matteoluigi
460 -
Everything posted by matteoluigi
Yes, I‘ve already solved that problem with three variables for one issue, the first is REAL or INTEGER, the second one is a STRING and the third one a ...CHAR variable, num2str converts my REAL or INTEGER into a STRING... works fine thanks a lot I will check out the rest tomorrow 🤗
Did I understand right, that I have to pack two procedures in one script? like that:
oh, excuse me, I have been translating directly from german. I want to select objects by record fields and not by their names and assign new data to other record fields. Let's say, "get me all geometry(=rectangles, polygons,...)" who match "(('Apartment',Housing'=HNr) &('Apartment',Apartmentnumber'=ANr)) and assign the values for total-nr of rooms and total area to a record field in every room-geometry of this apartment... Somehow it seems to me, that it isn't possible to assign an object to a handle which is chosen by a record field and not by its name... (and now I try to limit myself to assigning single objects to that handle 😉 ) sorry for bothering
Hi, sorry for bothering again 😉 but, you have been really of help!!! thanks a lot! i want to assign data to record fields of more objects. Is this possible? Or am I right when I say, that: - I can assign only one single object to a handle - I can only assign an object to a handle by its (in the Vectorworks-file) unique name? I`d prefer selecting more objects by database attributes and assign the data simultaneously to more than one object... Somehow I think, that I want to much, now. 😔 Do I? Thanks for you great help, anyway!
Sometimes there are missing things in Vectorworks which are really elementary... like having a doorbell at home without a button at the entrance-door for ringing... nearly. Actually I'm wondering again, what the worksheet-"sum" function really is for, when it's just for adding more variables one to the other instead of calculating a sum of a defined area. In Excel the function does look the following way: "SUM(A1:A20)" and it does create a sum from the complete cell-content from cell "A1" to cell "A20". (https://support.microsoft.com/en-us/office/sum-function-043e1c7d-7726-4e80-8f32-07b23e057f89) could be a greatnew feature for Vectorworks 2022 Maybe people don't need it very often, but, when you need this function, you really miss it.
SetWSCellFormulaN - really necessary creating a new worksheet?
matteoluigi replied to matteoluigi's topic in Vectorscript
Great, thanks -
writing data from vectorscript in a worksheet
And Num2Str also does work with Integer instead of Real variables. -
Is it really necessary, to create a new worksheet, everytime I run the script again? a) or can I "assign the worksheet to the handle in another way, too? (still looking for the way) b) is there any way, to check, wether a worksheet of a specific name already exists in the file? worksheet := CreateWS('Wohnungstypen-Auto', 5, 2); SetWSCellFormulaN(worksheet, zeile, 1, zeile, 1, inString);
works fine ✔️ -
Num2Str should do it with EINZW as REAL Number... -
works nearly fine, however SetWSCellFormulaN only works with Strings or Char - Variables. I'd like to insert an Integer-Value. How could I do that? Is there any possibility to transform an Integer-Value into a String? Or feed a String-Variable with Integer-content? EINZW: INTEGER; inString := EINZW; SetWSCellFormulaN(worksheet, zeile, 2, zeile, 2, inString); -
wow, thanks! sounds great! -
Hi, does there exist any possibility to write data from a Vectorscript-Script directly into an existing Vectorworks-worksheet? I didn't find a corresponding command. (maybe because the command doesn't exist) Alternative would be using "runscript" directly from the worksheet. Therefor I need to read out column A and insert it as variable in the script. (For example - A1: 1 -> "there are x 1-room-apartments")
