vmaini
    4
Reputation
2 Neutral
Personal Information
  • Occupation
    Architect & Professor
  • Homepage
    valentinamaini.net
  • Location
    Spain
Contact Info
  • Skype
    valentina.maini
Recent Profile Visitors
  1. Thank you Bruce, Yes . Actually I like that is a very simple to use tool...the problem for me is that uses all the graphics standards of UK- USA. I succeeded in changing the 2d aspect to have the appearance used here in Spain . The Italian version of VectorWorks (that I have used ) has a great tool for designing and placing in wall receptacles and switches that basically works with the three components that you have also made: box + components + finishing. Within the tool you can decide were to place the boxes ...for example in the same vertical line next to a door but with different heights for the different elements, very nice but quiet complex to use/learn . I've seen this same structure in the Revit family that BTicino has made ... impossible to use in VW. Actually I found this MEP part one of the most annoying things to "count" and describe in projects...and is a part with significant budget needs ... so it would be great to have in the international version of VW the Tool available only in VW Italy and Germany . Ups I wrote a lot 😅. All the best to you! ciao!
  2. Super work Bruce! Anybody knows if is possible to edit the 3d Appearance of the Receptacle ..Devices of the Vector Tool?
  3. Hi Luka and all, This is very useful ! How about reporting the detail /difference between window /ventilation area and window/glazing area ? And is it possibile to report the window frame area and the window glazing area? How to report the "Energo" data of windows? in space report or at leats in window/door report? Thank you! I think I found it : Space Window Area and Space Glazing Area , Correct?
  4. Hi, I have the same issue as @Brian H .VW23 Difficult to send the steps because the change in appearance of bubbles happens when opening the file. Also struggling similar to @simonato put back grid lines that I've deleted by mistake in section viewports. No problem with the grid, but if I delete by mistake a gridline in the viewport ¿how do I bring it back? Same it happens with data visualisation legends : if I delete the data visualization legend in the viewport how can I bring it back?
