nerocaesar1 Posted September 15, 2022 Share Posted September 15, 2022 Hello, I just upgraded from an old version where I could make "curtain objects" and move them the same way I could a "line" Click on an end point and drag it to where I want it to be. I work all in 2d and keep my ground plan drafts fairly simple. Is there a way I can make a simple 2d curtain in spotlight using the "soft goods" tool and then move it where it needs to be in the same manor I would a "Line"? This includes making it longer with the mouse and readjusting it easily without having to type in the rotation and the origin coordinates and making it a whole project. Again I'm looking for a simple solution, heck, I'll even just use the line tool if I could make it look line the curtain swirly line. Thanks, -Greg Quote Link to comment
Vectorworks, Inc Employee klinzey Posted September 15, 2022 Vectorworks, Inc Employee Share Posted September 15, 2022 The soft goods tool has a similar behavior but it is a little different because it is a polyline. If you double click the soft goods objects you will enter reshape mode. With a single line you will get 3 reshape handles, grab one on the end and drag it to change the length. 2 Quote Link to comment
nerocaesar1 Posted September 15, 2022 Author Share Posted September 15, 2022 That's the stuff, many thanks! Its not easy to search for that question when I dont have all the right vocabulary. Quote Link to comment
