Jeffe'
    31
    Never
Everything posted by Jeffe'
  1. As for the help problem, it relies on the Java plugin to work. Double check Safari and make sure it is configured correctly. They should really just make the help HTML based and not use Java.
  2. You can set the class to one of the "styles" under Window preferences>View>Special Classes, then turn them off. You can set them to have different rendering properties using this as well. BTW: the pic you linked to doesnt work. [ 03-29-2006, 05:30 PM: Message edited by: Jeffe' ]
  3. The Stretch and Vector Move look great! Anybody have a free script for this? It may be worth $100 for these, but it is something that should be built-in to the program itself.
  4. Just trying to put a single vertical muntin on all parts, top & bottom sashes of a single hung window with a transom. Here is a pic of what happens in the window dialog box - it actually looks like this in the 3d model view as well. I'll try to re-create the problem in another drawing as well and let you know. EDIT: happens in other files as well. [ 03-29-2006, 01:31 PM: Message edited by: Jeffe' ]
  5. I am having an issue with the muntion part of the window tool. If I enable muntins, the 3d view of the window seems to be "exploded" in that the sashes of the different components (say of a single-hung) are scattered vertically in line with the window. It took me quite a while to figure out that it was the muntins causing this odd display behavior. Any ideas? Or is this a known bug. /BTW: It used to work - think it is the 12.0.1 update.
