Harry Fitzsimmons Posted December 20, 2022 Share Posted December 20, 2022 Infinite lines (similar to autocad's xline) for lining up sections etc Quote Link to comment
0 Pat Stanford Posted December 20, 2022 Share Posted December 20, 2022 Good wish and I will support it. If you only need vertical and horizontal alignment, then you can place a loci and use a script to control (no longer available through the UI) Snap to Loci preference that give you extension lines off of loci. Make a new script of just the one line below. Every time you run the script it will toggle the extension lines on and off. SetPref(5, not getpref(5)); HTH 1 Quote Link to comment
Harry Fitzsimmons
1 answer to this question
