CW2020 Posted October 22, 2022 Share Posted October 22, 2022 I have a number of callouts in a file in where the leader line extends underneath the text; see attached. I'm hoping that's a setting I can turnoff on all existing callouts to match the typical/standard leader. Any input is appreciated. CALLOUT.vwx Quote Link to comment
Jesse Cogswell Posted October 22, 2022 Share Posted October 22, 2022 For the callout with the leader line extending under the text, the Bubble Style is currently set to ISO. If you want that to go away, change the Bubble Style to None. You can do this all in one go using the script below: PROCEDURE RemoveISOBubble; {Finds Callout object with Bubble Style ISO and reverts them to Bubble Style None} PROCEDURE RemoveISO(h:HANDLE); BEGIN SetRField(h,'Callout','New Bubble Style V20','None'); ResetObject(h); END; BEGIN ForEachObject(RemoveISO,(INVIEWPORT & ((R IN ['Callout']) & ('Callout'.'New Bubble Style V20'='ISO')))); END; Run(RemoveISOBubble); To get this working in your drawing, go the the Resource Manager, right-click and select New Resource - Script. It will ask you name a Script Palette to put this in, which could be something like "Macros" or whatever you need. Then name the script something like "Remove ISO Bubble Style" and copy and paste the code from above. Make sure that VectorScript is the selected language and press OK. This should populate into a small palette on the screen. Double-click the script in the palette to run it. 2 Quote Link to comment
CW2020 Posted October 22, 2022 Author Share Posted October 22, 2022 Thanks Jesse for the detailed analysis and explanation! Quote Link to comment
