DropboxCore + 10769365) [0x1107fb3d5] 1-11
              11  de_main + 145 (Electron Framework + 108737) [0x1139cd8c1] 1-11
                11  electron::fuses::IsRunAsNodeEnabled() + 5710690 (Electron Framework + 7589282) [0x1140efda2] 1-11
                  11  electron::fuses::IsRunAsNodeEnabled() + 5710449 (Electron Framework + 7589041) [0x1140efcb1] 1-11
                    11  electron::fuses::IsRunAsNodeEnabled() + 5714216 (Electron Framework + 7592808) [0x1140f0b68] 1-11
                      11  electron::fuses::IsRunAsNodeEnabled() + 5715495 (Electron Framework + 7594087) [0x1140f1067] 1-11
                        11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2918084 (Electron Framework + 19809172) [0x114c97394] 1-11
                          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2934722 (Electron Framework + 19825810) [0x114c9b492] 1-11
                            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2928705 (Electron Framework + 19819793) [0x114c99d11] 1-11
                              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x11531232c] 1-11
                                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x11533f81f] 1-11
                                  11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10118539 (Electron Framework + 27009627) [0x11537525b] 1-11
                                    11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10123574 (Electron Framework + 27014662) [0x115376606] 1-11
                                                         *3   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3
  <process clamped>
                                                         *8   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11
  Thread 0xdb1              Thread name "APEX_CONTEXT_NETWORK"                  11 samples (1-11)         priority 31 (base 31)
        11  ??? (DropboxCore + 46708922) [0x112a418ba] 1-11
          11  ??? (DropboxCore + 41869253) [0x1125a3fc5] 1-11
            11  ??? (DropboxCore + 41832908) [0x11259b1cc] 1-11
              11  ??? (DropboxCore + 41844498) [0x11259df12] 1-11
                11  ??? (DropboxCore + 41893160) [0x1125a9d28] 1-11
                  11  ??? (DropboxCore + 41854043) [0x1125a045b] 1-11
                    11  ??? (DropboxCore + 47650338) [0x112b27622] 1-11
                      11  ??? (DropboxCore + 47710078) [0x112b35f7e] 1-11
                        11  ??? (DropboxCore + 47710505) [0x112b36129] 1-11
                           *3   ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3
  <process clamped>
                           *8   ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11
  Thread 0xdbb              Thread name "APEX_BOUNDARY"                         11 samples (1-11)         priority 31 (base 31)
          11  ??? (DropboxCore + 9373968) [0x1106a6910] 1-11
            11  ??? (DropboxCore + 9659067) [0x1106ec2bb] 1-11
              11  ??? (DropboxCore + 9735255) [0x1106fec57] 1-11
                11  ??? (DropboxCore + 9099796) [0x110663a14] 1-11
                  11  ??? (DropboxCore + 9098309) [0x110663445] 1-11
                    11  ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11
  <process clamped>
  Thread 0xe31              Thread name "PYTHON_LOGGER"                         11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested utility), process unclamped, IO tier 1>
  <process clamped>
  Thread 0xea8              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
    11  _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11
      11  PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11
        11  ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11
          11  ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11
            11  _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11
              11  ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11
                11  _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11
                  11  _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11
                                11  ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11
                                  11  ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11
                                    11  ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11
                                      11  PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11
  <process clamped>
  Thread 0xea9              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeaa              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeab              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeac              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (458.3K cycles, 190.1K instructions, 2.41c/i)
        11  ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11
          11  ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11
                                11  _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11
  <process clamped>
  Thread 0xead              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeae              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeaf              Thread name "Dropbox::ActorThread"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb0              Thread name "Dropbox::xtl-netreq-0"                 11 samples (1-11)         priority 31 (base 31)
                            11  _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11
                                11  ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11
  <process clamped>
  Thread 0xeb1              Thread name "Dropbox::xtl-netreq-1"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb2              Thread name "Dropbox::xtl-netreq-2"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb3              Thread name "Dropbox::xtl-netreq-3"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb4              Thread name "Dropbox::xtl-netreq-4"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb5              Thread name "Dropbox::xtl-netreq-5"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb6              Thread name "Dropbox::xtl-netreq-6"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb7              Thread name "Dropbox::xtl-netreq-7"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeb8              Thread name "Dropbox::sleep thread"                 11 samples (1-11)         priority 31 (base 31)
                                                    11  PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11
  <process clamped>
  Thread 0xeb9              Thread name "Dropbox::GLOBAL_POOL_0"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeba              Thread name "Dropbox::GLOBAL_POOL_1"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xebb              Thread name "Dropbox::GLOBAL_POOL_2"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xebc              Thread name "Dropbox::GLOBAL_POOL_3"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xec0              Thread name "Dropbox::RTRACE"                       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xec1              Thread name "Dropbox::PERSISTENT_EVENT_REPORTER"    11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xec2              Thread name "Dropbox::BACKGROUNDWORKER"             11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xece              Thread name "Dropbox::ELECTRON_IPC"                 11 samples (1-11)         priority 31 (base 31)
                                11  ??? (libpython3.8.dylib + 2793022) [0x11c0cae3e] 1-11
                                  11  ??? (libpython3.8.dylib + 5349640) [0x11c33b108] 1-11
                                    11  ??? (libpython3.8.dylib + 5361372) [0x11c33dedc] 1-11
                                                             *3   machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3
  <process clamped>
                                                             *8   machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11
  Thread 0xed2              Thread name "APEX_CONTEXT_WORKER"                   11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (808.8K cycles, 347.7K instructions, 2.33c/i)
          11  ??? (DropboxCore + 37699712) [0x1121aa080] 1-11
            11  ??? (DropboxCore + 37708463) [0x1121ac2af] 1-11
              11  ??? (DropboxCore + 37727878) [0x1121b0e86] 1-11
                11  ??? (DropboxCore + 37695157) [0x1121a8eb5] 1-11
                  11  ??? (DropboxCore + 37719723) [0x1121aeeab] 1-11
  <process clamped>
  Thread 0xed7              Thread name "DBXLOG_WORKER"                         11 samples (1-11)         priority 31 (base 31)
          11  ??? (DropboxCore + 7960280) [0x11054d6d8] 1-11
            11  ??? (DropboxCore + 8021676) [0x11055c6ac] 1-11
              11  ??? (DropboxCore + 8010601) [0x110559b69] 1-11
                11  ??? (DropboxCore + 7926165) [0x110545195] 1-11
  <process clamped>
  Thread 0xee2              Thread name "Dropbox::SYNC_UI_UPDATE"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xee4              Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
    11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
  <process clamped>
  Thread 0xee6              Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
        11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x115371148] 1-11
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x115353bbd] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x115353f27] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x11535370e] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x115379c37] 1-11
  <process clamped>
  Thread 0xee8              Thread name "Chrome_IOThread"                       11 samples (1-11)         priority 31 (base 31)
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x11535c437] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2937951 (Electron Framework + 19829039) [0x114c9c12f] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x11535c238] 1-11
  <process clamped>
  Thread 0xee9              Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeea              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeeb              11 samples (1-11)         priority 31 (base 31)
        11  node::OnFatalError(char const*, char const*) + 428695 (Electron Framework + 55341991) [0x116e7a3a7] 1-11
          11  node::MultiIsolatePlatform::CancelPendingDelayedTasks(v8::Isolate*) + 1154 (Electron Framework + 55352210) [0x116e7cb92] 1-11
            11  uv_cond_wait + 9 (Electron Framework + 85577) [0x1139c7e49] 1-11
  <process clamped>
  Thread 0xeec              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xeed              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xef0              11 samples (1-11)         priority 31 (base 31)
     *3   semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-3
  <process clamped>
     *8   semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 4-11
  Thread 0xefc              Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xefd              Thread name "CrShutdownDetector"                    11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xefe              Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf00              Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf01              Thread name "ThreadPoolSingleThreadForegroundBlocking0"                       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf03              11 samples (1-11)         priority 31 (base 31)
        11  de_register_electron_app + 1323992 (Electron Framework + 1432760) [0x113b10cb8] 1-11
           *3   ??? (kernel + 7168864) [0xffffff80008d6360] 1-3
  <process clamped>
           *8   ??? (kernel + 7168864) [0xffffff80008d6360] 4-11
  Thread 0xf08              Thread name "JS_HTTP_WORKER"                        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf09              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf0a              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf0b              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf0c              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf10              Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf1f              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)     cpu time <0.001s (390.6K cycles, 94.6K instructions, 4.13c/i)
  <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0>
  <process clamped>
  Thread 0xf2a              Thread name "Dropbox::CONNECTIVITY_WATCH"           11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf2c              Thread name "Dropbox::AUTHENTICATE"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf3d              Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking1"                 11 samples (1-11)         priority 0 (base 0)
  <process clamped>
  Thread 0xf47              Thread name "Dropbox::DBXCONN_PYTHON_WORKER"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf4a              Thread name "Dropbox::USER-CACHE"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf51              Thread name "Dropbox::NavigationServiceWorker"      11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf52              Thread name "Dropbox::NativeIcon-IconRead_0"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf53              Thread name "Dropbox::NativeIcon-IconRead_1"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf54              Thread name "Dropbox::NativeIcon-IconRead_2"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf55              Thread name "Dropbox::NativeIcon-IconRead_3"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf56              Thread name "Dropbox::NativeIcon-IconRead_4"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf57              Thread name "Dropbox::NativeIcon-IconRead_5"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf58              Thread name "Dropbox::NativeIcon-IconWrite_0"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf59              Thread name "Dropbox::NativeIcon-ThumbnailRead_0"   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf5a              Thread name "Dropbox::NativeIcon-ThumbnailRead_1"   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf5b              Thread name "Dropbox::NativeIcon-ThumbnailRead_2"   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf5c              Thread name "Dropbox::NativeIcon-ThumbnailWrite_0"  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf5d              Thread name "Dropbox::NativeIcon-IconRead_0"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf5e              Thread name "Dropbox::NativeIcon-IconRead_1"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf5f              Thread name "Dropbox::NativeIcon-IconRead_2"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf60              Thread name "Dropbox::NativeIcon-IconRead_3"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf61              Thread name "Dropbox::NativeIcon-IconRead_4"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf62              Thread name "Dropbox::NativeIcon-IconRead_5"        11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf63              Thread name "Dropbox::NativeIcon-IconWrite_0"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf64              Thread name "Dropbox::NativeIcon-ThumbnailRead_0"   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf65              Thread name "Dropbox::NativeIcon-ThumbnailRead_1"   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf66              Thread name "Dropbox::NativeIcon-ThumbnailRead_2"   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf67              Thread name "Dropbox::NativeIcon-ThumbnailWrite_0"  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf68              Thread name "Dropbox::PERIODIC"                     11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf69              Thread name "ThreadPoolSingleThreadSharedForegroundBlocking2"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf6a              Thread name "CacheThread_BlockFile"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf82              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf84              Thread name "Dropbox::EVENTREPORTER"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xf85              Thread name "Dropbox::DESKTOP_LOGIN_PREFETCH-PRIMARY"                         11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa2              Thread name "Dropbox::SubscribeThread"              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa3              Thread name "Dropbox::NOTIFICATION_RETRIEVAL"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa4              Thread name "Dropbox::SUPPORTACTIONUPDATETHREAD"    11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa5              Thread name "Dropbox::SUPPORT_ACTION_MANAGER"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa6              Thread name "Dropbox::USERNOTIFICATION"             11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa7              Thread name "Dropbox::HOURLY_REFRESH"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa8              Thread name "Dropbox::BOUNDARY_FUTURE_COMPLETION_THREAD_POOL_0"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfa9              Thread name "Dropbox::BOUNDARY_FUTURE_COMPLETION_THREAD_POOL_1"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfaa              Thread name "Dropbox::p2p-client-threadpool-worker-1"                         11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfab              Thread name "Dropbox::p2p-client-threadpool-worker-0"                         11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfac              Thread name "Dropbox::NUCLEUS_P2P_THREAD"           11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfad              Thread name "TPRT_API_WORKER"                       11 samples (1-11)         priority 31 (base 31)
          11  ??? (DropboxCore + 33388256) [0x111d8d6e0] 1-11
            11  ??? (DropboxCore + 32698234) [0x111ce4f7a] 1-11
              11  ??? (DropboxCore + 47808224) [0x112b4dee0] 1-11
                11  ??? (DropboxCore + 47793916) [0x112b4a6fc] 1-11
                  11  ??? (DropboxCore + 47775492) [0x112b45f04] 1-11
                    11  ??? (DropboxCore + 47773526) [0x112b45756] 1-11
                      11  ??? (DropboxCore + 47773281) [0x112b45661] 1-11
  <process clamped>
  Thread 0xfae              Thread name "FS_API_CONTROL"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (274.5K cycles, 100.7K instructions, 2.73c/i)
          11  ??? (DropboxCore + 33388720) [0x111d8d8b0] 1-11
            11  ??? (DropboxCore + 32700041) [0x111ce5689] 1-11
              11  ??? (DropboxCore + 33373334) [0x111d89c96] 1-11
                11  ??? (DropboxCore + 32430897) [0x111ca3b31] 1-11
  <process clamped>
  Thread 0xfaf              Thread name "TIMER"       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (270.0K cycles, 59.0K instructions, 4.58c/i)
          11  ??? (DropboxCore + 47575904) [0x112b15360] 1-11
            11  ??? (DropboxCore + 47552354) [0x112b0f762] 1-11
              11  ??? (DropboxCore + 47583589) [0x112b17165] 1-11
                11  ??? (DropboxCore + 5210602) [0x1102ae1ea] 1-11
                  11  ??? (DropboxCore + 5209982) [0x1102adf7e] 1-11
                    11  ??? (DropboxCore + 46630552) [0x112a2e698] 1-11
  <process clamped>
  Thread 0xfb0              Thread name "OSX FSYNC WORKER"                      11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0xfb1              Thread name "OSX FS WORKER"                         11 samples (1-11)         priority 20 (base 20)
          11  ??? (DropboxCore + 43908704) [0x112795e60] 1-11
            11  ??? (DropboxCore + 43659918) [0x11275928e] 1-11
              11  ??? (DropboxCore + 43224264) [0x1126eecc8] 1-11
                11  ??? (DropboxCore + 43897014) [0x1127930b6] 1-11
                  11  ??? (DropboxCore + 43498878) [0x112731d7e] 1-11
                    11  ??? (DropboxCore + 43491494) [0x1127300a6] 1-11
                      11  ??? (DropboxCore + 43491249) [0x11272ffb1] 1-11
  <process clamped>
  Thread 0xfb2              Thread name "nucleus-threadpool-0"                  11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0xfbc              Thread name "Dropbox::FILEEVENTS"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfbe              Thread name "Dropbox::BOUNDARY_PUBLISHED_EVENTS_0"  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0xfcd              Thread name "Dropbox::DBFSEventThread"              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (1017.9K cycles, 1035.2K instructions, 0.98c/i)
  <process clamped>
  Thread 0xfce              Thread name "TPRT_API_WORKER"                       11 samples (1-11)         priority 31 (base 31)
          11  ??? (DropboxCore + 13057473) [0x110a29dc1] 1-11
            11  ??? (DropboxCore + 23299050) [0x1113ee3ea] 1-11
  <process clamped>
  Thread 0xfcf              Thread name "NUCLEUS_CONTROL"                       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (1231.1K cycles, 1343.3K instructions, 0.92c/i)
          11  ??? (DropboxCore + 13056961) [0x110a29bc1] 1-11
            11  ??? (DropboxCore + 23300857) [0x1113eeaf9] 1-11
              11  ??? (DropboxCore + 12177307) [0x110952f9b] 1-11
                11  ??? (DropboxCore + 23181725) [0x1113d199d] 1-11
  <process clamped>
  Thread 0xfd0              Thread name "TIMER"       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (310.8K cycles, 65.9K instructions, 4.72c/i)
  <process clamped>
  Thread 0xfd1              Thread name "nucleus-threadpool-0"                  11 samples (1-11)         priority 20 (base 20)
          11  ??? (DropboxCore + 34559984) [0x111eab7f0] 1-11
            11  ??? (DropboxCore + 34563473) [0x111eac591] 1-11
              11  ??? (DropboxCore + 34591020) [0x111eb312c] 1-11
                11  ??? (DropboxCore + 34572926) [0x111eaea7e] 1-11
                  11  ??? (DropboxCore + 34575701) [0x111eaf555] 1-11
  <process clamped>
  Thread 0xfd2              Thread name "NUCLEUS_NETWORK"                       11 samples (1-11)         priority 20 (base 20)
          11  ??? (DropboxCore + 41868805) [0x1125a3e05] 1-11
            11  ??? (DropboxCore + 41834780) [0x11259b91c] 1-11
  <process clamped>
  Thread 0xfd5              Thread name "OSX FSYNC WORKER"                      11 samples (1-11)         priority 20 (base 20)
          11  ??? (DropboxCore + 43908235) [0x112795c8b] 1-11
            11  ??? (DropboxCore + 43660532) [0x1127594f4] 1-11
              11  ??? (DropboxCore + 43207431) [0x1126eab07] 1-11
                  11  ??? (DropboxCore + 5210008) [0x1102adf98] 1-11
  <process clamped>
  Thread 0xfd6              Thread name "OSX FS WORKER"                         11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x133b             Thread name "Dropbox::RECV_EVENTS"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x133c             Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS"      11 samples (1-11)         priority 31 (base 31)
                11  _PyEval_EvalFrameDefault + 32500 (libpython3.8.dylib + 3935172) [0x11c1e1bc4] 1-11
                    11  ??? (libpython3.8.dylib + 2751635) [0x11c0c0c93] 1-11
                      11  _PyObject_MakeTpCall + 416 (libpython3.8.dylib + 2733808) [0x11c0bc6f0] 1-11
                        11  ??? (tprt.cpython-38-darwin.so + 84354) [0x12565b982] 1-11
                          11  ??? (tprt.cpython-38-darwin.so + 47922) [0x125652b32] 1-11
                              11  ??? (libpython3.8.dylib + 3070114) [0x11c10e8a2] 1-11
                                11  ??? (libpython3.8.dylib + 6682112) [0x11c480600] 1-11
                                  11  ??? (libpython3.8.dylib + 6683747) [0x11c480c63] 1-11
  <process clamped>
  Thread 0x133d             Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS"      11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x133e             Thread name "Dropbox::p2p_server_handler_pool_head-worker-0"                  11 samples (1-11)         priority 31 (base 31)
        11  ??? (libpython3.8.dylib + 2751904) [0x11c0c0da0] 1-11
  <process clamped>
  Thread 0x133f             Thread name "Dropbox::p2p_server_handler_pool_get-worker-0"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1340             Thread name "Dropbox::p2p-request-threadpool-head-worker-0"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1341             Thread name "Dropbox::p2p-request-threadpool-get-worker-0"                    11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1342             Thread name "Dropbox::P2P_SERVER"                   11 samples (1-11)         priority 31 (base 31)
                          11  ??? (libpython3.8.dylib + 2791145) [0x11c0ca6e9] 1-11
  <process clamped>
  Thread 0x1343             Thread name "Dropbox::P2P_DISCOVER"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1344             Thread name "Dropbox::LIST_LEGACY"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1345             Thread name "Dropbox::FINDER_SYNC_RESPONDER"        11 samples (1-11)         priority 31 (base 31)
  11  ??? [0x12def7b50] 1-11
    11  ffi_call_unix64 + 76 (libffi.dylib + 3948) [0x7fff5ea42f6c] 1-11
      11  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11
        11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  <process clamped>
  Thread 0x134e             Thread name "Dropbox::WATCHDOG"                     11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x134f             Thread name "Dropbox::INFINITE_PAGING_WORKER"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1350             Thread name "Dropbox::INFINITE_CONFIGURATION"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x14f0             Thread name "Dropbox::KEXT_LOG_REPORTER"            11 samples (1-11)         priority 31 (base 31)
      11  ??? (libpython3.8.dylib + 3952435) [0x11c1e5f33] 1-11
          11  ??? (libpython3.8.dylib + 2735738) [0x11c0bce7a] 1-11
  <process clamped>
  Thread 0x1523             Thread name "Dropbox::INFINITE_PAGING"              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x152e             Thread name "Dropbox::QUICKLOOK_SERVER"             11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x152f             Thread name "Dropbox::CLIENT_SHARING"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1530             Thread name "Dropbox::CLIENT_SHARING_NETWORK"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1531             Thread name "Dropbox::IDLEHANDLER"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1533             Thread name "Dropbox::SCREENSHOTS_PROCESSING"       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1536             Thread name "Dropbox::ACTIVITY_PROVIDER"            11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1537             Thread name "Dropbox::fileop_write_0"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1538             Thread name "Dropbox::fileop_read_0"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1539             Thread name "Dropbox::fileop_read_1"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x153a             Thread name "Dropbox::fileop_read_2"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x153b             Thread name "Dropbox::fileop_read_3"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x153c             Thread name "Dropbox::fileop_read_4"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x153d             Thread name "Dropbox::SEARCHTHREAD"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x155e             Thread name "Dropbox::CONTACTSBOLTUPDATE"           11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x155f             Thread name "Dropbox::UNITYSTARTSTOP"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1560             Thread name "Dropbox::UNITYWORKER"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x1561             Thread name "Dropbox::PHOTOUPLOADER"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x159c             Thread name "Dropbox::EVENTREPORTER"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x159d             Thread name "Dropbox::DESKTOP_LOGIN_PREFETCH-SECONDARY"                       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x159e             Thread name "Dropbox::p2p-client-threadpool-worker-1"                         11 samples (1-11)         priority 31 (base 31)
  11  <truncated backtrace> 1-11
  <process clamped>
  Thread 0x159f             Thread name "Dropbox::p2p-client-threadpool-worker-0"                         11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15a0             Thread name "Dropbox::NUCLEUS_P2P_THREAD"           11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15a1             Thread name "TPRT_API_WORKER"                       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15a2             Thread name "FS_API_CONTROL"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (260.9K cycles, 107.6K instructions, 2.43c/i)
  <process clamped>
  Thread 0x15a3             Thread name "TIMER"       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (244.1K cycles, 42.2K instructions, 5.78c/i)
  <process clamped>
  Thread 0x15a4             Thread name "OSX FSYNC WORKER"                      11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15a5             Thread name "OSX FS WORKER"                         11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15a6             Thread name "nucleus-threadpool-0"                  11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15a7             Thread name "Dropbox::BOUNDARY_PUBLISHED_EVENTS_SECONDARY_0"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15a8             Thread name "TPRT_API_WORKER"                       11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15a9             Thread name "NUCLEUS_CONTROL"                       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (973.5K cycles, 661.8K instructions, 1.47c/i)
  <process clamped>
  Thread 0x15aa             Thread name "TIMER"       11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (310.4K cycles, 66.4K instructions, 4.67c/i)
  <process clamped>
  Thread 0x15ab             Thread name "nucleus-threadpool-0"                  11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15ac             Thread name "NUCLEUS_NETWORK"                       11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15ae             Thread name "OSX FSYNC WORKER"                      11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15af             Thread name "OSX FS WORKER"                         11 samples (1-11)         priority 20 (base 20)
  <process clamped>
  Thread 0x15cc             Thread name "Dropbox::RECV_EVENTS"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15cd             Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS"      11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15ce             Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS"      11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15cf             Thread name "Dropbox::p2p_server_handler_pool_head-worker-0"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d0             Thread name "Dropbox::p2p_server_handler_pool_get-worker-0"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d1             Thread name "Dropbox::p2p-request-threadpool-head-worker-0"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d2             Thread name "Dropbox::p2p-request-threadpool-get-worker-0"                    11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d3             Thread name "Dropbox::P2P_SERVER"                   11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d4             Thread name "Dropbox::LIST_LEGACY"                  11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d5             Thread name "Dropbox::P2P_DISCOVER"                 11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d7             Thread name "Dropbox::fileop_write_0"               11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d8             Thread name "Dropbox::fileop_read_0"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15d9             Thread name "Dropbox::fileop_read_1"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15da             Thread name "Dropbox::fileop_read_2"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15db             Thread name "Dropbox::fileop_read_3"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15dc             Thread name "Dropbox::fileop_read_4"                11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15e7             Thread name "Dropbox::INFINITE_PAGING"              11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x15f0             Thread name "Dropbox::EXTERNAL_DRIVE_EVENTS"        11 samples (1-11)         priority 31 (base 31)
    11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
  <process clamped>
  Thread 0x15fa             Thread name "Dropbox::PHOTOUPLOADER"                11 samples (1-11)         priority 31 (base 31)
     *3   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3
  <process clamped>
     *8   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11
  Thread 0x248c4d           Thread name "Dropbox::SMARTSYNC_THUMBS"             11 samples (1-11)         priority 31 (base 31)
  <process clamped>
  Thread 0x58585f           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 37 (base 37)
  <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0>
  <process clamped>
  Thread 0x64d2dd           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x115353c1d] 1-11
  <process clamped>
  Binary Images:
           0x10fda3000 -        0x10fdaafff  com.getdropbox.dropbox 163.4.5456 (163.4.5456)                     <928C2064-C6DF-351A-B160-4CD1026B2844>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox
           0x10fdb6000 -        0x1136c5fff  com.dropbox.core 1.0 (1.0)                                         <027878E1-8F64-3EA1-9D27-FFC06193FD2E>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/DropboxCore.framework/Versions/A/DropboxCore
           0x1139b3000 -        0x11b396fff  com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
           0x11be21000 -        0x11c810fff  libpython3.8.dylib (0)                                             <7CB97AB5-BB44-3721-BB4B-8A757B1FD823>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/libpython3.8.dylib
           0x125647000 -        0x125662fff  tprt.cpython-38-darwin.so (0)                                      <4D99ABD8-6227-3EA0-8DAF-2805BC8235DE>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/python-extensions/tprt.cpython-38-darwin.so
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)                                <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff5ea42000 -     0x7fff5ea43fff  libffi.dylib (18.1)                                                <DA1198F8-9789-3F16-BF60-9DA170519295>  /usr/lib/libffi.dylib
Process:         Dropbox [391]
Architecture:    x86_64
Parent:          launchd [1]
UID:             504
Footprint:       10.15 MB
Start time:      2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
Num samples:     11 (1-11)
  Thread 0xda0              11 samples (1-11)         priority 62 (base 62)
     *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0xdad              11 samples (1-11)         priority 31 (base 31)
        11  ??? (DropboxCrashpad + 108940) [0x110dee98c] 1-11
          11  ??? (DropboxCrashpad + 102353) [0x110decfd1] 1-11
            11  ??? (DropboxCrashpad + 131057) [0x110df3ff1] 1-11
                 *11  semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11
  Thread 0xdae              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x104881000 -        0x104888fff  com.getdropbox.dropbox 163.4.5456 (163.4.5456) <928C2064-C6DF-351A-B160-4CD1026B2844>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox
           0x110dd4000 -        0x110e4bfff  com.dropbox.Crashpad 1.0 (1.0)                 <2F2625A7-E5D6-3C68-B503-7818B8BD88D9>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/Versions/A/DropboxCrashpad
Process:         Dropbox [393]
UID:             504
Footprint:       10.71 MB
  Thread 0xdb0              11 samples (1-11)         priority 62 (base 62)
  <IO tier 0>
     *11  hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11
       *11  unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11
                       *11  thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11
                         *11  ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11
                           *11  machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11
  Thread 0xdbc              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x1097be000 -        0x1097c5fff  com.getdropbox.dropbox 163.4.5456 (163.4.5456) <928C2064-C6DF-351A-B160-4CD1026B2844>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox
Process:         Dropbox Helper [435]
UUID:            F02A05BD-FC27-36B5-BDD7-8703972062E9
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper.app/Contents/MacOS/Dropbox Helper
UID:             504
Footprint:       10072 KB
  Thread 0xf0f              Thread name "CrUtilityMain"                         11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
  Thread 0xf2e              Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf30              Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
        11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10a207148] 1-11
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x10a1e9bbd] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x10a1e9f27] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x10a1e970e] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x10a20fc37] 1-11
  Thread 0xf31              Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf34              Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9e3470           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x10a1e9c1d] 1-11
