I´m facing huge difficulties at the time of exporting the DWGs.
I managed to achieve a seemingly good result an the design layouts looked ok BUT when I double clicked on a window to edit the contents I noticed the following:
I had a single window and its visible contents corresponded to 2 design layers which were exported as blocks. I think this is not right, but a workaround the absence of design layers in CAD. So far ok.
I made a new window of the same design layers and its content got unwillingly duplicated. Now I get 2 different blocks (different names, so NOT instances) for each design layer and each is placed in a different layer so that they can be differentially layouted...
Even crazier is that when I duplicated the first window, just for the sake of checking, though they are actually independent objects in vectorworks, and "should" have produced a third copy of the content blocks, it was actually the same content as the firs... I CAN´T FOLLOW THIS INTERNAL LOGIC...
Could any of you explain to me how do you produce usable, clean, professional DWGs that can be shared with project partners without being ashamed?
arquitextonica
Hi All.
0 answers to this question
