AstridArch
    3
Reputation
1 Neutral
Personal Information
  • Location
    United Kingdom
Recent Profile Visitors
  1. Thanks for your response. The doors have remained as 'Unstyled' and how you've described the Flip option only appearing once the door is inserted into a wall does apply to us as well. I've realised that on one project this is happening to was actually created in 2022, so can't be a Batch Convert issue. We've tried the Update Plugins procedure you've suggested, thank you. Fingers crossed this is the solution - it seems to be working so far, but because it was an intermittent problem I'm not sure if it's solved it or not. Time will tell!
  2. Hi, We have recently upgraded to Vectorworks Architect 2022 as an office and have been batch converting projects (previously using 2020). On more than one machine we are finding that existing doors in models can't be flipped - the "Flip" option is greyed out. These are unstyled doors, which were flippable in the previous version we used. We have tried shutting down the file/Vectorworks completely, and then it does work for a while but at some point the 'flip' function turns off again. Is this is a flipping bug or is there a fix we can work around without having to restart the software several times? Thank you.
  3. Interested in Architect + Renderworks; how much are you looking for? Thanks.