  Binary Images:
           0x108829000 -        0x108838fff  com.dropbox.Electron.helper (0)                                    <F02A05BD-FC27-36B5-BDD7-8703972062E9>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper.app/Contents/MacOS/Dropbox Helper
           0x108849000 -        0x11022cfff  com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Dropbox Helper (GPU) [433]
UUID:            20E2CB6F-CB69-332D-B3B7-E89BED0B74F8
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (GPU).app/Contents/MacOS/Dropbox Helper (GPU)
UID:             504
Footprint:       76.36 MB
  Thread 0xf02              Thread name "CrGpuMain"   11 samples (1-11)         priority 31 (base 31)
  Thread 0xf49              Thread name "GpuWatchdog" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x1073f3148] 1-11
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x1073de437] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x1073de238] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x10739432c] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x1073c181f] 1-11
                  11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9597957 (Electron Framework + 26489045) [0x1073780d5] 1-11
                    11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x1073fbc37] 1-11
  Thread 0xf4b              Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0xf4c              Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x1073d5c1d] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x1073d5f27] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x1073d570e] 1-11
  Thread 0xf4d              Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x1073d5bbd] 1-11
  Thread 0xf4e              Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf50              Thread name "VizCompositorThread"                   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x1019ad000 -        0x1019bcfff  com.dropbox.Electron.helper (0)                                    <20E2CB6F-CB69-332D-B3B7-E89BED0B74F8>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (GPU).app/Contents/MacOS/Dropbox Helper (GPU)
           0x105a35000 -        0x10d418fff  com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70)                               <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         Dropbox Helper (Renderer) [440]
UUID:            B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer)
Parent:          Dropbox [386]
UID:             504
Footprint:       103.17 MB
  Thread 0xf6b              DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  ??? (Dropbox Helper (Renderer) + 6304) [0x1076e38a0] 1-11
      11  ElectronMain + 145 (Electron Framework + 108401) [0x10d072771] 1-11
        11  electron::fuses::IsRunAsNodeEnabled() + 5710690 (Electron Framework + 7589282) [0x10d794da2] 1-11
          11  electron::fuses::IsRunAsNodeEnabled() + 5710449 (Electron Framework + 7589041) [0x10d794cb1] 1-11
            11  electron::fuses::IsRunAsNodeEnabled() + 5714198 (Electron Framework + 7592790) [0x10d795b56] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 36546778 (Electron Framework + 53437866) [0x11034e5aa] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x10e9b732c] 1-11
                  11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x10e9e481f] 1-11
                    11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10118539 (Electron Framework + 27009627) [0x10ea1a25b] 1-11
                      11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10123401 (Electron Framework + 27014489) [0x10ea1b559] 1-11
                            11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
                              11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0xf6f              Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf71              Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
        11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10ea16148] 1-11
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x10e9f8bbd] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x10e9f8f27] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x10e9f870e] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x10ea1ec37] 1-11
  Thread 0xf72              Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x10ea01437] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x10ea01238] 1-11
  Thread 0xf74              Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf77              Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf78              Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf79              Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf7a              Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf7b              Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf7c              Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xf7d              Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9c99c           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x10e9f8c1d] 1-11
  Binary Images:
           0x1076e2000 -        0x1076f1fff  com.dropbox.Electron.helper (0)                                    <B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer)
           0x10d058000 -        0x114a3bfff  com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)                            <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                                               <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         Dropbox Helper (Renderer) [10160] [unique pid 109769]
UID:             504
Footprint:       42.44 MB
Note:            1 idle work queue thread omitted
  Thread 0x64d6dc           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  ??? (Dropbox Helper (Renderer) + 6304) [0x103f228a0] 1-11
      11  ElectronMain + 145 (Electron Framework + 108401) [0x103f5c771] 1-11
        11  electron::fuses::IsRunAsNodeEnabled() + 5710690 (Electron Framework + 7589282) [0x10467eda2] 1-11
          11  electron::fuses::IsRunAsNodeEnabled() + 5710449 (Electron Framework + 7589041) [0x10467ecb1] 1-11
            11  electron::fuses::IsRunAsNodeEnabled() + 5714198 (Electron Framework + 7592790) [0x10467fb56] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 36546778 (Electron Framework + 53437866) [0x1072385aa] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x1058a132c] 1-11
                  11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x1058ce81f] 1-11
                    11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10118539 (Electron Framework + 27009627) [0x10590425b] 1-11
                      11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10123401 (Electron Framework + 27014489) [0x105905559] 1-11
                          11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Thread 0x64d6e8           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6ea           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
        11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x105900148] 1-11
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x1058e2bbd] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x1058e2f27] 1-11
              11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x1058e270e] 1-11
                11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x105908c37] 1-11
  Thread 0x64d6eb           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x1058eb437] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x1058eb238] 1-11
  Thread 0x64d6ed           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6ef           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6f0           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6f1           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 36241077 (Electron Framework + 53132165) [0x1071edb85] 1-11
            11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10099296 (Electron Framework + 26990384) [0x1058ff730] 1-11
  Thread 0x64d6f2           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6f3           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6f4           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d6f5           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64d703           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x1058e2c1d] 1-11
  Binary Images:
           0x103f21000 -        0x103f30fff  com.dropbox.Electron.helper (0)                                    <B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer)
           0x103f42000 -        0x10b925fff  com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                                            <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         DropboxActivityProvider [500]
UUID:            D0EACB89-0531-3AEF-8614-D06DE4C1255F
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider
Parent:          launchd [1]
Responsible:     Dropbox [386]
UID:             504
Sudden Term:     Tracked (allows idle exit)
Footprint:       5116 KB
CPU Time:        <0.001s (76.1K cycles, 23.5K instructions, 3.24c/i)
Note:            2 idle work queue threads omitted
  Thread 0x153f             DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0>
    11  main + 16 (DropboxActivityProvider + 60062) [0x10d229a9e] 1-11
      11  xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11
          11  NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11
  Thread 0x1547             Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x10d21b000 -        0x10d22efff  com.dropbox.activityprovider 1.0 (163.4.5456) <D0EACB89-0531-3AEF-8614-D06DE4C1255F>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider
        0x7fff610c3000 -     0x7fff610f2fff  libxpc.dylib (1336.261.7)                     <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8>  /usr/lib/system/libxpc.dylib
Process:         DropboxNotificationService [441]
UUID:            FA9BF1BD-9896-395C-8E53-CCD4E64A06CA
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxNotificationService.xpc/Contents/MacOS/DropboxNotificationService
Parent:          launchd [1]
UID:             504
Footprint:       1468 KB
  Thread 0xf7f              11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
    11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11
     *11  ??? (kernel + 7168864) [0xffffff80008d6360] 1-11
  Binary Images:
           0x10596c000 -        0x105973fff  DropboxNotificationService           <FA9BF1BD-9896-395C-8E53-CCD4E64A06CA>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxNotificationService.xpc/Contents/MacOS/DropboxNotificationService
Process:         EscrowSecurityAlert [4389]
UUID:            90B55EB5-EF5A-32D0-A814-57B971B96D67
Path:            /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Parent:          launchd [1]
UID:             504
Footprint:       1532 KB
  Thread 0x536a8            11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x100c87000 -        0x100c8cfff  EscrowSecurityAlert                  <90B55EB5-EF5A-32D0-A814-57B971B96D67>  /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Process:         ethcheck [209]
UUID:            11EFA59B-89BC-3B5E-909F-EEB1B4A6E237
Path:            /usr/libexec/firmwarecheckers/ethcheck/ethcheck
Parent:          launchd [1]
UID:             0
Footprint:       860 KB
  Thread 0x6ad              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c976000 -        0x10c97dfff  ethcheck                             <11EFA59B-89BC-3B5E-909F-EEB1B4A6E237>  /usr/libexec/firmwarecheckers/ethcheck/ethcheck
Process:         familycircled [357]
UUID:            57CB71EB-3D3A-304A-9881-1A99EF0F25C0
Path:            /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled
Parent:          launchd [1]
UID:             504
Footprint:       2372 KB
  Thread 0xb56              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c3ab000 -        0x10c3bafff  familycircled                        <57CB71EB-3D3A-304A-9881-1A99EF0F25C0>  /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled
Process:         filecoordinationd [331]
UUID:            044CD0FB-E6BB-34D3-8DA8-5D071348A278
Path:            /usr/sbin/filecoordinationd
Parent:          launchd [1]
UID:             0
Footprint:       1712 KB
  Thread 0x9c8              DispatchQueue 11          11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
  Binary Images:
           0x10b3e5000 -        0x10b3e5fff  filecoordinationd                    <044CD0FB-E6BB-34D3-8DA8-5D071348A278>  /usr/sbin/filecoordinationd
Process:         fileproviderd [337]
UUID:            93483853-37BF-394E-B28E-E857EEBD8FF1
Path:            /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
Parent:          launchd [1]
UID:             504
Footprint:       2876 KB
  Thread 0xa0f              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x107d21000 -        0x107d56fff  fileproviderd                        <93483853-37BF-394E-B28E-E857EEBD8FF1>  /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
Process:         Finder [278]
UUID:            A0E7FB21-BD6B-322F-A694-976B8BCCA775
Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Parent:          launchd [1]
UID:             504
Footprint:       791.05 MB
CPU Time:        0.007s (31.0M cycles, 9.8M instructions, 3.17c/i)
  Thread 0x7d7              DispatchQueue 1           11 samples (1-11)         priority 4-46 (base 4-46) cpu time 0.007s (30.1M cycles, 9.6M instructions, 3.15c/i)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0, priority 46 (46)>
    11  ??? (Finder + 25553) [0x109a523d1] 1-11
  <process clamped, process suppressed, timers tier 4 (throttled), IO tier 2, priority 4 (4)>
                           *1   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4
  <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)>
                           *7   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11
  Thread 0x92a              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4-46 (base 4-46)
  Thread 0x242c             11 samples (1-11)         priority 4-31 (base 4-31)
  <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0, priority 31 (31)>
  <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)>
  Thread 0x86c9c5           11 samples (1-11)         priority 4-31 (base 4-31)
    11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
     *1   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4
     *7   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11
  Thread 0x86d28a           11 samples (1-11)         priority 4-31 (base 4-31)
  Binary Images:
           0x109a4c000 -        0x10a1a2fff  com.apple.finder 10.14.7 (1143.7.1)     <A0E7FB21-BD6B-322F-A694-976B8BCCA775>  /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
        0x7fff3415a000 -     0x7fff34451fff  com.apple.HIToolbox 2.1.1 (918.7)       <88D7F19C-8C9D-384B-BAB5-8205CA282F2C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)     <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)           <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         findmydeviced [339]
UUID:            4E8CD738-9023-3B9F-B5B6-066EACB672EE
Path:            /usr/libexec/findmydeviced
Parent:          launchd [1]
UID:             0
Footprint:       2448 KB
  Thread 0xa45              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10e676000 -        0x10e6f7fff  findmydeviced                        <4E8CD738-9023-3B9F-B5B6-066EACB672EE>  /usr/libexec/findmydeviced
Process:         fmfd [322]
UUID:            F4CF4C9F-2B9F-3EEE-8752-73454F7C57A1
Path:            /usr/libexec/fmfd
Parent:          launchd [1]
UID:             504
Footprint:       6668 KB
  Thread 0x95a              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x107edb000 -        0x107f3bfff  fmfd (339)                           <F4CF4C9F-2B9F-3EEE-8752-73454F7C57A1>  /usr/libexec/fmfd
Process:         FMIPClientXPCService [9954]
UUID:            8B2C30F7-DBE5-3465-938A-BE57FF01CC53
Path:            /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService
Parent:          launchd [1]
Responsible:     assistant_service [5602]
UID:             504
Footprint:       2040 KB
  Thread 0xe6947            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10848e000 -        0x108519fff  FMIPClientXPCService                 <8B2C30F7-DBE5-3465-938A-BE57FF01CC53>  /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService
Process:         followupd [898]
UUID:            81FEAFBA-8AB6-39C7-A67D-5C59CC9F03D9
Path:            /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Parent:          launchd [1]
UID:             504
Footprint:       1448 KB
  Thread 0xa746             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1064ac000 -        0x1064c1fff  followupd (74.3.0.1.1)               <81FEAFBA-8AB6-39C7-A67D-5C59CC9F03D9>  /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Process:         fontd [304]
UUID:            36469CA0-7FA5-32F6-B0D3-ED7BB9F9F5D8
Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
Parent:          launchd [1]
UID:             504
Footprint:       15.72 MB
  Thread 0x8e4              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10a042000 -        0x10a084fff  fontd                                <36469CA0-7FA5-32F6-B0D3-ED7BB9F9F5D8>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
Process:         fpsd [8661] [unique pid 108276]
UUID:            BB4D7B2C-6D25-33AA-B591-E583B4677E80
Path:            /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
Parent:          launchd [1]
UID:             265
Footprint:       1284 KB
CPU Time:        <0.001s (53.4K cycles, 11.6K instructions, 4.61c/i)
  Thread 0x5ffd29           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
  Thread 0x5ffd55           11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (53.4K cycles, 11.6K instructions, 4.61c/i)
        11  ??? (fpsd + 88307) [0x1021f68f3] 1-11
          11  sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11
            11  __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11
  Binary Images:
           0x1021e1000 -        0x10226bfff  fpsd (2.13.61)                       <BB4D7B2C-6D25-33AA-B591-E583B4677E80>  /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
        0x7fff60ee5000 -     0x7fff60f6cfff  libsystem_c.dylib (1272.250.3)       <6016EDA1-440B-34D7-A232-686CD7FBEE90>  /usr/lib/system/libsystem_c.dylib
Process:         fseventsd [55]
UUID:            2114A6F5-90C6-3A5F-9B9B-E4E6BB55C3D9
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Parent:          launchd [1]
UID:             0
Footprint:       14.05 MB
CPU Time:        <0.001s (1584.5K cycles, 700.2K instructions, 2.26c/i)
  Thread 0x255              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
    11  ??? (fseventsd + 6802) [0x1033a8a92] 1-11
      11  mach_msg_server + 378 (libsystem_kernel.dylib + 100170) [0x7fff60fe774a] 1-11
  Thread 0x286              11 samples (1-11)         priority 49 (base 49)     cpu time <0.001s (357.4K cycles, 121.6K instructions, 2.94c/i)
  <IO tier 0>
        11  ??? (fseventsd + 50949) [0x1033b3705] 1-11
          11  ??? (fseventsd + 49830) [0x1033b32a6] 1-11
             *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0x292              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0 and passive>
  Thread 0x293              11 samples (1-11)         priority 50 (base 50)     cpu time <0.001s (49.5K cycles, 10.0K instructions, 4.95c/i)
  <IO tier 0>
        11  read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11
             *11  read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11
               *11  ??? (kernel + 7270151) [0xffffff80008eef07] 1-11
                 *11  ??? (kernel + 4405643) [0xffffff800063398b] 1-11
                   *11  ??? (kernel + 7168593) [0xffffff80008d6251] 1-11
  Thread 0x294              11 samples (1-11)         priority 31 (base 31)
        11  ??? (fseventsd + 34818) [0x1033af802] 1-11
  Thread 0x7e8ad7           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (152.6K cycles, 78.8K instructions, 1.94c/i)
        11  ??? (fseventsd + 34892) [0x1033af84c] 1-11
  Thread 0x7e8ad8           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (185.9K cycles, 82.9K instructions, 2.24c/i)
  Thread 0x7e8af6           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (499.6K cycles, 253.9K instructions, 1.97c/i)
  Thread 0x98055b           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (168.5K cycles, 76.9K instructions, 2.19c/i)
  Thread 0xa57cf3           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (171.1K cycles, 76.1K instructions, 2.25c/i)
  Binary Images:
           0x1033a7000 -        0x1033b7fff  fseventsd (1239.200.13)              <2114A6F5-90C6-3A5F-9B9B-E4E6BB55C3D9>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Process:         gamecontrollerd [333]
UUID:            7CDBC003-AC7C-3698-9978-3CCCF83AD6EA
Path:            /usr/libexec/gamecontrollerd
Parent:          launchd [1]
UID:             247
Footprint:       1900 KB
  Thread 0x9c5              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (gamecontrollerd + 37106) [0x10d7740f2] 1-11
      11  -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11
  Binary Images:
           0x10d76b000 -        0x10d776fff  gamecontrollerd (6.22.7)                <7CDBC003-AC7C-3698-9978-3CCCF83AD6EA>  /usr/libexec/gamecontrollerd
Process:         garcon [330]
UUID:            807E70BC-329F-354B-B43D-2EDB6E7DE3AD
Path:            /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Parent:          launchd [1]
UID:             504
Footprint:       22.64 MB
  Thread 0x9c2              DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0>
    11  NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11
      11  ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11
        11  ??? (PlugInKit + 83603) [0x7fff57147693] 1-11
          11  ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11
            11  -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11
                11  _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11
                    11  -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11
                      11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11
                        11  _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11
                          11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11
                            11  ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11
                              11  RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11
  Thread 0xab9              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
        11  _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11
  Binary Images:
           0x109d9b000 -        0x109da6fff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
        0x7fff324e2000 -     0x7fff33297fff  com.apple.AppKit 6.9 (1671.60.112)      <4AFB032C-2786-3AD7-8EDA-576956992A9C>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff57133000 -     0x7fff57156fff  com.apple.pluginkit.framework 1.0 (1)   <B00A2028-4490-3BEA-B0F1-082BB7C050DD>  /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
Process:         garcon [362]
Parent:          launchd [1]
UID:             504
Footprint:       19.45 MB
CPU Time:        <0.001s (141.8K cycles, 38.7K instructions, 3.67c/i)
  Thread 0xce0              DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  Thread 0xcf8              Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x1063ad000 -        0x1063b8fff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Process:         garcon [7210]
Parent:          launchd [1]
UID:             504
Footprint:       26.43 MB
CPU Time:        <0.001s (71.9K cycles, 23.9K instructions, 3.01c/i)
  Thread 0xbb55b            DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  Thread 0xbb565            Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x10d13c000 -        0x10d147fff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Process:         garcon [6304] [unique pid 105928]
Parent:          launchd [1]
UID:             504
Footprint:       18.05 MB
CPU Time:        <0.001s (72.8K cycles, 25.3K instructions, 2.88c/i)
  Thread 0x5cd264           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  Thread 0x5cd26d           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x10c5d9000 -        0x10c5e4fff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Process:         garcon [16673] [unique pid 116274]
Parent:          launchd [1]
UID:             504
Footprint:       18.82 MB
CPU Time:        <0.001s (101.4K cycles, 28.6K instructions, 3.55c/i)
  Thread 0x74ca19           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  Thread 0x74ca3a           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x100331000 -        0x10033cfff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Process:         garcon [63190] [unique pid 162773]
Parent:          launchd [1]
UID:             504
Footprint:       18.86 MB
CPU Time:        <0.001s (93.0K cycles, 28.3K instructions, 3.29c/i)
  Thread 0xa57d00           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  Thread 0xa57d0b           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x104be1000 -        0x104becfff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Process:         garcon [67150] [unique pid 166733]
Parent:          launchd [1]
UID:             504
Footprint:       15.56 MB
  Thread 0xa8e869           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)
  Thread 0xa8e888           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Binary Images:
           0x105696000 -        0x1056a1fff  garcon                                  <807E70BC-329F-354B-B43D-2EDB6E7DE3AD>  /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
Process:         Google Chrome [721]
UUID:            4C4C44C9-5555-3144-A14C-FD20701C5D68
Path:            /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
Parent:          launchd [1]
UID:             504
Footprint:       388.13 MB
CPU Time:        0.007s (32.2M cycles, 17.2M instructions, 1.87c/i)
Note:            3 idle work queue threads omitted
  Thread 0x2eb2             DispatchQueue 1           Thread name "CrBrowserMain"                         11 samples (1-11)         priority 46 (base 46)     cpu time 0.005s (20.3M cycles, 12.7M instructions, 1.60c/i)
  <thread QoS user interactive (requested user interactive), IO tier 0>
    11  main + 205 (Google Chrome + 6013) [0x10d92a77d] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x112dfb0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x114fe347f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x114533367] 1-11
            11  ChromeMain + 25049845 (Google Chrome Framework + 25061861) [0x1145de9e5] 1-11
              11  ChromeMain + 36126554 (Google Chrome Framework + 36138570) [0x11506ee4a] 1-11
                11  ChromeMain + 30451759 (Google Chrome Framework + 30463775) [0x114b0571f] 1-11
                  11  ChromeMain + 30452258 (Google Chrome Framework + 30464274) [0x114b05912] 1-11
                    11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11
                      11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11
                        11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x114c10cd4] 1-11
                          11  ChromeMain + 39964550 (Google Chrome Framework + 39976566) [0x115417e76] 1-11
                              11  ChromeMain + 48445938 (Google Chrome Framework + 48457954) [0x115c2e8e2] 1-11
                                11  ChromeMain + 12202 (Google Chrome Framework + 24218) [0x112dfde9a] 1-11
                                  11  ChromeMain + 94890799 (Google Chrome Framework + 94902815) [0x118879a1f] 1-11
  Thread 0x2ef8             11 samples (1-11)         priority 31 (base 31)
  Thread 0x2f1b             Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x118ba5f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x115c844c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11
  Thread 0x2f1c             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x114d4e2f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x115c7deb8] 1-11
                  11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
  Thread 0x2f22             Thread name "Chrome_IOThread"                       11 samples (1-11)         priority 31 (base 31)     cpu time 0.002s (10.7M cycles, 4.2M instructions, 2.56c/i)
  <IO tier 0>
            11  ChromeMain + 47967713 (Google Chrome Framework + 47979729) [0x115bb9cd1] 1-11
  Thread 0x2f23             Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x114d4e598] 1-11
                  11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x115c65d7e] 1-11
  Thread 0x2f32             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f34             Thread name "CrShutdownDetector"                    11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
             *11  ??? (kernel + 7294931) [0xffffff80008f4fd3] 1-11
               *11  ??? (kernel + 7168269) [0xffffff80008d610d] 1-11
                 *11  lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11
  Thread 0x2f44             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f4c             Thread name "NetworkNotificationThreadMac"          11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f4f             Thread name "ThreadPoolSingleThreadForegroundBlocking0"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757273 (Google Chrome Framework + 15769289) [0x113d01ec9] 1-11
            11  ChromeMain + 15758109 (Google Chrome Framework + 15770125) [0x113d0220d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11
  Thread 0x2f51             Thread name "CacheThread_BlockFile"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f52             Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 12781790 (Google Chrome Framework + 12793806) [0x113a2b7ce] 1-11
            11  ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x113195f6d] 1-11
  Thread 0x2f54             Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (318.0K cycles, 69.4K instructions, 4.58c/i)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x113d01eba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x113d021dd] 1-11
              2   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-2
                2   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-2
                  2   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-2
                   *2   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-2
              9   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x114b4a555] 3-11
                9   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 3-11
                 *9   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 3-11
  Thread 0x2f84             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f85             Thread name "ThreadPoolSingleThreadSharedForegroundBlocking2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f87             Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking3"                 11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
  Thread 0x2f89             Thread name "Service Discovery Thread"              11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2f8a             Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 46 (base 46)
    11  __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11
  Thread 0x2f9c             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2fa3             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2fa9             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2fd7             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x3010             Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 46 (base 46)
  Thread 0x31e7             Thread name "org.libusb.device-hotplug"             11 samples (1-11)         priority 31 (base 31)
  Thread 0x31e8             Thread name "UsbEventHandler"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 29318071 (Google Chrome Framework + 29330087) [0x1149f0aa7] 1-11
            11  poll + 10 (libsystem_kernel.dylib + 37738) [0x7fff60fd836a] 1-11
                 *11  poll_nocancel + 1184 (kernel + 7282560) [0xffffff80008f1f80] 1-11
                   *11  kqueue_scan + 415 (kernel + 6973295) [0xffffff80008a676f] 1-11
  Thread 0x343e             Thread name "PowerSaveBlocker"                      11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3886            Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3888            Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa77254           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x113d01eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x113d01f2d] 1-11
  Thread 0xa9d392           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113d01e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113d01efd] 1-11
  Thread 0xa9f29b           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (240.3K cycles, 61.3K instructions, 3.92c/i)
  <IO tier 0>
              3   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-3
                3   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-3
                  3   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-3
                   *3   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3
              8   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x114b4a555] 4-11
                8   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 4-11
                 *8   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11
  Thread 0xaa0570           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0572           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0786           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10d929000 -        0x10d95cfff  com.google.Chrome 108.0.5359.124 (5359.124)           <4C4C44C9-5555-3144-A14C-FD20701C5D68>  /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
           0x112df8000 -        0x11d90dfff  com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper [734]
UUID:            4C4C442C-5555-3144-A14B-566CC46741BF
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
Parent:          Google Chrome [721]
Responsible:     Google Chrome [721]
UID:             504
Footprint:       44.72 MB
CPU Time:        0.003s (13.4M cycles, 5.1M instructions, 2.61c/i)
  Thread 0x2f5b             DispatchQueue 1           Thread name "CrUtilityMain"                         11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper + 6412) [0x1089ea90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10ccad0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10ee9547f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10e3e5367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10e49082f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10e4912f5] 1-11
                11  ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x10e79af91] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d92b1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d92bbf6] 1-11
                      11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10fb17d7e] 1-11
                        11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-11
  Thread 0x2f91             Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x112a57f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10fb364c7] 1-11
  Thread 0x2f92             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10ec002f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10fb2feb8] 1-11
  Thread 0x2f95             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time 0.003s (12.9M cycles, 5.0M instructions, 2.61c/i)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10fc5d3f1] 1-11
  Thread 0x2f98             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x109a2            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa732b3           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (102.1K cycles, 19.4K instructions, 5.25c/i)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10dbb3eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10dbb3f2d] 1-11
              3   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10e9fc555] 1-3
              8   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 4-11
                8   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 4-11
  Thread 0xa9f048           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 1-11
  Thread 0xa9f2ac           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10dbb3e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10dbb3efd] 1-11
  Thread 0xaa0574           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (349.8K cycles, 151.7K instructions, 2.31c/i)
  <IO tier 0>
              3   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 1-3
                3   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-3
              8   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10e9fc555] 4-11
  Binary Images:
           0x1089e9000 -        0x108a19fff  com.google.Chrome.helper 108.0.5359.124 (5359.124)    <4C4C442C-5555-3144-A14B-566CC46741BF>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
           0x10ccaa000 -        0x1177bffff  com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper [735]
UID:             504
Footprint:       21.17 MB
  Thread 0x2f81             Thread name "CrUtilityMain"                         11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper + 6412) [0x10936990c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10e8580b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x110a4047f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ff90367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11003b82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11003c2f5] 1-11
                11  ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x110345f91] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10f4d61c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10f4d6bf6] 1-11
