chilternGD
    8
Everything posted by chilternGD
  1. That's interesting. I've been asked to upgrade my VW to 2022 from 2021, but worried that I will also need to upgrade from Mojave - either to Catalina or Big Sur. If I do need to change OS, which is the better to switch to? Don't want to screw everything up - my MacBook Pro is my livelihood.
  2. Also hoping for an odd number option within bifolds selection. Thanks!
  3. THANKS BOTH, this seems to have finally cracked it for the windows at least.
  4. Thanks @jcogdellThe class and layer are both switched on. I don't know what else to do. I've watched videos and know how to set the render settings for left, and right side of walls, I've tried all these but still they are transparent, as are my window frames. I've attached screenshots so you can see what my settings are. Any other suggestions?
  5. My extrudes are now correctly showing textures, but my walls are still transparent. Are there some special settings for walls I should know about?
  6. Thanks @jcogdell Use Textures was already on.
  7. Hi there, I'm having trouble getting textures to apply to my walls, extrudes etc correctly. I'm in Open GL I've set the texture in the Class AND in the render tab, but there are so many options there that I don't understand. Can you offer any suggestions?
