sam@pcd
  • Content Count
    14
Everything posted by sam@pcd
  1. sam@pcd
    Importing IFC...
    Hi, Can anyone help with importing IFC files into vectorworks?...First I imported the IFC file and then converted it in to an Auto Hybrid, then to 2D/3D symbol to give the object the 2D Visual I want. However when doing this process the IFC (BIM) data is hidden?..or disappears from the object.. Is there a way to add the BIM data so it is seen on the 2D/3D symbol?. Thanks
  2. Hi, I'm looking to convert the library I have alrady created from Vectorworks 2018 to 2019. Is there an easy way to do this? I opened 2019 and via the migration manager I was able to convert the title blocks etc, but it didn't give me the option for library's. Do I need to save each file individually?...It seems a bit tedious if this is the case. Can anyone help? Thanks
  3. sam@pcd
    Editing 2D and 3D
    Hi, Is there a way in which you can edit the 3D part of a symbol and it will automatically change the 2D part of the symbol? It just becomes a bit tedious when resizing a shelf, table etc... Thanks
  4. Hi, I am looking to add BIM to the 3D symbols which I've created in Vectorworks. Could anyone point me in the right direction to accomplish this? Thanks
  5. Hi, I am having issues importing revit files into vectoroworks. When I import the files it imports as a 2D/3D object, however the object doesn't have a texture, so I try the convert the Revit entity into an auto hybrib and the process buffers for an extremely long time. Is there a simpler more manageable way to handle Revit files in Vectorworks? And reduce the file size? Thanks, Sam
  6. sam@pcd
    Revit import, large file
    @Matt Panzer Hi Matt, Please see attached. Thanks, Sam WR500ML3 REVIT.rfa
  7. sam@pcd
    @hepburngc Hi Graham, This is how I import the file... And then the result is this... However, it only provides me with a 2D view of the Revit model and then I go inside of the symbol and I try and create an auto hybrid, but it buffers for a very long time. I can see the potenially for it to be a 3D object, but the model has no texture and the mesh lines make it very complex. Hope this makes sense. Cheers, Sam
  8. sam@pcd
    Adding BIM to symbols in Vectorworks
    @Hans-Olav Hi Hans, I am having a few problems trying to get the BIM information to show on the 3D symbol. I imported an IFC from a manufacturer and then created an auto hybrid and then a symbol. However the BIM information is on the IFC model within the 3d symbol and auto hybrid. How can I move that Information on to the symbol which i've created? Do you have any advise on this? Thanks, Sam
  9. sam@pcd
    @Hans-Olav Okay thanks, I will give that a go ūüôā Cheers, Sam
  10. sam@pcd
    Creating a Workgroup
    Hi, I am looking to create a work group folder for 3 people to use the same library in the office. Is there a way in which I can share the library's I have on my vectorworks with others and for those libary's to update as I change them? Thanks
  11. sam@pcd
    @Pat Stanford Hi Pat, Happy New Year! Thanks for this! I managed to get the files to appear in my favorites as I add them in to the workgroup folder However there is nothing appearing in the workgroup libraries drop down, the files are automatically added to the favorites. Is this correct? Thnakyou!
  12. sam@pcd
    Rendering Issue
    There is only the natural light I think ( I am very new to Vectorworks..) Could you have a quick look at the file?.. White_Lion_Vectorworks_Rev_B_20_11.18.vwx
  13. sam@pcd
    Rendering Issue
    I am having a problem with the rendering using a renderworks camera. I have created my own renderworks style, however while on some projects it works like a treat, others it tends to become very bright and blotchy in areas. Can anyone help? Cheers
  14. sam@pcd
    Rendering Issue
    Hi Robert, I have checked the ambient light slider under set lighting options and it is turned off..
√ó
