beanus
378 -
Posts posted by beanus
My computer has just installed the latest windows update and now VW seems to crash all the time, anyone else having this problem?
yep I do that at the moment but it doesn't give such a good result as the plant line
is it possible to draw a polyline and then convert it to a jagged line to represent a hedge in 2d with marionette (see attached)
I'm having a problems with the time it takes VW2018 to load compared to VW2017, 2017 takes 45 seconds to load and 2018 takes 3 minutes 45 seconds to load, is this normal?
wow thanks Pat that's exactly what I wanted, thanks again.
Hi Pat, I only need a simple 2D door or window inserted between the points I select, it doesn't need to be inserted into wall objects. I've attached pdf of the sort of thing.
Hi Pat, I'm trying to create a tool which measures between two existing points on a drawing and then draws a simple 2d door or window. I quite often have to trace over old drawings usually in btmp format. In an old cad package I used in the past (Truecad) I managed write a simple piece of code that would enable me to click on two points and a simple 2d door or window would be drawn between the two points, I think the programing language was basic.
20 hours ago, Pat Stanford said:
What are you going to do with the data? Do you just need to know what the distance is (One time display?) or need to place that distance in the drawing somehow?
If you just want a "dialog box" to come up and show you the distance then a script will be a better and easier option.
In my opinion, Marionette is the best option for programmatically creating objects in a drawing. Traditional scripts are a better option in most cases for modifying objects that already exist. Examples would be changing classes, fonts, colors, turning on options (Like Multiple Labels in Space objects) and even changing text blocks (company name changes)
The following script will display a dialog box showing the distance between the first two selected locus points in a file. It does not check that the selected points are loci and will error if run with other type objects selected. If you need a more robust version it would not take much to check the object types and fail gracefully.
Procedure LocLocDistance; Var H1,H2:Handle; X1,Y1,X2,Y2,Dist:Real; Begin H1:=FSActLayer; H2:=NextSObj(H1); GetLocPt(H1,X1,Y1); GetLocPt(H2,X2,Y2); Dist:=Distance(X1,Y1,X2,Y2); AlrtDialog(Concat('Distance is: ',Dist)); End; Run(LocLocDistance);
is it possible to get marionette to pick two previously drawn points by selecting them with the mouse, then return the distance between the points
Ok I've been fiddling around with marionette and I can't find a node that refers to mouse functions, how do I get the mouse position also how do I get a dialog box to appear to enter information in to?
is it possible to buy Ozcad's Windor outside New Zealand?
I've given up with the new stair tool it cannot produce even standard UK configurations, don't know who thought up the new stair tool they obviously don't have to use it. Stick to the custom stair tool you can produce most configurations even for stairs that were built years ago and don't comply with modern standards.
I've just been trying to use the new stair tool, I find it almost impossible to use who the hell thought this one up it just doesn't make sense why not improve the original one
hand (pan) tool works fine but zooming in with the "C" key causes objects to disappear also unable to select anything.
has anyone seen the free CAD software offered by ACCA, you get the software free and only pay for prints. Although it's not suitable for the type of drawings I produce it has some very good points. It links directly to estimating software, you can create walls of variable thicknesses and still insert doors/windows, the stair tool is excellent especially when it comes to modelling old existing stairs, inserting roofs and dormers is easy, inserting rainwater pipes is very intuitive and many other points. Also above all it didn't crash once. If Vectorworks could incorporate some of these features it would be an excellent program.
two steps forward and three back
2014 is about stable as 2013 was when it came out crashing all over the place. There doesn't seem to be a particular process causing problems 2014 seems to crash randomly, it's a complete pain in the arse.
I see there's another SP2 for 2013 this is the third SP2 whats going on?
just installed SP2 for version 2013 and the navigation palatte has become blank, help!
you could try using the space tool and running a report, that gives some of the info you need
Yep get this problem I've even tried deleting the ref files and putting them in again in 2013 but when I try to put ref files in the program crashes
Mike what's the spec of the computer you run vectorworks on, I use v2013 on two computers and it crashes on both and in some cases it won't open v2012 files
what happens to the crash dump files when they are sent? where are they sent? what do they mean? does anyone do anything with them? I've got about 70 of these files so far this year!
corner window with post not displaying correctly, am I doing something wrong?
Crashing Problems
in Architecture
Posted
hi, yep I had the latest update installed so I'm doing a complete reinstall of VW to see if that sorts the pronlem
