Storing long strings in PIO objects
The last time I tried it was 32767, something to do with Int types or LongInt, I can't remember.
I've in the past used a splitter command and had 3 params set aside for storing data eg (storeParam1, storeParam2).
code below is an example of how it would go
# Split every_length x characters
def value_splitter(listparams:list, value_to_store):
    listparams is List of record/plugin | field/parameter names
    val_str = str(value_to_store)
    max_char_length = 32767
    val_params = [val_str[i: i + max_char_length] for i in range(0, len(val_str), max_char_length)]
    if len(val_params) <= len(listparams):
        for i, x in enumerate(listparams):
            vs.SetRField(plugin_handle, record, x, val_params[i])
    else:
        raise ValueError("Number of parameters too few for splitter")
A while back, VW introduced the use of ObjectUUIDs. You could try storing these in a json file together with the rest of the other data you're wanting to store.
Edited by twk
    else:
ill have to give this a try. ideally i want to store it in a json format in the field. i think i could be fine with 32767 characters. i could also have it delete older data as it fills up. ill report back with what i come up with.
