garrettohler
18 -
Reputation
3 NeutralPersonal Information
Location
United States
Recent Profile Visitors
We fight this all the time with LED walls and TV symbols. It's very frustrating to have to add an extra surface to prevent this issue.
I had a interesting issue arise where a file in project sharing lost many of the data fields that were assigned. Fortunately, I have a backup copy of the file that can be used. I need to copy fields from the backup file to the main file, but the ID that the objects are assigned in the record are also wiped. Obviously, I need to have my tables sorted the same way to move the data properly. Is there a worksheet function that would show a unique object IDs that VectorWorks can see? That would allow me to sort these tables perfectly for this use. In the mean time, I'm attempting to use =CONCAT(XCENTER, ',', YCENTER) to create a sort of unique ID for the objects.
Disable Automatic Cable Type Based on Signal
garrettohler replied to garrettohler's topic in ConnectCAD
Cable Types.mp4 @Conrad Preen I think the video demonstrates the issue clearly. If you need a file as well let me know, but it happens on all of our files. It seems that I was wrong about cable types changing when a device moves. However, the second clip shows that the cable type font can change. Cable Types 2.mp4 Cable Types 3.mp4 -
Similarly, the cable type symbols used to be based on a text style, but now they are easily changed with the active text settings in the main toolbar. This leads to accidentally changing the fonts and the drawings looking sloppy. -
After transitioning to VectorWorks 2024, there seems to be a new feature that automatically assigns a cable type based on the signal. Previously, that was not the case. It's detrimental to our current workflow that utilizes larger "signal buckets" primarily for the purpose of a cable number prefix. Signals are Audio, Video, Lighting, Network, etc. "Audio" can have many cable types inside of this category, but once you have assigned a cable type to a signal, any time you move devices the cable type is overwritten based on the signal. Is there a preference that would allow for disabling this function? If not, could there be?
Worksheet Function in Data Visualization
garrettohler replied to garrettohler's topic in General Discussion
@Tom W. Ah ok. The key thing I missed was that you need a second record to link to the original. That made it simple. Now it works great. Thanks! -
@Tom W. I've played with all of the settings for a little while and I can't seem to get them to link the way that I think they should. I have a boolean check box for "Existing" conditions that we want to represent with a data visualization as grey. Ideally, it works both ways where from editing the tag info or editing the object you could check the box and it would be synchronized both ways. What am I doing wrong? -
I would like to create a data visualization that overrides the color of a tag based on the information displayed in a data tag field, as the tags have no other link to the objects for them to be visually overridden. There does not seem to be an option that allows you to utilize worksheet functions for a data visualization.
Objects in Hidden Line Renders are Randomly Red
garrettohler replied to garrettohler's question in Troubleshooting
2024-02-13 12-55-42.mp4 @Andrew Bell No data visualizations and no class colors. Whenever I change my Active pen color, random objects change color. -
Hello! I have objects that are randomly turning red in hidden line renders when I am working on a project. It seems like a bug. I am the only person in our office who currently has this issue. It happens across multiple files that I work on. I also just updated to VWX 2024 update 3.1 before posting this just in case. The video does it more justice, but you can see at first nothing changes when I try to update the settings and that the objects should not be red. After "spamming" it a few times, the object will finally take, and in this case, it cascaded to additional items that I did not update. I have noticed this more with objects that would be rigged. Lights, TVs, Speakers, Etc. Let me know if you have any ideas! Red Objects.mp4
Amplio Systems - AVL Design Engineer About our company Job Description: The Design Team supports the rest of Amplio Systems as they head out to sell, install and support Audio, Video, Lighting, and Acoustical Systems. The role of the Design Engineer is an integral position within the team. This role will work within various software products to assemble a design document that communicates the design intent and design detail for all stages of the project life cycle. Including the needed infrastructure to support the new or future systems. This also includes modeling of various systems within the proper software. This can range from Speaker Systems to House Lights, as well as various calculations of electrical/heat loads, rigging weights and assembly. This information will need to be translated into the project drawings for communication with other trades. Various models and other input may be required for Design For Sale processes. The Design Engineer is also responsible for a working system design and functional drawings as needed to ensure a fully working system which meets the customer's needs. The Design Engineer will work with a project team to specify the equipment list and also to assist in the development of the Scope of Work document. Interfacing with construction teams (Architects, General Contractors, Structural Engineers and Electrical Engineers) and clients will be a part of the normal project life cycle. Experience Required: 3-5 years of Design level experience Key Software: Vectorworks D-Tools SketchUp Excel AutoCAD and Revit experience are a plus APPLY HERE
Marissa, I looked at this file, and it's a helpful start! Even though I have tried a few things with Marionette, I think what I'll need to do in the end is a worksheet script of some kind that Pat mentioned. It would be ideal to see the results in that format. Frankly, I'm unsure how to get from Marionette to something I can use as a worksheet script. Thank you both for your help so far!
Check if Objects at Tagged.vwx
For some better visual reference, we have: The 3D Back Box object with a record. The back box schedule that reports the info from the record A Data Tag that gets moved to a different layer and reports data from the record to create the riser diagram. That keeps everything in sync. A Data Tag that goes on the plans as a viewport annotation that shows the physical location of the box and other record information. We lack a way to validate that all of the boxes are tagged twice, which is critical to our workflow and the communication of this information. We can have over 100 back boxes on a project, so validating this info manually (and hoping the client doesn't change anything) is difficult.
