hajom
    12
Everything posted by hajom
  1. Love the edit in place feature in the VW2020 for the name of class, layers, sheets, etc; but why not have the ability to edit all other attributes directly as well? At current release (SP2) you still need to open edit dialogue box to edit any other feature.. kinda silly imo.
  2. Okay. Thanks for pointing that out. I think it would be handy to have the biggest key, the space bar, be set up as the selection tool, being the most used tool (without holding it down) though...
  3. Awesome!! 🤩 But we're still on 2019... when is 2020 coming out?
  4. One more: could the space bar be shortcut option? Would be nice if I could use it as 'selection tool shortcut. Thanks!
  5. Apologies if this has been asked already... please link me to topic. Would be nice if layer, and especially class attributes could be edited directly from the organization dialogue window. ie if you want to change colour of pen in a class, just click on the colur swatch behind class and the colour selector window pops up and you can change the colour right there.
  6. Would be nice if you could switch between straight and rounded walls on the fly during drawing walls continuously
  7. It would be great to have the 'select+option' copy feature work without having to hold sdown the option key, but just toggling the option key. ie. if you want to copy something with the 'selection' tool: select the object, hit 'option' once (and release) and move copied object. Hit 'option' again if you change your mind.
  8. It would be nice if one could modify/edit classes in multiple viewports simultaneously. Not just turn them on or off, but also override class attributes like textures etc.. This would speed up work if one is rendering different options for certain components, ie. cladding options, component colours. Also it would be great, if one could override the texture for all aspects of object (wall, roof directions) with one button click. So you don't have to click 5 times to make sure the texture is going to be overridden for all aspects object. Thanks
  9. Hey guys, I seem to have the same problem here. All of a sudden a slab object has disappeared and when I try to copy from backup file, the slab in backup file disappears, too. Notice another slab sitting on another class than None; and it disappears when I move that slab to the 'None' class...
  10. Will do. I send the file to CAtech@vectorworks.net as well yesterday.. Learned I had to turn on 3D settings for object info palette; but still didn't show up for Energos... Thanks
  11. I have a problem with my space objects not showing the volume as well, and I have the 'show 3D' turned on.. @cxs Was that your issue? Did you resolve it? @Nikolay Zhelyazkov Any suggestions? Thanks
