AntoineDeHon
    12
    Never
Everything posted by AntoineDeHon
  1. I know how to do that. If I edit the sheet and rename it all of the functionality of the Architect package seems to stop working.
  2. I am trying to add sheets to a project that has been set up... Working on VW 10.5 on OSX. First off - I cannot add a sheet based on the documentation - says "File menu - VA Project Setup - VA Add Sheet" - This simply does not exist on my version...how are you supposed to access this feature. Secondly - If I rename the sheets (add numbers to the front of them so I can keep them in order) the entire system fails to work...meaning that I renamed all of the sheet names from the programs standard names then went to add a sheet by simply copying one of the sheets - I then went to use the "Organize - Task Manager" - the Task Manager completely fails and I cannot get it to function properly. Does this mean that I have to work with VW's sheet naming throughout the entire process or is there a way for me to safely rename the sheets so the interface of VW knows what I have done and will still function? antoine [ 11-07-2003, 11:07 AM: Message edited by: AntoineDeHon ]
  3. But where do I find the code for the standard patterns and hatches? I found the text file and understand where that is - can cut and paste - just don't know where to find the standard patterns to use to cut and paste. Thanks antoine
  4. Is there a download section for the plug-ins on the VW website?
  5. I am new to the Mac and Vectorworks so I need some advice for purchasing some new hardware to run RenderWorks... I have a background in 3d Studio so I know the hardware needs for a PC is high and am curious if the same is true for this software and a Mac. We are looking at a G5 - what specifications should we be looking at when purchasing? High clock speed? Ram? HD Space? Is Dual going to be worth the extra $$ or can we get away with the 1.85 ghz model? thanks antoine
  6. Is there anyway to use the bi-parting doors show one door open and one door closed? Like most typical french doors - you usually have one door that is closed the majority of the time.
  7. I too would like to know how you could use any of the hatches and patterns in the Wall Type setup instead of just the standard 11 hatches. We can use the "default fill" to take care of one of the hatches by setting the class to the fill that we want and that works fine for interior filled walls, but on the exterior we need to use two different fills that aren't available under the standard 11. We need the inner stud wall to be a pattern off of the Pattern Pallet and the exterior brick offset to be a hatch pattern that isn't in the standard set as well...any ideas? Thanks antoine [ 11-03-2003, 11:02 AM: Message edited by: AntoineDeHon ]
  8. Being a complete newbie to this program I need a little more guidance on this topic. We are looking to do exactly what the original poster needed - my question is where do you find the code for the hatch patterns that come in the Attibute Pallet? We want to use some of those hatches in place of the standard 11. We can use the "default fill" to take care of one of the hatches by setting the class to the fill that we want and that works fine for interior filled walls, but on the exterior we need to use two different fills that aren't available under the standard 11. We need the inner stud wall to be a pattern off of the Pattern Pallet and the exterior brick offset to be a hatch pattern that isn't in the standard set as well...any ideas? Thanks antoine [ 11-03-2003, 11:00 AM: Message edited by: AntoineDeHon ]