                      11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1116c2d7e] 1-11
                        11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11
  Thread 0x2fac             Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x114602f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1116e14c7] 1-11
  Thread 0x2fad             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2faf             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10f75eeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10f75ef2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1105a7e33] 1-11
  Thread 0x2fb6             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1107ab2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1118083f1] 1-11
  Thread 0x109a3            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa86029           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10f75ee82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10f75eefd] 1-11
  Thread 0xa9f646           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa064a           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x109368000 -        0x109398fff  com.google.Chrome.helper 108.0.5359.124 (5359.124)    <4C4C442C-5555-3144-A14B-566CC46741BF>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
           0x10e855000 -        0x11936afff  com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper [764]
UID:             504
Footprint:       14.02 MB
  Thread 0x32ce             DispatchQueue 1           Thread name "CrUtilityMain"                         11 samples (1-11)         priority 47 (base 47)
  <process frontmost, thread QoS user interactive (requested user interactive), IO tier 0>
    11  main + 252 (Google Chrome Helper + 6412) [0x104f5690c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c2540b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e43c47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10d98c367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10da3782f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10da382f5] 1-11
                11  ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x10dd41f91] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10ced21c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10ced2bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e069cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e069e1e] 1-11
                          11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  Thread 0x32d8             Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <process frontmost, IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cd01374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x111ffef88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f0dd4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5174fd] 1-11
  Thread 0x32d9             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e1a72f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10f0d6eb8] 1-11
  Thread 0x32da             Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d15ae82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d15aefd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10dfa3e33] 1-11
  Thread 0x32db             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d15aeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d15af2d] 1-11
  Thread 0x32dc             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f2043f1] 1-11
  Thread 0x109a8            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  11  <truncated backtrace> 1-11
  Binary Images:
           0x104f55000 -        0x104f85fff  com.google.Chrome.helper 108.0.5359.124 (5359.124)    <4C4C442C-5555-3144-A14B-566CC46741BF>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
           0x10c251000 -        0x116d66fff  com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper [67359] [unique pid 166942]
UID:             504
Footprint:       12.70 MB
CPU Time:        <0.001s (319.7K cycles, 55.9K instructions, 5.72c/i)
  Thread 0xa9f2a3           DispatchQueue 1           Thread name "CrUtilityMain"                         11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (264.8K cycles, 49.1K instructions, 5.39c/i)
    11  main + 252 (Google Chrome Helper + 6412) [0x1049e690c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10fbb60b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x111d9e47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1112ee367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11139982f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11139a2f5] 1-11
                11  ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x1116a3f91] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1108341c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110834bf6] 1-11
                      11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x112a20d7e] 1-11
                        11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fe794fd] 1-11
  Thread 0xa9f2af           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (54.9K cycles, 6.8K instructions, 8.06c/i)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110663374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115960f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x112a3f4c7] 1-11
  Thread 0xa9f2b0           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x111b092f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x112a38eb8] 1-11
  Thread 0xa9f2b1           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x110abce82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x110abcefd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111905e33] 1-11
  Thread 0xa9f2b2           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x110abceab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x110abcf2d] 1-11
  Thread 0xa9f2b4           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x112b663f1] 1-11
  Binary Images:
           0x1049e5000 -        0x104a15fff  com.google.Chrome.helper 108.0.5359.124 (5359.124)    <4C4C442C-5555-3144-A14B-566CC46741BF>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
           0x10fbb3000 -        0x11a6c8fff  com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (GPU) [733]
UUID:            4C4C4418-5555-3144-A1B2-D65FE009D631
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (GPU).app/Contents/MacOS/Google Chrome Helper (GPU)
UID:             504
Footprint:       2053.59 MB
  Thread 0x2f53             DispatchQueue 1           Thread name "CrGpuMain"   11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (GPU) + 6412) [0x10e76190c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1168ab0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x118a9347f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x117fe3367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11808e82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11808f2f5] 1-11
                11  ChromeMain + 41395209 (Google Chrome Framework + 41407225) [0x1190252f9] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1175291c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x117529bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1186c0cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1186c0e1e] 1-11
                                  11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
  Thread 0x2fd9             Thread name "GpuWatchdog" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1187fe2f5] 1-11
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1187fe598] 1-11
                  11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x119715d7e] 1-11
                    11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11
  Thread 0x2fef             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x2ff3             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x11985b3f1] 1-11
  Thread 0x2ff5             Thread name "VizCompositorThread"                   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x32cc             Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0x32cd             Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x109aa            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa5091            Thread name "com.apple.coremedia.imagequeue.coreanimation.common"             11 samples (1-11)         priority 54 (base 54)
  <IO tier 0>
        11  figThreadMain + 276 (CoreMedia + 71999) [0x7fff35fd493f] 1-11
          11  ??? (MediaToolbox + 2922460) [0x7fff396ac7dc] 1-11
            11  FigSemaphoreWaitRelative + 145 (CoreMedia + 83275) [0x7fff35fd754b] 1-11
              11  WaitOnCondition + 11 (CoreMedia + 154667) [0x7fff35fe8c2b] 1-11
  Thread 0xa81478           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1177b1eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1177b1f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1185fae33] 1-11
  Thread 0xa8cecf           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1177b1e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1177b1efd] 1-11
  Thread 0xa9f1a9           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
  Thread 0xaa09dd           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
              11  ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x1185f9bab] 1-11
                11  ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x116b6e149] 1-11
  Binary Images:
           0x10e760000 -        0x10e790fff  com.google.Chrome.helper 108.0.5359.124 (5359.124)    <4C4C4418-5555-3144-A1B2-D65FE009D631>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (GPU).app/Contents/MacOS/Google Chrome Helper (GPU)
           0x1168a8000 -        0x1213bdfff  com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff35fc3000 -     0x7fff360c7fff  com.apple.CoreMedia 1.0 (2290.14)                     <2C7A5348-7F19-3E28-97E4-6065A64B1DC9>  /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)                   <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff393e3000 -     0x7fff39a89fff  com.apple.MediaToolbox 1.0 (2290.14)                  <927F9E24-32DB-33F9-9866-4DD8092A51F4>  /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
Process:         Google Chrome Helper (Renderer) [8016]
UUID:            4C4C44A9-5555-3144-A132-36D8EA20CB02
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
Architecture:    x86_64
UID:             504
Footprint:       497.68 MB
Start time:      2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
Num samples:     11 (1-11)
CPU Time:        <0.001s (3.7M cycles, 1300.5K instructions, 2.84c/i)
  Thread 0xe38b1            DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (2.7M cycles, 1074.4K instructions, 2.53c/i)
  <thread QoS default (requested user interactive), IO tier 0>
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1054a190c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10d81d0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10fa0547f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ef55367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10f00082f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10f0012f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10f5eaef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10e49b1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10e49bbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10f632cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10f632e1e] 1-11
  Thread 0xe38bd            Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e2ca374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1135c7f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1106a64c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10dae04fd] 1-11
  Thread 0xe38be            Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38c0            Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10e723eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10e723f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f56ce33] 1-11
  Thread 0xe38c1            Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (966.5K cycles, 226.2K instructions, 4.27c/i)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10f7702f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1107cd3f1] 1-11
                   *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0xe38c3            Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38c5            Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38c6            Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38d0            Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38d1            Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38d2            Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38d3            Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38d4            Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe39ac            Thread name "WebCrypto"   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe63ec            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0394           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e723e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e723efd] 1-11
  Thread 0xaa05bc           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x1054a0000 -        0x1054d0fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10d81a000 -        0x11832ffff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70)                        <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         Google Chrome Helper (Renderer) [8017]
UID:             504
Footprint:       126.10 MB
CPU Time:        0.009s (39.9M cycles, 18.3M instructions, 2.18c/i)
  Thread 0xe38c9            DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time 0.008s (35.9M cycles, 16.8M instructions, 2.15c/i)
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x109a7f90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10bbb50b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10dd9d47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10d2ed367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10d39882f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10d3992f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10d982ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10c8331c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10c833bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10d9cacd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10d9cae1e] 1-11
                              11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
                                11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0xe38df            Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11195ff88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10ea3e4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11
  Thread 0xe38e1            Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38e3            Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10cabbeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10cabbf2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11
  Thread 0xe38e4            Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (3.9M cycles, 1532.3K instructions, 2.56c/i)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10db082f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10eb653f1] 1-11
  Thread 0xe38e6            Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38e8            Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38e9            Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38ec            Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38ed            Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38ee            Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38ef            Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38f0            Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe63ef            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x24179b           Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x743c06           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x743c0b           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9cdb1           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10cabbe82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10cabbefd] 1-11
  Thread 0xa9f73d           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa04b0           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0789           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa078a           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x109a7e000 -        0x109aaefff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10bbb2000 -        0x1166c7fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)                     <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                                        <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         Google Chrome Helper (Renderer) [8018]
UID:             504
Footprint:       31.56 MB
Note:            1 idle work queue thread omitted
  Thread 0xe38dc            DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10da9e90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x11513c0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11732447f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x116874367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11691f82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1169202f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x116f09ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x115dba1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x115dbabf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x116f51cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x116f51e1e] 1-11
                            11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Thread 0xe38fc            Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x115be9374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11aee6f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x117fc54c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1153ff4fd] 1-11
  Thread 0xe38fd            Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe38fe            Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x116042e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x116042efd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x116e8be33] 1-11
  Thread 0xe38ff            Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x116042eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x116042f2d] 1-11
  Thread 0xe3900            Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x11708f2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1180ec3f1] 1-11
  Thread 0xe3902            Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3906            Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3907            Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe390e            Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe390f            Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3910            Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3911            Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3912            Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe63f0            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10da9d000 -        0x10dacdfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x115139000 -        0x11fc4efff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                                     <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         Google Chrome Helper (Renderer) [8020]
UID:             504
Footprint:       42.71 MB
  Thread 0xe38f1            DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1019f090c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c7f90b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e9e147f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10df31367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10dfdc82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10dfdd2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10e5c6ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d4771c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d477bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e60ecd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e60ee1e] 1-11
  Thread 0xe3923            Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d2a6374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1125a3f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f6824c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cabc4fd] 1-11
  Thread 0xe3924            Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3926            Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d6ffeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d6fff2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e548e33] 1-11
  Thread 0xe3927            Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e74c2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f7a93f1] 1-11
  Thread 0xe3929            Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3936            Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3937            Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3958            Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3959            Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe395a            Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe395b            Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe395c            Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe63f2            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x865291           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d6ffe82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d6ffefd] 1-11
  Binary Images:
           0x1019ef000 -        0x101a1ffff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10c7f6000 -        0x11730bfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8021]
UID:             504
Footprint:       61.94 MB
  Thread 0xe38fa            DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10de0490c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10de630b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11004b47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10f59b367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10f64682f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10f6472f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10fc30ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eae11c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eae1bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10fc78cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10fc78e1e] 1-11
  Thread 0xe3939            Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e910374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x113c0df88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x110cec4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1264fd] 1-11
  Thread 0xe393a            Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe393c            Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10ed69eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10ed69f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fbb2e33] 1-11
  Thread 0xe393d            Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10fdb62f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x110e133f1] 1-11
  Thread 0xe3943            Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3946            Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3947            Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3952            Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
  Thread 0xe3953            Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3954            Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3955            Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe3956            Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe39e2            Thread name "WebCrypto"   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xe63f3            Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa03da           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10ed69e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10ed69efd] 1-11
  Binary Images:
           0x10de03000 -        0x10de33fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10de60000 -        0x118975fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                         <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                               <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         Google Chrome Helper (Renderer) [14405]
UID:             504
Footprint:       85.07 MB
  Thread 0x15c69b           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10f02b90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1179c00b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x119ba847f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1190f8367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1191a382f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1191a42f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x11978def0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11863e1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11863ebf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1197d5cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1197d5e1e] 1-11
  Thread 0x15c6a7           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11846d374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11d76af88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11a8494c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x117c834fd] 1-11
  Thread 0x15c6a8           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c6aa           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1188c6eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1188c6f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11970fe33] 1-11
  Thread 0x15c6ab           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1199132f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x11a9703f1] 1-11
  Thread 0x15c6ad           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c6ae           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c6af           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c903           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0x15c904           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c905           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c906           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15c907           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x15d7f8           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9fcb5           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1188c6e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1188c6efd] 1-11
  Binary Images:
           0x10f02a000 -        0x10f05afff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1179bd000 -        0x1224d2fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [98292]
UID:             504
Footprint:       192.89 MB
CPU Time:        <0.001s (440.1K cycles, 99.6K instructions, 4.42c/i)
Note:            2 idle work queue threads omitted
  Thread 0x58be4c           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (306.1K cycles, 69.1K instructions, 4.43c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10fe6390c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x114cf00b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x116ed847f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x116428367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1164d382f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1164d42f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x116abdef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11596e1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11596ebf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x116b05cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x116b05e1e] 1-11
  Thread 0x58be5a           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11579d374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11aa9af88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x117b794c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x114fb34fd] 1-11
  Thread 0x58be5b           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be5d           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x115bf6eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x115bf6f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x116a3fe33] 1-11
  Thread 0x58be5e           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x116c432f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x117ca03f1] 1-11
  Thread 0x58be60           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be61           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be62           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be78           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be79           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be7a           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be7b           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be7c           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf1d           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf9f           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bfa0           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bfa1           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bfa2           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bfa3           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bfa4           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bfe4           Thread name "Database thread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58cd19           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0668           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x115bf6e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x115bf6efd] 1-11
  Binary Images:
           0x10fe62000 -        0x10fe92fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x114ced000 -        0x11f802fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [98293]
UID:             504
Footprint:       165.95 MB
CPU Time:        <0.001s (535.4K cycles, 124.6K instructions, 4.30c/i)
  Thread 0x58be77           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (399.0K cycles, 84.7K instructions, 4.71c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1048d990c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1049380b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x106b2047f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x106070367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10611b82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10611c2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x106705ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1055b61c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1055b6bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10674dcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10674de1e] 1-11
  Thread 0x58be89           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1053e5374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10a6e2f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1077c14c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x104bfb4fd] 1-11
  Thread 0x58be8a           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
  Thread 0x58be8c           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10583eeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10583ef2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x106687e33] 1-11
  Thread 0x58be8e           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10688b2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1078e83f1] 1-11
  Thread 0x58be8f           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be91           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58be92           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf55           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf56           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf57           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf58           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58bf59           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x58ff70           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa786f3           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10583ee82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10583eefd] 1-11
  Binary Images:
           0x1048d8000 -        0x104908fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x104935000 -        0x10f44afff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8617] [unique pid 108232]
UID:             504
Footprint:       59.43 MB
CPU Time:        <0.001s (47.8K cycles, 8.6K instructions, 5.59c/i)
  Thread 0x5fddc6           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10575490c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10cceb0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10eed347f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10e423367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10e4ce82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10e4cf2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10eab8ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d9691c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d969bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10eb00cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10eb00e1e] 1-11
  Thread 0x5fddd3           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d798374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x112a95f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10fb744c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cfae4fd] 1-11
  Thread 0x5fddd4           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5fddd6           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (47.8K cycles, 8.6K instructions, 5.59c/i)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10dbf1eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10dbf1f2d] 1-11
              7   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10ea3a555] 1-7
                7   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-7
                 *7   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-7
              4   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ea3ae33] 8-11
                4   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cfae4fd] 8-11
                  4   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 8-11
                   *4   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 8-11
  Thread 0x5fddd7           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10ec3e2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10fc9b3f1] 1-11
  Thread 0x5fddd9           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5fddda           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5fdddb           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5ffab3           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5ffab4           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5ffab5           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5ffab6           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x5ffab7           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x600ed5           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9fb2e           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10dbf1e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10dbf1efd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ea3ae33] 1-11
  Binary Images:
           0x105753000 -        0x105783fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10cce8000 -        0x1177fdfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8814] [unique pid 108429]
Parent:          Google Chrome [721]
Responsible:     Google Chrome [721]
UID:             504
Footprint:       527.82 MB
  Thread 0x609b63           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x105a1d90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x107e0c0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x109ff447f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x109544367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1095ef82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1095f02f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x109bd9ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x108a8a1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108a8abf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109c21cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109c21e1e] 1-11
  Thread 0x609b6f           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1088b9374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10dbb6f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10ac954c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1080cf4fd] 1-11
  Thread 0x609b70           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x609b72           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x108d12eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x108d12f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109b5be33] 1-11
  Thread 0x609b73           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x109d5f2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10adbc3f1] 1-11
