I think this is a much needed improvement and/or simply be able to control the width/thickness of the heads, jambs and sills independently as we would often use a 1x4 jamb and 1x5 or 6 head casing.. This is needed with the Door settings as well.
Can anyone tell me how to override the default sketch mode for railing/fence objects? I often use an edited "certain" sketch mode for SD presentation drawings and the railings always render in "rough mode". I have tried setting the object information render mode for the railings to none and certain as well as changing the document default render mode to "none" and/or "certain" but the railing still render "rough"
Hey Peeps!
I'm having and issue coordinating my Revision "number" with the Revision Bubble Tool.
The title block only allows letters for the Revision Number and the Revision Bubble only allows Numbers.
I've search the Title Block Manager and looked for the Bubble object to modify the default data in either but cannot find any solution.
Thanks for any help - GSF
