Glen Posted December 19, 2022 Share Posted December 19, 2022 Hi Everyone, I am having an issue where the Section-Elevation Line is correctly showing on the design layer of the plan, but it is not showing on the sheet layer where the view port of the plan is. I decided to create a new file with no new classes and 1 layer to try and troubleshoot this issue. I am getting the same result. I read through the threads that have previously been corrected by changes classes/ using section line instance activation. When I am on the floor plan and use the Section-Elevation Line command to create an elevation on an elevation sheet layer. The Section-Elevation Line instance appears on the design layer correctly. I then create a viewport to a new floor plan sheet layer, and the section-elevation line disappears. I have uploaded the test file which has 1 design layer, and default 2 classes. I have 2 sheet layers: Elevation and Floor Plan Any help on this is appreciated! Glen Bell Mac Studio M1 Max - Mac OS Monterey VW 2022 SP6 VW22SP6Section-ElevationLine.vwx Quote Link to comment
Pat Stanford Posted December 19, 2022 Share Posted December 19, 2022 Select the Viewport. Bottom of the OIP is a button labeled Section Line Instances. From there you can choose which Design Layers and which Viewports the Section Line will show in. Quote Link to comment
Glen Posted December 20, 2022 Author Share Posted December 20, 2022 Thank you Pat. I see the Viewports tab on the line instances dialog. It works now. Total rookie mistake. I had been looking for sheet layers. Thank you for your reply! Quote Link to comment
