Squib
    7
    Never
Everything posted by Squib
  1. Not sure who this jenks fellow is but could also make a 3D nurbs curve that curls and rises (3D reshape and then lift the last control point in the Z) and then with a profile of the bank created select both and use the extrude along path tool that also allows for scaling....
  2. Further to last post attached images are at Images - (can't get the Image button to produce the right result)
  3. quote: Originally posted by Charles Chandler: When creating walls from all of the spaces on the source layer, it's supposed to reshape all of the existing walls on the destination layer. Right now it's only reshaping walls inside the bounding box of the spaces. That's a bug that will be fixed. Charles - I tried it again following your assertion that it works in part and you are right - it does update the stuff inside the boundary of all spaces - allbeit with symbols moved but at the boundary of the spaces which are unchanged it puts a new set of walls which don't contain the symbols as they should - I attach a sequence of images to support
  4. Oops - pressed the wrong button- my first reply!! There is a fantastic plugin that performs this and many other useful Spreadsheet functions by Julian Carr of Ozcad - it is called spreadsheet on drawing Nemetschek should employ this guy full time!!
  5. quote: Originally posted by Heather Fagans: An old saw I know, but text wrap in the worksheet would make my life so much more fulfilled... In trying to convince my boss to leap whole hog on the VW bandwagon, I've run into a few flaws, but none so great as the lack of text wrap. Pleasepleaseplease include this in the next upgrade! Heather Fagans Butz + Klug Boston, MA
  6. The manual says that, having created walls from spaces, the spaces can be modified and then the walls will be updated on running the walls from spaces menu item. Whichever way I do it and whatever layer the spaces or walls are on, all it does is create new walls rather than modify existing. What's happening?
  7. Haven't been able to create an elevation analysis successfuly - all it does is create a copy of the existing or proposed and usually doesn't let me create a legend. Have tried it on Mac and PC with different values etc. The slope analysis on the other hand works like a dream - no trouble -what's happening?
