I am attempting to create a point object plugin that generates a grid of boxes based on variable inputs for number of rows and number of boxes in each row.
I have managed to make the plugin draw the grid after a dialog has been opened however I can't figure out how to get it to draw the grid on creation.
I have the plugin set to event enabled with resets on for both move and rotate.
I believe my issues are stemming from overriding the default behaviour for object events.
Here is my program
PROCEDURE testing;
CONST
{Event ID's}
kEventID_ParametricRecalculate = 3;
kEventID_OnObjPref = 4;
kEventID_OnInitProperties = 5;
kEventID_OnDoubleClick = 7;
kEventID_OnUIButtonHit = 35;
kEventID_OnAddState = 44;
{Notification ID's}
kNotifID_CreatedReset = 0;
kNotifID_MovedReset = 1;
kNotifID_RotatedReset = 2;
kNotifID_ParameterChangedReset = 3;
{permissions}
kObjXPropHasUIOverride = 8;
kObjXPropAcceptStates = 18;
kDialogIDOffset = 4;
kWidgetButton = 12;
kButtonID = 1234;
VAR
objEvent, eventData :LONGINT;
objH, recH, wallH, tempH :HANDLE;
objName, recName :STRING;
gDialogID :INTEGER;
gNumEntries :INTEGER;
gWidth, gHeight, gPadding :REAL;
gVarArr :DYNARRAY[] of INTEGER;
result :BOOLEAN;
PROCEDURE DrawBoxes;
var
i,j, rowLength :INTEGER;
rowStr : dynarray[] of char;
isEmpty, isLinked :boolean;
BEGIN
result := GetCustomObjectInfo(objName, objH, recH, wallH);
recName := getName(recH);
if (objH <> nil) then {<--- seems to have an object usually}
begin
for i := 0 to gNumEntries-1 do
BEGIN
{vvv this is always an empty string until dialog is opened vvv}
rowStr := GetRField(objH, recName, Concat('_',num2str(0,i)));
rowLength := Str2Num(rowStr);
for j:= 0 to rowLength-1 do BEGIN
if rowLength <> 0 then
Rect( j*(gWidth+gPadding), i*(gHeight+gPadding),
j*(gWidth+gPadding)+gWidth, i*(gHeight+gPadding)+gHeight);
end;
END;
end
else AlertCritical('tried and failed', ''); {<--- never triggers}
END;
PROCEDURE DialogHandler(VAR item:LONGINT; data:LONGINT);
VAR
i, val :integer;
BEGIN
CASE item OF
1: BEGIN
for i:= 0 to gNumEntries-1 do BEGIN
result := GetEditInteger(gDialogID, (i*2)+kDialogIDOffset+1, val);
SetRField(objH, recName, Concat('_', num2str(0,i)), Num2Str(0,val));
end;
end;
end;
END;
PROCEDURE DialogGenerator;
var
actionItem :LONGINT;
result :BOOLEAN;
i, tempVal :INTEGER;
tempStr :dynarray[] of char;
begin
gDialogID := CreateLayout('Boxes per Row', FALSE, 'OK', 'Cancel');
CreateStaticText(gDialogID, (i*2)+kDialogIDOffset, concat('Row ', num2str(0, i+1)), 16);
tempStr := GetRField(objH, recName, Concat('_',num2str(0,i)));
{vvv creates parameters here for some reason vvv}
if tempStr = '' then {if parameters don't exist yet}
begin
NewField(recName, Concat('_',num2str(0,i)), Num2Str(0,gNumEntries), 1,0);
tempStr := Num2Str(0,gNumEntries);
end;
CreateEditInteger(gDialogID, (i*2)+kDialogIDOffset+1, Str2Num(tempStr), 16);
END;
SetFirstLayoutItem(gDialogID, kDialogIDOffset);
SetRightItem(gDialogID, kDialogIDOffset, kDialogIDOffset+1, 0, 0);
for i:= 1 to gNumEntries-1 do BEGIN
SetBelowItem(gDialogId, (i*2)+kDialogIDOffset-2, (i*2)+kDialogIDOffset, 0, 0);
SetRightItem(gDialogId, (i*2)+kDialogIDOffset, (i*2)+kDialogIDOffset+1, 0, 0);
END;
actionItem := RunLayoutDialog(gDialogID, DialogHandler);
end;
PROCEDURE init;
var
i :integer;
begin
gNumEntries := PNumber_Of_Rows;
gWidth := Pw;
gHeight := Ph;
gPadding := PPadding;
recName := GetName(recH);
end;
PROCEDURE setup;
var
i :integer;
tempStr : dynarray[] of char;
begin
result := SetObjPropVs(kObjXPropHasUIOverride, true);
if result = false then AlertCritical('Error','Failed to override UI');
result := SetObjPropVs(kObjXPropAcceptStates, true);
if result = false then AlertCritical('Error','Failed to accept states');
result := vsoInsertAllParams;
if result = false then AlertCritical('Error', 'There was an issue inserting parameters.');
if vsoAppendWidget(kWidgetButton, kButtonID, 'Select Columns', 0) = false then AlertCritical('Error', 'button broke');
result := GetCustomObjectInfo(objName, tempH, recH, wallH); {<--- this always fails}
begin
message('setup failed');
end;
if (objH <> nil) then {<--- this never triggers as GetCustomObjectInfo always fails}
begin
for i:=0 to gNumEntries-1 do
begin
if GetRField(objH, recName, Concat('_',num2str(0,i))) = '' then
begin
NewField(recName, Concat('_',num2str(0,i)), Num2Str(0,gNumEntries),1,0);
end;
end;
end;
end;
procedure CheckRecalculations;
var
outWidgID : LONGINT;
outPrmIdx : INTEGER;
outOldVal : STRING;
i, oldInt : INTEGER;
begin
{vvv never runs vvv}
if vsoStateGetParamChng(objH, outWidgID, outPrmIdx, outOldVal) then
begin
if (outPrmIdx = 1) then
begin
oldInt := Str2Num(outOldVal);
if (oldInt < gNumEntries) then
for i:= oldInt-1 to gNumEntries-1 do
NewField(recName, Concat('_',num2str(0,i)),Num2Str(0,gNumEntries),1,0);
end;
end;
if vsoStateGet(objH, kNotifID_CreatedReset) then {<--- never runs}
begin
setup;
end;
end;
BEGIN
init;
BeginGroup;
vsoGetEventInfo(objEvent, eventData);
CASE objEvent OF
kEventID_OnInitProperties: setup;
kEventID_OnUIButtonHit: DialogGenerator;
kEventID_ParametricRecalculate:
begin
DrawBoxes;
vsoStateClear( objH );
end;
kEventID_OnAddState: eventData := vsoStateAddCurrent( objH, eventData );
END;
EndGroup;
ResetObject(objH);
end;
Run(testing);
Things I've tried:
Adding the parameter creation code to the draw procedure
- works in drawing the boxes but the defaults end up being random numbers ("-823648", "2893659")
using CreateCustomObject
- draws the grid on creation but in the origin and not part of the plugin
using SetCustomObjectPath and setting it to FSActLayer
- completely fails (im not really sure what the FSActLayer is, I was just following the function reference's example)
To my understanding, the object has not actually been created yet in the initProperties event (5) which means I can't access its record to initialise the properties.
This makes no sense and I'm almost certain I'm missing something.
Any help would be greatly appreciated!
