steverschnitzel
28 -
Reputation
0 NeutralPersonal Information
Occupation
Architect
Location
Seattle, Washington USA
Is it possible to merge identical symbols? I have an Autocad file with many duplicate symbols-- for example, 6 toilets each with a unique name. Many are nested within other symbols. I'd like to simplify the file, using only 1 toilet symbol.
This problem has been resolved. We can get rid of it by closing other applications. It's not necessary to restart VW or the computer. The problem computer is the boss's. She likes to leave many apps open at the same time, switching between as needed.
I'm working from a model set of plans for a hotel. I'm trying to make dimensional edits to the guestroom configuration. I have imported a dwg that contains several viewports, 4 plan views and an interior elevation. The plan views are floor plan, furniture, electrical and reflected ceiling. all of the plan viewports are different views of the same guest room. Class settings differ. The trouble is that the class settings do not import properly. There are objects not visible in each viewport because classes are not turned on. This is a problem because the dwg has many X-refs. Each X-ref object brings in a whole set of AC classes with an X-ref prefix. It's too complicated to manipulate. Also some objects may be missing because they were left out during import, they were 2d or 3d I've tried importing both as 2d&3d and as 2d only. it doesn't seem to make much difference. If anyone has a tip that would simplify working with this type of file, please share it. Thanks
I have a symbol used for my title block that has multiple text blocks. The text blocks are linked to records for easy edits that retain formatting. It works great until I bring it into a file as a work group reference. Then I have to re-type all the data. Why doesn't the reference bring in the symbol as it appears in the source document? Is there some setting that affects this behavior?
When I edit a saved view to- say -turn on an additional layer, I get something unexpected. The resulting saved view contains multiple layer and class changes that I didn't make. The work around is to turn on the additional layer then save the view with a new name. It doesn't happen in all files. The file contains references. This behavior does not inspire confidence.
Seems like file size could get pretty big by adding a lot of pdfs. If you just want a quick reference consider pasting the web address into the drawing in a non plot class. I'ts not a bad idea to include the address in the printed file so that contractors can reference it. (applies to most small projects where there is no spec book as part of the project)
It used to be that the "paste" insertion point was the last point clicked before cutting or copying. Now I always get the insertion point as the middle of the object being pasted. Say i click on the corner of a rectangle>copy >click on another corner of the rectangle> paste, the center of the rectangle is pasted at the last click. This is what I used to get when I selected the object with a marque. I'd rather have the corner of the rectangle pasted at the last click. Is there a way to get back the older-more useful/elegant way of pasting? Perhaps a preference setting somewhere? The old way of doing things was especially useful when pasting large groups of objects.
I'm having trouble selecting hatched polygons where the hatch has no background fill. Is there a constraints setting combination that works well for this? This is in detail drawings where objects are crowded close together. Option dragging over the object is risky because groups get selected by accident- then sometimes deleted. I'm wasting time trying to find an object handle to select. And I'm zoomed in too close to draw a marque around the whole object.
Is there a way to select duplicates that exist in the same location? Say you zoom in then inadvertently select many objects, option click one, duplicating the all of them in place. You don't notice the mess you've made until its too late to undo or select previous. Is there a quick way to select all the duplicates?
Batt insulation and linear materials flip about the handle axis when ever I try to change the length by dragging the handle. What's the proper way to modify these objects?
Text missing from new dimensions & call outs
steverschnitzel replied to steverschnitzel's topic in General Discussion
When I started up this morning the problem was gone. I tried to repeat the behavior but can't get it to happen again. I set the the pen color to white - The whole dimension disappears. If line weight is set to zero the text and hash marks remain but lines disappear. -
When I draw dimensions no text appears. This includes with and without the "show" box checked in the info pallet. Text appears in dimensions drawn before the problem started. I've tried restarting and repairing permissions- no change. The problem occurs in all files- even a new one. Problem also happens in Callouts. It does not happen with Drawing Labels. The only recent change in my work station- I installed Adobe Acrobat reader 9 beta just this morning and an Apple update "Digital Camera Raw Compatibility Update" (2.3)"
I'm not positive but I think we've tried restarting Vectorworks with no change observed. Restarting the computer eliminated the problem. However we haven't tried that along with opening all the same applications. So I don't have a clear answer. The problem is intermittent. It's not associated with a particular file.
This only happens on one computer. Drawing label text is present in Information panel but not on the label itself. We found the problem goes away when other programs closed. This is the boss's work station. It is left on all the time. There are 2 Gigs of ram - Mac OS 10.5.X. Same thing happens with Callout tool text.
A vertical break is no problem. Just change the wall type. But if you're talking about horizontal changes that occur at windows or other items that cut walls, it's difficult (at least for me) Say you have a stucco exterior wall and a brick veneer wainscot to 36". Add windows with sills at 24". The windows need to cut 2 wall types. But they can't. I'd draw the stucco walls with the windows. Then add the 36" tall brick wainscot to the exterior. Where the wainscot needs to drop to the 24", place a shorter section of wainscot below the window sill. The breaks in the walls don't show when rendered. It's time consuming and looks best if the brick thickness is exaggerated. I've tried drawing a full height wall, inserting a window then duplicating in place the wall & changing it's height thickness and texture. This looks OK until rendered. Objects that occupy the same place don't usually render as desired You might try making a symbol of the window and the short piece of wainscot. You'll need to set the insertion point to account for the offset. I don't know of an easy way to do this.
