Landartma
344 -
Everything posted by Landartma
I have a report which is showing a plant which I can't see or find on my plan. I'm not sure how to get it out of there so I can clean up the report. You will see Plum Pudding Coral Bells. Thats the one that needs to go. What do I do?
I have two view ports I want to display different data. One has plant tags one has callouts. The sheet with the plant tags Cover Sheet is to display plant tags. The other, Specification Sheet, is to display the general specs for the job. I want to show the plant symbols on the Specification Sheet but not the plant tags. The plant tags show up on both but when I go to shut them off on the OIP tag function it takes them from both. How do I unlink the two viewports?
Thanks for the reply on that I will go over with Bryan. It a bit much to wrap my head around now. Thanks
I have the attached flagstone path which was created by Duplicate Along Path. I want to capture the individual pieces into a worksheet so I can estimate the amount of pieces I will need. Is there a way to do it? Somehow I see they are 3d symbols I must have created them like that. I'm not sure if that's an issue. LMK. Thanks.
What would the spreadsheet formula look like for volume of graded base (crusher run). I have 650 square, feet 6" deep, at 115lb/cuft. Long hand Its (650x.5)115/2000=18.7 tons. I'm in a worksheet and have my square footage worked out.
I'm trying to get a report on a viewport. When I put it in there is data missing. Plants, sizes, costs etc. I updated the data on plant styles. What am I missing.
I can't the crop function to work in viewports. The handles are not showing up. What's the setting? Thanks!
It was the scale. Thanks!
I have my shrubs on shrub layer in show snap modify others mode. The other layers do not show up. Similarly the shrub layer does not show up when I am in Design Layer One. Whats the setting to make all layers visible show up under show snap modify others mode?
Sweet! got it thanks so much that explains a ton.
Ah Ok think I see the problem. I am not getting the blue control handles. I am guessing I have a setting wrong. I can see the end of the tag line highlights red when I hover over it but the whole thing moves. You can see I highlighted LLBox at the top of the screen.
I am working on moving a plant tag but the tag is stuck to the plant symbol and moves the whole grouping. I have tried right and left click and hold looked at ungroup. Not sure what the setting is. Please let me know if you have the answer. Also when in a viewport how do I get back to the drawing?
I just created a symbol and did an edit command. It will not highlight when selected in the editor. I'm guessing that its a setting.
Yea I have been looking at the individual graphics in the editor and cant seem to find any difference. When I scroll down the graphics even out and become more crisp momentarily then snaps back to the muted colors. When I print it prints the muted colors on the screen.
Need some advice on how to get my graphics consistent. You will see a few nice and crisp and others muted. I looked in the attributes panel and it looks like the settings are consistent. What's the setting I'm missing?
Thanks Bryan! I put them into the resource manager drawing folder that I'm working on. When we do the training we can put them into Favorites unless I figure it out by then. I figured out how to do it through the Create Plant Style from Catalogue. Thanks!
I touched on this earlier but am still not clear. I want to create my go to plant list. If I understand correctly. I need to create a template, load a variety of generic symbols into the template, then manually edit each one as I import it via the plant style editor. The path "Get Plant Data", -find in the database, - Vectorworks tab, -Use Currently Selected Record, - manually enter sizes desired? Is there a way to have the Currently Selected Record integrate plant data "sizes" with insertion sizes. Is there a faster way or a way to create a file in a user group once so I can get it done one time and just update as needed?
I'm getting an error code when I try to update the plant database. Any ideas on how to deal with it?
I tried to create a landscape area from a nurbs. Is this possible? I ended up just tracing it as a landscape area but could not see how to close the curve so now have a jumble of weird vertices. How do I create a closed shape when creating a landscape area? It seems as if it would stare me in the face as it does when working with nurbs on the OIP. Is it just a snap function? I made it work that way but it does not seem to provide the control like in nurbs. Is there a way to manipulate the vertices in landscape area mode like there is in nurbs?
I placed VW boulders in a plan, resized using the asymmetric scaling function. I would like to save them as hybrid objects for when I start working in 3d. The boulders were in a group so I ungrouped them and have usable size boulders for the projects I typically do. I want to save them to a customized or user or work group library. I have looked at several of the tear sheets from VW but I'm not finding the answer. Where is the command to save a custom object to a user or workgroup library. I am working on populating usable symbols so I can start drawing plans in VW.
In the process of loading most used plants into resource manager. Everything seems to down load from the data base but the plants are getting assigned a standard height and spread of 12'8" and spacing of 11'. Whats the setting to make the uploaded plant take on the sizing of the plant in the database.