  Thread 0x609b75           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x609b76           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x609b77           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7e7           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7e8           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7e9           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7ea           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7eb           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a834           Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60bab4           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9b556           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108d12e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108d12efd] 1-11
  Thread 0xaa0911           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
              11  ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x109b5abab] 1-11
                11  ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1080cf149] 1-11
  Binary Images:
           0x105a1c000 -        0x105a4cfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x107e09000 -        0x11291efff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8845] [unique pid 108460]
UID:             504
Footprint:       177.66 MB
  Thread 0x60a7e6           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x106b9590c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x106bf40b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x108ddc47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10832c367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1083d782f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1083d82f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1089c1ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1078721c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107872bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x108a09cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x108a09e1e] 1-11
  Thread 0x60a7f5           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1076a1374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10c99ef88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x109a7d4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106eb74fd] 1-11
  Thread 0x60a7f6           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7f8           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x107afaeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x107afaf2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x108943e33] 1-11
  Thread 0x60a7f9           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x108b472f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x109ba43f1] 1-11
  Thread 0x60a7fb           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7fc           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a7fd           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a86a           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a86b           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a86c           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a86d           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a86e           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x61f058           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa7c96c           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x107afae82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x107afaefd] 1-11
  Binary Images:
           0x106b94000 -        0x106bc4fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x106bf1000 -        0x111706fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8846] [unique pid 108461]
UID:             504
Footprint:       51.79 MB
  Thread 0x60a869           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10c2a890c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c3070b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e4ef47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10da3f367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10daea82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10daeb2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10e0d4ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10cf851c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10cf85bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e11ccd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e11ce1e] 1-11
                          11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  Thread 0x60a87c           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cdb4374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1120b1f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f1904c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5ca4fd] 1-11
  Thread 0x60a87d           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  <truncated backtrace> 1-11
  Thread 0x60a87f           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d20deab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d20df2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e056e33] 1-11
  Thread 0x60a880           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e25a2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f2b73f1] 1-11
  Thread 0x60a882           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a883           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a884           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8bd           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8be           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8bf           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8c0           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8c1           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x61f059           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7a8daf           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d20de82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d20defd] 1-11
  Binary Images:
           0x10c2a7000 -        0x10c2d7fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10c304000 -        0x116e19fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8847] [unique pid 108462]
UID:             504
Footprint:       52.07 MB
  Thread 0x60a8bb           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10850690c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x11363e0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11582647f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x114d76367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x114e2182f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x114e222f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x11540bef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1142bc1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1142bcbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x115453cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x115453e1e] 1-11
  Thread 0x60a8cd           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1140eb374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1193e8f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1164c74c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1139014fd] 1-11
  Thread 0x60a8ce           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8d0           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x114544eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x114544f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11538de33] 1-11
  Thread 0x60a8d1           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1155912f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1165ee3f1] 1-11
  Thread 0x60a8d3           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
  Thread 0x60a8d5           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a8d6           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a928           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a929           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a92a           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a92b           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a92c           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x61f05a           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7aa987           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x114544e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x114544efd] 1-11
                   *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Binary Images:
           0x108505000 -        0x108535fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x11363b000 -        0x11e150fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [8849] [unique pid 108464]
UID:             504
Footprint:       51.42 MB
  Thread 0x60a946           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x104f9090c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x106ce90b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x108ed147f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x108421367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1084cc82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1084cd2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x108ab6ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1079671c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107967bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x108afecd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x108afee1e] 1-11
  Thread 0x60a953           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107796374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10ca93f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x109b724c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106fac4fd] 1-11
  Thread 0x60a954           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a956           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x107befeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x107beff2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x108a38e33] 1-11
  Thread 0x60a957           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x108c3c2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x109c993f1] 1-11
  Thread 0x60a959           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a95a           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a95b           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9aa           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9ab           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9ac           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9ad           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9ae           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x61f05b           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7ba7ba           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x107befe82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x107befefd] 1-11
  Binary Images:
           0x104f8f000 -        0x104fbffff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x106ce6000 -        0x1117fbfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)                         <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         Google Chrome Helper (Renderer) [8852] [unique pid 108467]
UUID:            4C4C44A9-5555-3144-A132-36D8EA20CB02
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
Architecture:    x86_64
UID:             504
Footprint:       67.60 MB
Start time:      2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
Num samples:     11 (1-11)
  Thread 0x60a9af           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10c81f90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1140310b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11621947f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x115769367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11581482f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1158152f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x115dfeef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x114caf1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x114cafbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x115e46cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x115e46e1e] 1-11
  Thread 0x60a9d0           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114ade374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x119ddbf88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x116eba4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1142f44fd] 1-11
  Thread 0x60a9d1           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0x60a9d3           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x114f37eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x114f37f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x115d80e33] 1-11
  Thread 0x60a9d4           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x115f842f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x116fe13f1] 1-11
  Thread 0x60a9d6           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9db           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9dc           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9e5           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9e6           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9e7           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9e9           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9ea           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x61f05c           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7fa766           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x114f37e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x114f37efd] 1-11
  Binary Images:
           0x10c81e000 -        0x10c84efff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x11402e000 -        0x11eb43fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70)                        <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         Google Chrome Helper (Renderer) [8853] [unique pid 108468]
UID:             504
Footprint:       51.05 MB
  Thread 0x60a9bd           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10ff4b90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1137840b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11596c47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x114ebc367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x114f6782f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x114f682f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x115551ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1144021c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x114402bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x115599cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x115599e1e] 1-11
                              11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
                                11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0x60a9f4           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114231374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11952ef88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11660d4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x113a474fd] 1-11
  Thread 0x60a9f5           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9f7           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x11468aeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x11468af2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1154d3e33] 1-11
  Thread 0x60a9f8           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1156d72f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1167343f1] 1-11
  Thread 0x60a9fa           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9fb           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60a9fc           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60abb7           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60abb8           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60abb9           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60abba           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x60abbb           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x61f05e           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7baf29           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11468ae82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11468aefd] 1-11
  Binary Images:
           0x10ff4a000 -        0x10ff7afff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x113781000 -        0x11e296fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)                     <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                                        <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         Google Chrome Helper (Renderer) [10098] [unique pid 109709]
UID:             504
Footprint:       180.05 MB
Note:            1 idle work queue thread omitted
  Thread 0x649307           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10f7e990c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10f8480b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x111a3047f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x110f80367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11102b82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11102c2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111615ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1104c61c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1104c6bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x11165dcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x11165de1e] 1-11
                            11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Thread 0x649322           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1155f2f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1126d14c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11
  Thread 0x649323           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x649325           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x11074eeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x11074ef2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111597e33] 1-11
  Thread 0x649326           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x11179b2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1127f83f1] 1-11
  Thread 0x649328           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x649329           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x110595914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1126b2d7e] 1-11
  Thread 0x64932a           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64ff7a           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117b39037] 1-11
            11  ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10fbe2f6d] 1-11
  Thread 0x64ff7b           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64ff7c           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64ff7d           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64ff7e           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x651257           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x660c32           Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x11074eeba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x11074f1dd] 1-11
  Thread 0xa8ced2           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa8ed5a           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11074ee82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11074eefd] 1-11
  Thread 0xaa030c           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa030d           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10f7e8000 -        0x10f818fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10f845000 -        0x11a35afff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                                     <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         Google Chrome Helper (Renderer) [10222] [unique pid 109831]
UID:             504
Footprint:       82.60 MB
  Thread 0x6501f5           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x103a6a90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10d1fa0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10f3e247f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10e932367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10e9dd82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10e9de2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10efc7ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10de781c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10de78bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10f00fcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10f00fe1e] 1-11
  Thread 0x650203           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10dca7374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x112fa4f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1100834c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d4bd4fd] 1-11
  Thread 0x650204           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x650207           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10f14d2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1101aa3f1] 1-11
  Thread 0x650209           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65020c           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65020d           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6574d5           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65bed1           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65bed2           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65bed3           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65bed4           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65bed5           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x65c46f           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10e100eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10e100f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ef49e33] 1-11
  Thread 0xaa05d2           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e100e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e100efd] 1-11
  Binary Images:
           0x103a69000 -        0x103a99fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10d1f7000 -        0x117d0cfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [14325] [unique pid 113930]
UID:             504
Footprint:       120.14 MB
CPU Time:        <0.001s (500.5K cycles, 107.7K instructions, 4.65c/i)
  Thread 0x68227c           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (300.8K cycles, 69.9K instructions, 4.30c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10fef190c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10ff500b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11213847f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x111688367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11173382f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1117342f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111d1def0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x110bce1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110bcebf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x111d65cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x111d65e1e] 1-11
  Thread 0x68229a           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1109fd374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115cfaf88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x112dd94c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1102134fd] 1-11
  Thread 0x68229c           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68229e           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)       cpu time <0.001s (50.9K cycles, 7.1K instructions, 7.12c/i)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x110e56eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x110e56f2d] 1-11
              2   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111c9fe33] 1-2
                2   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1102134fd] 1-2
                  2   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-2
                   *2   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-2
              9   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x111c9f555] 3-11
                9   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 3-11
                 *9   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 3-11
  Thread 0x6822a0           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x111ea32f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x112f003f1] 1-11
  Thread 0x6822a1           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6822a2           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6822a3           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682403           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
  Thread 0x682404           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682405           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682406           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682407           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682f23           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa07de           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x110e56e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x110e56efd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111c9fe33] 1-11
  Binary Images:
           0x10fef0000 -        0x10ff20fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10ff4d000 -        0x11aa62fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                         <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                               <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         Google Chrome Helper (Renderer) [14326] [unique pid 113931]
UID:             504
Footprint:       105.42 MB
CPU Time:        <0.001s (60.1K cycles, 7.1K instructions, 8.48c/i)
  Thread 0x682402           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10467990c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1046d80b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1068c047f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x105e10367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x105ebb82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x105ebc2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1064a5ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1053561c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x105356bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1064edcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1064ede1e] 1-11
  Thread 0x682412           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (60.1K cycles, 7.1K instructions, 8.48c/i)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x105185374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10a482f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1075614c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10499b4fd] 1-11
  Thread 0x682413           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682415           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1055deeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1055def2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x106427e33] 1-11
  Thread 0x682416           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10662b2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1076883f1] 1-11
  Thread 0x682418           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682419           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68241a           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682528           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0x682529           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68252a           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68252b           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68252c           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682f39           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9f663           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1055dee82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1055deefd] 1-11
  Binary Images:
           0x104678000 -        0x1046a8fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1046d5000 -        0x10f1eafff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [14354] [unique pid 113959]
UID:             504
Footprint:       94.99 MB
  Thread 0x68260e           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a27390c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10a2d20b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10c4ba47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ba0a367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10bab582f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10bab62f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10c09fef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10af501c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10af50bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10c0e7cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10c0e7e1e] 1-11
  Thread 0x68261a           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10ad7f374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11007cf88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10d15b4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a5954fd] 1-11
  Thread 0x68261b           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68261d           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10b1d8eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10b1d8f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c021e33] 1-11
  Thread 0x68261e           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10c2252f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10d2823f1] 1-11
  Thread 0x682620           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682621           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682622           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682696           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682697           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682698           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682699           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68269a           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x685740           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9fd4f           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10b1d8e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10b1d8efd] 1-11
  Binary Images:
           0x10a272000 -        0x10a2a2fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10a2cf000 -        0x114de4fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [14355] [unique pid 113960]
UID:             504
Footprint:       126.03 MB
CPU Time:        <0.001s (388.0K cycles, 93.1K instructions, 4.17c/i)
Note:            2 idle work queue threads omitted
  Thread 0x682695           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (213.0K cycles, 51.0K instructions, 4.18c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x108cbb90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10d5830b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10f76b47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ecbb367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10ed6682f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10ed672f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10f350ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10e2011c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10e201bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10f398cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10f398e1e] 1-11
  Thread 0x6826a2           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (59.1K cycles, 6.8K instructions, 8.65c/i)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e030374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11332df88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11040c4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d8464fd] 1-11
  Thread 0x6826a3           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
  Thread 0x6826a5           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10e489eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10e489f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f2d2e33] 1-11
  Thread 0x6826a6           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10f4d62f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1105333f1] 1-11
  Thread 0x6826a9           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6826aa           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6826ab           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682757           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682758           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682759           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68275a           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68275b           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6831a1           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9ffb3           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e489e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e489efd] 1-11
  Binary Images:
           0x108cba000 -        0x108ceafff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10d580000 -        0x118095fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [14360] [unique pid 113965]
UID:             504
Footprint:       122.16 MB
CPU Time:        <0.001s (358.9K cycles, 93.1K instructions, 3.85c/i)
  Thread 0x682756           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (233.4K cycles, 59.0K instructions, 3.95c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10897790c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1089d60b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10abbe47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10a10e367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10a1b982f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10a1ba2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10a7a3ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1096541c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109654bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10a7ebcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10a7ebe1e] 1-11
  Thread 0x68276d           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109483374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10e780f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10b85f4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x108c994fd] 1-11
  Thread 0x68276e           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682770           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1098dceab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1098dcf2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10a725e33] 1-11
  Thread 0x682771           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10a9292f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10b9863f1] 1-11
  Thread 0x682773           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682774           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682775           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682d51           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682d52           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682d53           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682d54           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x682d55           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684025           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa8cf15           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1098dce82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1098dcefd] 1-11
  Binary Images:
           0x108976000 -        0x1089a6fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1089d3000 -        0x1134e8fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [14399] [unique pid 114004]
Parent:          Google Chrome [721]
Responsible:     Google Chrome [721]
UID:             504
Footprint:       126.19 MB
CPU Time:        <0.001s (374.7K cycles, 97.6K instructions, 3.84c/i)
  Thread 0x684744           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (229.9K cycles, 59.5K instructions, 3.87c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1079ff90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x107a5e0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x109c4647f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x109196367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10924182f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1092422f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10982bef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1086dc1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1086dcbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109873cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109873e1e] 1-11
  Thread 0x684756           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10850b374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10d808f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10a8e74c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x107d214fd] 1-11
  Thread 0x684757           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684759           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x108964eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x108964f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1097ade33] 1-11
  Thread 0x68475a           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1099b12f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10aa0e3f1] 1-11