yeah, thanks, I got it all running, now 🙂 Now I would like, to write my results in a worksheet. Still working on it (and maybe thinking about running the script within a worksheet) {In this script, I count a) how many objects are connected with the database "Wohnungsnummer" (number of flat/apartment) b) in a for to loop i do loop through all apartments (in fact the loop runs as often as many rooms are in the building, not as many apartments, but, that's not my main priority) - every loop the script counts the number of rooms which are living rooms, rooms or workrooms (it's the way you define flats in germany, a 3 room flat for example consists of a kitchen, a bathroom, a corridor, a living room and two sleeping rooms, you only count the living room and both sleeping rooms)} PROCEDURE zaehlen; VAR NR: INTEGER; {counter for the running loop} ANZAHL: INTEGER; {number of all rooms} ZANZAHL: INTEGER; {number of rooms of the actually checked apartment} EINZW: INTEGER; {number of all 1 room-appartments} ZWEIZW: INTEGER; {number of all 2 room-appartments} DREIZW: INTEGER; {number of all 3 room-appartments} VIERZW: INTEGER; {number of all 4 room-appartments} FUENFZW: INTEGER; {number of all 5 room-appartments} BEGIN ANZAHL := COUNT(((('Wohnung'.'Zimmertyp'='Zimmer')|('Wohnung'.'Zimmertyp'='Wohnen')|('Wohnung'.'Zimmertyp'='Arbeitszimmer')))); {EINZW :=0; ZWEIZW :=0; DREIZW :=0; VIERZW :=0; FUENFZW :=0;} FOR NR:=1 TO ANZAHL DO BEGIN {Schleife, die alle Wohnungen "durchläuft" } ZANZAHL := COUNT(((('Wohnung'.'Whg-Nr'=NR) & (('Wohnung'.'Zimmertyp'='Zimmer') | ('Wohnung'.'Zimmertyp'='Arbeitszimmer') | ('Wohnung'.'Zimmertyp'='Wohnen'))))); {Zählt, wieviele Zimmerin der Wohnung sind mit der Wohnungsnummer NR.} IF (ZAnzahl=1) {erhöht den Einzimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN EINZW := EINZW+1; END; IF (ZAnzahl=2) {erhöht den Zweizimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN ZWEIZW := ZWEIZW+1; END; IF (ZAnzahl=3) {erhöht den Dreizimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN DREIZW := DREIZW+1; END; IF (ZAnzahl=4) {erhöht den Vierzimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN VIERZW := VIERZW+1; END; IF (ZAnzahl=5) {erhöht den Fünfzimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN FUENFZW := FUENFZW+1; END; END; CreateText(Concat('Da sind ', EINZW, ' Einzimmerwohnungen, ', ZWEIZW, ' Zweizimmerwohnungen, ', DREIZW, ' Dreizimmerwohnungen ', VIERZW, ' Vierzimmerwohnungen und ', FUENFZW, ' Fünfzimmerwohnungen.')); AlrtDialog(Concat('Da sind ', EINZW, ' Einzimmerwohnungen, ', ZWEIZW, ' Zweizimmerwohnungen, ', DREIZW, ' Dreizimmerwohnungen ', VIERZW, ' Vierzimmerwohnungen und ', FUENFZW, ' Fünfzimmerwohnungen.')); {Gibt aus, wieviele Wohnungen welchen Typs im Haus sind.} END; RUN(zaehlen);
@Pat Stanford does there also exist sth like else if?
thanks for your great help. Where can I find instructions how to use an if-clause in vectorscript?
@JBenghiat yeah, herbieherb already told me in the german user board 😉 I think about it. first i thought, I would feel more familiar with vector script, because I already have been coding in Vectorworks worksheets for a couple of years... however, just putting a "vs" in front is ok for coding python. great alternative, i guess, and of course keeping in mind that with marionette there exists a third alternative (which also includes python codes in its nodes)
sure, that's right... (as a counter it should be supposed to be an INTEGER Number of course... 😉 ) thanks in https://developer.vectorworks.net/index.php/VS:AlertInform is written: text. STRING The information to be displayed. advice STRING The text to be added in a smaller font under the main information message. minorAlert BOOLEAN The severity of the alert: minor(true) or major(false). however, thanks 🙂
Hi, I want to learn Vectorscript and actually not that bad (i think at all). I already have been coding a little bit C, C++, Basic, Pascal and PHP in my life (also it's 15 years ago 😉 ) but, however, I know a little bit about functions, procedures, variables, variable types... my skills only got a bit rusty. However I also did work in Vectorworks worksheets and regained a part of my forgotten skills, somehow. Actually I am struggling with some basics and sometimes I don't understand, what the compiler really wants to tell me... (PLEASE don't tell me, I could solve the issue of the script with a worksheet more easily... It's just a first try, let's say, a proof of coding skills. what's wrong with that code?? Line #10 BEGIN {Error: Expected BEGIN} {Error: Expected a RUN statement at the end of the script} There's a "RUN statement at the end of that script... Line #14 AlrtDialog('AlrtDialog'); { Error: Expected a string or char. } or { Error: Expected the assignment operator := } or { Error: Dod not expect this after end of statement - missing ;? } I mean, c'mon, I am copying the commands from the developer-wiki and still they are wrong? What's wrong about: There's the "PROCEDURE"-command and name in the beginning. followed by "BEGIN", "END;" and "RUN"(Name) sometimes I think compilers must be female... I don't understand them
