Thom
583 -
Posts posted by Thom
It seems I have asked this question before, but could not find anything using the search function.
I need to rotate a worksheet in the drawing. I understand this cannot be done using what should be an easy answer, use the rotate command. Is there a way to export and import the worksheet to be able to rotate it. I would rotate the entire dwg but there are too many components.
thks
Might as well add my vote to this one. Many times I will have 10 -15 sheets for a dwg. set and something will need to be tweaked. A save current view command would be very helpful.
Since no Landscape Architects have responded. Brick patio surfaces, segmented wall surfaces, and where the program is weakest, vegetation types. It is very tough to make a landscape dwg with renderworks.
Instead of layer linking, I have better success (that is if I understand your problem) using the sheets command to control the printed sheet look.
That worked - thks.
Now, how do I change the depth of the cell so the overall height of the worksheet is narrower.
[ 01-23-2004, 12:05 PM: Message edited by: tvetter ]
Do you mean change font size. Tried that while online with tech support. Did not work.
How do I reduce the size (overall physical) of the worksheet when changing sheet sizes, ie, when going from an 23 x 36 sheet to a 8.5 x 11?
[ 01-22-2004, 02:29 PM: Message edited by: tvetter ]
Go here for an excellent comparison list.
http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=12;t=003264
Secondly, forget all you know about autocad, VW operates on a simplier concept. Autocad will cloud your learning.
I am finding the need to produce nicer perspectives or computer models. What are fellow LA's using. Are you using Renderworks to produce these types of drawings or something like Artlandis or Photoshop. I am looking for the simplest way with the shortest learning period to produce the perspectives or models
[ 01-19-2004, 03:37 PM: Message edited by: tvetter ]
Quite frankly, as an ex-autocad user, when making the transition, the best thing to do is to forget anything and everything you know about autocad, and focus on how VW operates. If you try to use VW while trying to think in autocad termology it makes the transition more difficult.
From one ex-autocad user,
I agree with Tristan. This needs to be added to the wish list. As landscape architects are becoming more recognized for their unique abilities to create more sensitive, enviromental friendly, creative site plans, our software needs to allow us to do this easily. While site planning can be done in Landmark, the transition to construction dwgs. especially from working with dtm's is not user friendly.
The problem is an chicken and egg situation. VW needs more LA to buy the program, but without the improvements most LA's I talk to are reluctant to take the leap.
[ 01-17-2004, 12:14 PM: Message edited by: tvetter ]
BaRa
Perhaps a little out of the box thinking such as letting the public know more about the route future releases are taking would create more of a feeling of ownership by the users, therefore more loyality and promotion by existing users which is the best method of advertising possible.
PS: Unfortunately when I look at my family's busy schedule (and I make a serious attempt at spending time with my family) and the hours per day I spend infront of a computer screen, I probably also spend more time with VW then my family.
[ 01-15-2004, 09:33 AM: Message edited by: tvetter ]
I print to a pdf file - adobe and then transfer to by PDA. Ok to for field use.
Becki
Are you picking your placement location under the tree with your first click. If you click outside of any plants then the tree will not be affected. If you click inside of a plant symbol, Landmark assumes that you want to change the existing symbol to a new one.
Robert
Please note - the same comment as I made in a early post. Selecting by using the plant catalog dialoge box would be easier than selecting symbols.
"Also, is there a way that only the selected symbols used in the Plant Catalog show up in the Place plant tool? It is a pain to scroll thru unused symbols looking for your symbol."
Robert
When I pick a plant to insert in a drawing, as I understand it, I must select the plant from the dialog box of symbols. (This is after creating a plant catalog) Since all the symbols are shown whether they are assigned a plant or not, it is combursome to scroll through the symbols to choose the symbol assigned to the plant. If you could show a dialog box that would list plant names instead of symbols, it would be more convient for plant insertion into the dwg.
Robert
I would like to see a dialog box that would show plant names that have been added to the plant catalog. Scrolling through plant catalog symbols of which many may not be in use, is combersome at best when inserting plants into the drawing.
I would like to see a dialog box that would show plant names that have been added to the plant catalog. Scrolling through plant catalog symbols of which many may not be in use is combersome at best.
[ 12-02-2003, 03:02 PM: Message edited by: tvetter ]
Ever since upgrading to VW 10.5, I have been getting an error message on my printer after printing. I run Win 2000 pro with the latest HP driver (4.63)
Any ideas.
thks
[ 12-02-2003, 11:33 AM: Message edited by: tvetter ]
Viper x
It works for me, only not as smooth as it used to in previous versions. To get it to change the symbols already in the dwg. I redesign the symbol per Katie's instructions on your other link. I have found to make the existing symbols change or refresh, I need to click "show plant settings on and off". I am not sure why this works, but it is probably a bug. I am a notorious symbol redesigner because many of my detailed residences will have 50 - 60 different plants.
Let me know if this works for you.
Thom
[ 11-19-2003, 09:44 PM: Message edited by: tvetter ]
Just post here with all your questions. We should be able to help you speed up your learning curve. If you can - get the Landmark tutorial CD. It is helpful. I wish VW would put on a Landscape training specific class somewhere such as Salt Lake. Hummm training, skiing, cheap air fare. Might be able to afford the expensive class
Hint hint
It took me a good month to begin to feel comfortable with the change. The program works totally different than autocad / Landcadd. I am glad to have switched, even though Landmark has a long way to come, especially in irrigation design.
By the way, I stayed PC based.
I am looking for a script that would read the gpm that is assigned to each sprinkler and then would tabulate gpm as selected and using a greater than or less than concept to assign pipe sizes, labeling each polyline that connects between sprinklers.
Detail Symbol
in Site Design
Posted
It is late Friday and my mind is frizzled after a 60 hour week of irrigation design since Wednesday morning with no end in sight.
Anyway, I copied my design work from a old base to an updated one. When copying to the new base, the detail symbol partially disappears. The number portion is visible, the circle is gone. I do get a layer not visible message. I have checked all settings and they appear to be the same. Any ideas.
thks - it is going to be a long weekend
[ 04-23-2004, 08:45 PM: Message edited by: tvetter ]