  Thread 0x68475c           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68475d           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68475e           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684976           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684977           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684978           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684979           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x68497a           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x684e2b           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9f29d           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108964e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108964efd] 1-11
  Binary Images:
           0x1079fe000 -        0x107a2efff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x107a5b000 -        0x112570fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [15092] [unique pid 114696]
UID:             504
Footprint:       156.37 MB
  Thread 0x6e2029           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10ef0e90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1101e20b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1123ca47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x11191a367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1119c582f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1119c62f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111fafef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x110e601c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110e60bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x111ff7cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x111ff7e1e] 1-11
  Thread 0x6e203e           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110c8f374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115f8cf88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11306b4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1104a54fd] 1-11
  Thread 0x6e2040           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6e2042           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1110e8eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1110e8f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111f31e33] 1-11
  Thread 0x6e2043           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1121352f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1131923f1] 1-11
  Thread 0x6e2045           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6e2047           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6e2048           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6e2670           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x742ad3           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x742ad4           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x742ad5           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x742ad6           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x742ad7           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9fcb2           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1110e8e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1110e8efd] 1-11
  Binary Images:
           0x10ef0d000 -        0x10ef3dfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1101df000 -        0x11acf4fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [29530] [unique pid 129122]
UID:             504
Footprint:       303.31 MB
  Thread 0x7f56b4           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10aac190c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x110f940b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11317c47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1126cc367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11277782f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1127782f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x112d61ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x111c121c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x111c12bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x112da9cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x112da9e1e] 1-11
                          11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  Thread 0x7f56d1           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x111a41374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x116d3ef88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x113e1d4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1112574fd] 1-11
  Thread 0x7f56d2           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  <truncated backtrace> 1-11
  Thread 0x7f56d4           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x111e9aeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x111e9af2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x112ce3e33] 1-11
  Thread 0x7f56d5           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x112ee72f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x113f443f1] 1-11
  Thread 0x7f56d7           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f56d8           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f56d9           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5985           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5986           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5987           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5988           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5989           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f6c36           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0304           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x111e9ae82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x111e9aefd] 1-11
  Binary Images:
           0x10aac0000 -        0x10aaf0fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x110f91000 -        0x11baa6fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [29532] [unique pid 129124]
UID:             504
Footprint:       94.93 MB
CPU Time:        <0.001s (363.5K cycles, 96.6K instructions, 3.76c/i)
  Thread 0x7f5983           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (197.1K cycles, 55.0K instructions, 3.59c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10217390c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10ae570b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10d03f47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10c58f367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10c63a82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10c63b2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10cc24ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10bad51c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10bad5bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10cc6ccd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10cc6ce1e] 1-11
                                  11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
  Thread 0x7f598f           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b904374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x110c01f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10dce04c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10b11a4fd] 1-11
  Thread 0x7f5990           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5992           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10bd5deab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10bd5df2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10cba6e33] 1-11
  Thread 0x7f5993           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10cdaa2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10de073f1] 1-11
  Thread 0x7f5995           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0x7f5996           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f5997           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63d0           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63d1           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63d2           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63d3           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63d4           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f728b           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa93661           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10bd5de82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10bd5defd] 1-11
  Binary Images:
           0x102172000 -        0x1021a2fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10ae54000 -        0x115969fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [29539] [unique pid 129131]
UID:             504
Footprint:       48.64 MB
  Thread 0x7f63cf           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10aafc90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x11232b0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11451347f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x113a63367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x113b0e82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x113b0f2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1140f8ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x112fa91c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x112fa9bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x114140cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x114140e1e] 1-11
  Thread 0x7f63dc           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112dd8374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1180d5f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1151b44c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1125ee4fd] 1-11
  Thread 0x7f63dd           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63df           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x113231eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x113231f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11407ae33] 1-11
  Thread 0x7f63e0           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x11427e2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1152db3f1] 1-11
  Thread 0x7f63e2           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63e3           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f63e4           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f64ca           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f64cb           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f64cc           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f64cd           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7f64ce           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x83064b           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9fb2b           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113231e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113231efd] 1-11
  Binary Images:
           0x10aafb000 -        0x10ab2bfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x112328000 -        0x11ce3dfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)                         <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         Google Chrome Helper (Renderer) [29888] [unique pid 129480]
UUID:            4C4C44A9-5555-3144-A132-36D8EA20CB02
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
Architecture:    x86_64
UID:             504
Footprint:       312.07 MB
Start time:      2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
Num samples:     11 (1-11)
  Thread 0x7ffc4d           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10310490c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1031630b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10534b47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10489b367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10494682f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1049472f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x104f30ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x103de11c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x103de1bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x104f78cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x104f78e1e] 1-11
  Thread 0x7ffc5c           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x103c10374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x108f0df88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x105fec4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1034264fd] 1-11
  Thread 0x7ffc5d           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0x7ffc5f           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x104069eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x104069f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x104eb2e33] 1-11
  Thread 0x7ffc61           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1050b62f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1061133f1] 1-11
  Thread 0x7ffc62           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7ffc64           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x7ffc65           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x800f3d           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x800f3e           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x800f3f           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x800f40           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x800f41           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x802374           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0698           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x104069e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x104069efd] 1-11
  Binary Images:
           0x103103000 -        0x103133fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x103160000 -        0x10dc75fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70)                        <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         Google Chrome Helper (Renderer) [34828] [unique pid 134420]
UID:             504
Footprint:       405.33 MB
CPU Time:        <0.001s (1121.4K cycles, 263.1K instructions, 4.26c/i)
  Thread 0x853862           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (755.7K cycles, 165.2K instructions, 4.58c/i)
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x108a6a90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x11177c0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11396447f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x112eb4367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x112f5f82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x112f602f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x113549ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1123fa1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1123fabf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x113591cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x113591e1e] 1-11
                              11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
                                11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0x85387a           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x117526f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1146054c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x111a3f4fd] 1-11
  Thread 0x85387b           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1136cf2f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x1145feeb8] 1-11
  Thread 0x85387e           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x11472c3f1] 1-11
  Thread 0x853880           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853881           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853882           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x112682eba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1126831dd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1134cbe33] 1-11
  Thread 0x853887           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853888           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853889           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85388a           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85388b           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85398c           Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853c1e           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x854550           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x112682eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x112682f2d] 1-11
  Thread 0x858470           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85848d           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85848e           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85849d           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9ab4b           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x112682e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x112682efd] 1-11
  Binary Images:
           0x108a69000 -        0x108a99fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x111779000 -        0x11c28efff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)                     <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                                        <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         Google Chrome Helper (Renderer) [34829] [unique pid 134421]
UID:             504
Footprint:       47.85 MB
Note:            1 idle work queue thread omitted
  Thread 0x853886           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x109c4490c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10b7f90b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10d9e147f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10cf31367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10cfdc82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10cfdd2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10d5c6ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10c4771c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10c477bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10d60ecd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10d60ee1e] 1-11
                            11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Thread 0x853894           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c2a6374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1115a3f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10e6824c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10babc4fd] 1-11
  Thread 0x853895           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853897           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10c6ffeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10c6fff2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d548e33] 1-11
  Thread 0x853898           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10d74c2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10e7a93f1] 1-11
  Thread 0x85389a           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85389b           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x85389c           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538c1           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538c2           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538c3           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538c4           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538c5           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853c1f           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa87321           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10c6ffe82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10c6ffefd] 1-11
  Binary Images:
           0x109c43000 -        0x109c73fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10b7f6000 -        0x11630bfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                                     <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         Google Chrome Helper (Renderer) [34831] [unique pid 134423]
UID:             504
Footprint:       64.18 MB
  Thread 0x8538c0           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10290190c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x102bce0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x104db647f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x104306367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1043b182f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1043b22f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10499bef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10384c1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10384cbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1049e3cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1049e3e1e] 1-11
  Thread 0x8538d6           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10367b374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x108978f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x105a574c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x102e914fd] 1-11
  Thread 0x8538d7           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538d9           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x103ad4eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x103ad4f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10491de33] 1-11
  Thread 0x8538da           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x104b212f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x105b7e3f1] 1-11
  Thread 0x8538dc           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538df           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8538e0           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853a84           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853a85           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853a86           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853a87           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853a88           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853aa3           Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x853c20           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa7c1c5           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10391b914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x105a38d7e] 1-11
  Thread 0xa9fb25           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x103ad4e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x103ad4efd] 1-11
  Binary Images:
           0x102900000 -        0x102930fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x102bcb000 -        0x10d6e0fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [35669] [unique pid 135261]
UID:             504
Footprint:       126.52 MB
  Thread 0x861576           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a41e90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10f9600b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x111b4847f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x111098367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11114382f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1111442f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x11172def0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1105de1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1105debf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x111775cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x111775e1e] 1-11
  Thread 0x861589           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11040d374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11570af88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1127e94c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fc234fd] 1-11
  Thread 0x86158a           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x86158c           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x110866eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x110866f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1116afe33] 1-11
  Thread 0x86158d           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1118b32f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1129103f1] 1-11
  Thread 0x86158f           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x861590           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x861591           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x861720           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
  Thread 0x861721           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x861722           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x861723           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x861724           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8623ed           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa069c           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x110866e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x110866efd] 1-11
  Binary Images:
           0x10a41d000 -        0x10a44dfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10f95d000 -        0x11a472fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                         <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                               <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         Google Chrome Helper (Renderer) [35813] [unique pid 135405]
UID:             504
Footprint:       259.60 MB
  Thread 0x868bc1           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x104ed290c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10a8250b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10ca0d47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10bf5d367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10c00882f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10c0092f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10c5f2ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10b4a31c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10b4a3bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10c63acd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10c63ae1e] 1-11
  Thread 0x868bce           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b2d2374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1105cff88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10d6ae4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10aae84fd] 1-11
  Thread 0x868bcf           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x868bd1           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10b72beab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10b72bf2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c574e33] 1-11
  Thread 0x868bd2           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10c7782f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10d7d53f1] 1-11
  Thread 0x868bd4           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x868bd5           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x868bd6           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x869739           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0x86973a           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x86973b           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x86973c           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x86973d           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x86a673           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa8e13d           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10b72be82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10b72befd] 1-11
  Binary Images:
           0x104ed1000 -        0x104f01fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10a822000 -        0x115337fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [36177] [unique pid 135769]
UID:             504
Footprint:       300.11 MB
CPU Time:        <0.001s (1171.1K cycles, 249.6K instructions, 4.69c/i)
  Thread 0x87c39d           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (663.9K cycles, 142.7K instructions, 4.65c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10159290c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c6240b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e80c47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10dd5c367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10de0782f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10de082f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10e3f1ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d2a21c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d2a2bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e439cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e439e1e] 1-11
  Thread 0x87c3b2           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1123cef88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f4ad4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 1-11
  Thread 0x87c3b3           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e5772f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10f4a6eb8] 1-11
  Thread 0x87c3b5           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d52aeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d52af2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e373e33] 1-11
  Thread 0x87c3b6           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (90.4K cycles, 21.3K instructions, 4.24c/i)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f5d43f1] 1-11
  Thread 0x87c3b9           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87c3bb           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87c3bc           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10d52aeba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10d52b1dd] 1-11
  Thread 0x87c3bf           Thread name "WebCrypto"   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x10e577598] 1-11
                  11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10f48ed7e] 1-11
  Thread 0x87c401           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87c402           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87c403           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87c404           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87c405           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x87cddf           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9e820           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d52ae82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d52aefd] 1-11
  Thread 0xa9fd55           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (78.9K cycles, 14.4K instructions, 5.49c/i)
  <IO tier 0>
              10  ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10e373555] 1-10
                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-10
                 *10  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-10
              1   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e373e33] 11
                1   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 11
                  1   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 11
                   *1   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 11
  Binary Images:
           0x101591000 -        0x1015c1fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10c621000 -        0x117136fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [43546] [unique pid 143135]
UID:             504
Footprint:       254.25 MB
CPU Time:        <0.001s (1164.6K cycles, 264.1K instructions, 4.41c/i)
  Thread 0x8d4bb9           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (740.6K cycles, 155.1K instructions, 4.77c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10e9e090c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x11642d0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11861547f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x117b65367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x117c1082f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x117c112f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1181faef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1170ab1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1170abbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x118242cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x118242e1e] 1-11
  Thread 0x8d4bcd           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11c1d7f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1192b64c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1166f04fd] 1-11
  Thread 0x8d4bce           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
  Thread 0x8d4bd0           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x117333eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x117333f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11817ce33] 1-11
  Thread 0x8d4bd1           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1183802f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1193dd3f1] 1-11
  Thread 0x8d4bd3           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4bd5           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x11717a914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x119297d7e] 1-11
  Thread 0x8d4bd6           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4cc6           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4cc7           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4cc8           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4cc9           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4cca           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d4d0d           Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x8d5787           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9f6b4           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x117333e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x117333efd] 1-11
  Thread 0xaa0880           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
              11  ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x11817bbab] 1-11
                11  ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1166f0149] 1-11
  Binary Images:
           0x10e9df000 -        0x10ea0ffff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x11642a000 -        0x120f3ffff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [53802] [unique pid 153387]
UID:             504
Footprint:       101.90 MB
  Thread 0x9139c2           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x101f3b90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x101f9a0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10418247f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1036d2367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10377d82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10377e2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x103d67ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x102c181c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x102c18bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x103dafcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x103dafe1e] 1-11
  Thread 0x9139d7           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x102a47374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x107d44f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x104e234c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10225d4fd] 1-11
  Thread 0x9139d8           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9139da           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x102ea0eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x102ea0f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x103ce9e33] 1-11
  Thread 0x9139db           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x103eed2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x104f4a3f1] 1-11
  Thread 0x9139de           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9139e0           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9139e1           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x913a89           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x913a8a           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x913a8b           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x913a8c           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x913a8d           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x913d1e           Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x91479c           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa92695           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x102ea0e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x102ea0efd] 1-11
  Binary Images:
           0x101f3a000 -        0x101f6afff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x101f97000 -        0x10caacfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [55592] [unique pid 155177]
Parent:          Google Chrome [721]
Responsible:     Google Chrome [721]
UID:             504
Footprint:       460.44 MB
CPU Time:        <0.001s (1152.0K cycles, 257.3K instructions, 4.48c/i)
Note:            2 idle work queue threads omitted
  Thread 0x932fd9           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (770.5K cycles, 155.1K instructions, 4.97c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1094cf90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10952e0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10b71647f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ac66367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10ad1182f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10ad122f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10b2fbef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10a1ac1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10a1acbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10b343cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10b343e1e] 1-11
