Sean Gaule
  • Content Count
    4
Community Reputation
0 Neutral
About Sean Gaule
  • Rank
    Greenhorn
Personal Information
  • Occupation
    Architect
  • Location
    United Kingdom
  1. Hi, I'm working on a site model which was created with 3D loci and site modifiers. I now want to model the proposed site and keep getting a random high point in the middle of a proposed pad with 0m elevation. When I go to view edit the contours I can see two additional red polygons (site modifiers?) which seem to be creating the random high point. But I cant seem to see them in the model to delete them and I have definitely not created them. Any help or thoughts would be very welcome.
  2. Please add back in the BSI universal column library to the Structural Member Tool. For completeness, it would be great to have all the profiles from the Wide Flange Tool etc available straight from the Structural Member Tool. I know you can pull out the profiles and use them as Customs in the Structural Member Tool but it's irritating and adds more steps to a simple operation. Many thanks, Seán
  3. For traditional sash and case window in the UK we need to be able to set the taper for each part of the reveal independent from each other. Currently I use a wall recess to create the reveals and bay but it leaves window lines on plan which do not look correct and need to be masked over taking lots of time. See attached image for example of a traditional sash and case window and screen shot of work around in 3D an plan. Also, can we have custom vertical and horizontal glazing bars in top and bottom sashes. Thanks. Seán
  4. Hi, I've not posted before but have seen how helpful some members are, so I'm hoping someone can shed some light on my problem. I have a pitched roof, created from AEC, Create Roof. I have then added a second component within the roof settings called, external 150thick, and internal 250thick. The roof is associated to four walls below it. The internal face of those walls trims the Internal component. I have then created symbols for rooflights and dormers, added these to the roof. A couple of things then seems to go wrong: The roof is triangulated in hidden line and some Opengl views. The internal component doesn't display on the half of the roof with the rooflights. Only the first dormer added cuts a hole in the roof, the others simply appear to sit on the roof, not creating cut outs. If anyone has come across this before and found a solution, I'd love to hear. Thanks, Seán
