Alinoz
  • Content Count
    4
Everything posted by Alinoz
  1. Thanks again Michael, I've had an 18 hr day and I'm going cross-eyed. I'll have a look in the next couple of days. I definitely want it to rotate around the center of the object too. It might be a bit too complex for me this early in my Vectorworks journey. Kind regards, Al
  2. Thanks so much for the super quick reply Michael! I did get SetRot3D and Set3DRot mixed up. You assumed correctly, that I want to be able to rotate the selected object 90º from it's current orientation. Is it a complex one to write using the Set3DRot? Are there any simple examples of this, without doing extrusions etc? I got lost on the example at http://developer.vectorworks.net/index.php/VS:SetRot3D Thanks very much for your time 🙂
  3. Hi all, I'm a newbie to Vectorworks and Vectorscript, just started using it 5 days ago & I'm hooked. I'm trying to add a simple option with a script and then assign a keyboard shortcut to rotate the selected object 90 degrees around an axis. I know how to add the script to a menu and assign a keyboard shortcut. I used one of the scripts from here called Move to Origin, and it works a treat. What I need help with is getting the script correct. This is what I have and it does not work. I'm trying to rotate the selected object 90 degrees around the X axis. PROCEDURE Rotate90onX; VAR hnd : HANDLE; BEGIN SetRot3D(hnd,90,0,0,0,0,0); END; RUN(Rotate90onX); Any help or advice would be much appreciated. Thanks Al
  4. Thanks so much for this!!! I'm new to Vectorworks and this has been invaluable.