  Thread 0x932fec           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10f2d8f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10c3b74c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1097f14fd] 1-11
  Thread 0x932fed           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x932fef           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10a434eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10a434f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10b27de33] 1-11
  Thread 0x932ff0           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10b4812f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10c4de3f1] 1-11
  Thread 0x932ff2           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x932ff3           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10a27b914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10c398d7e] 1-11
  Thread 0x932ff4           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x93300b           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x11181f037] 1-11
            11  ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x1098c8f6d] 1-11
  Thread 0x93300c           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x93300d           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x93300e           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x93300f           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x933054           Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x933bbf           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9f8aa           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10a434e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10a434efd] 1-11
  Thread 0xaa087f           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
              11  ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x10b27cbab] 1-11
                11  ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1097f1149] 1-11
  Binary Images:
           0x1094ce000 -        0x1094fefff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10952b000 -        0x114040fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [56287] [unique pid 155872]
UID:             504
Footprint:       93.56 MB
CPU Time:        <0.001s (333.0K cycles, 89.6K instructions, 3.71c/i)
  Thread 0x9587c4           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (227.8K cycles, 58.9K instructions, 3.87c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1042ac90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10430b0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1064f347f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x105a43367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x105aee82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x105aef2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1060d8ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x104f891c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x104f89bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x106120cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x106120e1e] 1-11
  Thread 0x9587d4           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x104db8374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10a0b5f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1071944c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1045ce4fd] 1-11
  Thread 0x9587d5           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9587d7           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x105211eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x105211f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10605ae33] 1-11
  Thread 0x9587d8           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10625e2f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1072bb3f1] 1-11
  Thread 0x9587da           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  <truncated backtrace> 1-11
  Thread 0x9587db           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9587dc           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958a9e           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958a9f           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958aa0           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958aa1           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958aa2           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x959e86           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa067f           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x105211e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x105211efd] 1-11
  Binary Images:
           0x1042ab000 -        0x1042dbfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x104308000 -        0x10ee1dfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [56288] [unique pid 155873]
UID:             504
Footprint:       183.12 MB
CPU Time:        <0.001s (824.1K cycles, 216.4K instructions, 3.81c/i)
  Thread 0x958a9d           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (639.1K cycles, 177.1K instructions, 3.61c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10138490c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1072fd0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1094e547f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x108a35367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x108ae082f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x108ae12f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1090caef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109112cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109112e1e] 1-11
                          11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
  Thread 0x958aae           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10d0a7f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10a1864c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11
  Thread 0x958aaf           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958ab1           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x108203eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x108203f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10904ce33] 1-11
                  11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
  Thread 0x958ab2           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1092502f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10a2ad3f1] 1-11
  Thread 0x958ab4           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x958ab5           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10804a914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a167d7e] 1-11
  Thread 0x958ab6           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x96271e           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
          11  ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x10f5ee037] 1-11
            11  ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x107697f6d] 1-11
  Thread 0x96271f           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x962720           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x962721           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x962722           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x963f0d           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
     *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0x99cd5a           Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x108203eba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1082041dd] 1-11
  Thread 0xa8dfcd           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9d6d4           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa07ca           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108203e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108203efd] 1-11
  Thread 0xaa07cb           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa07ce           Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x101383000 -        0x1013b3fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1072fa000 -        0x111e0ffff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [56437] [unique pid 156022]
UID:             504
Footprint:       83.28 MB
  Thread 0x96271d           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a42f90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10a48e0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10c67647f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10bbc6367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10bc7182f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10bc722f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10c25bef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10b10c1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10b10cbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10c2a3cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10c2a3e1e] 1-11
  Thread 0x962728           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10af3b374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x110238f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10d3174c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a7514fd] 1-11
  Thread 0x962729           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x96272b           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10b394eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10b394f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c1dde33] 1-11
  Thread 0x96272d           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10c3e12f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10d43e3f1] 1-11
  Thread 0x96272e           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x96272f           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x962730           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x96b2ca           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703e2           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703e3           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703e4           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703e5           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703e6           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9366b           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10b394e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10b394efd] 1-11
  Binary Images:
           0x10a42e000 -        0x10a45efff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10a48b000 -        0x114fa0fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)                         <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         Google Chrome Helper (Renderer) [56647] [unique pid 156232]
UUID:            4C4C44A9-5555-3144-A132-36D8EA20CB02
Path:            /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
Architecture:    x86_64
UID:             504
Footprint:       90.66 MB
Start time:      2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
Num samples:     11 (1-11)
  Thread 0x9703df           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a75190c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1116010b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1137e947f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x112d39367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x112de482f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x112de52f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1133ceef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11227f1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11227fbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x113416cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x113416e1e] 1-11
  Thread 0x9703f4           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1173abf88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11448a4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1118c44fd] 1-11
  Thread 0x9703f5           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1135542f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x114483eb8] 1-11
                   *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0x9703f7           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x112507eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x112507f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x113350e33] 1-11
  Thread 0x9703f8           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1145b13f1] 1-11
  Thread 0x9703fa           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703fc           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x9703fd           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x112507eba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1125081dd] 1-11
  Thread 0x9aa8b4           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa02514           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa02515           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa02516           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa02517           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa02518           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa9ff39           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x112507e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x112507efd] 1-11
  Binary Images:
           0x10a750000 -        0x10a780fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1115fe000 -        0x11c113fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70)                        <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         Google Chrome Helper (Renderer) [62957] [unique pid 162540]
UID:             504
Footprint:       194.76 MB
CPU Time:        <0.001s (3.1M cycles, 1029.3K instructions, 2.99c/i)
  Thread 0xa4cc9c           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (669.1K cycles, 155.2K instructions, 4.31c/i)
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10d76e90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10defd0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1100e547f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10f635367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10f6e082f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10f6e12f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10fccaef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eb7b1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eb7bbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10fd12cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10fd12e1e] 1-11
                              11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
                                11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0xa4ccab           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x113ca7f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x110d864c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11
  Thread 0xa4ccac           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4ccae           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10ee03eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10ee03f2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fc4ce33] 1-11
  Thread 0xa4ccaf           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (332.8K cycles, 85.5K instructions, 3.89c/i)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10fe502f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x110ead3f1] 1-11
  Thread 0xa4ccb1           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4ccbb           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10ec4a914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x110d67d7e] 1-11
  Thread 0xa4ccbc           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10ee03eba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10ee041dd] 1-11
  Thread 0xa4ce77           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4ce78           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4ce79           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4ce7a           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4ce7b           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4cec9           Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa4e187           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x10fe50598] 1-11
  Thread 0xa9f299           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10ee03e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10ee03efd] 1-11
  Thread 0xaa064b           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa091c           Thread name "ServiceWorker thread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (1700.9K cycles, 673.5K instructions, 2.53c/i)
  <IO tier 0>
  Binary Images:
           0x10d76d000 -        0x10d79dfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10defa000 -        0x118a0ffff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405)                     <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                                        <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         Google Chrome Helper (Renderer) [66140] [unique pid 165723]
UID:             504
Footprint:       482.62 MB
CPU Time:        0.009s (41.4M cycles, 34.7M instructions, 1.19c/i)
Note:            1 idle work queue thread omitted
  Thread 0xa74570           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time 0.008s (37.2M cycles, 33.4M instructions, 1.11c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10f1f990c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x10f2580b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11144047f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x110990367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x110a3b82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x110a3c2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111025ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x11106dcd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x11106de1e] 1-11
                            11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Thread 0xa7457c           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115002f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1120e14c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11
  Thread 0xa7457d           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1111ab2f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x1120daeb8] 1-11
  Thread 0xa7457f           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x11015eeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x11015ef2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11
  Thread 0xa74580           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (1789.5K cycles, 539.2K instructions, 3.32c/i)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1122083f1] 1-11
  Thread 0xa74582           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1111ab598] 1-11
                  11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1120c2d7e] 1-11
  Thread 0xa74583           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10ffa5914] 1-11
  Thread 0xa74584           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x11015eeba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x11015f1dd] 1-11
  Thread 0xa7459a           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117549037] 1-11
            11  ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10f5f2f6d] 1-11
  Thread 0xa7459b           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa7459c           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa7459d           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa7459e           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa745e7           Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa75470           Thread name "MemoryInfra" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa7b2ca           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11
  Thread 0xa7eba4           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0932           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0933           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (1590.6K cycles, 642.6K instructions, 2.48c/i)
  <IO tier 0>
              2   ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-2
                2   ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-2
                  2   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-2
                   *2   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-2
              9   ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x110fa7555] 3-11
                9   mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 3-11
                 *9   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 3-11
  Thread 0xaa0934           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0935           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0936           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10f1f8000 -        0x10f228fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x10f255000 -        0x119d6afff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                                     <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         Google Chrome Helper (Renderer) [67230] [unique pid 166813]
UID:             504
Footprint:       36.06 MB
  Thread 0xa935a0           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10150890c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1074040b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1095ec47f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x108b3c367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x108be782f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x108be82f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1091d1ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1080821c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108082bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109219cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109219e1e] 1-11
  Thread 0xa935af           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10d1aef88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10a28d4c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11
  Thread 0xa935b0           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa935b2           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10830aeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10830af2d] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109153e33] 1-11
  Thread 0xa935b3           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1093572f5] 1-11
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10a3b43f1] 1-11
  Thread 0xa935b5           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa935b6           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xa935b7           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10830aeba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10830b1dd] 1-11
  Thread 0xa935ba           Thread name "ServiceWorker thread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x108151914] 1-11
                11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a26ed7e] 1-11
  Thread 0xa9f263           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10830ae82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10830aefd] 1-11
  Thread 0xa9fb4e           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0938           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
              11  ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x109152bab] 1-11
                11  ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1076c7149] 1-11
  Binary Images:
           0x101507000 -        0x101537fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x107401000 -        0x111f16fff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         Google Chrome Helper (Renderer) [67409] [unique pid 166992]
UID:             504
Footprint:       113.04 MB
CPU Time:        <0.001s (897.5K cycles, 205.8K instructions, 4.36c/i)
  Thread 0xaa0533           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (580.0K cycles, 135.1K instructions, 4.29c/i)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10097e90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1009dd0b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x102bc547f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x102115367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1021c082f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1021c12f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1027aaef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1027f2cd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1027f2e1e] 1-11
  Thread 0xaa0541           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x106787f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1038664c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11
  Thread 0xaa0542           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1029302f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10385feb8] 1-11
  Thread 0xaa0543           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11
  Thread 0xaa0544           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1018e3eab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1018e3f2d] 1-11
  Thread 0xaa0545           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10398d3f1] 1-11
  Thread 0xaa0546           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0547           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x102930598] 1-11
                  11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x103847d7e] 1-11
  Thread 0xaa0548           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10172a914] 1-11
  Thread 0xaa0549           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x1018e3eba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1018e41dd] 1-11
  Thread 0xaa076c           Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x108cce037] 1-11
            11  ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x100d77f6d] 1-11
              11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
  Thread 0xaa076d           Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa076e           Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa076f           Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0770           Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
               *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0xaa0794           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0795           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0796           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa07a5           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa07a6           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa09cc           Thread name "ServiceWorker thread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10097d000 -        0x1009adfff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1009da000 -        0x10b4effff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                         <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                               <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         Google Chrome Helper (Renderer) [67410] [unique pid 166993]
UID:             504
Footprint:       17.32 MB
  Thread 0xaa076b           DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10915a90c] 1-11
      11  ChromeMain + 453 (Google Chrome Framework + 12469) [0x1091b90b5] 1-11
        11  ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10b3a147f] 1-11
          11  ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10a8f1367] 1-11
            11  ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10a99c82f] 1-11
              11  ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10a99d2f5] 1-11
                11  ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10af86ef0] 1-11
                  11  ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x109e371c4] 1-11
                    11  ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109e37bf6] 1-11
                      11  ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10afcecd4] 1-11
                        11  ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10afcee1e] 1-11
  Thread 0xaa0777           Thread name "HangWatcher" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11
          11  ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10ef63f88] 1-11
            11  ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10c0424c7] 1-11
              11  ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11
  Thread 0xaa0778           Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10b10c2f5] 1-11
            11  ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10c03beb8] 1-11
  Thread 0xaa0779           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10a0bfe82] 1-11
            11  ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10a0bfefd] 1-11
              11  ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10af08e33] 1-11
  Thread 0xaa077a           Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10a0bfeab] 1-11
            11  ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10a0bff2d] 1-11
  Thread 0xaa077b           Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10c1693f1] 1-11
  Thread 0xaa077d           Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x10b10c598] 1-11
                  11  ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10c023d7e] 1-11
  Thread 0xaa077e           Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x109f06914] 1-11
  Thread 0xaa077f           Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10a0bfeba] 1-11
            11  ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10a0c01dd] 1-11
              11  ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x10af07bab] 1-11
                11  ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x10947c149] 1-11
  Binary Images:
           0x109159000 -        0x109189fff  com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer)
           0x1091b6000 -        0x113ccbfff  com.google.Chrome.framework 108.0.5359.124 (5359.124)       <4C4C4475-5555-3144-A123-1586F8E96E56>  /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework
Process:         GSSCred [248]
UUID:            6C0101E1-3D7A-3EBC-9C9A-1E99785A9E97
Path:            /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
Parent:          launchd [1]
UID:             0
Sudden Term:     Tracked (allows idle exit)
Footprint:       864 KB
  Thread 0x73b              11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
    11  __read_nocancel + 10 (libsystem_kernel.dylib + 8634) [0x7fff60fd11ba] 1-11
     *11  hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11
       *11  unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11
         *11  read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11
           *11  ??? (kernel + 7270151) [0xffffff80008eef07] 1-11
             *11  ??? (kernel + 4319092) [0xffffff800061e774] 1-11
               *11  spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11
                 *11  ??? (kernel + 6732104) [0xffffff800086b948] 1-11
                   *11  ??? (kernel + 7168269) [0xffffff80008d610d] 1-11
                     *11  lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11
                       *11  thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11
                         *11  ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11
                           *11  machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11
  Thread 0x73d              11 samples (1-11)         priority 20 (base 20)
  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
    11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11
     *11  ??? (kernel + 7168864) [0xffffff80008d6360] 1-11
  Binary Images:
           0x104e27000 -        0x104e2efff  GSSCred (520.270.8)                  <6C0101E1-3D7A-3EBC-9C9A-1E99785A9E97>  /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
Process:         helpd [61016] [unique pid 160599]
UUID:            C6A58A15-0037-3B3D-B0C3-B72275B8BCCE
Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
Parent:          launchd [1]
UID:             504
Footprint:       1252 KB
  Thread 0xa223fa           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x10bb8d000 -        0x10bba3fff  helpd                                <C6A58A15-0037-3B3D-B0C3-B72275B8BCCE>  /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
Process:         hidd [109]
UUID:            44A8BE5C-4536-36D0-BA5B-E63674BACEC1
Path:            /usr/libexec/hidd
Parent:          launchd [1]
UID:             261
Footprint:       3956 KB
CPU Time:        0.003s (12.4M cycles, 3.0M instructions, 4.10c/i)
  Thread 0x350              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (761.0K cycles, 308.8K instructions, 2.46c/i)
  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
    11  ??? (hidd + 3707) [0x10b6dde7b] 1-11
      11  CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11
  Thread 0x377              Thread name "IOHIDService - RunLoopCompatibilityThread"                       11 samples (1-11)         priority 63 (base 63)
  <process sudden termination clean, IO tier 0>
  Thread 0xaa093b           11 samples (1-11)         priority 63 (base 63)     cpu time 0.001s (6.2M cycles, 1764.3K instructions, 3.53c/i)
        11  _dispatch_worker_thread + 317 (libdispatch.dylib + 70141) [0x7fff60e5c1fd] 1-11
          11  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11
            11  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11
             *11  semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11
  Thread 0xaa0aaa           11 samples (1-11)         priority 63 (base 63)
  Binary Images:
           0x10b6dd000 -        0x10b6ddfff  hidd (1090.270.7)                       <44A8BE5C-4536-36D0-BA5B-E63674BACEC1>  /usr/libexec/hidd
        0x7fff60e4b000 -     0x7fff60e84fff  libdispatch.dylib (1008.270.1)          <97273678-E94C-3C8C-89F6-2E2020F4B43B>  /usr/lib/system/libdispatch.dylib
Process:         icdd [415]
UUID:            41A04085-D015-3C46-9A05-D8FC965CB04E
Path:            /System/Library/Image Capture/Support/icdd
Parent:          launchd [1]
UID:             504
Footprint:       6800 KB
  Thread 0xe71              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0>
  Binary Images:
           0x10253f000 -        0x10256efff  icdd (1534.2)                        <41A04085-D015-3C46-9A05-D8FC965CB04E>  /System/Library/Image Capture/Support/icdd
Process:         iconservicesagent [293]
UUID:            420F1282-060C-39EB-A7D6-811DF569A396
Path:            /System/Library/CoreServices/iconservicesagent
Parent:          launchd [1]
UID:             504
Footprint:       20.11 MB
CPU Time:        <0.001s (397.7K cycles, 105.2K instructions, 3.78c/i)
  Thread 0x87e              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x102f16000 -        0x102f20fff  iconservicesagent                    <420F1282-060C-39EB-A7D6-811DF569A396>  /System/Library/CoreServices/iconservicesagent
Process:         iconservicesagent [467]
Parent:          launchd [1]
UID:             0
Footprint:       3732 KB
  Thread 0x1264             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c7d4000 -        0x10c7defff  iconservicesagent                    <420F1282-060C-39EB-A7D6-811DF569A396>  /System/Library/CoreServices/iconservicesagent
Process:         iconservicesd [76]
UUID:            75B2D7C4-6817-3480-B918-B3DE935AFB2C
Path:            /System/Library/CoreServices/iconservicesd
Parent:          launchd [1]
UID:             240
Footprint:       2728 KB
  Thread 0x63e              DispatchQueue 11          11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x108c24000 -        0x108c27fff  iconservicesd                        <75B2D7C4-6817-3480-B918-B3DE935AFB2C>  /System/Library/CoreServices/iconservicesd
Process:         identityservicesd [298]
UUID:            07ED13B5-6D42-3B16-9DB1-1779485312B5
Path:            /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Parent:          launchd [1]
UID:             504
Footprint:       11.46 MB
  Thread 0x88c              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
    11  main + 299 (identityservicesd + 422411) [0x10dd3620b] 1-11
      11  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11
  Thread 0x8f1              Thread name "TransportThread Primary"               11 samples (1-11)         priority 31 (base 31)
    11  kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11
  Thread 0x8f2              Thread name "TransportThread URGENT"                11 samples (1-11)         priority 31 (base 31)
  Thread 0x8f3              Thread name "TransportThread Default"               11 samples (1-11)         priority 31 (base 31)
  Thread 0x8f4              Thread name "TransportThread Sync"                  11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10dccf000 -        0x10e194fff  com.apple.identityservicesd 10.0 (1000) <07ED13B5-6D42-3B16-9DB1-1779485312B5>  /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Process:         imagent [299]
UUID:            A38E8E09-3273-3AC5-9479-F1EC3EBBA71D
Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Parent:          launchd [1]
UID:             504
Footprint:       3896 KB
  Thread 0x89f              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10b891000 -        0x10b8f1fff  com.apple.imagent 10.0 (1000)        <A38E8E09-3273-3AC5-9479-F1EC3EBBA71D>  /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Process:         IMAutomaticHistoryDeletionAgent [4392]
