I tried searching for an existing topic to bump it, but couldn't find it. I wish there was a way to send out a Vectorworks file that had 'no edit behavior'. In other words, whomever opened it was unable to modify it in any way.
Is there a way to create a file to send out, referenced (?), that has no edit behavior? I have received/imported dwg files that have had the Union command performed on them prior to them being sent out. When I import one of these files and click on the item(s) in it, it says there is no edit behavior. I'd like to be able to do this to a Vectorworks file.
Pat, thanks very much for that. I appreciate the help. That worked.
Raymond, thank you for your help also. I'll explore your suggestion later, but for now, I have it working as I need.
much obliged,
Chris
Thanks Raymond. As I normally 'inherit' my files from other users, I think the your second suggestion may be better for me. How would I start by going this route?
Can I 'save' Vectorscripts that I create in a single file to the Resource Manager so that I can run the same scripts in any file I'm working in? The scripts I am using are ones that I've created through the Custom Selection tool.
Ah, nevermind. I 'figured it out'. After I've made a duplicate, and renamed it as whatever I want Stage Ref, in this case), I go back and select it from the Hoist Symbols folder under Open Files.
I am trying to figure out a way to be able to have points in my drawing that will export on/with a Hoist Worksheet so that I can print them with my layout stickers, which are generated from the Hoist Worksheet export. I want something that exports its data as if it were a hoist (X & Y coordinates), but isn't.
I've seen that I can create a custom hoist that I can rename, but in the export it obviously still shows as whatever Hoist Type it was created/duplicated from. Any ideas?
Could you educate me on the Data Visualization? When I double click on the truss it bonks and I get a message at the bottom of the screen that says "The selected object has no edit behavior".
