ASydDesigns
    12
Everything posted by ASydDesigns
  1. Can multiple single line text be combined into one multiline text box?
  2. I do NOT understand why the space tool tag is separate to the boundary. If I set the boundary not to display, I can no longer edit the TAG. This is an absolute nuisance! Why can't the tag be edited by selecting the tag?
  3. Ahhh!-perfect! I was using a 3D post symbol. I adjusted the 3D post symbol and that worked. Thank you!
  4. Thank you for your response. Unfortunately, the guardrail height is still greyed out even when set to unstyled
  5. Hi, I need to adjust the height of a railing system in Vectorworks 2024 but the setting is greyed and uneditable.
  6. Hello, I am having this same issue. Has there been any update on this?
  7. Yes, the walls are set to class line thickness. No components for these walls. However! I just discovered that they are set to render nay component and not object. When I changed to render by object. Voila! it worked Thank you!
  8. I am having issues with my Wall class line weight overrides in my elevation viewports. They are still displayed as thick lines even after changing the viewport class pen setting to a thinner line.
  9. I was wondering if additional Window saw operation options can be added. As of 2022 Jalousie as well as double or triple unit options for other types have to be made under custom operations. Because of this, the window schedule lists window types as custom which is not acceptable in my opinion.