UUID:            7CC6C869-9E8D-33C3-8EE2-CF3D0A794CA9
Path:            /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
Parent:          launchd [1]
UID:             504
Footprint:       2520 KB
  Thread 0x5372c            11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
  Binary Images:
           0x108d47000 -        0x108d49fff  IMAutomaticHistoryDeletionAgent      <7CC6C869-9E8D-33C3-8EE2-CF3D0A794CA9>  /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
Process:         IMDPersistenceAgent [303]
UUID:            F025E7EE-121F-3FAD-AC0D-6A14F0DD95C5
Path:            /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Parent:          launchd [1]
UID:             504
Footprint:       3396 KB
  Thread 0x8bc              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10ec45000 -        0x10ec46fff  com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000) <F025E7EE-121F-3FAD-AC0D-6A14F0DD95C5>  /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Process:         imklaunchagent [354]
UUID:            0DEB181A-D95C-3FB2-926D-5ECE7C36F322
Path:            /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Parent:          launchd [1]
UID:             504
Footprint:       3140 KB
  Thread 0xaf5              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
    11  ??? (imklaunchagent + 26159) [0x1048bc62f] 1-11
  Binary Images:
           0x1048b6000 -        0x1048c2fff  imklaunchagent (365.26)                 <0DEB181A-D95C-3FB2-926D-5ECE7C36F322>  /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Process:         IMRemoteURLConnectionAgent [399]
UUID:            8026AD1F-C961-3EC6-8EC9-677A5DB83984
Path:            /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Parent:          launchd [1]
Responsible:     callservicesd [296]
UID:             504
Footprint:       1096 KB
  Thread 0xded              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1062c9000 -        0x1062d3fff  com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984>  /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process:         IMRemoteURLConnectionAgent [42202]
Parent:          launchd [1]
Responsible:     avconferenced [42201]
UID:             504
Footprint:       3036 KB
  Thread 0x35e776           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
  Thread 0x35e77a           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10c53e000 -        0x10c548fff  com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984>  /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process:         IMRemoteURLConnectionAgent [44143]
Parent:          launchd [1]
Responsible:     imagent [299]
UID:             504
Footprint:       3596 KB
  Thread 0x3b29d1           11 samples (1-11)         priority 4 (base 4)
  Thread 0x3b29fb           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10df43000 -        0x10df4dfff  com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984>  /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process:         IMRemoteURLConnectionAgent [44144]
Parent:          launchd [1]
Responsible:     identityservicesd [298]
UID:             504
Footprint:       4160 KB
  Thread 0x3b29d6           11 samples (1-11)         priority 4 (base 4)
    11  ??? (IMRemoteURLConnectionAgent + 7212) [0x10a9bcc2c] 1-11
      11  xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11
        11  _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11
  Thread 0x3b29fc           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10a9bb000 -        0x10a9c5fff  com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984>  /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
        0x7fff610c3000 -     0x7fff610f2fff  libxpc.dylib (1336.261.7)                                     <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8>  /usr/lib/system/libxpc.dylib
Process:         installd [798]
UUID:            F019E35E-BE11-3F3F-8A55-42254D1B0677
Path:            /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Parent:          launchd [1]
UID:             0
Footprint:       1536 KB
  Thread 0x3f58             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1040e3000 -        0x1040e4fff  installd                             <F019E35E-BE11-3F3F-8A55-42254D1B0677>  /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Process:         iTunes [8660] [unique pid 108275]
UUID:            91006EE5-C8C4-3A53-B7F7-69A3B2FD991A
Path:            /Applications/iTunes.app/Contents/MacOS/iTunes
Parent:          launchd [1]
UID:             504
Footprint:       167.69 MB
CPU Time:        <0.001s (537.3K cycles, 121.9K instructions, 4.41c/i)
Note:            4 idle work queue threads omitted
  Thread 0x5ffc77           DispatchQueue 1           Thread name "iTunes main" 11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2>
    11  ??? (iTunes + 16106610) [0x103fbd472] 1-11
      11  -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11
        11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11
          11  _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11
            11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11
              11  ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11
                11  RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11
  Thread 0x5ffc8b           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0x5ffcc3           Thread name "CFRunLoopThread"                       11 samples (1-11)         priority 4 (base 4)
  <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2>
        11  ??? (iTunes + 24547263) [0x1047c9fbf] 1-11
          11  ??? (iTunes + 24542979) [0x1047c8f03] 1-11
  Thread 0x5ffd2c           Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 4 (base 4)
        11  __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11
  Thread 0x5ffd2d           Thread name "CoreAudioNotificationThread"           11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffd67           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (122.4K cycles, 27.7K instructions, 4.41c/i)
        11  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11
          11  bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11
            4   bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-4
              4   void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-4
                4   std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-4
                  4   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-4
                   *4   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-4
            7   bmalloc::Scavenger::threadRunLoop() + 262 (JavaScriptCore + 2260422) [0x7fff38405dc6] 5-11
              7   std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 95 (JavaScriptCore + 2265343) [0x7fff384070ff] 5-11
                7   std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117 (JavaScriptCore + 2265653) [0x7fff38407235] 5-11
                  7   std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 5-11
                    7   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 5-11
                     *7   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11
  Thread 0x5ffda7           Thread name "AudioDeviceManager - Client Command Processor Thread"            11 samples (1-11)         priority 4 (base 4)
  <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2>
          11  ??? (iTunes + 24536992) [0x1047c77a0] 1-11
            11  ??? (iTunes + 24403101) [0x1047a6c9d] 1-11
              11  ??? (iTunes + 24402596) [0x1047a6aa4] 1-11
                11  ??? (iTunes + 24411369) [0x1047a8ce9] 1-11
  Thread 0x5ffda8           Thread name "AFCVolumeNotificationThread"           11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffdac           Thread name "AVOutputDeviceManager - Client Command Processor Thread"         11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffdd2           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
        11  _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11
  Thread 0x5ffddb           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffe6b           Thread name "iCloud Music Library - Client Command Processor Thread"          11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffe6c           Thread name "iTunes Store Purchases - Client Command Processor Thread"        11 samples (1-11)         priority 4 (base 4)
  Thread 0x5ffe8c           Thread name "com.apple.coreanimation.render-server" 11 samples (1-11)         priority 4 (base 4)
  <process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0x5fff6e           Thread name "Sharing Artwork Manager Worker Thread" 11 samples (1-11)         priority 4 (base 4)
  11  <truncated backtrace> 1-11
  Thread 0x600160           11 samples (1-11)         priority 4 (base 4)
        11  ??? (CoreFP + 2847931) [0x1096664bb] 1-11
          11  sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11
            11  __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11
  Thread 0x600233           Thread name "CFRunLoopThread (Download)"            11 samples (1-11)         priority 4 (base 4)
  Thread 0x7ca1ad           11 samples (1-11)         priority 4 (base 4)
  Thread 0xa228ed           Thread name "iCloud Music LibraryAssetDL - Client Command Processor Thread"   11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x103061000 -        0x104d8bfff  com.apple.iTunes 12.9.5 (12.9.5)           <91006EE5-C8C4-3A53-B7F7-69A3B2FD991A>  /Applications/iTunes.app/Contents/MacOS/iTunes
           0x1093af000 -        0x10a89bfff  com.apple.CoreFP 2.13.61 (2.13.61)         <17D97459-6C26-3299-BCEB-1327CF36C4A2>  /System/Library/PrivateFrameworks/CoreFP.framework/CoreFP
        0x7fff324e2000 -     0x7fff33297fff  com.apple.AppKit 6.9 (1671.60.112)         <4AFB032C-2786-3AD7-8EDA-576956992A9C>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff3415a000 -     0x7fff34451fff  com.apple.HIToolbox 2.1.1 (918.7)          <88D7F19C-8C9D-384B-BAB5-8205CA282F2C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff381de000 -     0x7fff3903efff  com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff5e0c2000 -     0x7fff5e115fff  libc++.1.dylib (400.9.4)                   <9A60A190-6C34-339F-BB3D-AACE942009A4>  /usr/lib/libc++.1.dylib
        0x7fff60ee5000 -     0x7fff60f6cfff  libsystem_c.dylib (1272.250.3)             <6016EDA1-440B-34D7-A232-686CD7FBEE90>  /usr/lib/system/libsystem_c.dylib
Process:         kdc [99]
UUID:            028121B0-16D5-334F-B9F3-87362BD23627
Path:            /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Parent:          launchd [1]
UID:             0
Footprint:       3616 KB
  Thread 0x6c0              11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x10ba32000 -        0x10ba64fff  kdc                                  <028121B0-16D5-334F-B9F3-87362BD23627>  /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Process:         KernelEventAgent [105]
UUID:            A770FF79-5B99-3A4E-815D-4ED9D6C862BA
Path:            /usr/sbin/KernelEventAgent
Parent:          launchd [1]
UID:             0
Footprint:       944 KB
  Thread 0x27b              11 samples (1-11)         priority 31 (base 31)
  Thread 0x28b              Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x106607000 -        0x10660cfff  KernelEventAgent                     <A770FF79-5B99-3A4E-815D-4ED9D6C862BA>  /usr/sbin/KernelEventAgent
Process:         kextd [54]
UUID:            AC0D8B5E-1319-3F3D-9A21-44E33FC3F002
Path:            /usr/libexec/kextd
Parent:          launchd [1]
UID:             0
Footprint:       21.57 MB
  Thread 0x253              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x108e99000 -        0x108ebefff  kextd (528.250.4)                    <AC0D8B5E-1319-3F3D-9A21-44E33FC3F002>  /usr/libexec/kextd
Process:         keybagd [69]
UUID:            C9DD550F-1084-3895-B8E4-BC31DA94B3BB
Path:            /usr/libexec/keybagd
Parent:          launchd [1]
UID:             0
Footprint:       888 KB
  Thread 0x261              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x105606000 -        0x10562afff  keybagd                              <C9DD550F-1084-3895-B8E4-BC31DA94B3BB>  /usr/libexec/keybagd
Process:         keyboardservicesd [670]
UUID:            40536557-2424-30D3-B3FC-78AEE701AAA6
Path:            /usr/libexec/keyboardservicesd
Parent:          launchd [1]
UID:             504
Footprint:       7444 KB
CPU Time:        <0.001s (110.0K cycles, 28.6K instructions, 3.84c/i)
  Thread 0x1e2c             DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x101bce000 -        0x101bcefff  keyboardservicesd (99.15)            <40536557-2424-30D3-B3FC-78AEE701AAA6>  /usr/libexec/keyboardservicesd
Process:         knowledge-agent [422]
UUID:            19D9BAB0-38C7-394D-8331-5C747A6039CC
Path:            /usr/libexec/knowledge-agent
Parent:          launchd [1]
UID:             504
Footprint:       6572 KB
  Thread 0xe86              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10038d000 -        0x100394fff  knowledge-agent                      <19D9BAB0-38C7-394D-8331-5C747A6039CC>  /usr/libexec/knowledge-agent
Process:         launchd [1]
UUID:            8E81517F-114F-3276-9F42-11E387EAFB81
Path:            /sbin/launchd
Parent:          kernel_task [0]
UID:             0
Footprint:       23.70 MB
Note:            2 idle work queue threads omitted
  Thread 0x194              DispatchQueue 11          11 samples (1-11)         priority 31 (base 31)
  11  _dispatch_sig_thread + 53 (libdispatch.dylib + 77534) [0x7fff60e5dede] 1-11
  Binary Images:
           0x10e59c000 -                ???  launchd                              <8E81517F-114F-3276-9F42-11E387EAFB81>  /sbin/launchd
Process:         launchservicesd [87]
UUID:            792A3E4F-9072-3897-A01A-17F34CF0751D
Path:            /System/Library/CoreServices/launchservicesd
Parent:          launchd [1]
UID:             0
Footprint:       19.12 MB
CPU Time:        <0.001s (1236.8K cycles, 629.5K instructions, 1.96c/i)
  Thread 0x3e2              DispatchQueue 11          11 samples (1-11)         priority 4-31 (base 4-31)
  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2, priority 4 (4)>
     *10  ??? (kernel + 7168864) [0xffffff80008d6360] 1-10
  <thread QoS default, process unclamped, thread not darwinbg, process not darwinbg, process received importance donation from Dock [274], IO tier 0, priority 31 (31)>
     *1   ??? (kernel + 7168864) [0xffffff80008d6360] 11
  Thread 0xa9fe44           1 sample (11)             priority 37 (base 37)     cpu time <0.001s (467.1K cycles, 200.5K instructions, 2.33c/i)
  <Thread in another stack for 10 samples, thread QoS user initiated (requested user initiated, requested override user initiated), process unclamped, process received importance donation from Dock [274], IO tier 0>
  1  ??? [0x111200000005] 11
    1  start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 11
      1  __workq_kernreturn + 10 (libsystem_kernel.dylib + 11258) [0x7fff60fd1bfa] 11
       *1  hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 11
         *1  unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 11
           *1  workq_kernreturn + 2446 (kernel + 6776974) [0xffffff800087688e] 11
             *1  ??? (kernel + 6757610) [0xffffff8000871cea] (running) 11
  Thread 0xaa0ace           1 sample (11)             priority 37 (base 37)     cpu time <0.001s (618.5K cycles, 380.5K instructions, 1.63c/i)
  <Thread in another stack for 10 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process unclamped, process received importance donation from Dock [274], IO tier 0>
  1  ??? [0x7c00001112] 11
       *1  call_continuation + 46 (kernel + 1417422) [0xffffff800035a0ce] 11
         *1  ??? (kernel + 6756799) [0xffffff80008719bf] 11
           *1  ??? (kernel + 6757992) [0xffffff8000871e68] 11
             *1  ??? (kernel + 6760238) [0xffffff800087272e] 11
               *1  workq_setup_thread + 380 (pthread + 6593) [0xffffff7f82d939c1] 11
                 *1  workq_kevent + 132 (pthread + 6792) [0xffffff7f82d93a88] 11
                   *1  kevent_id_internal + 55 (kernel + 6980215) [0xffffff80008a8277] 11
                     *1  ??? (kernel + 6965794) [0xffffff80008a4a22] 11
                       *1  kqueue_scan + 77 (kernel + 6972957) [0xffffff80008a661d] 11
                         *1  ??? (kernel + 6977259) [0xffffff80008a76eb] 11
                           *1  ??? (kernel + 6972842) [0xffffff80008a65aa] 11
                             *1  ??? (kernel + 6951044) [0xffffff80008a1084] 11
                               *1  _bcopy + 11 (kernel + 1416683) [0xffffff8000359deb] (running) 11
  Binary Images:
           0x1030e5000 -        0x1030eefff  launchservicesd                      <792A3E4F-9072-3897-A01A-17F34CF0751D>  /System/Library/CoreServices/launchservicesd
Process:         locationd [93]
UUID:            B8F4AC31-17CD-3FF0-A2B6-1C5C17631E79
Path:            /usr/libexec/locationd
Parent:          launchd [1]
UID:             205
Footprint:       8472 KB
  Thread 0x404              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
        11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
         *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Binary Images:
           0x107aa2000 -        0x107f3afff  locationd (2245.16.14)                  <B8F4AC31-17CD-3FF0-A2B6-1C5C17631E79>  /usr/libexec/locationd
Process:         logd [68]
UUID:            47327F38-4CDF-31C7-A817-B14B211B2199
Path:            /usr/libexec/logd
Parent:          launchd [1]
UID:             0
Footprint:       38.32 MB
CPU Time:        <0.001s (247.5K cycles, 55.3K instructions, 4.48c/i)
Note:            3 idle work queue threads omitted
  Thread 0x2a9              DispatchQueue 11          11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x107094000 -        0x1070b5fff  logd                                 <47327F38-4CDF-31C7-A817-B14B211B2199>  /usr/libexec/logd
Process:         logind [103]
UUID:            D1BEC1E4-E071-323E-A458-209E318B794C
Path:            /System/Library/CoreServices/logind
Parent:          launchd [1]
UID:             0
Footprint:       1428 KB
  Thread 0x277              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x102217000 -        0x10222dfff  logind (100)                         <D1BEC1E4-E071-323E-A458-209E318B794C>  /System/Library/CoreServices/logind
Process:         loginitemregisterd [705]
UUID:            8060E0DE-ABCC-3EEC-93B1-BA36110DE7E7
Path:            /usr/libexec/loginitemregisterd
Parent:          launchd [1]
UID:             504
Footprint:       1388 KB
  Thread 0x2b68             11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x10ca1a000 -        0x10ca1bfff  loginitemregisterd                   <8060E0DE-ABCC-3EEC-93B1-BA36110DE7E7>  /usr/libexec/loginitemregisterd
Process:         LoginUserService [350]
UUID:            85BE5FD0-D500-32D6-944D-D6EEA072D0AF
Path:            /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService
Parent:          launchd [1]
Responsible:     SystemUIServer [275]
UID:             504
Footprint:       948 KB
  Thread 0xaaa              11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x1005e3000 -        0x1005e5fff  LoginUserService                     <85BE5FD0-D500-32D6-944D-D6EEA072D0AF>  /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService
Process:         loginwindow [102]
UUID:            6266338C-6F6C-32A1-8C75-A6E00DA259F3
Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Parent:          launchd [1]
UID:             504
Footprint:       40.06 MB
CPU Time:        <0.001s (72.9K cycles, 27.2K instructions, 2.68c/i)
  Thread 0x271              DispatchQueue 1           11 samples (1-11)         priority 47 (base 47)
  <thread QoS user interactive (requested user interactive), IO tier 0>
    11  ??? (loginwindow + 24144) [0x10ddcae50] 1-11
  Binary Images:
           0x10ddc5000 -        0x10deb3fff  com.apple.loginwindow 9.0 (1932.7.2)    <6266338C-6F6C-32A1-8C75-A6E00DA259F3>  /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Process:         lsd [176]
UUID:            5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74
Path:            /usr/libexec/lsd
Parent:          launchd [1]
UID:             0
Footprint:       15.14 MB
  Thread 0x3bc              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10fec1000 -        0x10fec1fff  lsd                                  <5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74>  /usr/libexec/lsd
Process:         lsd [276]
Parent:          launchd [1]
UID:             504
Footprint:       8832 KB
  Thread 0x7d4              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x106252000 -        0x106252fff  lsd                                  <5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74>  /usr/libexec/lsd
Process:         lsd [937]
Parent:          launchd [1]
UID:             501
Footprint:       1896 KB
  Thread 0xb1a8             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10baf6000 -        0x10baf6fff  lsd                                  <5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74>  /usr/libexec/lsd
Process:         Mail [98166]
UUID:            F994B41C-3868-3B50-9A05-B4FA72788739
Path:            /Applications/Mail.app/Contents/MacOS/Mail
Parent:          launchd [1]
UID:             504
Footprint:       154.77 MB
CPU Time:        <0.001s (628.2K cycles, 193.8K instructions, 3.24c/i)
  Thread 0x587f3e           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2>
    11  NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11
  Thread 0x587f85           Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (268.4K cycles, 109.5K instructions, 2.45c/i)
  <thread QoS user initiated (requested user initiated), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2>
  11  thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11
    11  _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11
      11  _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11
            2   bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-2
              2   void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-2
                2   std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-2
                  2   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-2
                   *2   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-2
            2   bmalloc::Scavenger::threadRunLoop() + 262 (JavaScriptCore + 2260422) [0x7fff38405dc6] 3-4
              2   std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 95 (JavaScriptCore + 2265343) [0x7fff384070ff] 3-4
                2   std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117 (JavaScriptCore + 2265653) [0x7fff38407235] 3-4
                  2   std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 3-4
                    2   __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 3-4
                     *2   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 3-4
            7   bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 5-11
              7   void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 5-11
                7   std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 5-11
  Thread 0x587fe7           Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Thread 0x588126           Thread name "com.apple.coreanimation.render-server" 11 samples (1-11)         priority 4 (base 4)
  <process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0x58817c           Thread name "com.apple.CFNetwork.CustomProtocols"   11 samples (1-11)         priority 4 (base 4)
  <thread QoS default (requested default), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2>
  Thread 0x9e31da           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10f8a9000 -        0x10fc58fff  Mail                                       <F994B41C-3868-3B50-9A05-B4FA72788739>  /Applications/Mail.app/Contents/MacOS/Mail
Process:         mapspushd [2903]
UUID:            4B8E71BB-547B-366C-8FAB-173C5977BD0B
Path:            /System/Library/CoreServices/mapspushd
Architecture:    x86_64
Parent:          launchd [1]
UID:             504
Footprint:       11.01 MB
Start time:      2022-12-30 22:13:30 -0800
End time:        2022-12-30 22:13:31 -0800
Num samples:     11 (1-11)
  Thread 0x45765            11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x104631000 -        0x10464ffff  mapspushd                               <4B8E71BB-547B-366C-8FAB-173C5977BD0B>  /System/Library/CoreServices/mapspushd
Process:         mDNSResponder [189]
UUID:            6E56C00A-5128-3E80-8B3E-F1213081DF13
Path:            /usr/sbin/mDNSResponder
Parent:          launchd [1]
UID:             65
Footprint:       5364 KB
  Thread 0x3fc              11 samples (1-11)         priority 31 (base 31)
  Thread 0x412              11 samples (1-11)         priority 31 (base 31)
         *11  ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11
  Thread 0x504e21           Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 31 (base 31)
  Thread 0x504e26           Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x1003ff000 -        0x1004a2fff  mDNSResponder (878.270.3)            <6E56C00A-5128-3E80-8B3E-F1213081DF13>  /usr/sbin/mDNSResponder
Process:         mDNSResponderHelper [190]
UUID:            255FA049-A136-3B25-A153-6E10E681E006
Path:            /usr/sbin/mDNSResponderHelper
Parent:          launchd [1]
UID:             0
Footprint:       1732 KB
CPU Time:        <0.001s (83.5K cycles, 17.2K instructions, 4.87c/i)
  Thread 0x40c              11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (83.5K cycles, 17.2K instructions, 4.87c/i)
        11  idletimer + 72 (mDNSResponderHelper + 30125) [0x10d4f75ad] 1-11
  Thread 0x40d              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10d4f0000 -        0x10d4fcfff  mDNSResponderHelper (878.270.3)      <255FA049-A136-3B25-A153-6E10E681E006>  /usr/sbin/mDNSResponderHelper
        0x7fff60fcf000 -     0x7fff60ff7fff  libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743>  /usr/lib/system/libsystem_kernel.dylib
Process:         mds [75]
UUID:            95FEB9D4-E067-37DE-A86D-B84A96F94EE0
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
Parent:          launchd [1]
UID:             0
Footprint:       122.10 MB
CPU Time:        <0.001s (512.2K cycles, 114.9K instructions, 4.46c/i)
  Thread 0x264              11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), IO tier 0 and passive>
  Thread 0x51b              11 samples (1-11)         priority 50 (base 50)     cpu time <0.001s (88.2K cycles, 14.7K instructions, 5.98c/i)
  <IO tier 0 and passive>
        11  read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11
                 *11  ??? (kernel + 4405643) [0xffffff800063398b] 1-11
                   *11  ??? (kernel + 7168593) [0xffffff80008d6251] 1-11
  Thread 0x76d              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x102c76000 -        0x102e0afff  mds (1191.59)                        <95FEB9D4-E067-37DE-A86D-B84A96F94EE0>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
Process:         mds_stores [251]
UUID:            8D62948F-3F1E-3441-B94E-1C4DCD8E0018
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Parent:          launchd [1]
UID:             0
Footprint:       207.01 MB
  Thread 0x745              DispatchQueue 1           11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process sudden termination dirty, IO tier 0 and passive>
  11  start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11
    11  ??? (mds_stores + 12259) [0x104a92fe3] 1-11
        11  __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11
          11  __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11
  Thread 0x74e              11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x104a90000 -        0x104ad1fff  mds_stores (1191.59)                    <8D62948F-3F1E-3441-B94E-1C4DCD8E0018>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Process:         mdworker_shared [67342] [unique pid 166925]
UUID:            EB02EF4C-A825-3EAE-81D8-30198EFEC09F
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared
Parent:          launchd [1]
UID:             504
Footprint:       13.69 MB
  Thread 0xa9cec4           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
    11  ??? (mdworker_shared + 37345) [0x102f6f1e1] 1-11
  Thread 0xa9ced0           11 samples (1-11)         priority 4 (base 4)
  <thread QoS maintenance (requested maintenance), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3>
        11  ??? (mdworker_shared + 45374) [0x102f7113e] 1-11
          11  ??? (mdworker_shared + 59363) [0x102f747e3] 1-11
  Thread 0xa9ced2           11 samples (1-11)         priority 4 (base 4)
        11  ??? (mdworker_shared + 117140) [0x102f82994] 1-11
  Binary Images:
           0x102f66000 -        0x102fb5fff  mdworker_shared (1191.59)               <EB02EF4C-A825-3EAE-81D8-30198EFEC09F>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared
Process:         mdworker_shared [67360] [unique pid 166943]
Parent:          launchd [1]
UID:             504
Footprint:       11.94 MB
  Thread 0xa9f38d           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (mdworker_shared + 37345) [0x10044a1e1] 1-11
  Thread 0xa9f395           11 samples (1-11)         priority 4 (base 4)
        11  ??? (mdworker_shared + 45374) [0x10044c13e] 1-11
          11  ??? (mdworker_shared + 59363) [0x10044f7e3] 1-11
  Thread 0xa9f398           11 samples (1-11)         priority 4 (base 4)
        11  ??? (mdworker_shared + 117140) [0x10045d994] 1-11
  Binary Images:
           0x100441000 -        0x100490fff  mdworker_shared (1191.59)               <EB02EF4C-A825-3EAE-81D8-30198EFEC09F>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared
Process:         mdworker_shared [67363] [unique pid 166946]
Parent:          launchd [1]
UID:             504
Footprint:       19.20 MB
  Thread 0xa9f3f9           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (mdworker_shared + 37345) [0x10f6631e1] 1-11
  Thread 0xa9f3fd           11 samples (1-11)         priority 4 (base 4)
        11  ??? (mdworker_shared + 45374) [0x10f66513e] 1-11
          11  ??? (mdworker_shared + 59363) [0x10f6687e3] 1-11
  Thread 0xa9f3fe           11 samples (1-11)         priority 4 (base 4)
        11  ??? (mdworker_shared + 117140) [0x10f676994] 1-11
  Binary Images:
           0x10f65a000 -        0x10f6a9fff  mdworker_shared (1191.59)               <EB02EF4C-A825-3EAE-81D8-30198EFEC09F>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared
Process:         mdworker_shared [67416] [unique pid 166999]
Parent:          launchd [1]
UID:             89
Footprint:       3276 KB
  Thread 0xaa0905           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  ??? (mdworker_shared + 37345) [0x108ccf1e1] 1-11
  Thread 0xaa090b           11 samples (1-11)         priority 4 (base 4)
        11  ??? (mdworker_shared + 45374) [0x108cd113e] 1-11
          11  ??? (mdworker_shared + 59363) [0x108cd47e3] 1-11
  Binary Images:
           0x108cc6000 -        0x108d15fff  mdworker_shared (1191.59)               <EB02EF4C-A825-3EAE-81D8-30198EFEC09F>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared
Process:         mdwrite [694]
UUID:            682C97DD-90FA-3EAE-9C93-26009EC55056
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
Parent:          launchd [1]
UID:             504
Footprint:       2700 KB
  Thread 0x267a             11 samples (1-11)         priority 20 (base 20)
  Binary Images:
           0x1047d9000 -        0x1047ebfff  mdwrite                              <682C97DD-90FA-3EAE-9C93-26009EC55056>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
   *0xffffff8000200000 - 0xffffff8000bfffff  kernel (4903.278.70)                 <041B6A6D-CD16-36FA-88B9-E32FF46EF89F>  /System/Library/Kernels/kernel
Process:         media-indexer [490]
UUID:            E3D3B060-22D1-3719-AF76-C59E0A6F651E
Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
Parent:          launchd [1]
Responsible:     assistantd [404]
UID:             504
Footprint:       55.81 MB
Note:            1 idle work queue thread omitted
  Thread 0x14f8             11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x107e09000 -        0x107e13fff  media-indexer                        <E3D3B060-22D1-3719-AF76-C59E0A6F651E>  /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
Process:         mediaremoted [57]
UUID:            EE689C22-C7FC-368C-8CC2-9EC8BCA54261
Path:            /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Parent:          launchd [1]
UID:             0
Footprint:       4112 KB
  Thread 0x258              DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
    11  main + 445 (mediaremoted + 309869) [0x10e78aa6d] 1-11
        11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11
          11  CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11
  Binary Images:
           0x10e73f000 -        0x10e82cfff  mediaremoted (4016.700.1)               <EE689C22-C7FC-368C-8CC2-9EC8BCA54261>  /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
        0x7fff34ecc000 -     0x7fff35312fff  com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff37154000 -     0x7fff37502fff  com.apple.Foundation 6.9 (1575.405)     <9FA71865-7713-3F53-91E7-5DCEBCF4F83D>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         Microsoft Excel [1251]
UUID:            F95C3997-A9A0-3920-BBC7-1DA91090A6DE
Path:            /Applications/Microsoft Excel.app/Contents/MacOS/Microsoft Excel
Parent:          launchd [1]
UID:             504
Footprint:       255.77 MB
CPU Time:        0.012s (51.8M cycles, 16.4M instructions, 3.16c/i)
  Thread 0x1bbae            DispatchQueue 1           11 samples (1-11)         priority 4-46 (base 4-46) cpu time 0.007s (29.1M cycles, 10.1M instructions, 2.89c/i)
  <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0, priority 46 (46)>
                         *3   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3
  <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)>
                         *1   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4
  <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)>
                         *7   ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11
  Thread 0x1bca7            DispatchQueue 10          11 samples (1-11)         priority 4 (base 4)
  <thread QoS background (requested background), process unclamped, thread darwinbg, IO tier 2>
  11  start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11
    11  _pthread_wqthread + 583 (libsystem_pthread.dylib + 9907) [0x7fff6108e6b3] 1-11
      11  _dispatch_worker_thread2 + 90 (libdispatch.dylib + 72518) [0x7fff60e5cb46] 1-11
        11  _dispatch_root_queue_drain + 324 (libdispatch.dylib + 70588) [0x7fff60e5c3bc] 1-11
          11  _dispatch_queue_override_invoke + 763 (libdispatch.dylib + 23123) [0x7fff60e50a53] 1-11
            11  _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11
              11  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11
                11  ??? (WLMKernel + 20022) [0x11a1f0e36] 1-11
                  11  ??? (mso20 + 16314) [0x1130a8fba] 1-11
                    11  Mso::Async::InvokeInCallbackContext(Mso::Functor<void ()>&&, Mso::Async::IDispatchQueue*, Mso::Async::Details::IIdleDispatchQueue*, bool) + 151 (mso20 + 16530) [0x1130a9092] 1-11
                      11  ??? (mso20 + 264761) [0x1130e5a39] 1-11
                        11  ??? (mso30 + 200414) [0x1137a3ede] 1-11
                          11  ??? (mso30 + 200526) [0x1137a3f4e] 1-11
                            11  ??? (mso30 + 201153) [0x1137a41c1] 1-11
                              11  ??? (MicrosoftCSI + 142119) [0x111235b27] 1-11
                                11  Mso::Synchronization::MsoWaitForMultipleObjects(unsigned int, void* const*, bool, MsoTimeoutInterval const&, bool, bool) + 359 (mso20 + 341138) [0x1130f8492] 1-11
                                  11  ??? (mso20 + 364873) [0x1130fe149] 1-11
                                    11  ??? (WLMKernel + 41423) [0x11a1f61cf] 1-11
                                      11  ??? (WLMKernel + 41615) [0x11a1f628f] 1-11
                                        11  ??? (WLMKernel + 42585) [0x11a1f6659] 1-11
                                          11  ??? (WLMKernel + 57210) [0x11a1f9f7a] 1-11
                                            11  MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x112e354c2] 1-11
                                              11  MBUCondition::WaitForDuration(unsigned int) + 25 (mbukernel + 58637) [0x112e3550d] 1-11
                                                 *3   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3
  <process clamped, process suppressed, timers tier 5 (throttled)>
                                                 *1   psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4
  <process unclamped, process unsuppressed, timers tier 0 (normal)>
  Thread 0x1bc41            11 samples (1-11)         priority 4-37 (base 4-37)
  <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0, priority 37 (37)>
  <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 37 (37)>
  Thread 0x1bc43            11 samples (1-11)         priority 4-31 (base 4-31) cpu time <0.001s (27.2K cycles, 5.4K instructions, 5.02c/i)
  <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)>
        11  ??? (merp + 39972) [0x112ef4c24] 1-11
  <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)>
  Thread 0x1bc45            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc47            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc48            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc49            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc4a            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc4b            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc4c            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc4d            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc4e            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0x1bc56            11 samples (1-11)         priority 4 (base 4)
