zero Posted May 5, 2004 Share Posted May 5, 2004 Newbie question; So I set mt DTM-Mesh class to "use at creation", then go to the Other tab, select a tecture to use, and tick "use textures at creation" I then run the DTM processor, change a setting, and click OK I would expect the DTM to now show up with a tecture on the 3d mesh (open GL enabled). However there's not. Any ideas? Thanks Quote Link to comment
Guest Posted May 5, 2004 Share Posted May 5, 2004 Edit the symbol representing the DTM either by double clicking it on the drawing, or editing through the Resource Browser. Select the object and make sure it has a solid fill. You can then add a texture from the resource browser. When finished making changes, click Exit in the upper right corner. Quote Link to comment
zero Posted May 5, 2004 Author Share Posted May 5, 2004 Thanks Katie worked perfect Mat Quote Link to comment