  Thread 0x1bc57            11 samples (1-11)         priority 4-37 (base 4-37)
  Thread 0x1bcb4            Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4-46 (base 4-46) cpu time 0.004s (17.4M cycles, 5.1M instructions, 3.43c/i)
  Thread 0x1bcdd            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4-31 (base 4-31)
        11  __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11
          11  -[__CoreSchedulingSetRunnable runForever] + 210 (CFNetwork + 314940) [0x7fff33deae3c] 1-11
  Thread 0x1bcf9            11 samples (1-11)         priority 4-31 (base 4-31) cpu time <0.001s (89.5K cycles, 17.3K instructions, 5.18c/i)
        11  ??? (mso20 + 2177272) [0x1132b88f8] 1-11
          11  ??? (mso20 + 2170488) [0x1132b6e78] 1-11
            11  ??? (mso20 + 2170001) [0x1132b6c91] 1-11
              11  WaitForSingleObjectEx + 35 (WLMKernel + 48256) [0x11a1f7c80] 1-11
                          11  MBUCondition::WaitForDuration(unsigned int) + 85 (mbukernel + 58697) [0x112e35549] 1-11
  Thread 0x1bcfa            11 samples (1-11)         priority 4-31 (base 4-31) cpu time <0.001s (82.7K cycles, 19.4K instructions, 4.27c/i)
  Thread 0x1bd0c            11 samples (1-11)         priority 4-31 (base 4-31)
  Thread 0xf8f62            11 samples (1-11)         priority 4-37 (base 4-37)
  Thread 0xf9060            Thread name "com.facebook.react.JavaScript"         11 samples (1-11)         priority 4-46 (base 4-46)
  Thread 0xf9061            Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4-37 (base 4-37)
  Binary Images:
           0x10cc55000 -                ???  Microsoft Excel                                <F95C3997-A9A0-3920-BBC7-1DA91090A6DE>  /Applications/Microsoft Excel.app/Contents/MacOS/Microsoft Excel
           0x111213000 -        0x111d76fff  com.microsoft.csi 16.54 (16.54.21101001)       <7E7BA304-03EB-3E0A-9F77-D070EA4B736C>  /Applications/Microsoft Outlook.app/Contents/Frameworks/MicrosoftCSI.framework/Versions/A/MicrosoftCSI
           0x112e27000 -        0x112e9afff  com.microsoft.mbukernel 16.54 (16.54.21101001) <6F64D620-0598-32E7-8519-B8F0D1CEC374>  /Applications/Microsoft Outlook.app/Contents/Frameworks/mbukernel.framework/Versions/A/mbukernel
           0x112eeb000 -        0x112f02fff  com.microsoft.merp 16.54 (16.54.21101001)      <B8DF2092-F9C5-3E24-ADFE-797453982157>  /Applications/Microsoft Outlook.app/Contents/Frameworks/merp.framework/Versions/A/merp
           0x1130a5000 -        0x11362cfff  com.microsoft.mso20 16.54 (16.54.21101001)     <45FA0676-7958-3751-82CA-1C2825CF6985>  /Applications/Microsoft Outlook.app/Contents/Frameworks/mso20.framework/Versions/A/mso20
           0x113773000 -        0x1142c2fff  com.microsoft.mso30 16.54 (16.54.21101001)     <6BFCC7A8-7B3A-3849-8377-55A61492A1D2>  /Applications/Microsoft Outlook.app/Contents/Frameworks/mso30.framework/Versions/A/mso30
           0x11a1ec000 -        0x11a25bfff  com.microsoft.wlmkernel 16.54 (16.54.21101001) <33E466A0-59B7-38CB-BDED-195E68C6305A>  /Applications/Microsoft Outlook.app/Contents/Frameworks/WLMKernel.framework/Versions/A/WLMKernel
        0x7fff33d9e000 -     0x7fff34140fff  com.apple.CFNetwork 978.6 (978.6)              <F6AC3859-B6F9-3212-A357-54AA096DAA9E>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff60e85000 -     0x7fff60eb1fff  libdyld.dylib (655.1.1)                        <002418CC-AD11-3D10-865B-015591D24E6C>  /usr/lib/system/libdyld.dylib
Process:         Microsoft Outlook [4828]
UUID:            129B1EA8-6D54-3106-BDD5-8151AFFDDE1A
Path:            /Applications/Microsoft Outlook.app/Contents/MacOS/Microsoft Outlook
Parent:          launchd [1]
UID:             504
Footprint:       1211.37 MB
CPU Time:        <0.001s (2.4M cycles, 1100.1K instructions, 2.16c/i)
Note:            5 idle work queue threads omitted
  Thread 0x5623c            DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (1837.5K cycles, 943.8K instructions, 1.95c/i)
  <thread QoS user interactive (requested user interactive), process suppressed, timers tier 4 (throttled), IO tier 2>
        11  ??? (Microsoft Outlook + 32969) [0x10fcaf0c9] 1-11
  Thread 0x56334            DispatchQueue 10          11 samples (1-11)         priority 4 (base 4)
  <thread QoS user initiated (requested user initiated), process suppressed, timers tier 4 (throttled), IO tier 2>
  Thread 0x5634f            DispatchQueue 10          11 samples (1-11)         priority 4 (base 4)
  Thread 0x56382            DispatchQueue 10          11 samples (1-11)         priority 4 (base 4)
  Thread 0xa315c3           DispatchQueue 936         11 samples (1-11)         priority 4 (base 4)
  <thread QoS user initiated (requested user initiated, ipc override user initiated), process suppressed, timers tier 4 (throttled), IO tier 2>
    11  _pthread_wqthread + 421 (libsystem_pthread.dylib + 9745) [0x7fff6108e611] 1-11
      11  _dispatch_workloop_worker_thread + 598 (libdispatch.dylib + 75501) [0x7fff60e5d6ed] 1-11
        11  _dispatch_lane_invoke + 385 (libdispatch.dylib + 41878) [0x7fff60e55396] 1-11
          11  _dispatch_lane_serial_drain + 602 (libdispatch.dylib + 39136) [0x7fff60e548e0] 1-11
                11  ??? (WLMKernel + 20022) [0x11b93ee36] 1-11
                  11  ??? (OutlookCore + 165976) [0x117418858] 1-11
                    11  CCommandQueue::ExecuteCommand(std::__1::shared_ptr<CCommand>) + 174 (OutlookCore + 163666) [0x117417f52] 1-11
                      11  CExchangeHangingNotificationMgr::Command::Threaded_StreamingEvents() + 1346 (Microsoft Outlook + 9484296) [0x1105b2808] 1-11
                        11  CExchangeHangingNotificationMgr::Command::GetStreamingEvent(std::__1::shared_ptr<EWS::CBaseResponseStreamObj>&, unsigned int) + 250 (Microsoft Outlook + 9479546) [0x1105b157a] 1-11
                          11  EWS::CBaseResponseStreamObj::NextResponse(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 475 (OutlookCore + 2335873) [0x11762a481] 1-11
                            11  EWS::CBaseResponseStreamObj::WaitForEvent(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 196 (OutlookCore + 2335298) [0x11762a242] 1-11
                              11  ??? (OutlookCore + 2339256) [0x11762b1b8] 1-11
                                11  std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 1-11
  Thread 0x562ef            11 samples (1-11)         priority 4 (base 4)       cpu time <0.001s (27.0K cycles, 5.2K instructions, 5.22c/i)
  <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2>
        11  ??? (merp + 39972) [0x1152d3c24] 1-11
  Thread 0x5635c            Thread name "com.apple.NSEventThread"               11 samples (1-11)         priority 4 (base 4)
  Thread 0x56370            Thread name "com.apple.NSURLConnectionLoader"       11 samples (1-11)         priority 4 (base 4)
  Thread 0x56374            11 samples (1-11)         priority 4 (base 4)
  11  ??? [0x1ffea500000001] 1-11
                        11  Service::Outlook::CServiceOutlookStreamingNotificationMgr::Command::Threaded_StreamingEvents() + 922 (Microsoft Outlook + 12846894) [0x1108e772e] 1-11
                          11  Service::Outlook::CServiceOutlookStreamingNotificationMgr::Command::GetStreamingEvent(std::__1::shared_ptr<REST::CRestResponseStreamObj>&, unsigned int) + 43 (Microsoft Outlook + 12845833) [0x1108e7309] 1-11
                            11  REST::CRestResponseStreamObj::NextResponse(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 832 (Microsoft Outlook + 984458) [0x10fd9758a] 1-11
                              11  REST::CRestResponseStreamObj::WaitForEvent(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 195 (Microsoft Outlook + 983525) [0x10fd971e5] 1-11
                                11  ??? (Microsoft Outlook + 9297126) [0x110584ce6] 1-11
  Thread 0x56386            Thread name "JavaScriptCore bmalloc scavenger"      11 samples (1-11)         priority 4 (base 4)
            11  bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11
              11  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11
                11  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11
  Thread 0x5638d            Thread name "com.facebook.react.JavaScript"         11 samples (1-11)         priority 4 (base 4)
          11  ??? (mso40ui + 436153) [0x11682c7b9] 1-11
  Thread 0x563ba            Thread name "com.apple.CFNetwork.CustomProtocols"   11 samples (1-11)         priority 4 (base 4)
  Thread 0x563ff            11 samples (1-11)         priority 4 (base 4)
  Thread 0x56461            Thread name "com.facebook.react.JavaScript"         11 samples (1-11)         priority 4 (base 4)
  Thread 0x56532            11 samples (1-11)         priority 4 (base 4)
        11  ??? (mso20 + 4293599) [0x1157703df] 1-11
          11  ??? (mso20 + 708254) [0x115404e9e] 1-11
            11  ??? (mso20 + 708798) [0x1154050be] 1-11
              11  ??? (mso20 + 1398862) [0x1154ad84e] 1-11
  Thread 0x152b24           Thread name "com.squareup.SocketRocket.NetworkThread"                         11 samples (1-11)         priority 4 (base 4)
  Thread 0x152b2c           Thread name "com.apple.CFSocket.private"            11 samples (1-11)         priority 4 (base 4)
  Thread 0xa97b3a           11 samples (1-11)         priority 4 (base 4)
        11  ??? (OutlookCore + 3399595) [0x11772dfab] 1-11
          11  Network::Http::CHttpMessage::SendInternal(std::__1::shared_ptr<Network::Http::CHttpRequest>, std::__1::shared_ptr<Network::Http::IHttpDataStream>, unsigned long, bool, std::__1::shared_ptr<Network::Http::IHttpDataStream>) + 163 (OutlookCore + 3274527) [0x11770f71f] 1-11
            11  ??? (mso20 + 690388) [0x1154008d4] 1-11
              11  ??? (mso20 + 2713733) [0x1155ee885] 1-11
                11  ??? (mbukernel + 74618) [0x11521a37a] 1-11
                  11  ??? (mbukernel + 51554) [0x115214962] 1-11
                    11  ??? (mbukernel + 58444) [0x11521644c] 1-11
                        11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11
                         *11  psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11
  Thread 0xa98369           11 samples (1-11)         priority 4 (base 4)
  Binary Images:
           0x10fca7000 -        0x11137afff  com.microsoft.Outlook 16.54 (16.54.21101001)                <129B1EA8-6D54-3106-BDD5-8151AFFDDE1A>  /Applications/Microsoft Outlook.app/Contents/MacOS/Microsoft Outlook
           0x115208000 -        0x11527bfff  com.microsoft.mbukernel 16.54 (16.54.21101001)              <6F64D620-0598-32E7-8519-B8F0D1CEC374>  /Applications/Microsoft Outlook.app/Contents/Frameworks/mbukernel.framework/Versions/A/mbukernel
           0x1152ca000 -        0x1152e1fff  com.microsoft.merp 16.54 (16.54.21101001)                   <B8DF2092-F9C5-3E24-ADFE-797453982157>  /Applications/Microsoft Outlook.app/Contents/Frameworks/merp.framework/Versions/A/merp
           0x115358000 -        0x1158dffff  com.microsoft.mso20 16.54 (16.54.21101001)                  <45FA0676-7958-3751-82CA-1C2825CF6985>  /Applications/Microsoft Outlook.app/Contents/Frameworks/mso20.framework/Versions/A/mso20
           0x1167c2000 -        0x116f3dfff  com.microsoft.mso40ui 16.54 (16.54.21101001)                <53FA5437-82E5-32DE-9160-ECE76034F279>  /Applications/Microsoft Outlook.app/Contents/Frameworks/mso40ui.framework/Versions/A/mso40ui
           0x1173f0000 -        0x1178dffff  com.microsoft.outlook.core.framework 16.54 (16.54.21101001) <628031FB-6A4A-34B5-BCC1-4D146AF116EF>  /Applications/Microsoft Outlook.app/Contents/Frameworks/OutlookCore.framework/Versions/A/OutlookCore
           0x11b93a000 -        0x11b9a9fff  com.microsoft.wlmkernel 16.54 (16.54.21101001)              <33E466A0-59B7-38CB-BDED-195E68C6305A>  /Applications/Microsoft Outlook.app/Contents/Frameworks/WLMKernel.framework/Versions/A/WLMKernel
        0x7fff6108c000 -     0x7fff61096fff  libsystem_pthread.dylib (330.250.2)                         <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7>  /usr/lib/system/libsystem_pthread.dylib
   *0xffffff7f82d92000 - 0xffffff7f82d99fff  com.apple.kec.pthread 1.0 (1)                               <6C7628FE-2621-3C19-B248-D4DA0D722123>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
Process:         Microsoft Teams Helper [843]
UUID:            4C4C4432-5555-3144-A1D1-18CB51E6E4EF
Path:            /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper
Parent:          Teams [836]
Responsible:     Teams [836]
UID:             504
Footprint:       18.50 MB
  Thread 0x61bd             Thread name "CrUtilityMain"                         11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested user interactive), IO tier 0>
  Thread 0x61ef             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11
  Thread 0x61f2             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10e7d5f48] 1-11
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10e7b801d] 1-11
            11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10e7b7e88] 1-11
              11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x10e7655d1] 1-11
                11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x10e79b6ba] 1-11
  Thread 0x61f4             Thread name "NetworkConfigWatcher"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6239             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10e7b164d] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x10e7b1c7d] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10e7e372c] 1-11
  Thread 0x9d9dae           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x10e7b16dd] 1-11
  Binary Images:
           0x10b54c000 -        0x10b571fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4432-5555-3144-A1D1-18CB51E6E4EF>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper
           0x10b583000 -        0x1138cbfff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Microsoft Teams Helper [851]
Parent:          Teams [836]
UID:             504
Footprint:       10.55 MB
  Thread 0x6294             DispatchQueue 1           Thread name "CrUtilityMain"                         11 samples (1-11)         priority 47 (base 47)
  <process frontmost, thread QoS user interactive (requested user interactive), IO tier 0>
  Thread 0x62ac             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <process frontmost, IO tier 0>
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10624bf48] 1-11
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10622e01d] 1-11
            11  _TIFFSwab64BitData + 5241469 (Electron Framework + 52567213) [0x10621acad] 1-11
              11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10622de88] 1-11
                11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1061db5d1] 1-11
                  11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1062116ba] 1-11
  Thread 0x62ad             Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1062276dd] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x106227c7d] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10625972c] 1-11
  Thread 0x62ae             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10622764d] 1-11
  Thread 0x62b0             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x102fbf000 -        0x102fe4fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4432-5555-3144-A1D1-18CB51E6E4EF>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper
           0x102ff9000 -        0x10b341fff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Microsoft Teams Helper (GPU) [841]
UUID:            4C4C4417-5555-3144-A16C-46E835C938B6
Path:            /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (GPU).app/Contents/MacOS/Microsoft Teams Helper (GPU)
Parent:          Teams [836]
UID:             504
Footprint:       521.45 MB
  Thread 0x6195             DispatchQueue 1           Thread name "CrGpuMain"   11 samples (1-11)         priority 31 (base 31)
    11  ??? (Microsoft Teams Helper (GPU) + 2670) [0x10754ca6e] 1-11
      11  ElectronMain + 146 (Electron Framework + 108402) [0x10759b772] 1-11
        11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x108671349] 1-11
          11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x108670a4b] 1-11
            11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x10867204d] 1-11
              11  device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 492644 (Electron Framework + 98494884) [0x10d36f9a4] 1-11
                11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x10a7635d1] 1-11
                  11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x10a7996ba] 1-11
                    11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x10a7d99b2] 1-11
                      11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x10a7dafd9] 1-11
  Thread 0x61fc             Thread name "GpuWatchdog" 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10a7d3f48] 1-11
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10a7b601d] 1-11
            11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10a7b5e88] 1-11
                  11  _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x10a740d3a] 1-11
                    11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10a7e172c] 1-11
  Thread 0x6200             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6201             Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x10a7af6dd] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x10a7afc7d] 1-11
  Thread 0x6202             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10a7af64d] 1-11
  Thread 0x6203             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6205             Thread name "VizCompositorThread"                   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x628c             Thread name "ThreadPoolSingleThreadSharedForeground0"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10754c000 -        0x107571fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4417-5555-3144-A16C-46E835C938B6>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (GPU).app/Contents/MacOS/Microsoft Teams Helper (GPU)
           0x107581000 -        0x10f8c9fff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Microsoft Teams Helper (Renderer) [846]
UUID:            4C4C4481-5555-3144-A13B-0A2785B65108
Path:            /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer)
Parent:          Teams [836]
UID:             504
Footprint:       30.29 MB
  Thread 0x6219             DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)
    11  ??? (Microsoft Teams Helper (Renderer) + 2670) [0x10de71a6e] 1-11
      11  ElectronMain + 146 (Electron Framework + 108402) [0x1118c8772] 1-11
        11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x11299e349] 1-11
          11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x11299da4b] 1-11
            11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x11299f04d] 1-11
              11  device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x11844000f] 1-11
                11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x114a905d1] 1-11
                  11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x114ac66ba] 1-11
                    11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x114b069b2] 1-11
                      11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x114b07fd9] 1-11
  Thread 0x6232             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6234             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x114b00f48] 1-11
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x114adc64d] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x114adcc7d] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x114b0e72c] 1-11
  Thread 0x6235             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x114ae301d] 1-11
            11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x114ae2e88] 1-11
  Thread 0x6236             Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x114adc6dd] 1-11
  Thread 0x6237             Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x623c             Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x623d             Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6242             Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6244             Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6246             Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6248             Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6249             Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6288             Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x4b1ed            Thread name "ThreadPoolSingleThreadSharedForeground1"                         11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Binary Images:
           0x10de71000 -        0x10de96fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer)
           0x1118ae000 -        0x119bf6fff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Microsoft Teams Helper (Renderer) [848]
Parent:          Teams [836]
UID:             504
Footprint:       417.55 MB
CPU Time:        <0.001s (2.1M cycles, 319.2K instructions, 6.68c/i)
  Thread 0x6255             DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (2.1M cycles, 319.2K instructions, 6.68c/i)
    11  ??? (Microsoft Teams Helper (Renderer) + 2670) [0x105b81a6e] 1-11
      11  ElectronMain + 146 (Electron Framework + 108402) [0x105bd5772] 1-11
        11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x106cab349] 1-11
          11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x106caaa4b] 1-11
            11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x106cac04d] 1-11
              11  device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x10c74d00f] 1-11
                11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x108d9d5d1] 1-11
                  11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x108dd36ba] 1-11
                    11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x108e139b2] 1-11
                      11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x108e14fd9] 1-11
  Thread 0x626c             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x626e             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 0 (base 0)
  <IO tier 0>
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x108de964d] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108de9c7d] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11
  Thread 0x626f             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x108df001d] 1-11
            11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x108defe88] 1-11
  Thread 0x6271             Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6276             Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6277             Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6278             Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6279             Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x627a             Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x627b             Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x627c             Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x62c4             Thread name "Watchdog"    11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  electron::fuses::IsOnlyLoadAppFromAsarEnabled() + 59623 (Electron Framework + 2101111) [0x105dbbf77] 1-11
  Thread 0x634c             Thread name "SharedWorker thread"                   11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2620787 (Electron Framework + 34077811) [0x107c3ac73] 1-11
                11  _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x108d7ad3a] 1-11
  Thread 0x63de             Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x6528             Thread name "Media"       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x4bbb4            Thread name "AudioOutputDevice"                     11 samples (1-11)         priority 97 (base 97)
  <IO tier 0>
     *11  hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11
       *11  unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11
         *11  read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11
           *11  ??? (kernel + 7270151) [0xffffff80008eef07] 1-11
             *11  soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11
               *11  sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11
                 *11  msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11
                   *11  ??? (kernel + 7168269) [0xffffff80008d610d] 1-11
                     *11  lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11
                       *11  thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11
                         *11  ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11
                           *11  machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11
  Thread 0xaa0311           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x108de96dd] 1-11
  Thread 0xaa092f           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa0930           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  _TIFFSwab64BitData + 5293588 (Electron Framework + 52619332) [0x108de9844] 1-11
              11  _TIFFSwab64BitData + 5291678 (Electron Framework + 52617422) [0x108de90ce] 1-11
  Binary Images:
           0x105b81000 -        0x105ba6fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer)
           0x105bbb000 -        0x10df03fff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Microsoft Teams Helper (Renderer) [855]
Parent:          Teams [836]
UID:             504
Footprint:       122.05 MB
CPU Time:        <0.001s (552.0K cycles, 117.8K instructions, 4.69c/i)
  Thread 0x638d             DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 46 (base 46)     cpu time <0.001s (304.4K cycles, 52.0K instructions, 5.86c/i)
  <thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
    11  ??? (Microsoft Teams Helper (Renderer) + 2670) [0x10e4f1a6e] 1-11
      11  ElectronMain + 146 (Electron Framework + 108402) [0x110d45772] 1-11
        11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x111e1b349] 1-11
          11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x111e1aa4b] 1-11
            11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x111e1c04d] 1-11
              11  device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x1178bd00f] 1-11
                11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x113f0d5d1] 1-11
                  11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x113f436ba] 1-11
                    11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x113f839b2] 1-11
                      11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x113f84fd9] 1-11
  Thread 0x6395             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <process unclamped, process received importance donation from WindowServer [197], IO tier 0>
  Thread 0x6397             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x113f5964d] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11
  Thread 0x6398             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x113f6001d] 1-11
            11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x113f5fe88] 1-11
  Thread 0x639a             Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  Thread 0x639c             Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  Thread 0x639d             Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  Thread 0x639e             Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  Thread 0x639f             Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
          11  device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14704420 (Electron Framework + 112706660) [0x1178a7464] 1-11
            11  _TIFFSwab64BitData + 5439771 (Electron Framework + 52765515) [0x113f7d34b] 1-11
  Thread 0x63a0             Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  Thread 0x63a1             Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  11  <truncated backtrace> 1-11
  Thread 0x63a2             Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  Thread 0x63a4             11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
        11  ElectronMain + 1482632 (Electron Framework + 1590888) [0x110eaf668] 1-11
          11  __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11
           *11  ??? (kernel + 7168864) [0xffffff80008d6360] 1-11
  Thread 0x63ae             Thread name "Watchdog"    11 samples (1-11)         priority 31 (base 31)
          11  electron::fuses::IsOnlyLoadAppFromAsarEnabled() + 59623 (Electron Framework + 2101111) [0x110f2bf77] 1-11
  Thread 0x64ae             11 samples (1-11)         priority 31 (base 31)
    11  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11
     *11  semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11
  Thread 0x64af             11 samples (1-11)         priority 31 (base 31)
  Thread 0x64b2             11 samples (1-11)         priority 33 (base 33)
        11  ??? (libskypert.dylib + 236557) [0x11c30ec0d] 1-11
          11  ??? (libskypert.dylib + 873540) [0x11c3aa444] 1-11
            11  ??? (libskypert.dylib + 873789) [0x11c3aa53d] 1-11
              11  ??? (libskypert.dylib + 919229) [0x11c3b56bd] 1-11
                11  ??? (libskypert.dylib + 856130) [0x11c3a6042] 1-11
                  11  ??? (slimcore.node + 4809242) [0x11ba2b21a] 1-11
                    11  ??? (slimcore.node + 4844661) [0x11ba33c75] 1-11
                      11  ??? (slimcore.node + 4885937) [0x11ba3ddb1] 1-11
                        11  spl::eventWait(spl::EventGCD*&, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000l> >) + 83 (libskypert.dylib + 202627) [0x11c306783] 1-11
                          11  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11
                            11  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11
  Thread 0x64b3             11 samples (1-11)         priority 47 (base 47)
    11  kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11
  Thread 0x64b4             11 samples (1-11)         priority 47 (base 47)     cpu time <0.001s (91.3K cycles, 15.7K instructions, 5.80c/i)
                  11  ??? (libskypert.dylib + 891947) [0x11c3aec2b] 1-11
                    11  spl::semaWait(spl::EventGCD*&, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000l> >) + 68 (libskypert.dylib + 203044) [0x11c306924] 1-11
  Thread 0x64c5             11 samples (1-11)         priority 31 (base 31)
  Thread 0x64c6             11 samples (1-11)         priority 31 (base 31)
  Thread 0x64c7             11 samples (1-11)         priority 31 (base 31)
  Thread 0x64c8             11 samples (1-11)         priority 97 (base 97)
  Thread 0x64c9             11 samples (1-11)         priority 31 (base 31)
  Thread 0x64da             11 samples (1-11)         priority 97 (base 97)
  Thread 0x64db             11 samples (1-11)         priority 97 (base 97)
  Thread 0x64dc             11 samples (1-11)         priority 31 (base 31)
  Thread 0x4bdcd            11 samples (1-11)         priority 31 (base 31)
  Thread 0x4bdcf            11 samples (1-11)         priority 31 (base 31)
  <thread QoS default (requested default, ipc override default), process unclamped, process received importance donation from WindowServer [197], IO tier 0>
  Thread 0xaa02db           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11
  Thread 0xaa09b0           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  Thread 0xaa09b1           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  Thread 0xaa09b2           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  Thread 0xaa09b3           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  Thread 0xaa09b4           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  Thread 0xaa09b5           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  Binary Images:
           0x10e4f1000 -        0x10e516fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer)
           0x110d2b000 -        0x119073fff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
           0x11b595000 -        0x11c09cfff  slimcore.node (0)                               <B242AE45-7AE1-3851-9B27-1CE8C4AA6464>  /Applications/Microsoft Teams.app/Contents/Resources/app.asar.unpacked/node_modules/slimcore/bin/slimcore.node
           0x11c2d5000 -        0x11c6ccfff  libskypert.dylib (0)                            <ED5FA20C-9486-3165-B580-59068806BEEB>  /Applications/Microsoft Teams.app/Contents/Resources/app.asar.unpacked/node_modules/slimcore/bin/libskypert.dylib
        0x7fff60e4b000 -     0x7fff60e84fff  libdispatch.dylib (1008.270.1)                  <97273678-E94C-3C8C-89F6-2E2020F4B43B>  /usr/lib/system/libdispatch.dylib
Process:         Microsoft Teams Helper (Renderer) [856]
Parent:          Teams [836]
UID:             504
Footprint:       299.17 MB
CPU Time:        <0.001s (236.0K cycles, 42.5K instructions, 5.55c/i)
  Thread 0x649c             DispatchQueue 1           Thread name "CrRendererMain"                        11 samples (1-11)         priority 31 (base 31)     cpu time <0.001s (236.0K cycles, 42.5K instructions, 5.55c/i)
    11  ??? (Microsoft Teams Helper (Renderer) + 2670) [0x1055b4a6e] 1-11
      11  ElectronMain + 146 (Electron Framework + 108402) [0x105604772] 1-11
        11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x1066da349] 1-11
          11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x1066d9a4b] 1-11
            11  cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x1066db04d] 1-11
              11  device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x10c17c00f] 1-11
                11  _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1087cc5d1] 1-11
                  11  _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1088026ba] 1-11
                    11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x1088429b2] 1-11
                      11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x108843fd9] 1-11
  Thread 0x64a0             Thread name "ThreadPoolServiceThread"               11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64a2             Thread name "ThreadPoolBackgroundWorker"            11 samples (1-11)         priority 4 (base 4)
  <IO tier 0>
        11  _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11
          11  _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10881864d] 1-11
            11  _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108818c7d] 1-11
              11  base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10884a72c] 1-11
  Thread 0x64a3             Thread name "Chrome_ChildIOThread"                  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10881f01d] 1-11
            11  _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10881ee88] 1-11
  Thread 0x64a5             Thread name "GpuMemoryThread"                       11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64a6             Thread name "Compositor"  11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
    11  mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11
     *11  ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11
  Thread 0x64a7             Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64a8             Thread name "CompositorTileWorker1"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64a9             Thread name "CompositorTileWorker2"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64aa             Thread name "CompositorTileWorker3"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64ab             Thread name "CompositorTileWorker4"                 11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64ac             Thread name "CompositorTileWorkerBackground"        11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0x64c2             Thread name "DedicatedWorker thread"                11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2620787 (Electron Framework + 34077811) [0x107669c73] 1-11
                11  _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x1087a9d3a] 1-11
  Thread 0xa9fd36           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
          11  _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1088186dd] 1-11
  Thread 0xaa09fd           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
  Thread 0xaa09fe           Thread name "ThreadPoolForegroundWorker"            11 samples (1-11)         priority 31 (base 31)
  <IO tier 0>
            11  _TIFFSwab64BitData + 5293588 (Electron Framework + 52619332) [0x108818844] 1-11
              11  _TIFFSwab64BitData + 5291678 (Electron Framework + 52617422) [0x1088180ce] 1-11
  Binary Images:
           0x1055b4000 -        0x1055d9fff  com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108>  /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer)
           0x1055ea000 -        0x10d932fff  com.github.Electron.framework (16.2.8)          <4C4C4462-5555-3144-A1AC-15EC19C8E608>  /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
Process:         Microsoft Word [76988]
UUID:            8B281AE7-626F-3575-AA9B-2C3471F6CAD3
Path:            /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word
Parent:          launchd [1]
UID:             504
Footprint:       223.73 MB
CPU Time:        <0.001s (445.8K cycles, 82.2K instructions, 5.42c/i)
Note:            3 idle work queue threads omitted
  Thread 0x49c185           DispatchQueue 1           11 samples (1-11)         priority 4 (base 4)
  <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2>
      11  -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11
        11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11
          11  _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11
            11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11
              11  ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11
                11  RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11
  Thread 0x49c293
